So add a low-ESR cap to your parts order before it ships on Monday. I have been pretty happy with Murata ERB series capacitors that have 40mΩ ESR at 3MHz.
I had some 270pF SMD caps: kemet c1206h271jggact250 which suppose to be low ESR, so I measured one to be 269.8pF and an ESR of 7.5 Ohm at 100kHz (my max). I tested it with the T200-2 core with the 40 turns 1mm diameter wire measured L= 18.82uH and DCR of 0.065 Ohm (100kHz) and a single turn input loop from the FG. Result is: 270pF SMD cap, 500mVpp input voltage, Fres 2204kHz at 19.9Vpp output voltage with -3dB points (19.9V x 0.707 = 14Vpp) at High 2210.2kHz, low 2196.6kHz = 13.6kHz difference with a Q of 2204 / 13.6 = 162 I also used a big variable air capacitor set to 270.2pF which measured an ESR of 2K at 1kHz, but that was lowered to 3 Ohm at 100kHz. Result is: 270pF Air cap, 400mVpp input voltage, Fres 2174kHz at 15.6Vpp output voltage with -3dB points (15.6V x 0.707 = 11Vpp) at High 2182kHz, low 2165.6kHz = 16.4kHz difference with a Q of 2174 / 16.4 =132.5 So the ESR of the capacitor is a major factor for a good Q result. Those Murata ERB series capacitors look even better, so worth a test with them. I don't think comparing this measurement result with the ones done before is valid, so i won't list them here. Itsu
« Last Edit: 2026-04-27, 14:55:11 by Itsu »
