2026-08-15, 01:45:03
Pages: 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15
Author Topic: Transformer Induction  (Read 41962 times)
Smudge,
I having trouble understanding what you are proposing here!
For example:
I said-
I understand your theory of doubling the charge with a pre-biased capacitor as you depict in FIg 4.  For example, we charge a cap to 4vdc and then apply 4v/turn on the primary.  Our cap now reaches a potential of 8v (due to charge separation) with the proper polarities applied.
You said-
"No!  This is not a capacitor charged to 8V yet.  We have a situation where the dielectric has been stressed to be equivalent to what it would be under normal charging to 8V, but the CV value of charge for 8V is not present on the electrodes.  We have energy stored in the dielectic that is double what it was, but the charge in the electrodes has not changed.  I am not aware that this situation has ever been looked at before."
What means are we using to stress this dielectric?  Is this a poled dielectric that we then assemble with the top and bottom plates and insert into the core?  Let's assume yes at this point.
So now we have "the dielectric has been stressed to be equivalent to what it would be under normal charging to 8V" as you stated above.  (I don't understand why we wouldn't start with 4v!)  Now we apply 4v/turn to the primary.  In your case as stated, we would expect the voltage stress across the dielectric to now be 12v and the energy required to accomplish this change in charge would come from the energized primary.  Here is where I totally disagree!  In all my experimentation with this type of charge separation, at no time have I ever seen energy taken from the primary for charge separation in any open circuited object. IMO, the energy required for this charge increase comes from the aether as I've stated many times before.  Why is your example any different?
We can now apply the R load to said capacitor during the time 4v/turn is applied to the primary and we will see a drop in the cap voltage of 12v commensurate with the value of R.  If we wait to apply R until the 4v/turn is removed from the primary, we will then see 8v across the cap and will proceed to discharge with R.
I have already run tests on your basic scheme and the results were COP<1.  However, I must say that I used vertically oriented plates for the capacitor and you state that these types would not work!
Edit:  I see that you are assuming a resonant condition from your last post.  Is this resonance between the primary and the stressed dielectric?  All my references above were using a pulsed primary.
I found the perspective often depends on whether the person is a logical experimenter or simply uses generalized math and equations.
This problem is similar to the capacitor paradox imo. Charged cap A when connected to uncharged cap B equalizes it's voltage/charges with B. Half the voltage/charges end up on each cap A and B but somehow we lost 1/2 the energy. Most get this problem wrong because they generalize. Energy is lost because a set number of concentrated charges on A have redistributed themselves over twice the surface area of A plus B lowering the total charge density. This is the cause of the measured energy loss in A-B and any heat or radiation from the connection wire is simply an effect from the redistribution of charges. So in my opinion the supposed paradox is most people confusing cause and effect.
  As always, I'm interested in your research, Jon... but having trouble following ATM.
Perhaps in part because I'm concerned about the stability of our world ATM...  hoping we avoid WW III in the next months...
Are you sure?  The stuff is hygroscopic and conductive when even slightly damp.
You're right, there's serious doubt. It is an ionic material. It would have to be very dry. I don't think ChatGPT's advice would be a good choice in practice.
There is a major flaw in the reasoning I see here and there. We are not dealing with a simple capacitor. It is never charged in the sense that free electrons would have accumulated on one plate while we would have a deficit on the other. It is impossible without contact with the plates.
It is the dielectric that is polarised and attracts positive or negative charges depending on the plate. Even if it has a certain capacity, the so-called capacitor is in fact closer to the functioning of an electret. While we are talking about capacitors, it is the ‘electret’ effect that is the focus of discussion, and it is not the same thing.
The electric dipoles are not free to follow the direction of the electric field almost instantaneously as in a simple capacitor. They are subject to constraints in the material, which can keep them in a particular orientation, constraints that the electric field has to overcome in order to polarise them.
