2026-08-15, 01:56:33
Pages: 1 2 3 4 5 [6] 7 8
Author Topic: Quantum Field Fabric  (Read 39610 times)
I also make mistakes. So a regular auto transformer will do. The 10.2844 voltage ratio still stands? Could one triac be enough or are two necessary?
My original experiment only had the one lamp dimmer, as Sweet showed only one in the photos of his magnet programmer setup.
I just made this little coil.
Can anyone feel the energy off the tip on the center conductor?
Can you identify the form of that energy?
One turn to 10.28 turns is the ratio I used in the 100 watt experiment.
This was the first experiment that led to the TPU system, only now I have added the ratio for a vibration resonance between the two fields.
It's electrical properties show amplification of fast transition wave forms.
Dave L
Flexibility in Coupling Methods
Wrapping my head around all the variables took a bit of time and experiments.
Voltage - Frequency - Geometry - Distances
These can all be used in various ways, and by including mediator fields applied externally the possibilities of energy flow are very high in number.
When all is reduced to vibration frequency, and the basics of how vibration flows against the electron flow, there are many builds that can hit on over unity systems.
Examples:
Coil diameter can be matched to couple to a source field, earth grid node, gravity resonance, Planck fractal, 333000 Hz fractal, etc.
A random sized coil, can be coupled to any one of these as well, using a sum through a mediator field, applied using a scalar coil.
The convergent energy will then increase the area of the A fields tension with respect to voltage on each loop of the wire.
A ratio like the E/P, can be used between turns count, or applied frequencies from F gens, or even voltages in a capacitor to ground.
We only need to determine what kind of field we are using, and how it must be calculated then manipulated.
Source Field => Nuclear Isotope => Electron shell [E/P gap] For one example.
333000 Hz fractal => phi ratio => nuclear tension => pi/2 => directly into E/P gap.  Voltage charge from the Field Fabric of Earth.
Instant charge on a capacitor with no electrical current. EM Discharge is then normal with a time constant.
Many of these can be perfected if they are developed.
Once one has a feel for the Source of this energy form [mass vibration], can measure it, and then can inject it as a convergent field bubble, all kinds of energy is available.
Dave L
Dave L
In Reply 134 I made a small coil that sets up an E/P resonance. Flip that coil over and slowly stick a finger down into the center area, and note there is an intense energy of vibration inside, what they used to call the "A field", the area inside each wire loop.
In this case I am using a turns ratio to activate that energy but the finger will tell you immediately it only exists inside the wire loops as you can feel the edge of this field as you pull your finger back out.
If we clip an Ammeter probe around a wire with current, it does not matter where the wire passes through the inside of the loop, the amp meter will read the same no matter if it passes near one side of the hole or in the center of the hole, there is no loss across that hole.
If we run an iron wire through a large diameter coil, it is the same, it does not matter where inside it passes through, the energy is the same near the wire loops or at the center. You can show this using two paper clips on a large diameter coil.
As we wrap a copper wire into a loop, when the ends come within about 1/8 inch or less, the "A field" comes up inside the wire loop, and this is a coherent Isotope mass vibration energy, it is a nuclear force. It is self powered from the copper Isotopes.
By inducing other frequencies into this loop it may become easier to feel this mass vibration energy.
A normal coil with a finger inside, can be scanned with an F Gen to prove this, but a Scalar Cancelling coil will isolate only the mass vibration to a higher level by adding the inwards pressing tension on the field.
In the old days coil diameter was an important part of designs. This was dropped with the measurements of inductance and capacitance, where it was discovered the EM field can be resonated alone without involving the Mass vibration frequency, if all the energy comes from the EM side.
Thus the total disconnect between the self powering part and the EM side.
The original equations did include the A field, the linear force that will not move a meter but can be felt with a finger.
By altering the tension on this nuclear field, we can add energy to the EM entropic side, in theory, by factors of 4x as the area is a 2 dimensional form of energy.
In a capacitor, the voltage tension sets in the gap between the plates, as the voltages spin on each plate in opposite directions. We can increase and manipulate that tension as well using tempic field energy of specific frequency between the plates.
There are various ways to accomplish this increase of the tension from sources of energy that are constantly present all around us all the time.
In a capacitor it is usually an Aluminum plate, and understanding the nuclear level of the Aluminum Atom will open the mental doors.
When we start to play with mass vibration fields, we are tapping into a source of energy that was forgotten.
However this was most likely the first one discovered in playing with copper wire.
This is because a person can feel them directly with the body.
Slim Spurling developed a whole system of wound coil forms based on this "Tensor energy."
Dave L
The Oregon Vortex
https://www.roadsideamerica.com/story/2659
I visited this place many years ago and was amazed that gravity is not a constant everywhere on this world.
Unfortunately it is a tourist attraction presented as a mystical experience. North of Medford and near Grants Pass.
Light Distortions
Photo of relative Height Changes
I did this with my wife at the time, and it is not only real, when we changed spots our relative visual heights changed considerably. I looked straight at her face in one position and in the other I looked down at her face.
Also as you walk towards the area that makes you look smaller you are pulled towards it, and walking away from that spot is harder to pull away from it.
We tend to perceive our reality as linear, based on the path of light, and we judge light to always travel in a straight line. However gravity can bend the path of light, and the closer you are to a higher gravitational pull the more the bend. However we cannot see the bend, we see only the light as if it were traveling straight, thus there can be confusion from the eyes, and the head that do not match anymore. A sensation felt inside the body, they are deeming a mystery, a mystical experience.
In the photo above we see the two girls and note their relative heights change as they switch positions.
However being there and doing this, one gets the full experience of a gravitational distortion, but it is a complete spherical effect with a corona around the entire location where the effect stops abruptly. An outer boundary that is well defined.
Now the most impressive thing I witnessed, I will always remember, inside that tilted over building, they had two free hanging weight on ropes attached to the ceiling maybe 10 feet apart, and from just outside the door they were not both free hanging in parallel alignment, there was about a 15 degree difference sighting down them. To me positive prove of a gravitational distortion.
For me with a scientific curiosity, I wanted to understand the effects there, rather then keep this a mystery, and many years later I duplicated that effect in my own garage many times, with many different vibration field bubbles.
The connection between these vibration field bubbles, gravity, and inertia, appears to be real.
NASA studied this effect there and stated it is merely light being bent, and said no more.
Obviously they did not state that only gravity can bend light, or that walking towards the compression field pulls you towards it, and walking away is harder like climbing out of a hole. These effects were not subtle to me. This is why it is so popular with sensitives, and psi people, the effects are very real.
That experience changed my belief systems, as to gravity and the distortion of light.
