2026-08-15, 01:56:32
Pages: 1 2 3 4 5 6 [7] 8
Author Topic: Quantum Field Fabric  (Read 39609 times)
Someone might need a simpler explanation for a spherical transformer. I have a copper hollow sphere. I'll wrap the bifilary entrance winding (turns) around it. On your site, two coils are common on the output. These coils are connected in series but the coils are connected at mutual angles of 90 degrees to each other and at the same time have a mutual angle of 90 degrees relative to the input winding.A signal in the range 1-2 Mhz at a voltage of+-5 V (10V pp) at a current of 0.1 A (the internal resistor of the function generator is usually 50 ohms) is powered to the input coil. On the output will be what voltage and current ? The output load will be 50 ohms.
The goal of the experiment is to prove what happen to a square wave in a transformer, how it gets split, and how you can then put it back together perfectly. You can design the electrons however you want, turns ratios and such do not really matter to the scope traces, as amplitude can be adjusted.
If you want to work with power however turns ratios will begin to matter, as termination to a load must be considered.
Then if you decide to feed the circuit primary with a cancelling coil, to see what happens to the back EMF, and then if you can still recover the power in the other two alignments, this could be documented better for sure. Be sure to make notes on the configuration you are using.
Dave L
The meaning of the words luminiferous ether,Orgon,scalar field can be replaced by the word vibration or tempic field. In that case, a strong vibration field must cause an oranur effect ( Wilhelm Reich ) and orur effect.
Oranur, is excessive inflow energy.
It was discovered that with nuclear explosions, the electrons are sent outwards first with an EMP blast, leaving around the area of the nuke, bundles of free roaming Protons, the Neutrons break down to Protons and Electrons. If the Protons come into contact with other matter they will tear loose electron shells and start to mess up other matter in the area.
One such bundle of Protons would get trapped inside a refrigerator or other metal enclosures with magnetic materials surrounding it all the way around.
Thus we have some nuclear radiations that continue for maybe years, which are destructive.
These are strong inflow fields, and what Reich called Oranur, from radio active metals. He discovered this using radioactive samples in a lab as I recall.
At the time he did not have understanding of the E/P ratio, but he could feel when it was out of balance in matter.
Too many protons not enough electrons, Oranur.
It is pretty rare unless you live next to Chernobyl, or in Japan. I believe a Geiger counter may reveal it but have no experience with that.
luminiferous ether - something sensitives could see, when bringing up higher frequencies from the Field Fabric. I have seen the blue glow around Joe Cells and spherical crystals, and after long martial arts workouts around my own hands. It is like a 2nd or 3rd harmonic above normal light but still stimulates the cones and rods of the eye at a higher harmonic and becomes visible to the eyes. It has an intense glow to it and the mind speeds up when we feel it. Many doing alternate energy experiments with vibration frequencies experience this, as well as the people seeking ascension.
We are very used to seeing the normal range of vision, but where this higher harmonic starts to vibrate up the eyes at higher frequency, we feel this  intensely and see it as a more intense light then normal. The descriptions of the Higher light are many, one of which is the feeling of a higher love with an intelligence present.
It is likely the frequency is always there at some level, but a rare event when our mind speeds up enough to begin to see it where the level has been boosted.
There are many other names to describe this effect, the Kundalini of yoga where we begin to see the intense light.
All the different paths over the many years have different vocabularies for the same effects.
Raising the frequency of the physical body, and with it, it's perception frequency.
When I went down to Oregon to build Joe Cells with Bernie, I took a RainMaker unit with me, and just for fun I set it up in the passenger side floor on the jig we made to hold Joe Cells. I brought my hand down to the crystal ball, and both me and Bernie saw a flash of the Blue light as it jumped from me into the sphere. That was the first time for Bernie to see it. I was simply bringing up a field on the sphere, and in that case it turned out to propagate all through the vehicle, and that is something we later realized with the Joe Cells, the energy travels through the entire car frame when it couples harmonically to it's mass.
