2025-12-18, 20:54:39
Pages: [1] 2 3 4 5 6
Author Topic: Space: The final frontier  (Read 63605 times)
Hack link to chat page.
http://www.overunityresearch.com/chat/index.php
I am going to start this thread out with nothing but pertinere:
And to this list I would add Tesla's balanced coil if I could find it again. It was as big as a room.
http://serenityhealing.net/20.html
« Last Edit: 2010-01-12, 19:41:06 by giantkiller »
Done.
Aside from all the science, these configs all hold the same parameter.
The PDF is the grand daddy of them all.
http://www.elisanet.fi/dncmrc/lthesis.pdf
The flash movie is a red wire with a blue mag field modulated by the circuit field resonance that Don Smith talk about recharging his battery while running.
http://www.overunityresearch.com/index.php?action=dlattach;topic=33.0;attach=176
« Last Edit: 2009-12-20, 06:25:23 by giantkiller »
Amazing simalarities Paul...  :)
I don't think it's coincedence.
Marco.
I had a wooden core coil with 53 turns 24awg secondary and 7 turn 16awg primary. Natural resonant freq showed up as 188khz to 240khz. Add .0033uf to tank it on both windings. Got the draw down to 43ma. with a 100ohm resistor in series using sine wave.
Looks like the Pri and Sec are close in mass.
Marco.
My Smith air coil build with scope shot. square in on the middle coil and sine out on the 2 outer coils.
My center piece is just a chunk of flexi tube. It just happens to fit in the spool. Aint life great!
pictures of box connections.
you can put 50 to zero ohms between the fet and coil.
« Last Edit: 2010-02-12, 03:39:00 by giantkiller »
GK coil.
I like that GK coil.. Very Clever ..
Then like this....
http://www.youtube.com/watch?v=gY63-25hp44
 8) 8) 8) :o :o :o :o ;) ;) ;) ;) :D :D :D :D :D
That is the only combination I could perceive that would do anything in the TPU. After all, we knew it had to be Tesla somewhere and this driver is in 99% of the devices and its true what Grumpy said about raising the voltage.
At 242vdc I almost burned up my rat shack transformer.
I have stopped posting publicly. I saw the firestorm over agentgates and don't want to go thru that again.
« Last Edit: 2010-01-10, 07:22:32 by giantkiller »
Then like this....
 Thats interesting!
One thing I learned that made a big difference for me is to place a restriction on the pulse going into a resonant tank system and also place a restriction on the output...... leaving enough energy in the two tanks to ring each other up.... until the output tank can overcome the restriction and do some work...
If you load the output side of the tank system directly the magic never has a chance to happen..
Its the hand off between the two tanks that creates so many chances to capture the energy that initally exists on a blank wire..
I ran across this:
He has the right information but wants to do too much electronics.
http://www.alt-nrg.org/plans.html
I also thought about what sparks asked me about the electrolitic caps on the supply. I don't need True DC. What if the DC is at its highest point of the ripple when the fet turns on?
The ripple shows up with 14mghz in it and that sharp spike appears on top of each crest. But not enough of them for my satisfaction.
What I am going to do next is take the NST and pulse the gate while connecting the NST output to a FWRB for the DC supply. At 3kv I need to put resistance at the gate and drain for starters.
Also adding diodes at the tanks to lock the energy in the resonant circuit area.
The Trinity
The WW  ;D
here caps and hv supply.
Then like this....
 Thats interesting!
if you make it go faster than it is supposed to then the medium must compensate.
I think I got it this time. It is the geometry of the winds is all.
Look at the green winding with the spaces, capacitance and inductance. We get a frequency from that. The last youtube I made was driving just that with 4khz sine wave. I get ~8mghz out.
I realize this also looks like a shortwave antenna if the stranded was laid out straight. Then I remember the notched PVC coil has 2 of these GK coil primaries.
And I woke up!
If i have three layers of these windings with a slightly different spacing or wire length then I would be heterodyning in a circle. That means a rotating magnetic field.
If it travels across the scope screen then it travels in a circle.
Layer one tested with 4khz @ 140vdc. Screams at ~9mghz. I realized that is all there is to the lastest coil build. I can make a 3 layer, 4 quadrant tpu the size of a golf ball.
3 wire lengths. 3'8", 3'2", 2'8". The frequencies will correspond. An upcoming scope shot will tell.
I have my fet 6 inches from the coil and that equates to 140 volts with a jagged wave top. If I rasie the voltage to 242 then the wave top is very even on top, less ac wave part.