When we now consider that bending the light velocity path, and then consider how the atom is structured with fields that are near light velocity, we come to a new understanding of matter and gravity. The matter as well is in fact distorted and changes its dimensions along with the bending of the light.
If we set up a spinning wheel and then place a drag on one side the wheel will be pulled towards the side with the drag on it.
If we set up two wheels spinning opposite directions and place drag on the same side of both, the pull will become more linear.
On the side of the atom that is spinning slower, the atom is then pulled towards the slower moving side. That is the basics of gravity.
The basis of the UTRON device.
In the UTRON saucer design we place the EM coils on the outer side of the craft, and pulse it on the Aluminum cones creating drag outwards and upwards at 45 degrees, rather then the normal inwards of gravity.
When the drag becomes equal to or greater then the gravity field, the craft looses weight and then levitates, but its mass is the same.
Gravity does effect light velocity as a gradient, and this gradient changes with altitude more then we might expect. Across the distance of an atom, there is a gravitational gradient, and c velocity is different on both sides of it. It takes a pretty large planet, and why they deem gravity as a weak force of nature.
While this does not explain fully the source of gravity, it does explain the reason for the effect of gravity on the atoms mass.
What I am trying to say here is that in the photo of the two girls, their bodies do actually change dimensions, as every atom inside the body operate also at near light velocities. I could feel this when walking between the two positions, and spent much time doing that.
Just outside this area is a road, where cars appear to roll up a hill due to the same kind of a distortion. They claim it is a optical illusion, but it is actually a gravitational distortion. If you survey the road, you would have to conclude they are rolling up hill, but also the road seems to look narrower then it should looking towards the end that has heavier gravity.
These sort of places on the earth draw in both Religious and Spiritual people, and many fantasies are created around them, even ghost sighting that may be real experiences into lower 4th density.
Now from this we can extrapolate a few things of physics. As viewing the earth from far away, it may appear to look smaller then it is, as if you are inside a lower gravity craft, this light distortion would be present between the two points in the same way. If however you increase your internal gravity, this could be corrected or even reversed.
The man stepped through the saucer hull into the craft and observed the inside was much larger then it looked from the outside. An experience that was recorded by a few men who actually did this. Anyway the Oregon Vortex is only one of many I have discovered, and Sedona Arizona also has several of these.
Dave L
Reality Distortions and the effect on our consciousness
Not that these experiences for me came before the work with vibration, but to infer what kind of distortions we can run into when creating these field bubbles. They can change the physics inside the field bubble and change the speed of our thought and memory process.
Sedona Az has one called Bell Rock. As we approach it, our mind starts to accelerate, and the field warp is expansive.
One can set there all day on a rock until the sun goes down and just feel so close to God, and not a care in the world.
The Mystics love this, but the effects are very real. While they are working mostly on their own emotions, and turbulence on the Astral level, the effect is real.
A few miles away is one called Cathedral rock. This one pulls inwards into our self, and may stimulate recall of past lives. Time seems to move very slow here and we start to see parts of our self we have attempted to become blind to. Every dark emotion will come up, and every trauma event in our life as if to haunt us. We may start to see into the astral realm clearly and see beings around that are normally not visible to us.
These reactions are common, and many people simply get confused, then write them off.
Ones of spiritual progression flock to these vortexes, some move there to live. You can over time reach total accurate memory recall of your entire life's time track. It becomes impossible to bury any memory as the coherent field on the head connects all of it into one field that is in sync everywhere.
These are similar effects we can have with strong field bubbles that we create. Inflow - Cathedral Rock, Outflow - Bell Rock.
The mind will attempt to correct the optical distortions, and some will get a headache whom have no ability to relax into the distortions and accept they are real.
After design and use of the Rainmaker 1, I was very happy to be able to experience all these effects at home without making the 1000 mile plus trips to Oregon or Sedona. However during walks through Totem Park, I began to feel vortexes in that area, right where I live. I would move off the trail and began to map them, then to find out other sensitives would show up in these hidden spots also to meditate. They would say "Dave you are waking up!"
I took my wife in, and we found spots where we had the same distortions of relative height by reversing positions.
I then began some EM testing around the area of the park to discover that the EM background field was lower then expected.
This energy seems to eat EM for lunch. Later I confirmed this effect is also common with Joe Cells in cars.
Actually the higher tension on the nuclear center causes the electron shells to stabilize more. It causes the atoms to hold the electron shells more tightly confined in the test gear, and so we see this reduction of noise from the background RF field.
This park through history had been respected as a place with calming effects, and no wonder I can measure a difference in the RF background noise field!
Also near the river, we found and played in crop circles, made in the heavy tall grass.
Lots of strange energy effects and the grass patterns seem to amplify it in the summer. Some will swirl flat in large circles with a boundary all around where it stands perfectly vertical.
Growing up I had no idea we had all these effects right where I live!
Measuring the tension of a field on a Joe Cell, is actually the reverse of measuring the background RF noise. Where the noise level will dip, the vibration field will peak.
In the movies they show the meters peaking when they run into a ghost. I do not think that is accurate, but it is sensational for the movie.
The area should go cold, and the EM meters should dip and go quiet, below the background noise floor.
An op amp could be set up to reverse this, so the meter puts out an indication of the RF noise floor dropping.
However if it runs on a battery, that battery will likely go dead in short order also.
A strong vibration field bubble that is coherent may tend to short out and stabilize the different points of charge inside it.
In the atom it will separate the negative and positive charges into different layers that are kept separated.
So my point here is to show the effects fit the mental model of the atom perfectly, the same responses we expect to see down there inside each atom, confirms what we see at our level of field bubbles also. Electron and Proton spinning in opposite directions but never discharging, the only thing present we can tap into without depleting the atom, is the vibration field that moves between them. The Strong force.
To reverse gravity for thrust, we have to setup an inflow field in the direction we wish to be pulled towards.
Just an in the vortexes where our linear height is changed with respect to what is around us.
The field bubbles center has to be to one side of the center of the craft, to create the thrust.
The ship will then begin to look smaller towards the attraction, and larger looking back where you were.
It would then feel as if you were falling rather then accelerating. Best Guess.
I have experienced most all these effects first hand, both in nature, and with devices.
This is the part EM people have no experience or belief with in general.
Nuclear Energy!
Dave L
Pi bend in reality
As we set on earth and consider the gravity gradient, as we move outwards 1 inch, we expand the circumference of entire field by pi times the change of the diameter.
That is the diameter of this circle times pi is the circumference, and yet we see this length as not being curved at all. Flat earthers are not so far off, with some of their observations as the curve of the gravitational field to bend light is real, and the closer to the ground we get the stronger this bend.