That is when we tune a Joe Cell into the cars frame, everyone in the car feels the acceleration of mind along with the acceleration of the mass.
Dave L
How can be improved telepathic communication ?
I have a question as well as a clarification about the E/P on the autotransformer. Could I use mosphet transistor instead of triac? At an AC power frequency of 50 hz, pulses with a frequency of 100 hz will be on the output of the bridge rectifier.The transistor will switch the current with a frequency of 65820,222 hz to a 200 W bulb. What should be the time gaps between these impulses? Could it work? Can I use european autotransformer ?
https://www.tme.eu/cz/details/oiea1/autotransformatory/breve-tufvassons/
All I can speak to are the units I was using. Having 2 times the voltage will probably increase the rise time on your pulsing. Do you not have 240 vac lamp dimmers over there? Tune the rise time at 100 Hz clipping and see if you can feel when you hit the right ratio by feel.
After you experience the SSF effects, then use a scope to cipher the wave shape.
Remember you cannot see the Tempic field vibration on the scope, and it will be determined by the "power" the light draws, as much as the rise time of the voltage being clipped wile under load condition. This produces the feedback vibration that begins to take the load, supporting the incident EM wave.
When higher harmonics come into fractal alignment with the 100 Hz wave, the vibration power will move towards the lower frequency.
However the higher energy comes from the higher frequency being present in the vibration field bubble.
This bubble will get stronger with increased power at the load and can then be palmed at some distance out from the auto transformer as you play with it.
I do not remember the man who built a device, and when he was running the power generators for a town, was able to tune in the HV lines so that the generators output dropped to nothing at one point. The Lines to the town were carrying the load of the town.
He then attempted to go the route of patents and marketing and was shut down.
If you have worked around a large hydro where they have these monster fly wheels spinning, then you have felt the vibration I am speaking of.
You may be able to get a tour, and take some ear plugs. There is no way you will not be able to feel that vibration!
Dave L
It begins with vibration sensitivity, and then moves to spherical field bubbles of vibration around the head.
The progression is natural.
Innteractive Lessons In Vibration Sensing
Almost every path offered speaks of vibration and frequency, and there are many out there.
We had identified probably 5 or 6 different sensations we noted in the early times of opening, as we tend to explain the energy as a particular sensation in the hands or arms, etc... Tickles, Heat, A crawling tension, sparkles of blue light, Relaxation, cold, electricity, a light wind, and pressure, many feelings are reported.
If we get in a field with too strong of this energy, it can cause numbness, as with the Bashar Fractal.
http://www.resonantfractals.org/Doc/PCC/BasharFractal.html
At the bottom of this one I made a heavy copper tube, that was much too intense to be touching with the bare hands for very long.
It is based on the side length of the Bashar Cones. [51.692 cm] A powering vibration. I also noted there that the 100 watt experiment was also that strong as I had insulated myself and touched the hot wire to feel it directly. Consider the vibration was powerful enough to power the light bulb.
Dave L
Apparent Power The "i" and "j" Operators
The i and j operators, are to hide the reality in a mask of pretending the power present cannot not be accessed. Or is "not real."
As the Electron and Proton shells operate and spin or cycle at 1000x or more frequency differential, they are often out of phase in a powering circuit.
Modern Electronics uses a couple of different mathematics systems to represent this, without identification of where it happens in the atom.
This allows them to turn the process into a theoretical math system imparted without understanding of the actual physics, and creating a pretend loss of energy.
The i [imaginary] number system was chosen to represent power that they state is not real, it is calculated as the product of the voltage and current when they move out of phase with one another vectorially. This math system obscures the reality, by using a pretend concept. As I recall the j operator. It is basically vector addition of two vectors at 90 degrees to one another, and if you were awake when you learned that, the vision of coils at 90 degrees may have popped into you mind. Or not, because that is "not real" to them. They are holding you in a 2 dimensional coil system, hoping that you will not be able to wake up and think 3 dimensionally.
As there is no such thing as a negative level of power, only a polarity, or direction of motion, the number system can be easily altered to remove the imaginary functions, and we need to understand quadrature mental thinking in 3 dimensions to cipher this.