I like to keep my voltage down so tonight I will move the fet closer to the coil and put it in the center. My thinking is that is why the components are sitting on the ring. I know, why else. But it serves a purpose for the feedback of parasitic ringing.
top coil is 11.03 Mghz 18vpp
mid coil is 10.94 Mghz 19vpp
bot coil is 10.17 Mghz 28vpp
Serially connected bot to mid to top is 9.997 Mghz 19vpp
All in parallel is 4khz 5 vpp. No Mghz ringing.
Moving the fet closer after resonation starts does nothing. The ringing starts up immediately anyway.
The varicaps are in parallel for this test.
The vdc meter readings are taken when the oscillator side is always shut off. The meter readings are inconsistent when the oscillator side is turned on.
DC power supply across the fet, 100ohm 5 watt resistor, and bot coil has to be greater than 45vdc for the ringing to appear. Moving the coil nearer the fet at less then 45vdc does not actuate the resonation!
At 49vdc the ringing in chirp patterns starts to appear.
At 60vdc the ringing is solid and no chirping appears. I remover the varicap and the ringing stops, still at 60vdc.
No tank varicaps in parallel!
At 86vdc the ringing starts as the chirping waveform.
At 88vdc and above the chirping disappears into the full ringing waveform.
After the ringing is full on then raising the volts to 140 does nothing to the p2p of the gate ringing. Higher than 140vdc will give you headaches.
Hope this helps.
Another test I will do is to drive some of the coils on Mighty Little. I can almost predict the results. Short length, low turns count, fatter wire gauge relates to standard conduction. Large voltages can be applied to smaller gauges giving the better outer field generation. As the wire thickness increases we advance into higher levels of conduction if the voltage is not raised accordingly.
Patent http://www.pat2pdf.org/patents/pat5339061.pdf
http://www.aetherenergy.com/Technologies/PAGDrefs.php
Oh Yeah, Baby! http://www.pureenergysystems.com/academy/papers/Evolution_E.V.Gray_Circuit_Topology/index.html
I gather other pics to put here for doco sake.
« Last Edit: 2010-01-15, 19:56:12 by giantkiller »
This is the response from Borderland Sciences:
Hello,
I have not spoke to Eric in a few years now.
He does his best thinking in his cars, so I have heard.
All who wander are not lost....may be the best way to understand Mr. Dollard : )
James
--- On Tue, 12/22/09, paul@denver.net <paul@denver.net> wrote:
Subject: Hello to Eric Dollard
To: bsrf@sbcglobal.net
Date: Tuesday, December 22, 2009, 11:19 AM
I heard he is living out of his car! I need to contact him.
Do you or anybody know how I can reach him, what his current status is?
Paul
GK.. if you are looking for eric..
he just did a presentation in sf..
The San Francisco Tesla Society
presents a free presentation featuring
Eric Dollard
"A History of the Marconi & RCA Station:
Bolinas California"
Sunday, November 8, 2009  1:45 p.m. - 4 p.m. at the
San Francisco Public Library
Senator Milton Marks Richmond Branch
351 9th Avenue @ Clement
10th Avenue Entrance
San Francisco, CA 94118
http://www.sftesla.org/Newsletters/2009/SFTS_news_2009_11_08.htm
The San Francisco Tesla Society Information Hotline
(415) 820-1451
is available 24 / 7 when you can't get to the web.
Provided by Baylink Voicemail Communications.
The cardboard is an air form. It lets the most energy ring in space instead of sumped inside a captive media. Like the ECD. Sumped equals losses if your view is correct. But in reality the same energy is somewhere else just not in the place we want where it can do the most good.
In other words: Inside metal is a bad place. No electrical current or magnetic current but air current/flux lines. The lines appear in 2 different ways, flux in the metal or flux in the air. If you ring the metal flux the metal sings. If you ring the air flux the planet sings because the air flux is coupled with the earth flux and atomic flux. This gives us 2 tuning forks instead of one.
The flux lines are actually standing waves of electron polarity. Which denotes a frequency. Put iron filings on a paper and expose them to a magnetic to expose the flux lines. Measure the distance between them at their furthest distance, usually the middle. That will give you the base or a harmonic distance of the frequency wave.
The strange wavehill hump points to the compwave. The pancake uses this as transmission media.
One more thought like this and I qualify for planetary expulsion.
--giantkiller.
text
Hi, pics to order take 4..
C:\Documents and Settings\Admin\My Documents\output.JPG
Missing pics coming,
output light,
Finished microphone to fm synthesizer adapter amplifier for voice input to Superliminal Heterodyning Integration Transmitter.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-12-18, 20:54:39