We take some flat earth measurements at water level and they do not add up, but we do it on a mountain between mountain peaks and they do add up to show more of a curve. The light bends less the higher we go, looking parallel to the surface.
The aircraft, flies level, and does not run off the earth as it curves down under them, as the gravity gradient does not change along that curve, and reality and our linear dimensions are determined by that curve, not by what is actually a straight line.
If however we move away from the Joe Cell or the earth we start to see the curve as now we are no longer inside the bend of the field.
Flat earthers have to reject all notions of gravities effects to bend our reality!
As we already realized that when you bend the path of light you also distort all the atoms in the body and in any other mass like the plane flying over the earth. We are also being bent but cannot see it from inside the field.
Dave L
Power Draw
120 Hz with harmonics off the clipped DC 1/2 sine waves, that is correct. In what I call "slop tuning," a square wave can produce a stack of frequencies going up very high, it creates a sharp rise time. As we change where the phase cuts in in the sine wave, with a load on the circuit, it changes these harmonics in frequency.
Others have worked with wave shaping on the rise time of the wave, but also on the way it flips polarity instantly to a negative pulse. That is, we see on the scope a fast rise upwards towards positive voltage, and then instantly the wave is coming up from the bottom of the screen from the negative side. This indicates energy flowing from the Proton side into the outer Electron shell, and it happens very fast on the scope, so fast there is no visible trace connecting the two. It was like seeing magic how a voltage could change polarity so fast, and took some time to realize what was happening.
I do not know for sure exact frequencies from measurements, this is what we are attempting to discover, all I know is it feels like the E/P ratio, very harmonic and spellbinding to the senses. Where in a square wave feels very nasty, so there is this transition to feel good energy as I hit the point where it self powered.
Now as we play with the lamp dimmer setting, it will only produce vibration energy if there is a load on the circuit.
Unscrew the 100 watt bulb, and the field bubble stops working on the EM side. That was the only way I could find to shut it down.
The lamp dimmer causes the load to go into a pulsed vibration on the entire circuit, and this is the energy that feeds backward to the source side.
When the vibration pulse comes into a sync with the Source side at some nice harmonic, it starts to take the load on the EM side and support it.
This indicates energy is then flowing from the Proton nuclear mass level into the E/P electrical energy gap.
The monster blue spherical field bubble then came up, I found myself setting inside of. My wife walked through it and the hair on her arms stood up, so we can deduce it was an electron field bubble orbiting the device. An indication we are emulating an atom at larger fractal dimension.
With a volt meter from ground to a screw driver, I had 60 vdc everywhere inside the field bubble in the air where I was setting, immediately around the unit. So I believe the core of this field probably went positive.
Without the feel felt tuning ability, it would be like being blind to what is being tuned in.
Now with a scalar bismuth coil and F gen, one can experiment with this ability to feel where a mass vibration becomes resonant and peak it exactly at it's most intense level.
All the times I reached self powering came from this ability, and only then could I begin to make formulas.
And since no one has been able to duplicate that 100 watt experiment, I am starting to feel that the sensitivity is a necessary part.
That is, a "conscious awareness" of the vibration energy may have to be present. An unknown right now.
I do know there are no existing formulas from electronics to explain how it can even work.
Sweets output from his scalar coils was cold, indicating a Proton field that is contractive [inflow].
That is the only field that can pull energy inwards from the universe.
Electron shell is radiant outwards and entropic.
Tensor energy, is a stress, and when any component is stressed, the nuclear level responds to pull the atom back inwards. So even a diode that is running near it's upper rating can start to create an expanded Tempic vibration field.
Wilbert Smith was handed a tool to measure the stress level or tension in different areas of the earth. He was told that when we set off the nuke tests, on the opposite of the earth the Tempic field would change for a time, and this is what caused some military jets to fall apart over a particular runway.
The energy shot all the way through the planet from the nuclear release.
A fine plastic fishing line is pulled very tight near its breaking point, against a steel coil or guitar string. As the binding force changes it deflect a needle.
I made one of these one time and observed it for some years. Over time it would change periodically. The needle moved no more the 1/8 inch however.
Binding Force Meter
It indicates if the binding force of the atoms in an area has changed due to a change in the Quantum Field Fabric response to stresses.
Wilbert called the study "Project Magnet," even though he knew it was not a magnetic force but a tempic one.
They had a plane set up to go to these places where the jets had fallen apart and see how long it took for the effect to diminish so the airport could be reopened. His meters worked, and he had recorded some location around the earth with diminished binding force.
Same thing happened with approaching the saucers too close, the jets would fall apart not able to hold the structure when they were under stress.
The main reason that the saucers will now shoot off when our planes start to chase them.
Wilbert stated "They" could not believe we were so stupid to fly our aircraft so close to the saucers, but they would now start to move away as any aircraft approached them.
That is some of the background, in this kind of research and experiment.
Have you ever been around something being pulled so tight it then broke, and you could feel the stress of it?
Or an electronic component that finally blew out. An electrical arc can produce these kind of fields in a spark gap.
Supposedly if you hit the violet range of light, the radiance can be beneficial to health.
They sell violet wands, and the Orgone people use them to charge up cement blocks to become radiant with this kind of energy.
HV is directed through a gas tube, and they sell two different colors. Skin damage will supposedly heal much faster.
Dave L
Hello David, I can't feel any vibration from your little coil. An air coil for E/P ratio could be used. The power supply could have a frequency above 1 khz. When the autotransformer is powered by an alternating current with frequency of 60 Hz,then the output bridge rectifier voltage has a pulse rate of 120 Hz. The second higher harmonic frequency will be 78984.27 Hz on triac. Which frequency is used to calculate the second higher frequency ? Is it 60 or 120 Hz?
Philip, make another coil the same without passing the wire through the center, and then do some electronics testing on the two for comparison.
This was how Stephen Marks started and ended up with a working TPU system.
When Otto slowly trimmed a wire while pulsing it, we found the dimensions that greatly amplified this in the 90 degree relationship.
His was so powerful they exploded into platonic form pieces, and destroyed his equipment in the full  blown build configuration.
Dave L
TPU
Most of these systems used coils at 90 degrees as in NMR work.
So how do we locate the copper wires natural ringing frequency?
Pulse it with a positive square wave one time, or very short duty cycle then on the relaxation time, monitor the sine wave ringing frequency.
Find that frequency. As I recall all the copper wire I tested was right at 5 Mhz. However the wire was not long enough for this to be coming from EM resonance. It is the nuclear mass responding to pull the electron field back into its stable form.
It is a shock vibration, resulting from the use of a sharp square wave pulse with fast rise time.
