2026-08-15, 04:36:11
Author Topic: GIZA pyramid Over Unity Energy no less.  (Read 2954 times)
The house on my linkin profile is a pole construction, 3 floors pyramid shaped with 50 foot at the base. Built in 1988, the roof leaks.
When I made it to Cairo in 1994, I paid particular note to the features I would find from the "Pyramid Wars" books of Zac Sitchin. Fore knowledge of what was hidden for about 8,000 years is a point of accuracy in ancient books and gives a new timeline of how things went down. Gilgamesh's Grave in Iraq '03 is another marker that may be covered up but that guy killed the owner at Baalbek in the Cedar mountains of Lebanon. Also known as the Landing Pad. Giza was the Launching Pad.
I think I know a little bit of what Pyramid energy and the Dendera Temple Energy mystery is, from a Field Science perspective.
The short and simple version for just one 'over unity' aspect is, as recorded, where a male climbed to the top and drank a bottle of wine and then held said bottle in brown paper over his head, making a crude Capacitor, had sparks jump out of the top of the bottle.
Looking at the 'basics' we find that the volume of this pyramid has the same volume as a 1/2 sphere where height and radius are equal. Then we find it actually has 8 sides. If it were only four sided, it would resonate with the spherical shape of the earth in perfect harmony. It becomes a Giant Tuning Fork for 'something' spherical. Being 'of the earth and resting upon it' with an Organic Layer of Petrified Life encasing/insulating the structure as Limestone. It should vibrate with earths frequencies like everything else, but this change in Volume gives it a Differing frequency than earth and this meets the requirements of 2 dissimilar Elemental Frequencies to make a battery. The Earth and 'not Earth" for the tuning forks crystals to all want to sing. It could also be the differing vibrations of the Earth and Wind contributes to its battery effect. The wind vortexes around it equally no matter the direction. Vortexing is an act of Charge Up, Hypercharge and Enrichment in marble terms. These cats knew about the Vibe.
Like a capacitor, it could store vast amounts of 'energy' within the focal point and 'trapped' by 3 'locks' one has to stoop under to enter the Teleport Deck.
It comes back to Frequency and Resonance or a bunch of Tuning forks acting upon another bunch of tuning forks. As a simplified Definition of electricity.
The 'near' pyramid shape of Cheops resonates with the frequency of the Earth as an INCREASE in vibrations held within its Field. This is 'hypercharging' Charging Up, Enrichment, of the structure. The increase is multi fold with many inputs. Like the human body has many energy inputs, skin, lungs, stomach and the rotating magnetic Field of the magnetized red blood cells, the pyramid Resonates with the Earth. These Vibrations like Light and heat from the earth, plants, the air, are refracted in a glass pyramid, so to is Vibrations of energy refracted and bounced around inside to a focal point. It retains these vibrations and becomes a source of Vibrations if you know how to use one wire electricity.
The entire complex represented the pinnacle of a now lost Civilizations achievements as like a living museum with many functions of everything they could do all rolled into one Giza Complex. The question really is, was it the Atlans or the Posideans that built it all. One had Crystal power the other had the best 'mechanical' tech carved in stone the cone heads could provide including the Dendera Vacuum Cell. I will e-slap you if you call it a light bulb. TutenConeheaden died in a glider found as trash upon opening tomb door and was the last of his line of an inbred de-gene-rate family.
It resonates from frequency inputs. As a capacitor it stores vibrations. It is a Self charging Earth Battery. These Earth Life Frequencies, it stores and emits as resonating energy, it resonates with biological life and makes things healthier etc. Everything is actually just VIBRATION, without it there's just the Aether for energy. Combine the two in ANY CELL built by Joe and you have some really neat magic for cool stories for the bros to laugh at... But wait there's more.....
Pyra Root word for Fire.
Fire... also known as Energy and can also be what we call "electricity". It is the 4th State or highest vibratory State of (our) physical Matter.
Electricity.... Made by 2 dissimilar 'elements' in close proximity. Can even be 'made' by the division of a single 'element' giving 2 dissimilar 'elements' even if they are 'identical' to the 'eye'. Lord Kelvins 'Thunderstorm' for example.
'mid'  usually refers to a "measure" or amount.
Pyramid... a Measure of Fire. A measure or amount or container of (for) electricity.
Giza pyramid. Built from over a million pieces all interacting with each other using Elemental Vibratory Physics.
Shape Physics... (as some call it) Where Shape modulates Vibrations into 'patterns'.
As with everything, any 'conglomerate' of elemental frequencies making a Unified Field will have a Unified Polarity. This Giant Magnetic Field with a North Pole at the terminal known as the capstone, will retain and amplify vibrations and even 'emit' or 'harvestable' as 'electrical' vibrations.
The Universe, like the human body is a Unified Field (theory to them)
The Giza Pyramid is a Unified Field of Vibrations Insulated from its surrounds by a Limestone or marble casket...
https://www.lifecoachcode.com/2017/01/05/russian-scientists-discovered-800-million-years-old-woman/
Food for further thought.... As everything is made from "magnetic Light" everything is 'conductive' to magnetic "current"
Meaning everything will have its vibrations Modulated when adding More Vibrations such as 'electricity'.
We/they have not yet placed into the Earth Tech, 'magnetic Shielding' and so even the plastic surrounding the wires is 'conductive' to the magnetic Field as Vibrations, as a NON PHYSICAL PHENOMENA Telsa said was critical to furthering one's education.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 04:36:11
