Smudge,
The caps used to form the 8uf total capacitance in my resonance test are wound foil types. With the foils placed vertically in the core window, both are charged separated equally with no energy being generated in the cap. This makes your lesson above different as you appear to have horizontal plates in your capacitor which allows for energy to be developed during charge separation.
Therefore, in my experiment as shown in post #192, when the very first positive pulse is applied, the H-Field from the primary induces the amount of current shown in the bare wire connected to the cap at resonance. As seen with each successive pulse to the primary, the resonant current builds to a continuous peak level as determined by the overall circuit losses. The cap receives a small amount of energy during the positive half cycles to the primary with this energy being discharged during the negative half cycles. The average is therefore zero when running in resonance continuously and stabilized.
I do adhere to the notion that the H-Field can also be called leakage flux but I prefer the former.
Now, I will make a statement that will get me classified as a heretic I'm sure! When Faraday did his original induction tests using an iron toroid with a primary and secondary, he created his induction formula from his readings taken with his equipment at the time. His resultant induction law we know is accurate and not in question. However, he had no means at the time to measure the overall voltage differential around the perimeter of the core. IMO therefore, one can apply his induction law to a solenoid coil and the E-Field will be linearly distributed around the perimeter of the coil. However, when we have a folded or closed flux loop as in a toroid core, "U" core, or "E" core, the E-Field is not distributed linearly so we have to be careful if we apply his induction law to such.
My experimentation seems to show that the E-Field (in a rectangular cross sectioned toroid) is nearly all contained between the top and bottom surfaces of the core. I know this is a real point of contention so I am attempting to devise experiments to prove or dispel this apparent anomaly. I already have some to show but I have another test to try before disclosing anything at this time.
Regards, Pm
