2026-08-15, 01:43:36
Author Topic: Aether Tides and Upcoming Free Energy Experiment  (Read 348 times)
Hello fellow free energy seekers.  This is my first post.  I have been researching/experimenting with aether energy since the early 1970's.  Like many of you, I have studied a lot of the devices in Patrick Kelly's most excellent book: "Practical Guide to Free Energy Devices".  I have built some devices that worked like earth batteries but most of them were missing the secret sauce.  I was disappointed to learn that the best ones that showed the most promise had their key secrets die with their inventor's untimely death.  It seemed that all of the best of the best were suppressed with extreme prejudice without fail.  I was convinced early on that this free energy development was a dangerous occupation.  So, I exercised extreme caution and operated largely in secret.  My research was without boundaries.  I studied UFO's, antigravity, ancient technologies and consciousness among my quest to develop a free energy/gravity technology based on aether energies.  I found that aether energies had consistently been renamed throughout history, so, until you realize that, one can miss some key ingredient that others had discovered using a different term for aether.  From those studies there emerged some special devices that shone through that could be incorporated into other designs.  Avramenko's plug, Tesla coils with his sustained energy output, just about everything "wireless" Tesla invented, a jitter oscillator connecting to the "zero point energy" (that I would call the aether energy), Edwin Gray's spark tube device.
I also found a very interesting device among diverse fields.  A box contraption Reich called an "orgone accumulator" (aether accumulator).  I found similar boxes in UFO's (Daniel Fry draws the inside of a UFO with something he called a "differential accumulator" in his book titled "The White Sands Incident") and Bob Lazar's Sports Model depicting waveguides (similar in function to a resonant cavity in terms of aether energy) installed in that UFO.  Installed in the Great Pyramid is something called a sarcophagus which is basically a similar sized cavity as well.  One other device that I think is also a similar resonant cavity is something called the "Arc of the Covenant" as written in the bible with detailed plans to actually build one.  So that is what I did.  I built one in my garage in the early 1980's.  However, I used other metals (lead and aluminum) in  place of gold metal.  Instead of acacia wood I used fir plywood.  I also built in a tuning slug so I could test its resonance - it turned out to be about 28.5khz.  That is not an exact frequency, however, as my oscillator would wander by a couple of hundred hz either side of that.
Cheers,
Jim (AetherDragon)
« Last Edit: 2026-03-29, 03:02:55 by AetherDragon »
https://youtube.com/watch?v=mFLo1tNHbec
My current work is born out of my investigations in trying to find a natural "power take-off" mechanism that we can finally hook our machinery to.  My focus of this investigation has been into hurricanes for the following reasons.  There is some evidence that these exhibit antigravity and time distortion.  There is no "hard evidence" to point directly at.  I did, however, discover an anomaly that furthered my interest in this direction.
One day while being focused on hurricanes and, in particular what drives a normal rotating storm into a category 5 monster, I imagined the storm acting like a huge centrifuge.  Would the gases separate and find their own equilibrium within that storm or would they react in some different way.  An experiment was in order.
My initial experiment was to place into a storm glass air and water.  Into another storm glass I placed CO2-and-water.  Nothing happened immediately.  The water level of the CO2-and-water happened to follow that of air-and-water by about 1 cm.  I placed them together on a ledge in the living-room of my home at the time so I could casually observe them once in awhile.  Weeks went by.  One day I noticed that the storm levels had reversed themselves.  The air-and-water was now following the CO2-and-water storm glass.  I was mystified.  I continued to observe them while trying to figure out what local event could have happened that could have caused such a reversal.  Then something happened that further added to the mystery: they reversed their order again about one week later.
Many more weeks went by.  Eventually I figured out why or I should say when the changes took place.  What I'm about to say will be hard to accept for the more orthodox scientific minds among you.  I observed that whenever the sun and the inner planets (Sun-Mercury-Venus-Earth-Mars - 5 points) were aligned in a spiral pattern (within a single 360 degrees - without overlapping around the Sun) this strange reversal would take place.  Further observance revealed that they didn't actually reverse.  What happened is that the CO2-and-water storm glass stopped reacting to the changing air pressure (it froze its levels) and when the natural local air pressure reduced, the air-and=water levels in the storm glass sunk below that of the CO2-and-water level.
But there is more...
I started to look around to see what, if any, effects can be seen matching these "aether tides of Earth" as I now call these events.  Shockingly, I discovered that nearly all of the category 5 hurricanes that impacted and were logged by the US happened during these so-called "aether tides".  Anyone can easily check this out themselves as one can google the event times when these great hurricanes happened and a good orrery can determine the planetary positions at those event times.
These hurricanes include:
- Hurricane Patricia (October 23rd, 2015), the most powerful hurricane in recorded history occurred within the Earth-Aether-Tide of October 8 – October 23rd, 2015.
- Hurricane Camille (August 16th, 1969) occurred within the Earth-Aether-Tide of July 4 – August 29th, 1969.
- Hurricane Allen (August 7th, 1980) occurred within the Earth-Aether-Tide of July 22 – September 22nd, 1980.
- Hurricane Katrina (August 28th, 2005), Hurricane Rita (September 22nd, 2005) and Hurricane Wilma (October 19th, 2005) all occurred within the Earth-Aether-Tide of August 16 – October 19th, 2005.
- Hurricane Andrew (August 23rd, 1992) occurred within the Earth-Aether-Tide of August 23 – October 25th, 1992.
- Hurricane Ivan (September 15 – 18, 2004) although just a category 3 hurricane, it may be significant because it also spawned 120 tornadoes occurred within the Earth-Aether-Tide of September 9 - October 1st, 2004.
Tornadoes include:
- The Tri-State Tornado (March 18, 1925) recorded as being the most powerful tornado in history, occurred within the Earth-Aether-Tide of February 21 - March 25th, 1925.
- The 1974 Super Outbreak is an unusual occurrence. Seven F5s and 23 F4s were generated in addition to the 143 tornadoes that were spawned in an 18 hour period between April 3 – 4th, 1974. This tornado outbreak occurred within the Earth-Aether-Tide of March 4 – May 18th, 1974.
So I am now building a prototype hurricane-in-a-jar apparatus.  I want to know if one gets CO2 and water spinning fast enough within an aether tide whether it will keep spinning when the motor is shut off.  If so, we have ourselves the makings of a fine free energy generator-type device.  This might be the secret ingredient that the Viktor Schauberger's Vortexer operated on.  Interestingly, that unit was apparently central to the Nazi flying saucer development near the end of WW2.  Also, this invention became subject to extreme suppression.  I intend to perform this experiment in about one month because the next aether tide will happen for almost the entire month of May, 2026 according to my orrery.  Alternatively, I suppose, I could just do it over a ley line if one was close, or at a ley line intersection point if one was close.
Anyway, nice to be among you working on free energy development at these uncertain times.  The world so needs to divorce itself from oil-and-gas and nuclear, imho.
Cheers,
Jim (AetherDragon)
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 01:43:36