They use a math rule, the square root of a negative number, creating confusion and actual distraction, of the fact that both negative charge and positive charge create positive pressure, or attractions and repulsions. The two spin opposite directions yet both are real, not imaginary.
The square root of a negative voltage, and the square root of a positive voltage, are both very real values, neither is imaginary because the two went out of phase! And one disappeared from your scope.
"Apparent power" is the product of both when they are 90 degrees out of phase, and "real power" does not appear until they are both back in phase.
It is what you see only in one plane of motion of a coil that powers a transformer. They pretend what happens at 90 degrees is not real or useful power. This is a lie. 3D geometry visualization corrects this problem.
What this mathematics teaching hides from us, is the reason to use a 90 degree coil system to turn apparent power back into real power instantly, and to turn back emf into forwards emf using phase reversal.
In mathematics, the negative numbers represent debt, or less then nothing at all, which is not something we can actually apply in reality.
This is a theoretical concept, but in nature we do not find "less then nothing" ever present anywhere. We instead find polarity, and both polarities are always very real.
We can thus drop the imaginary part and treat the two as simple vectors. Recognizing that when they start moving into a power situation in all copper medium, they go out of phase 90 degrees under load. Under some conditions, the energy of the positive charge may jump instantly into the negative charge level, as it moves outwards in the copper atoms from nuclear center into electron / proton gap. There is a mathematics for that sort of wave shaping, where tempic field tension instantly converts to electric field tension, with no electric current flowing in the circuit.
Inside to outside energy flow. [This is the geometry missing in electronics teachings, but is later found in physics and NMR technology.]
We were not taught that this is possible. No one is taught that this is possible other then in Fusion or Fission.
I was able to demonstrate to myself it is possible. http://www.resonantfractals.org/Doc/V2EM/V2EM.html
And thinking in 2D is the only way to fool most of the people all of the time.
Then we have the ones of debunking processes, that seem to be locked into this 2D reality when it comes to free energy concepts.
They cannot picture or model in their heads, a circular spin in rotation around a sphere!
Just as with a graph that has two lines crossing at 90 degrees, two coils at 90 degrees in series can hold the energy of any angle appearing between them. It only takes two! Between the two planes of motion will be all the information of the entire wave.
As the phase changes between the two coils, each of them picks up some of the energy, and when they are summed we get it all back no matter the angle of phase shift between them. The 3D model shows this is "self evident." Then when we apply it, it obviously works. The fact that no one today knows why it works, stops them from playing with it.
Is the ability to think in 3D, a new conscious opening for mankind?
Or have the people who take math into the 3D realm, not paid attention to Electronics teachings?
When this comprehension comes in, it opens a door, and you will look back and say, how were we so blind?
There is no such a thing as power that is not real, or imaginary, that whole concept is quackery.
100 years ago people knew this, and today people are still winding coils using trial and error, and tweaks!
Fooled by complex 3D wave forms.
Dave L
Thinking in 3D
While people are busy imagining 4D and 5D theories to explain their tweaks, or imagining there is some magical time thing, it seems most cannot yet think in 3D! Motion in a 3D system with dual paths of spin inside a dual layered atom.
Positive spin moves through the incident coil and in load transition, negative spin separates from it, bounces around to 180 degrees in phase, then generates back emf.
Picture this in your mind with a 3 dimensional set of two spin fields on one sphere.
As an output coil system we then place two coils at 90 degrees on the sphere, and both will then begin to pick up all of the information of the entire spin system. Both spins in 3D.
All copper medium has a coherent Mass spin field, as well as a coherent Electric field at the level of the atoms in it.
That is, the mass spin of all the atoms in copper is already aligning, and when we hit it with an AC changing voltage, the two spins do different dances in two different direction of motion around the sphere.
The sad part is that even electronics engineers, with the latest training do not understand it.
They have degrees that represent the pinnacle of our human knowledge, and they do not have ability to use 3D mental models with two layers operating against one another. Inside every copper atom the negative and positive can never short out or kill one another, they can only change spin alignment.