The E/P alignment in the wire goes to 90 degrees of separation and both fields flare up until they come back into alignment and cancel out again.
It is during the separation of the two fields where we can extract more energy then went in.
When you get the frequency on the wire right, then you can do the trimming to maximize it and you can locate the two lengths of wire loops that Stephen Marks was using in the two different sizes of the devices he built.
This is the length of the two loops of wire that go around inside the center of the coils at 90 degrees to the pulsing system on the donut with a lot more wire used.
However you probably can see that effect from the two little coils, best guess.
The important thing to realize is that this is not an EM resonance as we calculate in electronics class causing the amplification of the energy.
The massless electron shell will snap to 90 degree at microwave GHz frequencies, but the nuclear proton with all the mass of the copper can only turn at MHz frequencies at the atoms level. When it does it will then oscillate back and forth several times becoming a generator of energy until the wave stabilizes again. It is a mass vibration effect.
http://www.resonantfractals.org/Doc/Magnetism/Overunity.htm
Dave L
Field Density
Field Density
To understand a scalar coil with two winds where the current is opposing between them, none of the energy is lost.
On the Density sphere which is a hollow copper sphere, and all points would be shorted together by current electrical definitions, we discover we can generate voltage nodes at 2X voltages of the applied voltage at 90 degrees to the scalar coil.
See the photo with the top hat coil on it. With a scope showing voltage peaks being generated top and bottom of the sphere, while the two scalar winds supposedly cancel. They do not cancel, 2 waves of energy spinning opposite directions around the sphere meet at the top and bottom of the sphere and generate 2x voltage nodes as the two fields cross one another moving in opposite directions of magnetic polarity.
This is what happens in a scalar coil with a wire passing through its center at 90 degrees to the coil, handed us in a big way with the large copper sphere representing the copper atom.
Other photos down the page go on to show these can be manipulated and produce spikes with square wave ringing of the copper.
This was happening at 1.6 mhz on that sphere.
Then near the bottom we see the 5 KHz wave appearing from the 5 MHz oscillations cyceling around the copper sphere and mixing.
That 5 KHz wave is unique to all copper near as I know with these scalar cancelling coils.
In this one we get out an 80 volt peak spike for a 20 volt square wave input on the scalar coil, a 4x jump.
Hope those photos work.
Dave L
Fast Transitions
We see that the fast transition wave instantly jumps to the 90 degree angle of the coil system and spikes upwards to 4x of the input voltage.
That is on a standard cancelling coil system a fast transition will produce 4x voltage nodes outwards at 90 degrees to the coil.
This is a property of the copper atom.
Now on the density sphere we can capture both the Proton energy parallel to the input coil, and the electron spikes on a 90 degree coil running around the sphere, by setting these two output coils up with one reversed in phase, so that the Proton spin and the Electron Spin add rather then subtract. This can only be accessed when they are separated by 90 degrees. Basically the back emf now adds energy to the forwards emf, as a sum as we do the phase reversal.
Geometric power factor correction. A no loss transformer.
By recombining both we get out both the voltage and the current as real power, where in most people soon discover the high voltage spikes have no real power if tapped from the 90 degree coil only.
Many people measure these high voltage spikes and get excited that they can gain energy or power from them, but as we connected them into a load or a capacitor we soon discover they cannot produce fast current rises without the Proton spin present. The power comes from both E and P levels, but the power of motion mostly comes from the Proton level, and it only rotates about 45 degree up on the copper sphere, it never makes it to the top.
This is the real physics of the scalar coil and fast transition pulsing even in a normal coil, they generate HV nodes at 90 degrees on a wire running through the center of the coil, with reversed spin direction of the Proton field.
The two kinds of energy spin in opposing directions, and when they settle to normal alignment they cancel one another.
This is how the TPU gets its self running energy, using very specific wire geometry and frequency control.
Dave L
Measuring the frequency splitting effect
On a density sphere we wind two normal coils on the equator, one input and one output, and then run some frequencies through these and note there is serious high frequency roll off and attenuation but the lower frequencies come right through fine. A square wave ends up rounded off to a sine wave form.
We then add a 90 degree coil running over the top and bottom, and scope this also as we again do a frequency run. We then notice where the high frequencies are ending up. They jump into the 90 degree coil and are not lost.
We then do the series connection with reversing phase between the two output coils and discover out comes the square wave we were sending in.
This is with all normal non cancelling coils.
The point here is that energy in copper medium that experiences a pulsing of the load divides the frequency spectrum, the Electron shells rotate so much faster then the Proton shells, and the two carry different frequency components spinning in opposing directions. Creating the back emf during times of heavy loading transition. They fight and cancel. The atom fights to hold its form and frequency responding to any outside influence but there is a delay time for the two to come back into alignment. During this delay time they are separated and running independent of one another.
Current electronics adds de spiking capacitors to keep components from being destroyed by these instantaneous HV transitions, where a 90 degree coil captures them, and if sent back into the output circuit in correct phase they are again tamed. The energy is then not lost.
You can prove this to yourself using these simple experiments and measuring the results.
This set up will then pass a square wave right though it, with all the frequencies present in the output side, a complex wave form.
You will now have a full comprehension of 90 degree coils, and the two layers of the atom that work to stabilize it.
Dave L
Bidini Recovery System
If we do not capture the spike when it is 90 degrees out of angular phase with the Proton energy, it will come back into alignment with the Proton plane of motion and create a reversed EMF spike on the wire. Bidini captured this using a reversed diode to route it into a storage capacitor as it is being depleted by the forwards current.
This is because the Electron field rolls over the sphere all the way 180 degree to realign with the incident wave.
If this happens during the relaxation time of the incident pulsing circuit there is less attenuation.
The reversed diode is not a very efficient method to recapture this energy as its spin is being attenuated by then.
This technique is now being used in a lot of coil systems to capture extra energy from magnetic devices.
Diode splitting of the forwards and reversed emf pulses from the same circuit with one coil orientation.
DC pulsing with doides on both sides forwards and reversed, and the loss will be the energy drop through the diodes.
It works.
Dave L
Battery use versus instant recovery
As with the reversed diode method, which captured these high frequency pulses as the reverse current in the incident circuit, Bidini used a battery system, where he played with frequencies to charge up a battery while depleting another one to run the motors and pulsing coils.
He eventually discontinued this battery charger, as high frequencies tend to de-sulphate a battery but not lead to deep cycle recharge very well.
At least that is what I believe for the reason from what I read about his work.
Wherein the 90 degree coil system reverses the effect back to a forwards EMF that simply puts the energy back into the correct phase of the circuit while power is being drawn from it. Hendershot used this to make little DC motors that would self run with no battery at all.
