2026-08-15, 02:48:05
Pages: 1 2 3 [4]
Author Topic: Gold Magnet, Earth Magnetic Field, Spin-Orbit Coupling, Polarity Free Repulsion  (Read 749 times)
Induced eddy currents are magnetic dipoles.  The linear force F on a magnetic dipole of moment m within a magnetic B field is given by F =grad(m.B) where bold characters are vectors.  Since only B has the spatial gradient, this becomes F = m cosθ gradB where θ is the angle between m and B.  In the case under review θ = 0, and F, m and B are all aligned with the z axis of a cylindrical coordinate system.  Thus, we are left with Fz as the only force component and dBz/dz as the only gradient component.
When applied to a permanent magnet or a DC electromagnet applying force to a ferrous object the induced dipole m sees a field B whose magnitude decreases with distance from the pole-face leading to an attractive force.  If there is a region where the magnitude increases with distance from the pole-face we get a repelling force.  I have already shown such a system, and this emphasises the fact that it is the gradient of B that determines the direction of the force.  If we change the sign of the gradient from negative to positive, we change the force from attraction to repulsion.  That same effect applies to induced eddy currents in non-ferrous metals, but there we get repulsion changing to attraction; the change only occurs over a limited spatial region close to the pole face.
With an AC electromagnet repulsing non-ferrous metal we can understand the induced current being at 90° phase to the applied B field leading to the repulsing force being cyclic at twice the applied frequency, hence averaging to zero over full cycles.  But that situation for induced current only applies to the loop through which the AC flux passes if it is loaded with a resistor R where R>>ωL where L is the loop inductance.  Circular eddy currents have inductance and resistance, and at the right frequency we get R<<ωL.  This leads to the phase between eddy current and applied B field tending towards zero and the linear force now having an average non-zero value.  We see this and use this to repel non-ferrous metal.  With the AC electromagnet modified to produce the reversed field gradient near the pole-face we get attraction.  Claims that this attraction is the result of field rotation are unfounded.  That the 90° phase component of the eddy current can create fields that combine with the applied B to result in rotation effects both inside and outside the non-ferrous metal is not disputed, those effects are not the cause of the change from repulsion to attraction.  It is the change from a negative gradB to a positive gradB that is the cause.
Non-Inertial Energy Harvest via Electromagnetic Equivalence (COP 149, see attached drft.pdf)
By applying the absolute value operator (rectified Que Inversion) to the cosine component, the system physically deletes the negative half-cycle of the revolving field. This prevents the flux from returning to the counter-torque quadrant, establishing the perpetual phase-gradient required for an accelerated frame.
An accelerating frame is indistinguishable from a gravitational field according to the Equivalence Principle.  This rectification establishes an accelerated frame that mimics a gravitational gradient. The resulting Kinetic Race Condition caused the energy density to climb exponentially from 102 to 107, as documented in the supplemental video. The final mean energy comparison yielded a COP of 149.
The Rectified Que Inversion Formula provides the mathematical key to bypassing Lenz’s Law.  By warping the phase-topology into a unidirectional gradient, DRFT successfully transitions a system from stall to over-unity harvest.