How do they blatantly hide this from the masses of smart people who take the time and spend the money on higher education?
This one does not even need sensitivity to detect, you can scope all the coils on a sphere and prove it to yourself. There is no imaginary motion, of either layer of the atoms. Positive Proton charge, and Negative electron charge are both real forms of energy, that cancel inside every atom at rest.
However when we move into batteries, we discover they do not cancel perfectly. We can get small voltages from them, by using two elements with different ground state charges. We have a list of many different elements and the inherent charge they will produce at rest compared to one another.
Every metallic element has a galvanic response, listed as a voltage charge.
All the information is already known, one needs to find the right questions to reach comprehension, and break free of the 2D thinking, with entropy the only reality in their mind.
Then one can set out to design a spherical coil system, that will achieve both no loss, and / or, self powering between the two layers of the atoms in all the copper present.
Dave L
Magnetic Field Disconnect
We can set up two long strings of disc magnets, bring them together at the center at 90 degrees, to prove to oneself that the fields at 90 degrees have no attraction from the ends that are now too far separated.
A similar thing happens with the two layers of the copper atom, when the Electron shell hits 90 degree separation from the Proton shell.
The spins between them decouple, and both are set free of the others opposing force in motion.
We can also chart the angular spread of a magnetic pole, and where the neutral part of it begins and the magnetic part ends. This requires vibration sensitivity to chart the conical angles when we wrap a coil on a magnet and vibrate up the poles. A finger can show you where this magnetic field is actually a cone off the poles. This is very close to 45 degrees. Anything out further then about 45 degrees changes in the mix between the two fields.
The Isotope fractals also show us that in a natural atoms conical Isotope fields these ends at 30 degrees out.
This is where the Proton spin has a field reach, and on the density sphere with pulsing we can feel it no higher then about 45 degrees maximum.
Where the Electron shell field jumps to 90 degrees, its 45 degree angular spread rotates around the sphere and at about 45 + 30 = 75 degrees, they fully separate.
During this time of spin separation they both fly free of the others counter spin influence. These surges in energy level are powered from the copper atoms themselves. That is where the free energy appears, and all the circuits designed to capture it hinge around this mental model. Some form of complex wave is applied to the coil, and then reverse traveling energy is captured.
Now with the 3D mental model, you can begin to fathom why this is how it works.
If we capture this energy in the incident coil, it will be 180 degrees out of phase, so mush be captured with a low loss reversed diode.
If we capture this energy at 90 degrees of the incident coil, then reverse the coils phase back into the incident alignment, we get all of it back in phase.
I do not know any better way to explain this, but if you build it, and scope it, you will then understand it.
A copper only transformer.
Floyd Sweet hands us some turns ratios that are interesting to consider also. But that is the next step in the development, first one must grasp the atomic level of the atoms to take this further, as now we can play with the E/P ratio to set up circuit level resonance between the two levels.
This is a straight forwards way to end up calculating things that will produce results consistently.
EM Considerations
Dave L
Physics
Backing up now, to fill in the blanks if possible, we need to understand the physics of what EM is and the difference in polarity of the two particles that create it all. This comes from physics.
The difference between positive charge and negative charge in the atom is the spin direction.
These two spins, attract, but can never disintegrate one another.
CCW spin is the electron with strong magnetic field, but very little mass.
CW spin is the Proton, and with the same electric field, it also has the main mass of the atom.
If you accelerate a ball by throwing it into the air, it will spin with the dominant field, where the mass is located the Proton.
Proton spin is responsible for inertia and gravity that interact with space directly.
Now we cannot really know the direction or the path of each electron on an atom, but what we can know is that the overall bundle of motions results in a magnetic field forming around the entire atom with a polarized North and South end of the spherical bundle. Each electron has spin, but part of its power becomes orbital spin. Electron is a two spin particle in resultant fields forces. It's spin is called a 720 degree path, or two rotations.