I have not been able to find his diagrams recently, with the square 90 degree coil systems that ran those motors.
They were not very large and as I recall had three sections.
Dave L
at PhilipN
Please, would you be kind to avoid polluting this thread with repetitive quotes ?.
thanks
Alvaro
Observation of the waveform, collapses it into a particulate of Photons or Electrons, or in my case Isotopes?
This was a hypothesis of the two slit experiment, and altered my personal perception a great deal. We still do not know if it is true or fantasy. As I am a believer in science usually over mysticism, I am still quite opened on this, but actual experiment is in order for proof, rather then arm chair conjecture.
In experiment, we need to better define what the words observation, and perception are, and what impact they may have on the physics of the universe.
So in my own case, working with the universe and its laws, I believe I have witnessed manifesting of energy and matter, through the use of accurate perception and intense observation.
This brings the mystical belief system into question, if we know how to look for a thing, it can manifest in front of us, and if we make a correct dimensional form for it to occupy, it will fill this form.
So we then have to add the words intention and will to the conscious equation.
This is based on the concept that the entire universe is filled with a system of wave frequencies which can account for all matter and energy that can exist. If we identify the wave frequency, and then convert this to a distance, then look for the wave to collapse into a form of matter or energy, then it will.
I have often questioned myself in this dynamic, as a scientist, and admit, there is no way to prove this to anyone else.
There is a measure of faith involved in even attempting it, and that word creates a new complication, that it could be pretend.
They say if you can still ask the question am I sane, then you probably are.
So how come I find energy present in the 10.28 wind coil, with the wire passing one time through the center, and another person does not?
What is the difference?
When I hold the coil and present it to my wife, who claims she cannot feel this stuff, she does feel it. I had her touch the ends of the two wires one at a time and she again exclaims, "yes I feel that!" Then silently goes back to sleep, pretending it is not real in the next breath.
What she then tells me is Dave you have been doing this meditation stuff for many many years, and I will never be that sensitive.
Attempting to observe what the difference actually is I record what I know, or think I know:
I feel chi from over 20 years of working with it, and in the beginning it was only pretend or imagination, but became real with my first crystal after shooting intense emotions into it. That opened the first door.
I learned how to slide out of body using the RM-1, to show me what the spherical awareness is, and learn to feel it and activate it.
I also then proved the concept of fractal expansion, and was then able to use data from science to bring up fields, that set there in front of me by knowing how the mathematics applies, and understanding the source I am tapping into.
My current belief is that an accurate mental model of how the universe manifests form is necessary to access each level of the process and then experiment with it first hand.
The conscious field bubble, can see to microscopic or macroscopic levels of dimension, and infer comprehensions to the physical ego mind if it learns how to manage these fields around the head, and this to me is a technical process. It always works consistently, and in general it always proves science has been mostly correct.
My personal science is then very different then public belief systems, and yet I do not find many contradiction between them, mine seems to be just including more of the practice of yoga. In yoga it is stated, do not believe anything until you can prove it to yourself from direct experience.
So while they hand us a chart of the charkas, they do not write these in stone, it is up to us to personally experiment with them our self to discover what is real and what is not real about these energy centers in and around the body.
The hardest question to answer "What am I?"
If I loose my arm, am I still me, the receiver of my senses.
The most surprising question "If I loose this physical body, am I still me?"
Where is the receiver of all my senses? Is it even inside my physical body?
These are technical questions. Over a longer life time with more experience, these answers become more clear when you start to reflect on what actually did happen for you over your path in life. The awareness naturally expands to a dimension that no long can fit inside the physical body.
As a science this is not very appealing to have to face head on, that only some people will ever be able to do these things.
I do believe that if a younger person is raised with the knowledge taught them it could work much faster for them.
I do not know if that is true.
Taking inventory on ones who have participated on my sites over the years, many came to a level of sensitivity through some form of trauma, physical or emotional. And then started to seriously ask the right questions, what is this life all about, what am I , and what did I experience during an accident, or a malady? Why? Many have recall of out of body experiences, and altered states of consciousness.
They pick up the calipers and things start to work the first time.
How am I different then all these and why did I stop those discussion groups?
I embraced the sciences and look for the overlap in the spiritual and scientific levels to create one data base of all truth.
I feel that anyone with an opened mind would eventually do this over time and experience, if they were seeking the answers.
You cannot shut out observations of how the physical body responds to physics, anymore then how the meters of EM work and arrive at some absolute universal level of truth.
The discussion groups became overwhelmed with emotional fears, during the covid episode, and many of these people totally went off the deep end into the fantasy realm of conspiracy theories. One after another, and each one contradicting the last one. They lost the ability of logic.
I was spending hours tracing articles back to the Russian propaganda, and showing the intention of many of these was to undermine our trust in our governments.
The distrust was contagious and eventually filtered down to the point where they stopped trusting me. That was the clincher, as I consider myself a sincere person that seeks only accuracy and truth, and have never attempted to deceive in this effort. If I discover a document is in error I correct it and thank who brought it to my attention. I watched the diss information divide the people in the group and polarize them into a level of total distrust. When the blame game starts to run rampant, it's time to flee! The mob mentality rules, and peoples intelligence vanishes.
I believed a group that was more technical would be a better forum to experience for time.
These concepts however, do not seem to fit anywhere at this time, as the methods used are not practical for everyone, or possibly anyone in the scientific realm.
The two slit experiment should at least get people to open their mind a little and begin to question what is awareness, and why does it effect this experiment with how light manifests in two different forms, just by observing it. The coherent wave crashes into particles of Photons when we simply observe the process!
What is my own awareness, and what can it do either inside the body, or outside the body?
Truly I do not now where to go with all this. At each step of learning I am further from what anyone around me can fathom as real.
I have seen a lot of false beliefs die in my lifetime, but my path has taken me too far now.
I am reminded of the experiment long ago, they put a bunch of psi people in a dark room and asked them to look for the light.
It took some time but the light started to manifest in the room, actual visible photons of light.
That is how far I have come individually with the Isotopes, and the atomic mass vibration spheres. Only with the correct data it is instant.
Using the same methods the E/P ratio was embraced as real by other sensitives who tried it and also had it come up instantly.
One Orgonite person loved the identification of the element Niobium that was used in the Utah Monolith and activates Quartz crystals and Quartz sand!
I scanned that remotely to discover the element used in the sheeting.
By using science I was able to come up with ways to instantly bring these energy forms up, and others responded with amazement. Yet they did not ask to read how that was possible. I am relatively certain, they do not have the science vocabular to understand what I recorded.