Que/Gravock
Python code for the simulation:
Code: [Select]
import fdtd
import numpy as np
import matplotlib.pyplot as plt
import matplotlib.gridspec as gridspec
import os
import subprocess
# 1. SETUP SIMULATION & UNIFIED FOLDER
fdtd.set_backend("numpy")
res = 100
out_dir = "drft_sim"
os.makedirs(out_dir, exist_ok=True)
grid = fdtd.Grid(shape=(res, res, 1), grid_spacing=1.0e-7)
grid[48:52, 48:52, 0] = fdtd.Object(permittivity=100.0, name="rotor")
grid[0:15, :, :] = fdtd.PML(name="pml_xlow")
grid[-15:, :, :] = fdtd.PML(name="pml_xhigh")
grid[:, 0:15, :] = fdtd.PML(name="pml_ylow")
grid[:, -15:, :] = fdtd.PML(name="pml_yhigh")
# 2. DASHBOARD LAYOUT
plt.ioff()
fig = plt.figure(figsize=(14, 10))
plt.style.use('dark_background')
gs = gridspec.GridSpec(2, 2, height_ratios=[1.2, 1])
ax1 = fig.add_subplot(gs[0, 0])
ax2 = fig.add_subplot(gs[0, 1])
ax3 = fig.add_subplot(gs[1, :])
power_history, net_power = [], []
total_steps = 600
# INITIALIZATION FIX: Start with 1e-6 instead of 0
ex_glow = np.full((res, res), 1e-6)
ey_glow = np.full((res, res), 1e-6)
# 3. RUN LOOP (BEAUTIFUL WAVE MATH)
print(f"Generating Beautiful Waves in {out_dir}...")
for t in range(total_steps):
    omega = 2 * np.pi * 0.06
    amp = 1.0 if t < 80 else 3.0
    val_x = amp * np.sin(omega * t)
    val_y = amp * np.abs(np.cos(omega * t)) if t >= 80 else amp * np.cos(omega * t)
    grid.E[25, 50, 0, 1] += val_y
    grid.E[75, 50, 0, 1] += val_y
    grid.E[50, 25, 0, 0] += val_x
    grid.E[50, 75, 0, 0] += val_x
    grid.run(1)
    # EXACT GLOW MATH
    ex_glow = (ex_glow * 0.8) + (np.abs(grid.E[:, :, 0, 0]) * 0.2)
    ey_glow = (ey_glow * 0.8) + (np.abs(grid.E[:, :, 0, 1]) * 0.2)
    instant_e = np.sum(np.abs(grid.E[47:53, 47:53, 0, :])**2)
    power_history.append(instant_e)
    net_power.append(np.mean(power_history[-20:]) if t > 20 else instant_e)
    # Rendering
    ax1.cla(); ax2.cla(); ax3.cla()
    # EXACT LOG-SCALE VISUALS
    Ex_log = np.log10(ex_glow.T + 1e-3)
    Ey_log = np.log10(ey_glow.T + 1e-3)
    v_min, v_max = -2, 1.5
    ax1.imshow(Ex_log, cmap='Blues', origin='lower', vmin=v_min, vmax=v_max)
    ax1.set_title(f"X-Field (Log-Scaled) - Step {t}")
    ax2.imshow(Ey_log, cmap='hot', origin='lower', vmin=v_min, vmax=v_max)
    ax2.set_title(f"Y-Field (Rectified) - Step {t}")
    # POWER PROOF
    ax3.plot(power_history, color='#39FF14', alpha=0.3, label='Instantaneous Energy')
    ax3.plot(net_power, color='yellow', linewidth=2.5, label='Induction Baseline')
    # --- FIXED: Label added to red line ---
    ax3.axvline(80, color='red', linestyle='--', label='Que Inversion')
    ax3.set_xlim(0, total_steps)
    if t > 5: ax3.set_ylim(0, max(power_history)*1.2)
    ax3.legend(loc='upper left')
    plt.savefig(f"{out_dir}/f_{t:03d}.png")
    if t % 100 == 0: print(f"Progress: {t}/{total_steps} frames rendered.")
