I would like to point out the following which I thot I had already posted but couldn't find it on the forum so if I did, here it is again.
The observation with this experiment is that the total voltage drops across each primary turn in the hole of a closed flux core (in this case our same toroid) sum to nearly the total V/T applied to the primary. IOW, there is little to no voltage across the wire on the outside of the core. IMO, any voltage drop in the outside wire is due to product of the current in the primary times the resistance of that portion of the primary winding.
The attached pix shows the test setup with a four turn primary that has little loops formed at the ends of each primary wire in the center or hole of the toroid. Two probes are then used to take differential measurements of the average voltages present at the ends of each turn of the primary. Measurements are taken when the primary has a positive voltage applied and also when the 3/4 bridge collapses with the voltage to the primary will then be negative. With the intrinsic nature of a 3/4 bridge, the collapse or negative application to the primary will always be slightly higher than the positive application due to a diode in the flyback or collapse path back to the power supply.
This is a table of the voltage measurements. The first voltage differential listed is taken during the application of a positive voltage to the primary and the second differential is taken during the primary collapse and is therefore negative.
#1 = 3.608v, -4.080v #2 = 3.640v, -4.202v #3 = 3.704v, -4.241v #4 = 3.600v, -4.131v __________________ Tot =14.552v, -16.654v
Vap=14.56, -16.670v
VaP is the differential voltage measured across the leads attached to the primary for an accurate V/T for both polarities. The results seem to indicate that nearly all the voltage drop across the excited primary exists in the wire in the hole of the toroid between the upper and lower surfaces,
Regards, Pm
