2026-08-15, 04:55:03
Pages: 1 2 3 4 [5]
Author Topic: Crystal Over Unity  (Read 35900 times)
For how long? FOREVER
Can it be used to power a 2500W electric resistive space heater ?
Works on Hot Plates and Standard 240VAC motors, Incandescent and LED light bulbs
https://medias.netatmo.com/content/445594a1-48b6-4452-8ef8-5e450964e761.jpg
Crystal Over Unity
Do you have any evidence to back up this claim?  How do you know it outputs 2500W if you can't measure it?
PW
Again, Our evidence is available to show you anytime.
Again. We are't going to invite the black hats to come and take us away.
We measure it by Load for the umteenth time. How many hot plates boiling water will it run.
We literally had a rack of 100 light bulbs and needed more Load and so added hotplates because this is what we had laying around. We build everything from junk and left over scrap or what we have on hand.
Do you have a video of what that demonstration would look like?
Are measurements allowed?
PW
Indeed...
The title of this thread and its original post is related to a claim that when a laser beam is split into multiple beams using a "special crystal", the sum of the measured "power" of those multiple beams is greater than the "power" measured from the original beam.  In other words, a claim of overunity (more power out than in), presumably due to the "special" crystal.
Correct.
A pdf document was attached to the OP that provided some details as to how measurements were performed and their results.
Correct. Each Inventor will then make their own device and then have their own ORIGINAL IP.
The document states that a phototransistor was used as a measurement sensor.  I could not find a data sheet for the phototransistor specified (If anyone else can find a data sheet for the Z3235 specified in the pdf doc, please post a link...).
Attached is a Picture of a 'Watch" made of Pure Silver and Gold Inlays with Platinum Rings inside filled with Charged Water powered with the Solar Diodes as used in the crystal laser doc. To make a kind of mini Precious metal JoeCell Energizer for the Human Body that one wears instead of placing hands or body in a JoeCell for Bio Electric Field Enhancement similar to the Aquachifootbath.com  We made 11 of them. When I showed one to Joe, he picked it up and all he hairs on his arm stood up and he said, finally you've made something I like.
There is no mention of any power source or bias method utilized with the phototransistor.  Additionally, the measurements provided were given as a voltage instead of current.
Once this 'application' of lasers and crystals is understood, Its a pandoras box. Its obtuse for a reason.
If the Z3235 is indeed a phototransistor (or photodiode), it is possible that the claimant, not understanding how to use a phototransitor, merely measured the voltage between the phototransistor's terminals.  If this is the case, the data provided is meaningless and the original claim would therefore be unsupported by the evidence provided.
Claimant was questioned about this possibility and was asked to provide additional information regarding how the phototransistor was utilized during the performance of his experiments.
Many posts later, these questions remain unanswered...
True, we got side tracked on transistors as a way for you to see for yourselves very little is understood about the Crystal in a Transistor and everything happens for a reason. So to understand crystal over unity first we need to know ALL there is to know about a crystal. (we arent there yet) I can teach you how to do it but any evidence I provide is a noose around my neck and like that hard head verpies and Desal by Magnetics, the controversy and failure to understand anything about what a Magnet is, comes into play much less comprehend what is being said or watched on VIDEO EVIDENCE, followed up BY an independent fact checkers Report,... YOU WONT UNDERSTAND without a basics of magnetic Science.  The Special Crystal. I would have thought I'd have to answer more on this subject before this. You can end you life with one of these. I dont want that on my Karmic Consciousness. Its available but not for attitudes like verpies so no its not 'public yet'. Privately, yes but according to how this info is received in these threads.
PW
Player advances one step.
Just a post to bring some points made in other threads relevant to this one.
The distraction of Magnetic and para-magnetic to materials is by design To Hide the true Nature of magnetism or the Magnetic Bias of 'elements'.
The distraction of Alkaline and Acidic to the Magnetic Polarity of Liquids (or whatever) is by design so you dont understand Magnetic BIAS of the GASES or LIQUIDS as evidenced in this Video.....  https://rumble.com/vh7v87-im-plosions-and-ex-plosions-demo.html?mref=6zof&mrefc=4
Copper is a 'South Pole' metal and Iron is a 'North Pole' Metal. Together they make a Battery.
Our words have confused our thoughts because there is no Magnetism in the Atom Structure of PARTICLE theory but there is Para-magnetism in the practical applications of this particle theory....  We call this Dissociative Cognizance
WATCH Joe de-pole neodymium magnets with HIS HANDS... in this video: https://www.youtube.com/watch?v=qM3x2z5Twno
towards the end around 8 minute mark.