The ones with the science seem to avoid the psi phenomena. I can fully understand not wanting to open that door. It forces a person to become more aware of observing them self, and to feel things to a greater depth more intensely, including emotions that may not be so nice to feel.
We become a part of the experiments and our reactions must be observed and then altered.
I remember the first time I attempted to get out of my body. I was in my easy chair and meditated for hours to slide up and out the top of my head.
Pushing and asking, and intending, and finally it worked. As I popped up about 6 inches out, my 4th density body appeared to me as the most horrifying face I had ever seen. I was instantly knocked back inside my body, with a great surge of fear, and pondered that experience for a long time. I was too young and not ready, and I had committed to having one more child, so it was delayed by intention of my own higher self.
One must stay inside the ego mind system of the physical to accomplish some things we intend to do, before we are allowed to discover the truth of what we are and start to explore the other levels.
My 4th density body had taken the form of a being with the most powerful and perfect muscular body, with the most horrifying head I had ever seen.
At 4th density time flow rate, which is highly accelerated in time it was a real scare. This is the deception it uses to keep the physical body in its place during the development process of our consciousness as it slowly expands over the years. I first pondered why is there a demon setting right over my head, but now I laugh as I realize it was me all along. LOL!
That 4th density body now works with me, and I have come to know it much better. It can take any form.
I now realize where a lot of the folk lore and belief systems came from. Newbies, that never got any further with it.
The martial arts opened me more then most I suppose. Face every demon and takes it's power away by conquering your own fear.
Dave L
Quantum Field Fabric Crosses a line of Religion and Belief systems of Magic
The personal game of deception.
This creates all sorts of conspiracy theories.
"There are evil rulers from another dimension that are controlling us! Archons."
"There is a devil that seeks to destroy all human life on this world through works of evil intention and deception."
And no matter how many times I scan people to discover they are playing a game of deception between the two levels with the veil in between, they do not believe me. So then one has to accept this is the plan on this world right now, and there really is no quick fix.
In healing work, they say, we cannot heal anyone, we can only point to the path of healing for them and assist if they choose to move that direction.
In general it is emotional work, and free will choice to believe whatever you chose.
However because I trust doctors and science, I get a bad reputation with many in those groups.
Truth is truth no matter where we discover it. Bias is in general an emotional process of polarizing the emotions.
The quantum Field is blind to what we label or deem it emotionally. It responds to everyone, whether they are aware or not.
I discovered that a debunker is going to find what they are searching for, and the mind was made up before the process began.
Set out to disprove the Quantum Field is real, and that is exactly what will be reinforced in your ego mind, even before you ever attempted to find it.
This indicates one is not ready for what that will mean if it is discovered to be real for them.
Joe Cells are then deemed magic, or quackery. No matter we may see a UFO sometime in our life overhead.
4th density is quackery, no matter if we happen to see a ghost, or have a psychic flash.
And the most important ones, atoms do not exist! LOL! Electrons are not real! I have heard all of this from so many people trying to discover their reality from where they are.
What we want to believe matters, as if we get it wrong, and never change that, then we stay where we are, and do not advance as a civilization.
There is nothing beyond the reach of our awareness.
My physics teacher used to joke, the last chapter had been omitted from our textbook, magic.
Then he decided to teach us Einstein's relativity and show how the equations were arrived at!
That was in high school. It totally blew my mind at the time.
He was a nuclear physicist. LOL!
I finally discovered what he meant, the Quantum Field Fabric of Max Planck! Total Magic!
Energy and form from empty space!
Dave L
Hello David, what is the difference in meanings of the words orgon energy, scalar energy, vibration energy ? Orgon energy is a spherical particle of blue glowing faintly under a microscope with a diameter of about 1 micrometer ( Wilhelm Reich). The meaning of the word Orgon has the same meaning as tesla's luminiferous ether, and it is the same phenomenon. The tempic or vibrational field describes the luminiferous ether or is it something else? The vibration frequency of a wire 19.05 meters long is 19.05 Mhz. The luminiferous ether (Orgon) resonance frequency of a wire with a length of 19.05 meters is 4.8 Mhz.
Vocabulary is a problem, compared to experience.
An example:
A politician declares a war, as to maintain his power to justify it.
A tactician plans a war, and from his mental imagery sees a victory.
The warrior however steps inside the war, and experiences it first hand.
Which one has a better knowledge of what war is?
This is the same with Vibration, Chi, Orgone, Life Force, the Quantum Field Fabric, etc.
Viet Nam was not even called a war, that would have needed a vote of congress to declare. They called it a police action, to get around the law, and it killed more Americans then WW2. What stopped that war, was when they started putting up the dead soldiers photographs each week in major magazines, and people started to realize how many real young men were being killed each week! It was horrifying to the people, and the soldiers.
One can never wrap their head around "feel felt" science, without using the body to measure it, to feel it, and to experience it.
Ask 10 people playing with what they call Orgonite, and you will get 10 different answers. These ones do not have a clue how to link it with any known science. Basically, the link is emotional. They will express a device by how it makes them feel. If it opens them to seeing auras, or what is termed "the light." They are experiencing this energy while standing inside it, and seeking to make it stronger with each build, using feel felt means only.
Regardless of what Reich recorded, "Life Force Activity" the meaning of the word today is different, as no one can measure this who calls it that.
Reich's description "When this blue auric field comes up, life takes off getting very energized and busy," and he related it to sexual energy, energy of propagation of the species. A psi ability to see this kind of light, and no one I am aware of has ever confirmed this in the same way as he did with a microscope. What blue light???
I related it to two vibration frequencies with a ratio of pi / 2 , will take on an infinite dance of exchange. Actual self sustaining form of energy, which can be measured and verified, as has been by several experimenters around the world. It can be experienced on concentric Joe Cell tubes and felt to a long distance away.
When this energy form takes off working, for the people who are inside the experiment, they detect it as very real, an experience they will not forget easily.
The skeptical ones of detached science like the Wars politician or tactician, sets there with no way to detect this from afar, and claims it is only emotions being generated by people, and thus it is not real. What they feel does not matter as much as the outcome of the battle.
They have no idea that their very existence relies on this dance of vibration to sustain both sides of a dance that never ends at the atoms level.
The E/P dance. If either side were to kill the other, all matter would disappear. Their pig headed perception they can actually win when killing other humans is insanity. Yet they claim those who can feel the war from the inside, do not deserve a say in this.
Same with the sciences, refusing to step inside the experiment and feel the reality of it, and not just try to fit it inside their ego minds, which it cannot fit. The formulas for electricity came after people realized it was real by touching and feeling it.