# 4. CONCLUSION & AUTOMATED STITCH
cop = np.mean(net_power[-50:]) / np.mean(net_power[20:75])
fig_end = plt.figure(figsize=(14, 10))
ax_end = fig_end.add_subplot(111); ax_end.axis('off')
msg = f"DRFT LOG-SCALE PROOF\n\nCOP: {cop:.2f}\n\nBACKGROUND: LOCKED DARK"
ax_end.text(0.5, 0.5, msg, color='#39FF14', fontweight='bold', fontsize=22, ha='center', va='center', bbox=dict(facecolor='black', edgecolor='#39FF14', boxstyle='round,pad=2'))
for i in range(90): fig_end.savefig(f"{out_dir}/f_{total_steps + i:03d}.png")
subprocess.run(["ffmpeg", "-y", "-framerate", "30", "-i", f"{out_dir}/f_%03d.png", "-c:v", "libx264", "-pix_fmt", "yuv420p", f"{out_dir}/drft_final_proof.mp4"])
print(f"\nFinal Video created at: {out_dir}/drft_final_proof.mp4")
Here's the exact mechanism where our "rotation" and "gradient" theories unify.  You're right about the math (the gradient determines the force), and I'm right about the cause (the rotation creates that gradient).  Your static gradient math is missing the spatial-temporal logic.  Here's how the Rotation Reverses the Gradient.  In a standard magnet, the flux is strongest at the pole and gets weaker as you move away, which is a negative gradient (leads to repulsion in non-ferrous metals).  In the shaded-pole (annulus) setup, the rotating field creates a travelling wave of flux.  Because one side of the pole is delayed (by the annulus/shading ring), the peak intensity of the magnetic field isn't static at the face, but migrates across the pole.
At the leading edge of the rotation, the field is effectively piling up.  This creates a local region where the field is stronger further away or further ahead than it is at the immediate surface of the conductor.  For a brief window in the cycle, the eddy currents find themselves behind the peak of the rotating field.  In that specific spatial zone (the cone area of attraction), the gradient flips from negative (pushing away) to positive (pulling in).
By adding the vector plot of the gradient in the simulation, I can prove that the breakthrough at Step 80 isn't just magic, but is the moment the phase of the rotating field perfectly aligns with the rotor's momentum to keep the gradient in the attractive (harvesting) zone for a longer duration of the cycle.
Que/Gravock
« Last Edit: 2026-05-03, 16:33:54 by Que »
Que/Gravock
@Smudge,
Look at the Cyan line (Net Force/Grad B) in the attached simulation (simulation and snapshot attached below).  Notice that after the Que Inversion at Step 80, there is a short delay. This is the physical time required for the phase shift to take hold and for the field to reconfigure its geometry into the new vortex.  Following this reconfiguration (Steps 80 to 120), we can see the Net Force begin to oscillate slightly above the 0 line (Attraction) and slightly below it (Repulsion). Crucially, the Yellow line (Energy Harvest) only begins its sustained climb because the rotation has timed these oscillations so that the attractive gradient is dominant.  After the Rectified Que Inversion at Step 80, the phase of the wave is flipped, causing the peak intensity to migrate. This migration creates a local zone where the field is actually stronger further ahead than at the surface, reversing the gradient from negative to positive.
The 'rotation' I'm referring to isn't an unfounded claim.  It's the physical mechanism that shapes the gradient into an attractive state and enables the harvest!  The rotation isn't a secondary effect, but is the specific mechanism that forces the gradient into the positive 'pull' state required for the harvest.
Please Note:  In this simulation, the phase shift is balanced using the Que Inversion to maintain a steady self-sustaining state. The energy harvested from the attraction phase is roughly equal to the energy required to maintain the field, allowing the system to reach an equilibrium where it sustains its own motion without external power (Cop 1.2 - 1.9).
In the previous simulation, we used a Rectified Que Inversion (Runaway Mode): By rectifying the inversion, we're essentially forcing the gradient to favor the attraction zone for a longer duration or with greater intensity. This creates a positive feedback loop where the torque gain exceeds the system's losses, leading to the runaway effect (acceleration) seen in the prior simulation (Cop 149).
