2026-08-15, 13:05:00
Author Topic: Hydrostar Old Partial Schematic For Hydrogen Generator  (Read 919 times)
Others have requested, in the past, on how the original Hydrostar Hydrogen Generator had the pulses divided down to get 20Htz from 20,000 htz main oscillator.  That was for going to the toroid coil for magnetic field pulses into the rising ions of solution. The IC CD4059AE can be used for that, as well as a divider for 1000 cycles down to 1 per second, for a flashing LED, so as verification that the main oscillator is in working state for your other circuits. Ic available on Internet Ebay. The full manual is available on disc. I purchased the original paper manual. The toroid wire coil is too much trouble to make, but can be purchased completed. The Hydrostar circuit was an offshute of the Meyer resonance cell by Chambers . He used to work as tech engineer for Meyer in Ohio. He fled to Canada and filed Patent for HIS version of the circuit. The Patent omits notation of flyback coil high voltage connected to the Main electrode pipes water capacitance cell. He says the magnetic field circuit increases energy content of fuel gases emitted, by spinning the ions in different direction. Hydrostar was a circuit to increase car gasoline mileage by introducing Hydrogen and oxygen for about 25% increase in gas mileage.
You can do the same thing with permanent magnet type heater fan motor running backwards with fan attached to front grille of car with WIND generated current going back to trunk electrolysis cell at the standard low efficiency for the same 25% MPG increase. Already done many years back. Less complicated circuit. Hydrogen fuel on the go!
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 13:05:00