From afar you try to quantify all this vocabulary with formula now, and sum it up inside your ego mind, and still have no clue what it means to those working inside it. The Orgone groups, have a totally different vocabulary and meaning for many of the same words we use.
The Eastern Religions believe in a non localized mind, that is, the physical brain like a radio, is a receiver of our consciousness, it is not the source of it. The Western belief system is that inside your head, is everything you can see and feel, and it is inside there creating your consciousness.
Would we start to tear down a radio, searching to find the singers of the music inside there?
Probably 2/3 of the world, believe in reincarnation, and consciousness having a spiritual reality that exists outside the physical body.
In many cultures it is normal to speak openly of psychic experiences. Each one develops a different mental model to make these acceptable to experience personally, except for ours. For the Western cultures it is a taboo.
There is no way to quantify something one cannot detect!
Yet there is truth in both sides of this, and each tends to want to deny the other.
It is where we have both truths, and find how they connect that we make advances.
I cannot teach anyone these things, if they continue to believe all they are is found inside the physical brain, and they do not exist outside the physical body also as mind.
I do not believe in the work of Max Planck because of my faith in science!
I raised up fractals of vibration from his data, and can feel it is real personally!
I hand these to other sensitives and they all agree it is real.
For them however, no more proof is necessary, and why would they waste their time calculating these things, when they can just "tune" them in for themselves. They care not the Source of this energy, they connect with it consciously.
They judge for themselves, what is desired and what is not desired to feel, then they begin to control it through practice.
There is only one universe we have access to, and it is the same universe we all find ourselves inside of.
Vocabulary is an obstacle, for those without direct experience of this universe.
Those with experience make sane choices.
Learning to directly connect with your non local mind is a mental choice.
Until that comes, no amount of mental models will render anything but what the physical body is limited to directly.
Yet nearly everyone has experienced this non local mind!
Using it to accomplish science is a new concept.
But I found science is the only thing it can do and be 100 percent accurate in.
Science and Taboo of psi
A good video.
When you open this ability accurately, you can answer all these questions for yourself, as then you will have the means to truly answer them.
Most of the dabblers today cannot answer them for you anyway, not yet.
I have presented the tools to bridge this wall and start to quantify what the non localized mind can be used for.
If we do not believe that awareness exists at every point in this universe, then it would be hard to move our awareness to another point and retrieve something real.
Interactive Lessons in Vibration Sensing
Dave L
They were particles called bions that can be seen on a microscope.
A Personal Connection with the table of Elements
Once one gets past the sensationalism and the intense emotions of finally opening the door to work outside the physical body, then the work can begin on the science part.
Getting familiar with how it feels to be an atom of various forms, is at first a challenge, and one must understand how this science is derived to finally realize it is very real.
Identification of the Elements
During this opening, one may experience dreams, of being the electron and looking at the proton, or being the proton and looking out at the electron, and realizing there are sensations for both perceptions, which are so addictive, these little conscious bundles never want it to end.
Each one is also curious of the others, and trying to reach a state of comprehension about what they are, and if they can improve themselves, in the process of creation. This exists from the very first level, as it does in us.
The dance of the atom has become universally accepted as the right path in this universe to pursue a system of creation of the physical realm.
This is what you get from connecting with these guys personally.
Life thus seems to begin, with the never ending dance of the electron and proton, and the fact that they never loose interest in this dance.
There are more people today coming to grips with the notion that all stable form in the physical side of this universe, relies on a template design which exists on the lower 4th density, and runs as a pattern program. The 3rd density Field Fabric then carries out these operations.
Any being polarized towards creation over destruction, can have access to these patterns using their own astral or 4th density body.
How in the world could people like Max Planck have otherwise discovered these things?
The physical ego mind must set up an interface for accurate communications with the 4th density conscious aspect, and using IT's language, not serial format as used in our physical world in speech patterns. Speech patterns have unique meaning to a culture, but not to the universe.
The language of the universe is basically frequency defines form.
There are frequencies for spheres, and the atom has a spherical field defining it's mass. We can calculate these spheres from the AW atomic weight, and experience them as larger fractal dimensions, and these work. We measure mass on a scale as weight in our gravity field, we do not measure mass using EM test gear.
The smallest change in mass possible is the mass of one proton.
The smallest change in EM is the charge of one electron.
The smallest change we can measure in light is the wavelength packet generated by the electron jumping between two orbitals on an atom.
Wavelength and frequency, are the means to identify all phenomena in the hierarchy of creation of the physical reality.
This is the language of the lower 4th density realm.
Nearly all sensitives have realized "frequency of vibration" is what they are feeling, and their very consciousness is gaged by what frequency they are tuned into. Tuned into at the physical brain.
Thus we have the experiential term "sliding". And this is not pretend, it is the mechanics of consciousness itself.
Learning to tune in the physical brain to a lower fractal of the 4th density, will transfer the knowing into the physical ego mind system.
However you have to seek answers that it can hand you accurately, using it's language.
The first technical concept to fathom and experience is the platonic form vibration on a sphere, because that is how the entire head can come to one single frequency all the way through all it's mass. And inside a coherent vibration field bubble that is spherical, all that is inside can then communicate fully with everything else. This is how consciousness works to create larger awareness in the physical with more complex operations working simultaneously. The ego mind can then experience multilevel awareness of all operates simultaneously.
The physical mind can then be shown how to slide up and down the frequency bands, and tune into different things.
My wife hands me the new jar of pickles and asked me to open it for her.
I scan the lid tapping a finger at the center and find resonance at the physical head and working through my hands hold that vibration on the lid.
The lid comes opened with a single turn as if I were taping it physically with an impact tool, but at much higher frequency then anyone could move their hand. It works every time.
We have to train the mind to respond to these commands to slide using intention, and first experiencing what this energy form of mass vibration is, and remember it does not move an EM meter, and it does not shoot out sparks of high voltage. To us the mass of an object seems stable and fixed, but it is not. All these atoms are doing a dance, and when we get them all vibrating as one, the physics changes in the physical world.
This has been hidden in the arts of psi and yoga, and chi flows, for a long time, and they are still around because they work.
Under too many names, they are disguised from the sciences, because to use them we have to step inside the experiments with our own consciousness, which is nothing more then a spherical field of vibration that attaches to the physical body and controls it, to act as one body, where every part supports the whole.
How does the babies hand know to keep growing into a hand rather then a foot? The same DNA is found in all it's cells.
Experiments can prove these things, as one time I held a caliper over my head and with intention tuned in a frequency that interfered with my own conscious links and almost knocked myself out of body. As the body started to go limp and I felt the disconnect, I quickly stopped the experiment and it took a little time to recover sync with my body from the astral level where I control it from.