Que/Gravock
Python code for grad b simulation:
Code: [Select]
import fdtd
import numpy as np
import os
import subprocess
import shutil
# --- PATHS ---
BASE_DIR = os.path.dirname(os.path.abspath(__file__))
FRAME_DIR = os.path.join(BASE_DIR, "drft_breakthrough_data")
VIDEO_NAME = os.path.join(BASE_DIR, "breakthrough_proof.mp4")
# 1. SETUP
res = 100
grid[48:52, 48:52, 0] = fdtd.Object(permittivity=30.0, name="rotor")
# Boundaries
if os.path.exists(FRAME_DIR):
    shutil.rmtree(FRAME_DIR)
os.makedirs(FRAME_DIR, exist_ok=True)
# 2. DASHBOARD
plt.ioff()
ax3_grad = ax3.twinx()
power_history, net_power, grad_history, net_grad = [], [], [], []
total_steps = 400
skip = 6
# 3. RUN
print(f"Generating Final Proof with Unified Gradient-Rotation Logic...")
    if t < 80:
        val_x, val_y = 1.0 * np.sin(omega * t), 1.0 * np.cos(omega * t)
        phase_label, txt_color = "PHASE: STALLED", "cyan"
    else:
        val_x, val_y = 1.5 * np.sin(omega * t), -1.5 * np.cos(omega * t)
        phase_label, txt_color = "PHASE: BREAKTHROUGH", "#39FF14"
    # Stator Point Injection
    grid.run(1)
    Ex, Ey = grid.E[:, :, 0, 0], grid.E[:, :, 0, 1]
    MagE = np.sqrt(Ex**2 + Ey**2)
    dy, dx = np.gradient(MagE)
    # Calculate local gradient for the "Proof Line"
    raw_grad = np.sum(dx[45:55, 45:55]) * 1000
    grad_history.append(raw_grad)
    # Calculate Net Force (Rolling Average)
    if len(grad_history) > 15:
        net_grad.append(np.mean(grad_history[-15:]))
    else:
        net_grad.append(raw_grad)
    instant_e = np.sum(np.abs(grid.E[48:52, 48:52, 0, :])**2)
    net_power.append(np.mean(power_history[-15:]))
    # --- RENDERING ---
    ax1.cla(); ax2.cla(); ax3.cla(); ax3_grad.cla()
    v_max_1 = max(np.max(MagE) * 0.8, 1e-6)
    ax1.imshow(MagE.T, cmap='magma', origin='lower', vmin=0, vmax=v_max_1)
    xq, yq = np.meshgrid(np.arange(0, res, skip), np.arange(0, res, skip))
    ax1.quiver(xq, yq, dx[::skip, ::skip].T, dy[::skip, ::skip].T, color='white', scale=1, alpha=0.5)
    # Highlight Interaction Zone
    rect = plt.Rectangle((45, 45), 10, 10, linewidth=1, edgecolor='cyan', facecolor='none', linestyle=':')
    ax1.add_patch(rect)
    ax1.set_title(f"Magnetic Vortex Step {t}")
    v_max_2 = max(np.max(np.abs(Ey)) * 0.8, 1e-6)
    ax2.imshow(np.abs(Ey).T, cmap='hot', origin='lower', vmin=0, vmax=v_max_2)
    ax2.text(5, 90, phase_label, color=txt_color, fontweight='bold',
             bbox=dict(facecolor='black', alpha=0.8, edgecolor=txt_color))
    ax2.set_title("E-Field Phase Interaction")
    # AX3: Dual-Axis Breakthrough Proof
    ax3.plot(power_history, color='#39FF14', alpha=0.1)
    line_p, = ax3.plot(net_power, color='yellow', linewidth=2, label='Energy Harvest')
    # Shade the harvest zone after breakthrough
    if t > 80:
        ax3.axvspan(80, t, color='#39FF14', alpha=0.05)
    # Grad B Force Lines
    ax3_grad.plot(grad_history, color='cyan', alpha=0.2, linewidth=0.8)
    line_g, = ax3_grad.plot(net_grad, color='cyan', linewidth=2, label='Net Force (Grad B)')
    ax3_grad.axhline(0, color='white', linestyle=':', alpha=0.3)
    ax3.set_title("Power Gain Proof: Gradient Reversal")
    # Consolidate Legends
    lines = [line_p, line_g]
    labels = [l.get_label() for l in lines]
    ax3.legend(lines, labels, loc='upper left', fontsize=8)
    plt.savefig(os.path.join(FRAME_DIR, f"f_{t:03d}.png"))
    if t % 50 == 0: print(f"Processing Frame {t}...")