Similar is true for the Proton, we know that for each Electron in a stable atom, there is also a paired Proton down inside the nuclear center to balance it also generating a magnetic field that is much weaker, but bonding with it to create the stability of the atom.
If we tilt the Electron and Proton to magnetic 90 degrees and press them together we get a Neutron, and it's field is slightly matching the Electrons.
Neutrons have very tiny negative spin like the Electron does. When a Neutron is removed from the atom it looses it's field coherence and breaks apart into one Electron and one Proton.
So the entire system of all matter is composed of only these two bundles of energy known as Electrons and Protons, separated by a field called the strong force. The strong force creation reduces the weight of the atoms Isotope by the formula E=MC^2, yet Einstein's equation right there inside all the atoms, so hard to argue with.
The structure of atoms is the lowest basis for solid matter that is stable and does not disappear in milliseconds.
An Isotope is a collective field generated by all the Protons and Neutrons in the core of the atom. Isotopes are manipulated in the technology NMR from outside using magnetic and RF fields.
Now moving beyond classical physics.
And from the inside in NVR they are manipulated using vibration fields that resonate or interact with them using specific functions and frequencies.
NVR [Nuclear Vibration Resonance,] a term created by me, when we discovered we can manipulate the Nuclear Isotope of atoms using scalar coils, and vibration tuned devices. The part that is obscure also to modern science is we can also do this using mental techniques known mostly as Chi, or vibration we can channel through our physical brain matter and nervous systems.
The brain matter and the nervous system is materially unique. It is the only matter I am aware of that can be tuned to distances of resonance, without using a scalar coil or cutting a resonant length in an element. The physical brain matter can "slide" in frequency under the direction of the consciousness of the person inhabiting the body. The "Kime" which in English is the focus and the will. It can switch and set up points of resonance at a great many frequencies of vibration.
This science then opens a door to sliding out of the range of the physical awareness, and teaching us, we have another appearance of a physical body in another realm. Vibration is the crossing point between the realms. Consciousness works differently in each one, but Vibration and frequency are ever present in all of them.
Consciousness lives inside this universe and relies on a few things we can observe that must be present for it to operate.
For Consciousness to detect time, or time flow rate, it must have a memory system to differentiate one moment from the next.
Memory storage is thus universal to all life forms, which can learn from the past, or to predict the future based on study of the past.
We do not often think about, what we are, and what we need to exist as we are, but these are necessary to understand to put time into a context of reality. The point is that our perceived time flow rate is not fixed. Our perception in the human form body with the brain matter, will latch onto the loudest vibration it feels and that will be the point in the spectrum where consciousness lands. If we generate a stronger vibration field bubble at a different frequency, our conscious awareness will jump to that frequency and be able to store memories in the sequence of time at a different rate.
When we wake in the morning, if we are observant, we may discover that at times, lots of information will be flowing through our mind before we sync back into the local earth time flow rate of 3rd density.
Moving from the waking state at night, we go through about 8 different levels of the dream realms, and then astral project into the 4th density.
For the first 2 hours or so we go into delta in the physical 4Hz or less, and we go out into the astral plane on 4th density, and have interactions with others on that level. After about 2 hours we then come into the theta ranges, and start to dream. The dreams may be a filter, but often suggest the plans we have made while out of body with others. Thus some of the "planned future" can bleed through accurately, but most is lost in the symbols added at the dream levels. REM sleep is noted as [Rapid Eye Movement] in this phase of the dream levels.
Conscious Vibration Frequency changes in every different layer, and along with it the speed of memory storage.
Vibration frequency is the only thing that separates the layers of consciousness, and the velocity of thoughts and actions.
Fractal octaves, is how we breech the other layers and maintain our local consciousness while experiencing our non local consciousness simultaneously.
If you ever watched a really good organ or piano player, and wondered how they can play such complex music using both hands and both feet all at once doing four different directed flows in real time, that is how it works, to have one foot in two worlds simultaneously. Only now they are operating at different time flow rates. The physical mind can and does tune into several different conscious layers just to be inside the physical body.
