2026-08-15, 02:34:58
Pages: 1 2 3 [4] 5 6
Author Topic: Simplicity  (Read 61801 times)
This is basic premise which non grounded OU must follow. Devices that have a ground connection are pulling electrons from there.
The non grounded must excite to ring then pick a spot along the ringing to attach to or buffer for a useful looping to occur.
Study the Armstrong and you will see whether a proclaimed OU device is worth your time. If you dont see an Armstrong then move on.
For instance does anyone see the Armstrong in the Witt device? I do. The looping is handled by the parallel proximity and the buffering is handled by the rpm limiting.
It wont work on a single axle because the field is not coupled to the driver. YOU CAN NOT MANAGE ENTROPY in a reasonable way. It cost too much in componentry and effort.
The Bedini motor(little school motor(its not his invention)) is a joule thief with mechanical buffering. Not sorry to burst egos.
Oscillate, pump, harvest are the only steps one needs. Any configuration needs buffering to get or limit to a usable current level.
The configuration is the mechanical output head which is the builder's choice.
So once the current or emp is seen then you have completed Oscillate and pump. Harvesting take control/buffering. HV diodes are a good start.
A simple OU start is to build an Armstrong oscillator with microwave transformers. This can be driven with joule thief. One might not see this on the internet because its such a great start that HV is no problem to get but to manage. I accept no liability for your efforts. You are basically building an arc welder but instead of shorting through metal connections you would want to buffer that explosion of energy after the pumping.
Each step has its experts and very detailed posting of builds and science behind it. Great nuggets for forward progress if one cares to stuff immeasurable diatribe into their brain bucket.
The quickest way is to accept the Armstrong model as a lens to look through. You'll find this adheres to non grounded devices. Now if you want to use a Kapanadze to drive an Armstrong then this will put you well ahead of where most get stuck but you will be forever be attached to ground. Iron wire cores are great to reduce eddy currents.
This excerpt here is the most complete description one will find explaining OU and not trigger TPTB.
Use a microwave oven circuit and replace the magnetron with a Tesla coil secondary. Immense amount of energy will exit. That emp will cause a suitable ringing for most to experiment with. I started out there after I told SM the TPU was driven by a stungun circuit (Armstrong with a charge pump) then moved to uwave xfrmrs. I eventually moved back to using/harvesting electric flyswatter ckts. Its cheaper, done and expendable.
There are a lot of categories of builds and circuits to use because all fall into the trap of their area of soapbox. If one doesnt see the Armstrong then make no further attempts as there will be no progress.
Self oscillation is the primary mover.
Just bounce a weak magnetic field in resonance.
The resonant frequency is dependent on 3 things:
1) The configuration of the head, i.e. material and shape.
2) The space/distance that the bounce is to occur in.
3) The relation of the space/distance to the field strength.
This is why Bedini, SM, and Mueller used cabinet magnets.
This is why Bedini stated Neodyniums were to strong.
Coral castle is based upon the distance as a major factor because the head was crystaline.
Don Smith's units were the distance of the spark gap to the resonant coil field.
If you see a spark gap then the field is being micro pressured/thumped(SM) from it resonant statis base.
If you want a unit with out a spark gap well good luck. Only the EMP shakes the stability into ringing.
Review the Witt device again to see the large field interaction with the commutator sparking inside. Sounds like a magnifying transmitter to me.
The comp wave generator does just this to expose the slight pressure return from the aether.
Funny thing I never get arguments for pointing out the obvious.
Just enough truth to not get disappeared.
It sounds easy, the only thing missing is all the relevant details between the the cause and the effect.
which is of course basically everything...
Since the magnetic field does not rotate with the rotating magnet(Maxwellian proof) then the magnetic moments are rotating with in the magnet. Are the moments aligning to the planet? If so then the planet is aligning to a greater external static force that does not modulate on the vertical/torus axis. That toroidal field must be the solar system to galaxy to universe.
Since the moments are rotating then there must be a frame drag between the moments and the molecular structure.
...but the molecular structure doesnt exhibit any change.
