Thanks, i will take a look at it again tomorrow. My earlier photo of the PCB should show the red SG clip to your point TP2 and its black ground clip to your point B Also the scope is on those same points, so probe tip to TP2, its ground clip to point B I was only sweeping the L1C1 tank circuit. This evening i was studying this design note: http://users.skynet.be/BillsPage/ClassE030909.pdf As always, things are more complicated as then first anticipated, and this design is without the notch coil. I followed those design notes / calculations and not even need the circuit be designed for a specific frequency (13.56MHz), but also for an intended drain voltage (24V / 40V etc.) and output (100W, 200W etc.). So i calculated my amp. for 13.56MHz and for 24V and 40V with resp. 100W and 200W output. 2 scenarios come out of that with fairly different values for L's and C's, see below diagram for these different value's. Q of L1 was measured to be 8.5. One question came in mind; does it matter if we have first L1 then C1 or vv (using verpies his diagram)? (it seems that the L-match inductance is being combined with the resonance inductance, so these 2 L's should be connected and not be separated by C1). Thanks Itsu
« Last Edit: 2015-07-16, 13:05:17 by Itsu »