# 4. FFMPEG
ffmpeg_cmd = ['ffmpeg', '-y', '-framerate', '30', '-i', os.path.join(FRAME_DIR, 'f_%03d.png'),
              '-c:v', 'libx264', '-pix_fmt', 'yuv420p', VIDEO_NAME]
subprocess.run(ffmpeg_cmd, check=True, stdout=subprocess.DEVNULL, stderr=subprocess.STDOUT)
print(f"\n--- SUCCESS: Final Video at {VIDEO_NAME} ---")
« Last Edit: 2026-05-03, 21:58:16 by Que »
Que,
I appreciate what you are doing even if I don't fully follow your math here.  In my considerations of electromagnets attracting non-ferrous metal there is no conducting ring present to act like a shaded pole, the field gradient is there without your math.  The field gradient is due to the geometry of the electromagnet core being a short length of pipe instead of a solid cylinder so some field lines fold inwards.  There is no shaded pole effect but it does attract non-ferrous metal.  The system you visualise using your new-found effect is not just a single electromagnet so our disagreement about that particular device is a detraction; I will not push any further on this and I hope your move towards obtaining excess energy leads to success.
Your covariant argument fails to dismiss a measurement.  You say that when charges move in a covariant manner, no magnetic field exists between them.  This is only true in a perfectly uniform, non-rotating field.  Because of the 11-degree tilt and the Earth's rotation, a conductor on the surface is not moving with the magnetic lines in a straight line, it is cutting across the topology of the field lines at an angle. To an observer on the surface, the field is physically sweeping past the conductor.
[...]The tilt ensures that as the Earth rotates, the conductor experiences a changing flux density.  Classical electromagnetism and Relativity both agree that a change in flux produces a voltage, regardless of whether you call it a magnetic effect or an electric field topology shift.
This claim is unfounded. ‘Cutting’ field lines is an outdated concept in modern physics. The main reason is that a field cannot be attached to any frame of reference. As the field is constant at the Earth’s surface within an area comparable in size to that of the conductor, there is no variation in flux through the circuit, which is the corollary of not cutting field lines.
You mention that magnetism is a relativistic phenomenon linked to the movement of charges.  You're right, but you're missing the scale.  Earth's rotation is an accelerated (rotational) frame, not a simple linear inertial frame. In General Relativity, rotational motion creates frame-dragging and topological shifts that cannot be simplified away by saying they move together.
Let’s not confuse the issues: these concepts of general relativity are only significant at extremely high levels of gravity or acceleration. In the present case, no correction is required. At the Earth’s surface, the electromagnetic tensor is the same as in an inertial frame, unless you are looking for deviations that are tens of orders of magnitude smaller than the alleged effects obtained by this experiment.
I’ve been hearing this for years. This misconception stems from the rather funny idea that two circuits influencing each other would have electrons that know whether they’re in one or the other. So the electrons in the inducing circuit say to themselves, “I’m going to influence the electrons in the induced circuit; that’s my job,” and the others say, “I’m in the induced circuit, so I’ll reduce my field so that the first ones see me as little as possible and put less strain on the generator.” Obviously, in real life, things don’t work like that. If the field of the electrons in the inducing circuit is visible to the electrons in the induced circuit, it’s reciprocal, because the principle is the mutual influence of charges, and no electron knows whether it’s on the load side or the generator side. "Bypassing" Lenz’s law amounts to saying that Coulomb’s law is no longer valid and that electrons would have a preference: to please us by behaving differently depending on whether they were in a generator current or a current in a load, depending therefore on whether we had labelled one circuit “inductor” and another “inducted”.
