Mags: from the HP4342A manual it turns out the main internal circuits are fed from a PS which gives +25V and -25V DC with respect to the common ground. using split DC supplies for RF and HF circuits is common, helps unwanted interactions between circuit stages. regarding the copper PCB area under the large toroid: I see what you mean but consider the HP toroid core enclosure revealed in the teardown video, they used teflon insulation spacers directly under and above the core and the dielectric constant of teflon is 2, i.e. twice that of the air, meaning the stray capacitance added to the measuring circuit was quasi doubled, yet they used it. The spacer Itsu applied between the large core and the PCB surface should contribute much less unwanted coupling capacitance I think. see pages 25 and 26 for replicated transformers and measurements in this paper: http://www.ve2azx.net/technical/HP4342A_Q%20Meter_Tests1.pdf he used 65 mil plastic spacers at bottom and top Verpies: Yes, the feed-through cap is included in the schematic too, labelled as C4, 56 pF, see the attached schema in Reply 70, previous page. Gyula
