2026-08-15, 14:12:03
Author Topic: transistors / tubes / IO phase angle  (Read 5276 times)
Iv been giving the whole transistors thing a lot of thought  and  here is what i have so far..
Switching speed between transistors and tubes - with a properly designed system this is not a huge deal
Noise between transistors and tubes - this can go either way depending on what you are ding but in general tubes are better at sine waves.
Amplifiers ( as a complete system ) between transistors and tubes - Huge difference if you are considering the input to output phase angle and noise
The time it takes a signal to pass through a transistor amplifier ( 1995 pre amp / amp ) is magnatudes longer than it takes for a tube ( pre amp / amp )
So... if your system was a feedback system and relied on exact phase angle between input and output.. to say hit a natural RF then tubes win hands down.
you would not want things to drift toward "max conversion" for any reason
Yes!! you do - you want exact conversion - then you can introduce the desired delay " you want " to control the reaction
O' sorry G - i see what you mean now....
all depends on the setup
some VCO's and crystal multivibrators are very stable
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 14:12:03