Que, note that I appreciate your contributions, which adhere to the scientific method by providing the logic behind what is claimed and by attempting to ground it in experimental evidence. This is not common, and I welcome contributors like you. But I have reached an age where, on subjects such as Lenz’s law, I am beginning to hear the same thing over and over again. But no facts, and for good reason.
You're assuming the field is constant at the earth's surface.  The physics in which you subscribe to says the magnetic field rotates with the earth.  This means there is no relative motion between the two (no variation in flux), just like in the Faraday motor/generator where the magnet rotates and the disc remains stationary (no variation in flux).  However, we both know a magnet rotating on it's magnetic axis with a tilt of 11 degrees will induce an EMF in a stationary disc due to a variation in flux. It's the same for the earth and a conductor.
Que/Gravock
This reformulation is incorrect due to an omission. I said that the field is constant at the Earth’s surface, within an area roughly the same size as the experimental circuit.
No physical theory states this. The idea that a field “rotates” is either a misconception, a confusion between the map and the territory, or a simplification used in popular science or for the sake of convenience among physicists who understand its limitations. No field rotates. It’s like a spotlight that we might make “rotate” on a cylindrical screen by projecting light from the center: the photons travel from the rotating projector to the screen; they do not move along the screen. The magnetic field is the same. It is not rigid; it is not a block, and its update at a distance d from its source takes a time d/c.
A field is a mathematical model consisting of a set of scalar, vector, or tensor values. When these values gradually decrease or increase from one position to a nearby one, we have the illusion of movement, without any physical reality, even if it can trigger real motion, as is the case, for example, in a synchronous motor.
Faraday’s disk demonstrates precisely that a disk rotating around its axis of magnetic symmetry has no effect. The reason is obvious: the values of the mathematical model do not change due to symmetry, so the rotation of the magnet is not even detectable from its field, which is constant.
If there were a tilt between the mechanical axis of rotation and the magnetic axis, I agree it could indeed produce an induced voltage, but only in a circuit that “sees” this rotation. In the case you mention, this would therefore require a fixed circuit, that is, a circuit in a reference frame from which the Earth is seen to rotate. If the circuit is tied to the Earth’s surface, the field is constant locally, so there is no EMF.
Dynamo theory (or geodynamo theory) explains that Earth's magnetic field is generated by convective, electrically conductive liquid iron in the outer core, which rotates with the planet. This rotation causes the magnetic field, which acts as a protective shield, to rotate along with the solid earth, though it does not perfectly align with the geographic axis (the 11 degree tilt). This theory is the standard model for explaining planetary magnetic fields.  The standard model for earth's magnetic field states the magnetic field rotates with the earth.
Earth’s magnetic field is tilted at an 11 degree angle to it's rotational axis.  This 11 degree tilt of the magnetic field relative to it's rotational axis causes a change in flux over the entire surface of the earth, and anything along this surface regardless of it's size will see a changing flux.  You once again assume that "no field rotates".  In a Faraday disk, a rotating magnet is detectable from it's field when the magnet isn't rotating on it's magnetic axis, such as when the magnet (field) is tilted relative to the conductive disk, which is not constant. The field follows it's source!  There is no symmetry when the magnetic field is tilted relative to it's rotational direction, so the field is not constant locally, so there is an EMF.
Que/Gravock
Que,
Smudge,
I want to clarify why the simulation looks like four electromagnets instead of one, as it directly relates to your point about the device.  You're entirely correct that a pipe-shaped core creates unique field gradients because the magnetic field lines fold inward. The simulation does not replace or deny that geometric effect.