This means that if we ‘discharge’ the capacitor in a short time, we do not recover the ‘charge’. We recover a small part of the charge, the only free electrons from the plates that the polarisation of the dielectric had attracted, and this does not instantly cancel out the internal orientation of all the dipoles of the dielectric inside the insulator, with which the plates are not in contact except at the surface. The so-called capacitor will partially repolarise after a certain time following its discharge.
Such a component no longer responds to the classic equation I(t)=C.dU(t)/dt. A factor dependent on polarisation, which has a memory effect, must be added. It would be more like C.dU(t)/dt + (U(t)−Um)/Rm, where Um and Rm are related to the ‘memory’, with Rm including the attenuation of the repolarisation.
But the  cap-cap energy transfer doesn't have to behave like that.  If the transfer is conducted through an inductor then theoretically 100% of energy in cap A will be transferred to cap B.  In practice ~90%.
the inductor makes use of the transfer.  just cap to cap, the transfer happens without doing any work by way of the transfer. the fifty percent loss occurs because we didnt do anything with the tramsfer other than moving the electrons till the potential pressure is equalized.
mags
the inductor makes use of the transfer.  just cap to cap,...
There is no such thing as cap-to-cap energy transfer in practice.  The effect of the interconnecting component cannot be ignored ...be it a resistor, inductor or a compound of the two.
There is energy conversion in any real transfer, e.g. conversion of current to heat in CRC transfers or current to magnetic flux in CLC transfers.
Energy conversion is equivalent to work.
No, moving electrons are electric current and flowing any current through a resistor results in its conversion into heat and flowing this current through an inductor results in its conversion into magnetic flux.  Thus conversion always happens during an energy transfer.
Practically you cannot connect two capacitors with a wire that does not have a resistance nor an inductance.  For rigorous treatment you have to account for both phenomena.
Smudge,
I start with the fact that in non-electrolytic capacitors there is never any flow of charge into or out of the dielectric.  When we charge the capacitor by applying current the electrodes gain or lose electron charge and thus create an electric field in the dielectric which becomes polarised; at the surfaces in contact with the electrodes that polarisation appears as though these surfaces have charge on them.  Those induced surface charges create electric fields that oppose the flow of current onto the electrodes, so our charging system uses energy to supply the current.  The current source is seeing a back emf.  This is a slightly different viewpoint that to charge a capacitor you apply voltage and the capacitor demands current.  Note that the charge separation in the dielectric is driven by the charge separation on the electrodes, but there are two different charge separations; they normally have the same value.  To differentiate between these, I used the term dielectric displacement for the charge separation in the dielectric (maybe I shouldn’t since displacement D is a recognised EM vector alongside E).   The electrode charge separation is given by the integral of the current with respect to time.  Within our circuit, when we do the math, that integral relates to voltage and we think of the capacitor being charged to that voltage.
Turning to the uncharged disc capacitor filling the hole of a ring core having no electrical connection to electrodes.  The dielectric displacement will be driven by the E field due to the changing flux in the core, not by an E field from charge on the electrodes since there is no means for charge to get there, and that is a different ball game.  The randomly orientated electric dipoles in the dielectric are aligned by that ring core E field, but we cannot consider it to be a charged capacitor yet (there has been no conduction current so there is no electrode charge).   If the E field can be removed faster than the dielectric can relax and we put R across the electrodes the dielectric will quickly drive current to get the electrodes charged, losing a small amount of stored energy in doing so.  That current spike ceases when the magnitude of charge on each electrode equals the opposite polarity bound surface charge on the dielectric.  Thereafter we do have a conventional charged capacitor discharging exponentially through R with a reversed current.  The loss of dielectric energy to get charge onto the electrodes is small so the voltage on this capacitor after that current spike is close to the earlier E field potential difference across it.
Turning to the situation where we previously charge the capacitor (to 4V) and your specific queries.
I thought this was quite clear.  There is no primary current and no flux in the core.  We simply charge the capacitor conventionally (to 4V).  This can be done outside the core and the charged capacitor then placed into the core, or it can be done with the capacitor in place.  The dielectric is now stressed, has charge displacement, has internal charge separation held there by the charge on the electrodes.