Different modalities of electron effects appear at different pressures depending on what the test is being performed. I also believe that different views arise between people when they can only view the dynamics through their filters.
Sorry I have not answered anybody.
A single frequency can be used when there are two 90 degree coupled coils made of dissimilar metals because both fields connect as long as the resonance exists then one collapses into an EMP into the second field. This is just like the primary of a Tesla coil EMPing the resonant field of the secondary.
Stan Deyo 2005 talk mentions the Lorenz torsion of two angular fields connecting.
 Am I correct in understanding the process as: Resonant coils of dissimilar metals at right angles; one will essentially "thump" the other; then harvest?
 I saw some comments probably 10 years ago from a guy in the Philippines harvesting the standing wave from the secondary of a resonant Tesla coil using a series wound bifilar coil (in order to avoid secondary reflection).
Something Bedini said on a Don Smith thread on EF, about a year before he passed - that ambient charge will enter a pulsed coil at its center (Bloch Wall) as the magnetic field of the coil collapses. I think Bedini attributed this influx of charge to gravity (he spoke of a ubiquitous gravity wave that could be harnessed in this fashion).
So is the "thump" what enables the aether to pump into the setup?
Always enjoy your posts.
Bob
Yes. The companion wave tests that Grumpy, JDO300 and I did showed the one bump echo returning. Its like a one reflection from a very stiff material.
The coil was a paper towel tube wound with bifilar lamp cord and struck with two very short pulses really close together.
We used the bidirectional GBTs switch board that Jason designed. I bought four and they are indestructible.
So that being said then I took hold of the Bloch wall knowledge and realized that there is one in space between two opposing fields that could be manipulated electronically.
The Kunel patent fit the bill. I had that patent years before and it stuck. I had previously realized that the Kunel patent attached to the High Q multiplier was the schematic for the TPU.
All the devices we were shown that work are either mysteriously lacking a vital piece of the puzzle or the author talks 'Special' materials.
The working devices all bounce the virtual Bloch wall in space. Move it what ever way one can and its all the same event.
The Kunel patent is the document that tells all. I found that patent after I built the GK4 and realized its the same protocol but in a VERY noisy fashion.
I know everyone wants to know or be the hero of the world with this tech. But dont. Forget the fame and glory and follow the Kunel patent along remembering all the devices you have seen and you will see those that are just noise or those that work.
In all the SM vids you will see him with slight of hand magnet. The buzzing is a relay oscillator. Its all Tesla. The buffering of the energy down to a usable level the next step. After that we all know what to do.
The information from me has never changed about this. Its always been right in our faces. I just got there the earliest by realizing the stun gun charge pump, the Fe garden wire and the magnets.
In your question and comments here you already are seeing the obvious.
In other forums I talk till I am blue in the face about adding Fe or NiFe material to their noisy builds but I cant get them off that trail. And thats ok because when this last coupling protocol is seen they have an enormous amount of inventory that will work. Thats how I made so many dangerous test results.
Look at what Hubbard and Hendershot did. The Hendershot weave predisturbs the field at the inside surface layer.
Look at what Muller did. He cuts the field and then reconnects. The beauty of all this repeat is the info world is so polluted with this tech that no one is going be able to claim ownership because everyone will see the Kunel protocol and all of testing and repeating in millions of threads.
The latest I realized is the Phryll coil. Its under the pretense of alien mystical nonsense, so to speak. But I just built one using steel instead of silver. This is alien tech. The specs of it are so artistically scientific its amazing.
The content is 2 dissimilar metals, one frequency and a crystal(that is the magnet) and the angle of the tube sides. The main thing that loses everyone is the coils are 90 degrees perpendicular to each other. The GK4 claims that break through also. The Deyo wedding cake coil is also 90 degrees and he is the first and only to announce its not the coils, its a natural event of two field reconnecting at an oblique angel and getting its Lorenz torsioned. Absolute Gold. But then he says but thats for another talk which I have not seen yet. So in other words you want the DARPA level secret? There it is.