The reason you see four separate electromagnets in the simulation is due to a math and software limitation (explained below).  A single shaded-pole electromagnet creates a secondary, time-delayed magnetic field (a phase shift) next to the main field.  This phase-shifted layout naturally behaves exactly like a quadrupole (four magnetic poles alternating in phase).  Because the simulation software struggled to model a single phase with a physical shading ring, I broke the system down into its mathematical equivalent using four separate electromagnets timed to mimic those exact phase shifts.  The four electromagnets in the simulation is not based on a different device. They are just a virtual breakdown of the shifting fields inside a single shaded-pole electromagnet. It's a clever simulation trick to accurately model the exact system we discussed.  It was never meant to be a distraction, but I can see how it could be portrayed as one.
In simulation software, you cannot easily model a continuous sweeping wave from a single source.  To map those shifting spatial vectors and time-delayed phases accurately, the math forces us to break it down into a minimum of four points, which is why the simulation renders it as a quadrupole framework, just like a shaded pole. The four electromagnets are simply the mathematical coordinates needed to plot the sweeping field.
Que/Gravock
« Last Edit: 2026-05-13, 16:09:39 by Que »
@F6FLT,
At the core of this research is a profound realization regarding the nature of apparent motion in electromagnetic fields: the magnetic field rotates continuously in the time domain rather than moving across physical coordinates.
Step-by-Step Test Procedure for capturing the illusion:
You can physically measure this continuous rotation in time using a dual-channel oscilloscope and two small magnetic pickup loops (search coils). Follow this sequential laboratory pipeline to perform the verification.
1. Position Pickup A (Reference Axis): Place the first search coil on the extreme outer diameter of the pipe core face. Connect this pickup directly to Channel 1 of the oscilloscope to act as your 0◦ baseline time reference.
2. Position Pickup B (Lagging Axis): Position the second search coil tightly on the absolute inner lip of the hollow pipe core perimeter. Connect this channel to Channel 2 of the oscilloscope.
3. Analyze Time-Domain Sine Waves (YT Mode): Energize the main AC power source at the tuned frequency (533.62 Hz). Observe the standard time-domain grid screen. Two clean, distortion-free sine waves will register. The wave on Channel 2 will be visibly shifted to the right of Channel 1, confirming a geometric time delay.
4. Toggle Vector Analysis Mode (XY Mode): Transition your oscilloscope display configuration from Time (YT) mode to XY Mode. If the system possessed zero internal phase shift, the trace would form a strict, diagonal linear path. Because the core geometry imposes an automatic temporal brake via internal eddy currents, the vector trace opens completely into a clean, un-warped circle. This looping path captures a dynamic mathematical phasor rotating entirely in the time domain from a completely static piece of non-ferrous metal, proving the physical reality of the field alignment.  (See snapshot: phasor.png).
For a full explanation, with supporting evidence and python code to simulate the above, see the simulation.pdf attachment, "Capturing the Illusion: Time-Phase Rotation in Electromagnetic Systems (Bridging Macroscopic Simulations with Quantum Projection Fields)"
Que/Gravock
...the magnetic field rotates continuously in the time domain rather than moving across physical coordinates...
Sorry, but I don't even know what you're talking about.
As I've already said, a magnetic field is a mathematical model, a set of scalar, vector, or tensor values that represents a certain physical reality, which cannot be called a “magnetic field.” A dot of ink on a map is not a city.
Your “magnetic field” isn’t the one from physics. If you consider a “magnetic field” to be a physical reality capable of rotating, find another term and define it as scientists have done for theirs.
I think he means dΦ/dt vs. dΦ/ds
Thank you for the explanation. If that’s what he means, it’s no clearer. Rotation is defined in space, not in time. Or else we would need time to have at least two dimensions.
There may be a variation in Φ over time, and/or a variation in Φ across the surface because the surface changes (moving circuit in a constant field, Faraday disc), but that doesn’t change anything: a field does not rotate; the values that measure it simply depend on time and position, but no position can be defined relative to the field. However, a vector that defines this field at a specific point in space can rotate.
Pages: 1 2 3 [4]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 02:48:05