We then energise the core to create an E field that doubles the stress in the dielectric.  It has not doubled the charge on the electrodes, that charge Q=CV remains at the Q=4C value.  The magnetic vector potential A field penetrates the dielectric to add its E=-dA/dt field to the field already there from the +- Q on the electrodes.
We did start with 4V charge on the capacitor.
No.  We have already done that, we don't do it twice. The dielectric was stressed to 4V (and the electrodes carried the Q=4C value), now it is stressed to 8V (while the electrodes still carry Q=4C).
With respect I am not aware that you used a disc capacitor as shown.  In all your experiments I see a small purchased capacitor of unknown internal structure.
No.  We quickly turn the E field off so the 4V/turn on the primary is turned off.  With resonance the primary current could be passing through zero at that voltage so this is not difficult, we hold the current at zero.  Then we apply the R load.
What capacitor did you use?  Did it nearly fill the core hole with dielectric?
[snip]
No, not even close!  It was a flat wound polyester film cap placed vertically that probably occupied 5% of the hole area or less.
Edit: I have enough Barium Titanate to fill a toroid with a hole that is ~19 cm^3 in volume.  I will do the test after fabrication over the next several days.
Edit: With the given physical dimensions, the capacitance should be ~1300nfd using k=5000 for the dielectric.
Are you going to sinter it or compress it ?
I'd like to see whether the di/dt in the primary changes as the dielectric is inserted while all other things are being equal.
The presence of that dielectric will make the apparent inductance of a coil wound on the core change value.  So maybe simple before and after inductance measurements would suffice.
Edit.  If you give me the core details I will calculate the inductance change for uncompressed powder.  Electrodes would not be needed for this simple test, just fill the hole with the powder.  Of course to take things further it requires the electrodes to be present and the means to connect to them without the conductor encircling the core.
I am going to just compress it as I have no means to sinter it.  I hadn't thought about making the assembly removable but maybe that would be useful.
The core I will use is has a center hole measuring 31mm in diameter x 25mm high.  My powder is 99.9% pure ground to 0.5-3.0 micron.
As for any connecting electrode being inside the core hole, it will exhibit charge separation resulting in an overall null measurement.
Edit:  Change of plan- I will use an already available insert that measures 25mm I.D. X 21mm in height.  This will allow the assembly to be removed and will also provide room for a load resistor and connecting lead.
We are in complete agreement. That is what I was saying earlier in a different way in my reply #29.
OK, I finished the assembly described in my edit above.  The sleeve was a 3D printed cylinder which had a round copper electrode CA'd to one end.  I then packed the inside with BT physically until no more could be forced into the sleeve and the BT was slightly above the upper surface of the sleeve.  The top copper electrode was then put in place and forced to completely close with a vise.  Numerous rounds of narrow tape was then used to hold the BT in what I think is a compressed state.  The resultant capacity-a very disappointing 17pf!  Applying manual physical pressure results in ~33 pf!  This is essentially a failure IMO.
Obviously, the BT must be a compressed and sintered block.
Smudge and F6FLT,
So you both think that when I charge separate say a film capacitor as I demonstrated many times in the E-Field area in the center hole of a toroid, we are not really seeing a true charging of the capacitor?  This belief arises from the fact that there is no apparent connection to the electrodes to supply the charging current, correct?
If so, then how do you explain the fact that a charge separated cap is able to supply energy commensurate with a given capacitance and charge separated voltage, to a load that is connected during the time the primary is supplied with a given V/turn?
Well, that's because the capacitance of a two-plate capacitor is inversely proportional to the thickness of the dielectric and directly proportional to its permittivity and the areas of the plates.
This means that the effective permittivity of your dielectric is ~2x higher when compressed.
This is obviously a failure IMO.
Not if your goal is to obtain the maximum dielectric polarization work instead of the maximum capacitance between plates.