Now if you are still following this, here is the coup de grace. By using dissimilar metals one can use one frequency because the two metals react differently to the one frequency. I never used capacitors on the GK4 and look what that open face microwave did. The downfall of all the only Cu devices is the builder is trying find the magic setup to keep Cu ringing forever. This is a fools journey. Put a naturally occurring field in there to break it or massage it in some way and you will 'HAVE IT'. This is what Smith, Hubbard, Hendershot, Steven Mark, Muller, and Bedini does. But everybody goes off trying to reinvent. What idiocy. Nobody is going to come out of the chute like I did with what the GK4 exposed. Not bragging. Strangely lucky. It is what it is. And if somebody does end up with something then you can bet its something mentioned in the post right here. I guarantee it. I send nuggets to Muller's daughter all the time and she lights up. She knows what her dad did. She wants me to give a public talk but I deny. There are just too many question after no matter how simple I talk about it. I just dont understand the blindness to the documentation.
This is the spoon feed that SM refused to do. Probably his way of backing the truth of the NDA. Remember he said 'It really is simple.' Thats mean 'Simply copying the patents.'
It really is radio. Transmitter closely coupled to receiver. He captures the transmit reflections.
There is enough technical docs supplied to interrogate.
https://rumble.com/v6srbp5-non-rotating-flux-on-a-rotating-magnet.html
Repeat your experiment on a monochrome CRT.  You are not seeing lines of flux, you are seeing a defocused projection of the shadow mask as electrons exiting the holes of the shadow mask are deflected.  That is why the colored dot pattern does not rotate, the shadow mask is stationary.
PW
Will do.
Thanks for the detailed reply, GK. I'm now a homesteader the last 5 years, and work pretty much to exhaustion these days, so not always time to engage the way I'd like to - so my apologies for not gratefully acknowledging sooner. That said, I do understand your post much better after letting it percolate in my brain and re-reading it a week later. There's gold in there, and I appreciate you doing that.
One thing I thought I'd throw out there, which you may or may not choose to address: I noticed Bedini was using Litz wire on some of his setups. I know what Litz wire in a coil does. Do you see a value in it here?
Bob
PW
 O0
Interesting conversations.
On EM, light and the non-rotation of fields. My analogy is a gatling gun, the barrel or source may rotate but the bullet leaves in a straight line. This is because once a particle, wave or bullet leaves the source it becomes independent from it. Think of a light bulb, the moment a photon leaves the surface of the filament it becomes independent from it. Rotating the light bulb has little or no effect on the particles leaving it.
Here is a good example,  https://www.youtube.com/watch?v=EtsXgODHMWk, Visualizing video at the speed of light — one trillion frames per second
This gives us a very good clue as to the nature of the Primary Fields (Electric, Magnetic and Gravitational) and why they do not rotate with the source.
I fail to see how your Gatling gun analogy proves or disproves fields do not rotate with the source.  The Gatling gun is still firing one barrel from a fixed position regardless of the fact that multiple barrels rotate into alignment with that position before launching a projectile.  Like any gun fired from the same position at any firing rate, the projectiles will follow the path toward which they were launched (given that windage and gravity are ignored).   The rotating barrels of the Gatling gun play no role in modifying the launching of the projectiles (aside from keeping the barrels cooler).  The projectiles are launched just as they are with any other single barreled gun firing in the same direction.
It is true that once the projectile is launched, movement of the barrel has no effect on the already launched projectile.  In a similar fashion regarding your light bulb, once a photon is emitted, modification of the bulb's position or on state no longer affects that previously launched photon.  However, photons and projectiles are not "fields".
Again, I fail to see how the video offers any clues as to whether fields rotate with their source.  The question of whether or not a magnetic field rotates with a magnet has been pondered for some time, and there remains debate among scientists as to whether it does or does not.   I am in the camp that believes that fields do rotate with their source.  Rotation of a purely homogenous magnetic field may appear to be stationary, however, it is a trivial matter to detect the variations in the rotating field caused by microscopic domain irregularities.  It is therefore reasonable to state that the field is at least modulated as the magnet rotates due to these domain irregularities.  Macroscopic irregularities are much easier to detect and the variations in the field that occur due to those macroscopic variations do indeed rotate with the magnet (a useful trait used every day to detect rotation of a shaft, etc)
In my imagineering of the world, a field is a modified region of space and any movement of the source of that field will modify that region of space accordingly.