A human can be hit on the head and the shock will knock them unconscious in the physical. A computer that receives a shock will either not miss a beat or will be broken permanently. Our conscious connection is not running on EM, it is running on a vibration connection with our non local mind.
These things become "self evident" when we step inside our experiments and experience them directly, then actually take note and look at how it really works. It is not hard to prove these things, when we are ready to open that door to ask, "what am I?"
Hardware and software all come together in a computer, and one who understand both, can usually find the problem in a failure mode.
The program for manifesting, is vibration frequency with consciousness only to activate it from the 4th density side.
Thus the higher self is also found to have function. Scientific function.
This is the tool and the system to take science further into the study of what mass is, and how to manipulate inertia and gravity.
If I bounce a basket ball in the court, we cannot measure the frequency with a piece of EM test gear, any more then we can feel the oscillation of the H atoms vibrating against the O atoms in water at a vibration frequency of 632 Hz!
Yet we make a SS tube at a resonant length using a prime number multiple of 0.632 mm pour in the water and we can feel the tension in the water rising up to incredible levels. What's more the vibration will self sustain between the tube and the water stressing the water bonds of the H to O atom. If we design a Joe Cell such that every water gap also has a platonic form vibration on it fitting a multiple of this frequency then we have the water bond stretching both vertical and horizontal in 3D and simultaneously pull on both H atoms at 105 degrees of separation, as both need to come off to fracture the water bond. We then pour in some charged water with lots of free electrons and using only 5 volts the water bubbles up instantly gassing out it's component parts separated into gas form.
People who play with Joe Cells, are considered mystics! They can feel this stuff and are told it is important to feel it.
They may have no clue as to the atomic level of what they are doing, but they have clear intention of what they want to achieve, and it works.
Dave L
mm = khz
This formula is the staple of designs that harness the power of the Fields around us.
One of my fellow experiments has been experimenting with the gravity fractal, and adding a lot of EM frequencies over the top of a very complex pile of different vibration devices. He finally got a self sustaining field to come up after application of the pi/2 ratio on the Gravity fractals!
He loves to tell me how it's going, and I love to read it!
He somehow has an abandoned rail road track tied into this menagerie of devices, and is getting some very interesting effects with voltages as well.
Then he discovered that pulsing bismuth at higher frequency with iron at the lower frequency could establish a self sustaining form of field energy that can be photographed using IR and UV lenses on his camera.
He was very pleased that the energy does not stop working when he stops playing with it!
How simple was that? Calculating a pi/2 ratio off a background field operating between the earth and the moon, that will not move an EM meter.
Since the moon is trapped into an orbit around the earth we know the energy form is real, what we had to discover is that it operates as a fractal vibration also and we can harness and use it.
With the measured mm = khz application we can now design such things and have real responses from them.
This guy never makes anything small, and this stack of devices must be as tall as he is.
Derivation of the Gravity fractal was accomplished from real experiments.
It exposed David Wilcock as a man who simply shared what he researches but does not ever experiment with, his data did not work.
Gravity Rods
Dave L
Someone might need a simpler explanation for a spherical transformer. I have a copper hollow sphere. I'll wrap the bifilary entrance winding (turns) around it. On your site, two coils are common on the output. These coils are connected in series but the coils are connected at mutual angles of 90 degrees to each other and at the same time have a mutual angle of 90 degrees relative to the input winding.A signal in the range 1-2 Mhz at a voltage of+-5 V (10V pp) at a current of 0.1 A (the internal resistor of the function generator is usually 50 ohms) is powered to the input coil. On the output will be what voltage and current ? The output load will be 50 ohms.
Dr. Dale writes me today,
I balanced the inputs last night and was down to about 1.5 Volt signal on both.  Amazing results for so little energy input.  A lot of what you say about vibration is along the same lines of Keeley and Dale Pond.  Sympathetic Vibratory Physics. With a lot better understanding of isotopic MRI "hooks", as you call it.  Unlike Pond's stuff, your model construction and results are verifiable and your frequencies work.  For the most part.
Congratulations!  Well Done!
One of the main reasons I like the gravity fractal is that you apparently derived it from astronomical data, and not from waving your caliper around.
Working one on one with a few builders, searching for new phenomena, we have a had a lot of successes like this.
Less energy in more energy out, and the new phenomena of large field bubbles, that can effect the IR and UV spectrums as well.
Dave L
Mit and Bions
A busy little bunch of particles that grab minerals from the body, crystalize them so they can be flushed out. According to MIT.
No mention of sex, or blue auric field, but they do seem to propagate themselves.
As to the smallest appearance of life, Reich found something real that is very small indeed. However with the feel felt senses opened we discover the atom is conscious as well. I now find no cut off point where life changes to non life moving smaller.
That is, for the Quantum Field to manifest anything requires an auric field around it drawing energy from the space around it, to support the energy of vibration that powers it. The basic function of the proton. Inflow of energy. And with the new frequency layers of the atoms, we have the basic physical form of our own conscious field at smaller fractal dimension. Reich did not have a way to measure the vibration frequencies or determine the geometries, and so used a vague term Orgone, to represent this energy at what ever level he found it to be present.
i believe what got Reich into trouble was his claim that it was connected to sexual stimulation, and he had a small cult following of people who were having a lot of sex, and even with under-aged members. That is from memory and I do not know the source, but there was a woman who came forwards and told this story how she had been subjected to this at a young age and hated the guy.
Our connection to life, is much deeper then only sex, it is the pi/2 ratio of vibration, and one will instantly recognize it as life force when experienced.
Consciousness as we know it can only exist after we have a spinning circular form, handing us a clock rate for memory storage to occur.
It is first supported by a platonic form vibration, that is out of sync with the Matrix, so it spins.
The ratio between the two vibrations at 90 degrees is pi/2, the diameter of the circles platonic form vibration and 1/2 the circumference of the spin.
This is a vibration ratio we recognize as life force. [feel felt experience] This is universal to everyone who has tried it in the sensitive area.
So with the basic model of how life manifests into the physical, we do not find a point going inwards where it ends.
It is the opposite, that life springs from the Field Fabric at the first step of creation of anything that can move through the Vibration Matrix of Max Planck.
A Quote from Planck himself.
"All matter originates and exists only by virtue of a force which brings the particle of an atom to vibration and holds this most minute solar system of the atom together. We must assume behind this force the existence of a conscious and intelligent mind. This mind is the matrix of all matter.”
As I now believe life is already present, and then begins to manifest itself using the Field Fabric. Life does not originate from lifeless matter that is stationary, as nothing is stationary.
Dave L
Pages: 1 2 3 4 5 [6] 7 8
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 01:56:33
