Hi Gyula, remember, the coils on the drawing are shown in series, but they presently are in parallel (bucking). Below is measured with the magnets, the ground wire on the top and tube/output coil present, no caps: The DC resistance of the pancake coils measured between points A and B is 0.4 Ohm. The inductance of the pancake coils measured between points A and B is 4.64uH The DC resistance of the tube/output coil is 0.4 Ohm The inductance of the tube/output coil is 10.8uH I do remember the negative resistance oscillator, i will look it up and see i can build one. EDIT: found the link (private thread) here: https://www.overunityresearch.com/index.php?topic=3910.msg81273#msg81273 in there there is this link to a negative resistance webpage: http://www.zen22142.zen.co.uk/Theory/neg_resistance/negres.htmI also will try out lowering the 10nF and/or adding a "few uH variable coil". As i understand it from verpies/Smudge, the goal now is not to get the pancake coils radiate, but only to have the H-fields penetrate the water inside the tube to get the protons resonate which then is being picked up by the tube/output coil. Thanks, itsu
« Last Edit: 2021-01-28, 11:57:53 by Itsu »
