2026-08-15, 02:49:47
Author Topic: Anomalous voltage increase  (Read 33732 times)
Today I did some experiments to see what the influence magnets have on a coils flyback.
To keep this short I will focus on the only way I found that increased the flyback voltage.
The best result was placing a 2" cube neo on both sides of a coils soft iron core : SN | SN | SN
I connected a 12vdc car battery to an IRF840 switching the positive line.
I drove the IRF840 directly with a 10v square wave from an HP Function Generator at 5000hz
Bear in mind the IRF840 has an internal free wheeling diode..
I placed a Pearson wide band current probe in line with the coil and a x100 probe across the coil.
From my tests it looks like there is a significant voltage increase with the magnets present in the SN | SN | SN setup
SN | NS | SN    and    SN | SN | NS  both decreased the flyback voltage.
coil 1:
20 awg high ohm coil on soft iron core
168v without magnets
212v with magnets
44v increase
coil 2:
20 awg  low ohm coil on soft iron core
395v without magnets
540v with magnets
145v increase
At certain frequencies below 5000hz there were some anomalous current spikes that I need to go back and look at, in fact one killed two of the mosfets.
Anyone want to independently verify these results???
NOTE: This requires a really solid mounting for the 2" neo cubes and big neos are very dangerous to work with! Be careful!!
Thanks..
Darkspeed
« Last Edit: 2010-01-31, 08:14:54 by darkspeed »
Hi ds
Sounds interesting, yes i would be up for a rep, but will need to order some magnets to try, but first i need to get my current stuff sorted, i have loads on at the moment.
Those are large magnets, can it be scaled down a bit maybe 1 inch square magnets.
anyway sounds interesting, keep at it.
Peter
Hello darkspeed
This sounds very interesting!  I have a question, what did the amperage do?  Did the draw decrease or increase when using the neos?  Also did the current change on the output in any significant way?
Peter, I will try it with the next smaller neos I have ( 1 x 0.75 cylinders ) and see if I get anything..
stprue, I kept the current probe visible on one of the scope channels and since the coil is firing with the neos and not against them there was no additional current draw in the coil.
The only strange current issues were the random current spikes below 5000hz.
Im going to do some more work on it today
ds
What are your core dimensions and how many turns was your coil.
Core is a 17mm x 17mm x 75mm soft iron core..
I will have to go measure the windings as these were a couple of coils i pulled off the shelf that I had built a while back.
The only part of the event that is opposing the polarity of the setup is the flyback and I am not sure why a static opposing magnetic field increases the energy in a flyback event??
Replicated the result with 1 x 0.75 n42 neo cylinders
42v increase with two cylinder magnets on each side of core ( compared to the 145v increase with the 2" cubes )
coil :   2.2311mh @ 10khz     2.54ohm @ 100hz / 93.69ohm @ 10khz
« Last Edit: 2010-02-01, 03:23:37 by darkspeed »
I just started from scratch with a different coil / different HP / different scope and was able to reproduce the results
I also just had a friend report that he could get the same results.
Is this a known effect that I somehow just missed before??
Anyone know of this??
Iv been working with earplugs all day because the 5-6khz tone will rive you insane..
« Last Edit: 2010-02-01, 01:00:18 by darkspeed »
Darkspeed:
You may be a bit surprised to learn that the magnitude of the spikes has nothing directly to do with the magnets.  Somehow the magnets are causing secondary effects that are influencing the main parameters that affect the maximum spike voltage.
The first parameter is the amount of current flowing through your coil.  There is no need to switch the square wave to the MOSFET gate at 5 or 10 KHz.  Try 50 Hz instead.  This will likely ensure that you have the maximum possible current running through your coil when you switch the MOSFET off and you will not go insane from the high frequencies that you are suffering though now.
The second parameter is the speed the MOSFET switches off.  The cleaner and sharper you can make your square wave to the gate the higher the spike voltages you will get.
The third parameter is the inductance of your coil, the higher the inductance the higher the voltage spike.
Your external magnets are somehow affecting the above three parameters to give you increased voltage on your spikes.
The formula for the spike voltage is v = L di/dt.   You should try searching on that.
Careful if you start tuning and getting higher and higher spikes I assume that you will likely blow your MOSFET.
Thanks MileHigh!
That reminded me to do something I forgot to do... remeasure the inductance with the magnets in place..
That may be effecting it.. I will check it out..
The best result so far has been feeding the HP through a Wavetek so I could adjust the duty cycle.
Setting it to 5khz on the HP and 10us on the Wavetek, then inverting the output, so 5000 times per second the mosfet turns off for 10us
Ok.. Now I feel like an idiot.. I was not expecting it to change the resistance of the coil..
Resistance without magnets     2.54ohm @ 100hz / 93.69ohm @ 10khz
Resistance with magnets         1.93ohm @ 100hz / 43.14ohm @ 10khz
Inductance without magnets     9.268mh @ 100hz  /  2.5528mh @ 10khz
Inductance with magnets         3.844mh @ 100hz  /  1.2589mh @ 10khz
The resistance and the inductance drops with the magnets
Cyril Smith (PhD. Physics?  - he's associated with MPI) posted something about this a few years ago.
Might be in one his articles here:
http://74.125.113.132/search?q=cache:SAeqsKBrsqUJ:jnaudin.free.fr/html/meg.htm+cyril+smith+magnet+coil&cd=1&hl=en&ct=clnk&gl=us
Is the inducatance and resistance different with the polarity of the magnets reversed?
(I see that the differences with and without the magnet are nonlinear.)
Generally we speak of resistance at a particular frequency as "impedance", otherwise some might get confused and infer an actual change in DC resistance with the magnets. This is not the case.
Nice to see that your inductance bridge allows excitation frequency selection, makes impedance plots easier.
Nice work ds, you didn't understand the effect and now you do, as do we, thanks
This gives me another test to add to my pulse experiments.
Peter
Good question.. I tried that and both the resistance and inductance stays the same when i switch polarity... but with opposing magnets on each side both rise..
got me really thinking about the orbo and how this works in a toroid
Haha yes ION "impedance" im bad about that, just like i call neons spark gaps and bulbs resistors lol...
Peter
Thanks Peter, im the master at learning stuff the hard way..
write this down and make a diagram
can you change the impedance of a toroidal transformer with a magnet? - sure you can
EDIT:
What "is" the imaginary part of impedance?
write this down and make a diagram ??
are you talking self inductance?
When I think orbo I think  ed leedskin magnet
I'm talking about how the magneici effects the impedance and inductance
I wonder if it will effect the permittivity of a dielectric?   Hmm - got a doorknob or other plate cap around?
In answer to the question about imaginary  part of impedance: http://hyperphysics.phy-astr.gsu.edu/Hbase/electric/impcom.html
I have a case of 40kv 2000pf  doorknobs  -  outline what you have in mind
actually forget the doorknobs
Do you have vacuum caps?
See if a magnetic field alters the permitivity of free-space within the vacuum cap.
http://74.125.95.132/search?q=cache:nJYwn_GMsLIJ:hyperphysics.phy-astr.gsu.edu/HBASE/electric/elefie.html+permittivity+%22magnetic+field%22&cd=1&hl=en&ct=clnk&gl=us
I actually dont have any vacuum caps..
If I ordered one any advice on pf to get..
http://cp.literature.agilent.com/litweb/pdf/5980-2862EN.pdf
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 02:49:47