Just my two cents...
PW
picowatt
Good response and this was the only point I was trying to make in my analogies. Something leaving a source becomes independent of the source.
Good catch, when developing magnetic levitation devices and bearings I noticed all magnets have irregularities. My field mapping arrays determined field strength is never uniform near the surface. The far field is more uniform but the near field is a mess.
I think we need to define what constitutes a true "field rotation". In my testing a rotating irregularity on the magnet surface caused a periodic change in the field detectors. Here a change in the field strength in one specific area rotates with the magnet. However we can do the same thing with many small magnets with different field strengths rotating. This is not a true "field rotation" imo it is a periodically changing field strength at the source.
This comes back to my analogies and understanding the difference between a source (field carrier) and something external to the source (the field). When we adopt the "field carrier" model things become clearer imo.
ChatGPT can explain it better...
Question, does a magnet spinning on the north-south axis have a rotating field. The field is uniform, how can it rotate?.
Answer,
First: What does it mean for a magnet to spin on the North-South axis?
Assume we have a bar magnet with its magnetic dipole aligned North-South (i.e., magnetic north pole pointing geographic north). If you spin this magnet around its own magnetic axis (i.e., rotate it like a top, aligned N–S), then:
The direction of the magnetic dipole doesn't change — it's still pointing North. The field lines don't change either — they're symmetric around the axis. So, to an external observer, the magnetic field appears static, not rotating.
So does it have a rotating field?
No, not in this configuration. If the magnet spins about its own dipole axis (N–S), and the field is uniform and symmetric, there is no rotating magnetic field in space — the field does not change direction at any point in space.
In effect, many people are confusing a field change and a field rotation.
The answer to this question has been known for a long time. By definition, a field is only a vector at one position in space.  If its intensity and direction are constant, by definition it does not rotate, since it is static. This is the case when a cylindrical magnet rotates around its magnetic axis; the field remains constant everywhere.
If this same magnet were to turn 90° from its magnetic axis, then at a given point in space the field would increase, decrease or change direction, giving the impression of rotation, in the same way as if I were to project a laser light onto a cylindrical wall by turning the torch, I would see a point of light rotating along the wall. Does this mean that something is moving along the wall? Of course not, the photons always come from the lamp, they don't move along the wall.
With a magnetic field, it's the same thing. The field is created by the magnetic dipoles of its source. As with the lamp, there is a source. It can be modelled as an emitter of virtual photons that mediate the field. The virtual photons originate from the source, so they do not rotate tangentially somewhere in space.
F6FLT
Well said and I agree.
Simply put, when we spin a magnet on it's polar N-S axis the field does not rotate with the magnet. However a rotation or movement on any other axis moves the poles and the field does change.
If a static magnet induces a field in an approaching cored coil, the core will become a magnet if close enough. There will be a field induced in the coil. At this point, if any further movement of the cored coil occurs, it is then the magnet that is moving through the coil field. The magnet doesn't cause resistance in the coil. It's statically sitting on a bench. The induced field within the coil generates resistance in response to change... nothing to do with magnet, it is just inducing the field, not the response of the coil to the induced field. The equilibric forces rotating around the bloch wall within the coil field are responsible for the resistance to change.
Robert Adams (and many others) knew that this induced field in a coil could be biased, to alter how the equilibric forces react to change - counterwound pulse coils on either side of the rotor in this case.
And in the device I've been working with that uses counterwound secondaries, a dead short or load at 1800rpm will speed the device up.
Moving magnets over connected counterwound coils... simplicity... but you need to understand that the bloch wall is etheric in nature. Ie . It is a higher energy density, which is why working with the bloch wall is so important.
However, if your cylindrical magnet was actually a can containing a motor driving a charged sphere, then the field magnitude at any point around the magnet would change value as the magnet's rotation speed adds to or subtracts from the internal motor's speed!!
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 02:34:58
