2026-08-15, 07:12:47
Author Topic: The T reactor  (Read 21997 times)
Well i thought i would start a thread on this(what was suppose to be a junk project),as it turns out that it has some interesting things going on. I am in the process of changing to batteries in hope that i can loop it without to much trouble.
Anyway,here is the first video of the setup.
https://www.youtube.com/watch?v=QVffZOnerUk
OK.here is the second video,where the system is running on batteries. As you will see in the video,we have a very good example of the run battery climbing in voltage,even though we are only drawing from the battery,and no power being returned. It's being triggered from my SG,and the inductive kickback is being sent to a charge battery ahla hudini style.
https://www.youtube.com/watch?v=YWPJXqUFD4o
Can you post a schematic? I'm always worried when a device is clocked by an external SG because it's possible that the signal generator is supplying significant power to the circuit. That's one reason why I built in a dedicated 555 pulser to my EMJ build, to get rid of the possibility that the external signal generator was contaminating the power measurements.
I heard your gonna put in Ground Rods [like Clarence]
didn't you get the memo... :o
*  Ground rod *  Memo
https://www.youtube.com/watch?v=D39u9eeGG4c
For a fellow such as yourself [that makes it rain during experiments  :D] I wouldn't stand too
close ...
*  Ground rod *  Memo
close ...
Funny you should say rain-->it's been raining since lunch time here. >:(
Schematic ? lol
Im still changing things around here every couple of hours. I'd be drawing schematics full time at that rate.
We have 5v P/P from the SG,and a 100 ohm resistor on the base. So the SG may be delivering 62.5mW max,as we have only 2.5v delivered to the base,and we are drawing 387mW from the battery. Just go's to show how battery voltage can increase when a light load is drawn from them O0.
*  Ground rod *  Memo
close ...
Man that looks awsome. If that is slow motion on one lightning strike,then how fast were those little lightning bolts that seem to build the path for the larger ones that looked like they were in slow motion. O0
So Its already raining....
perfect time to call "the Power" .. :D  but you better wait till tomorrow to bring the thunder and lightning
you wouldn't want to wake the neighbors. 8)
** I see your comment above
yes that one is from Tinsel ,[better copy than the first]
this is what can happen when you summon the beast...be careful with those ground rods  O0
 [and you Do know I'm quite serious  given your reputation around here]
Hey guy's,your going to want to see the next video. I built a new coil of my own design for the reactor,in the hope of collecting power from the reactive power. Anyway,i decided to give it a go as a inductive kickback charger,and what happened next has me a bit baffle'd :o
I will let the video tell the story,and will get it up ASAP. O0
  Looking forward to it, TinMan.  Luv your videos!   O0
Here is the video on my new coil design. I guess the best thing to do is just watch the video.
I am yet to determine the power source that is running the device ATM
https://www.youtube.com/watch?v=0vHhgYW3GDI
I hope the TinMan is resting now [1 AM in OZ],sometimes its good to go to bed with dreams of self runners [been there]
And I hope when you wake up it will not be just a dream    O0
Lol-im to hyped up chet to sleep.
OK-you will need to sit down-and no laughing.
It seems that the only conection we need to get it to run is a !!!ground wire!!!-->yes,ground-not mains neutral,although they are one in the same here. So i ran a wire from the device to the grounded copper water pipes of the house,and it run's. How it runs i dont know yet,but i will work it out.
Now you have to go drive some Rods into the ground and take it outside and hook it up
careful your neighbors don't lock you up [2 AM hammering Rods in the dark]
 :D
Slider [below]
He's referencing the Clarence deal [Barbosi and Leal thread]
Clarence has 48 ground rods and counting for his unit to work.
I like Brad's better....
Ahhhh...so do you think it's a leaky Ground connection ?
The circuit would still have to fire at that 36kHz and upward rate though, which is weird enough. Thing being, that the transistor would have to fire to produce that rate and there isn't the current to do so ?
Here's a test. If you could wind a coil around the Neutral wire and see if it inductively couples to still run. That would then make it a 'wireless' feed.
Or plonk a big copper ground rod in your yard.
However, on from there would be to tune it much like a crystal set and run the neon from ambient waves. Maybe WiFi, phone coverage waves, radio stations. It's obviously efficient at lighting that neon, so perhaps it can be tuned around to charge batteries or run motors.
Group: Renaissance Man
Dear Tinman.
I have to disagree with regards to the frequency change. From my perspective there was no change in the main spikes, was the scope counting the intermediate spikes between ?
You appear to have a modern day Cook coil !! Very well done.
 :o Slider thinks it could be proximity to the new Space rock.
Haha, well, hey that's the other odd new thing in the room  >:-)
The distant Ground rod idea is based on own experiments.
If you take 2 copper rods (house gauge copper) and drive them at least 4ft apart into anywhere in your back garden, then put a crystal set earphone/speaker straight across the rods, you may well hear mains hum.
ETA: the distance might well be used to advantage, rather than forming resistance. Place the ground rods, connect with wire that forms 2x 1/4 wave of the AM radio band. So about 100ft of wire to each, suspended as straight wires in the air, at least a couple of feet from the ground. Then connect the circuit to it.
Dear Tinman.
Yea,as i mentioned in the video,i think the scope was trying to read the smaller spikes when they rose slightly in amplitude.
And what is a Cook coil?
Dear Tinman.
Ooop's sorry missed the dialogue !!  ;)
Daniel McFarland Cook. He made the comment in his patent that the effect worked with a single coil but with a pair, was far superior.
Based on Sliders comments could the device be picking up a Wi Fi signal or some other Medium frequency transmission ? As daft as it may sound are you able to construct a simple tuneable tank circuit based around the fundamental frequency ? And see if you can tune into it ?
Dear Tinman.
We dont have anything that is around that frequency here in OZ. My wifi is 2.3GHZ,and most radio stations around here  are around 90 MHZ. Not sure what the TV stations are,but will look into that. It has to be running of some sort of signal input from some where,and i will find it sooner or later-i hope.
TinMan:  I think you've just reproduced the Kunel patent, in a slight variation.
http://www.intalek.com/Index/Projects/Patents/DE3024814.pdf
You are the first to do it that I know about.
Very interesting.
Dear Tinman.
I just re read my post !! Duh, you already have !!   :D  ;D
Had to reread it myself Grum, but, yes indeed, he's tuned it exactly, to something  8)
The Kunel Patent looks related for sure.
Are the magnets running around like a weird TPU and PMH crossover, allowing them to oscillate based on coil resistance, inductance, loop area and magnetic strength ? could that be how the frequency manifests ?
Could there indeed be a Leedskalnin inclusion here.
or,
Will Brad post that he's found the frequency to be a TV remote, stuck in the 'on' position, that fell under his chair ? lol
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 07:12:47