Joe works with Ferrite Magnets. Neodymium is NOT magnetic. Its a Static Catalyst to enhance the Field Effect of Iron. Just Like Chromium added to iron is a Catalyst to INHIBIT the Field effect of Iron as in Non Residual Magnetic Stainless Steel. So it dont rust just like iron being conditioned with a Pure North Pole Energy as a washer between two SAME North Pole FERRITE Ring magnets.
Allen from Philosophy.org gave me a 'pen' that could detect the North Pole Field of any magnet with a light indicator. He wanted me to give it to JoeCell as a present.
So on my next visit, I handed it to Joe and he said to keep it cause he didnt need it. But its a present Joe.
So Joe picked up a magnet and used the pen and every time he held it to the magnet's N it either lite up and the next time didnt light up North Pole. He did this repeatedly to prove his point.
Joe can Flip the poles by Touch.
In another demo he took to magnets and holding them close together for a second the Field Just Collapsed in each magnet leaving a couple lumps of ferrite. Then doing the reverse they became magnetic again.
Magnets are not what they say they are.
Back to the drawing board.
Many have seen Joe flip the Polarity of the Battery in the car making the 'spark' to the spark plug the wrong polarity and no matter how you crank the engine over it will not start.
In another demo, the battery was flat from the lights being left on. To start the car a COIL was placed between the 2 terminals of the Battery so the Other Side of the Battery was now active and in an second of turning the key,. the engine started. Batteries also arent what you think they are.
Understanding these two NON PHYSICAL Phenomena will upwise humans immensely.
Posted by MerLynn:
So, now you are claiming you did not use a "Z3235 phototransistor" as was stated in the "crystal laser test.pdf"?
I think its time to consider "pulling the plug" on this entire thread...
PW
Semantics, colloquially speaking, as similar I could have said anything. I interrupted my Call to Papers for Steve at Tesla Tech to write that post and such errors occur.
On that Note I would rather you never posted again on this Bench. you are not here to learn but to find fault with the 'explanation or terminology' NOT the Science.
Any error is enough for you it seems, so consider yourself out of the game.
Your skepticism is no longer needed in this discourse.
Any non relevant post by you will be deleted if this attitude persists. You couldve just asked for clarification but no, you went for the juggler
So what was used?  A "phototransistor" or a "solar cell"?
It is not semantics, they are completely different devices with different operating characteristics.
I have repeatedly asked how the phototransistors were utilized during the cited tests and you have repeatedly ignored those questions.  If you can't answer the questions, or don't know how a phototransistor should be used in a circuit, man up and just say so...
PW
Did receive a note from TinselKoala on this part number
Those guys...
Z3235 is not a phototransistor
It is an IR emitter LED
940 nm, blue diffused package, GaAs crystal
Like all LEDs it can respond like a photodetector when stimulated by the proper wavelength
Perhaps this is where the confusion exists
Additional quote
Z3235:
Vf 1.2V @ 20mA If
5mm diffuse blue package
About 2 USD per each
End quote
Those guys...
Additional quote
Z3235:
Vf 1.2V @ 20mA If
End quote
Patience is a virtue
@pico
It matters naught the numbers dont match. Things always happen for a reason.
Takes a wizard to understand these "works in mysterious ways".
Crystals arent for everyone.
We did the experiment, We got the results.
It wasnt the only one. It was a R&D Company.
If its the wrong one for the job, pick another one. Surely by now you can do it better than we did.
I do remember it was the same as we used in the watches.
None of us were qualified electricians and I didnt think to check numbers...
Until you actually do the experiment and clearly its not that difficult.
Will you know the power of an Atlantean Fire Crystal of mythological fame.
Your attitude precludes you from perfecting the Intent of the Experiment and if you succeeded you would own a priceless item.
AND YOU WOULD HAVE INVENTED IT
Man you closed that door of opportunity with such haste.
Now there's NO chance you will try. And I aint spoon feeding you anymore.
And this is a good thing.
This Tech isnt for everyone and certainly not you.
You have tainted the mindset of the forum to be supreme judge of anything you've never heard of before.
So perhaps things in time are mysteriously arranged to shed light 2 decades later.
My UFO encounter at 17 has had a lifetime of synchronicity and prophetic occurrences. Uri Geller claimed his powers came from a close encounter.
Believe what you will,
But believe no more in Crystals as you will never understand them just like diodes and transistors or the very Vibrational energy you so desperately seek and believe you deserve more of than you can earn. This is above your pay grade attitude.
But really congratulations for finding a chink in my Armour. Its still impregnable tho.
And Ive spoken enough of this.
But you did learn and hear things you would never have thought possible to be dreamed up much less the product of 32 years of Research and Development Experiments. Creating a 100 million industry and counting. Where's your runs on the board? Its rhetorical.
Pages: 1 2 3 4 [5]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 04:55:03