If the polarization of that dielectric takes a lot of work then it should affect the di/dt of the primary winding.
It is because the effective permittivity of the powder is 82.2 (for the 17pF value) and not the 5000 that is expected for the solid version.  Goes to show that touching surfaces have an effective air gap, you need the chemical bond to eliminate that.  Same happens in magnetic material, two C cores clamped together never reach the reluctance of an equivalent uncut ring core.
Not necessarily.  Taking your core measurements and assuming the core has square cross section, and assuming a relative permeability of 1000, the inductance of 10 turns is 0.384mH.  This will resonate with 17pF at 1.9MHz.  Without that C the coil will have some self resonance that may be much higher.  Dumping the lump of dielectric in the hole should have the same effect as connecting a 1 turn secondary to an external 17pF capacitor and achieving that resonance.  If I had all the core details I could refine this math (as you could also) to see whether looking for resonance is a viable method to tell us the wanted effect is there.
Smudge and F6FLT,
Yes
Correct me if I am wrong, but there your circuit connecting the load encloses the flux in the core so that V/turn is present within the circuit.
The toroid core I am using is metglas and with a 10T primary, the inductance is 3.4mh.  Therefore, the resonance frequency with 17pf of dielectric in the hole should be ~662kHz.  I have tried driving the primary with a 50 ohm source using sine waveform and also a series connected 1k resistor with the primary.  I see no resonance at any time manually sweeping the frequency spectrum.  I then removed the dielectric and placed a single secondary turn with 22pf capacitance and again found no resonance with a sweep.
I also tried single and multiple pulses with the same results.  The primary self-resonance is ~50MHz.
Edit:  I also tried a ferrite core with a 10T primary and 608nH inductance.  Resonance would be ~1.56MHz but I still found no resonance as above in all conditions.
That has been the case with most of my past experiments however, thanks to you and this latest dielectric test, I have produced the following results seen below.
Basically, the ferrite core has a 4V/T primary with a 1.22ufd cap in parallel with a 90uh inductor both of which are in the center core hole.  All leads are in the core center hole exposed to the E-Field.  The resonance frequency is ~15.1kHz as seen in the scope pix below.  CH1(yel) is the gate drive for the primary mosfet devices, CH2(blu) is the power supply, CH3(pnk) is the voltage across the LC network, and CH4(grn) is the LC current.
ICR1 shows the differential at the charge separation switching to be 6.15v.  Note this is larger than the 4V/T of the primary.
ICR2 shows the RMS values for the LC voltage and current.  This LC resonance is not seen by the primary.
Also note that this test is running continuously but can also be demonstrated with a single pulse as well.
It is my opinion that my tests with loads outside the core are also operating in this fashion but via Lenz, they affect the primary energy.
So, I leave you with the question, what is supplying the energy to this resonance circuit?
The capacitance of my cap, that I described here, is 4.2µF.  I attribute this difference to the ~10µm thickness of the dielectric.
According to the formula C = επr2/d the capacitance of this cap should be 8.7µF but because my dielectric powder is not sufficiently compressed or bonded, its permittivity is ~2x less than the advertised 5000.
@Partzman:  To cold bond the BaTi powder, you can find some shop with 80 ton press and ask them squeeze to powder for you into a pellet. 80 ton press is not an exotic piece of equipment (here is a video of a 500 ton press)
Let's be quite clear about this.  When the primary current is maximum (at the top of a sine wave) E is zero so no energy stored in the dielectric.
Yeah, the derivative is zero at the top of the sine wave, but getting to that top requires a period where the current changes and E is nonzero.
Your compression got you within a factor of 2 to the 5000 permittivity.  Using the same formula for patrzman's capacitor that would be 1nF at that 5000 value and only chieved 17pF  his permittivity down by a factor of over 60.
Agreed but I assumed a dielectric with no hysteresis so the previous history (an opposite polarity E rise and fall) would not affect this experiment.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 01:45:03
