Yeah looks the piece - I would suggest keeping everything at or below 80% max of its limit - or oversize as it seems you have with that cooler module (in terms of power use) Only suggestion I might add is, use a really good 120-200mm fan with good static pressure ratings (think Corsair / Noctuna / Imhotep style adapted Bedini maybe ?) Gives you full control over the fan motor through an Arduino Nano or nearby PC (could be worthwhile) Then form some ducting to accommodate the 3-4x larger fan, tapering the diameter to meet the cooler. Could use the heat as PM for a small TeslaTurbine + Flywheel + Axial PMA / Newman gen. & feed back as PM for the system in mention (provided this doesn't stray too far from the objective) Alternatively, the extra current could be used purely to cool the FET's (not clear which would be best) Consider using PEEK M4 machine screws, and, provided the wall is thick enough, perhaps pilot the block with a small tap & Die set by 1mm depth or so (not sure this will end happily though  ) Not sure which clamps you are referring to (Irwin quickgrips??  ) Then use this stuff as insulator (superior transmission to grease / silicones afaik) https://www.amazon.co.uk/AIMIMI-Insulator-Heatsink-Insulation-Transistor/dp/B09T2NB245?th=1
« Last Edit: 2023-08-22, 23:09:14 by Excelsior »
