2026-08-14, 22:39:06
Author Topic: AAM Experiment  (Read 6566 times)
@ Smudge:
Please take a look at the attached Atomic Angular Momentum experiment and verify my math:
Where is Grumage when you need him?  He is not scared of red hot iron....
@ Verpies
Your calculations are correct.  Your first formula relating angular acceleration to B is incorrect, but you use the correct formula in your calculations.
Your first formula relating angular acceleration to B is incorrect, ...
What should it be in your opinion ?
I stand corrected, your formula is OK.  I have great difficulty recalling formula that used to reside in my brain in the same way I can't recall words that I know and used often in the past.  It may be helpful to others if you included the meaning of τ as angular force or torque under that equation.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-14, 22:39:06