We can move the body around, say walking, while we also speak or sing, and at the same time feel sensations, or maybe read a book. Multitasking.
We do not often think of the complexity of this, but adding one more layer is not really so hard to believe is possible. When you are ready, it is natural.
If we live long enough, it just happens.
The structure of the universe,
Conscious field
Tempic field
Electric Field
Magnetic Field
Awareness exists first, and then the rest can be manipulated into forms.
As we slowly work our sciences backwards from the physical that is, into each piece, and level of dimension, we slowly come to understand the universe, as it operates. Consciousness has the ability to hand us all the information, because this is shared with us, as we are a part of the universe, and it also has Consciousness or we could never receive it.
As scientists in study of the universe, we finally come to the point of realizing, consciousness exists inside this universe, and has access to memory systems, even before matter was created inside it. Spin alignments and field forces are extremely organized at the Quantum Level of reality.
To the extent we can learn to operate in the three densities of incarnation simultaneously, we can take our science with us into them, or should I say, we can bring back into the physical brain, a more accurate mental model of how it all works.
This is then a far more complete mental model of the universe.
Getting back accuracy in the information we bring through is the hard part, if one is lost in the personal emotions [Too Young].
How an atom operates is not very interesting to a child in high school when the hormones are flaring up! They will struggle to memorize and then repeat what they are taught, but will have very little "power to reason" about it. They would find more interest in mystery and magic, then in science that will seem too robotic for them.
However when one can focus on a task at all their levels of consciousness, and also interact and feel what they are working with, it all changes a great deal. The vibration science is then a next step to the world many desire to be in. One with antigravity and free energy devices.
It does not end with simply knowing how an atom is put together and how each field force operates, it then takes off on manipulating these directly and feeling what is happening at that level. To be consciously inside the experiment as you are discovering for yourself how it all works. We eliminate the paths that do not work, and then start to record what does work.
If we cannot feel a vibration, then it is not real to us, and we must search other frequency bands to find our limits, then we can start to expand them slowly. As we then finally hit on frequencies that cause our brain to accelerate, or to slow down, the universe itself teaches us all about itself.
The possibilities are far more fantastic, then we could have even dreamed or imagined going in.
The first times I realized I was manipulating inertia and gravity, were high points in my life that no one can take away from me.
Just feeling the body get lighter while the mind takes off with total clarity, an experience I will never forget.
This is the New Science of Wilbert Smith, and it includes awareness at the first step of the foundation.
When we begin to comprehend it, it will shake the world.
Wilbert Smith Index
Dave L
Field Coherence
Field coherence is the magical quality of millions of small particles aligning such that one of their fields gets larger as "one field."
In my time Quantum means one.
We take a piece of iron, nickel, or cobalt, with the small magnetic domains all at random angles, each one is a field with a North and South pole.
Each has only one North and South pole.
We set them inside a coil and hit this coil with 1000 amps, and all the little domains align with that larger field, having only one North and South Pole, and the core is magnetized to become one coherent field. We remove the core and discover it has only one N/S polarity, and any one of its domains may have become only a part of the North, South, or center neutral section of the new larger field bubble. The new field is a quantum field having only one set of qualities of a magnet. [magic stuff]
If we heat the metal we discover at some temperature the domains again all vibrate so much the electron shells disconnect, all the domains go back into random orientation, and the larger magnetic field that was one, crashes back to its component separated parts, and each part now again carries both a N, and S pole within itself independent of the others.
All electronics people understand this process, if they had formal training.
Iron Nickle and Cobalt have unique construction, such that on the electron shells they can become magnetic, and the electron shells are the method they use to form crystalized structure between atoms. Magnetizing then reorients these electron shell bonds into the same alignment.
We can cut up a large magnet, and discover there is attraction only in one geometric orientation between the smaller magnets in alignment with the poles. There is repulsion in the other two dimensions. Cut the magnet through both poles all the way down and the two pieces will repel, cut the magnet through the center or blotch wall and the two pieces will attract.
This is a good revealing of what a coherent field is, and that it is not always defined by the smaller appearance of what it originates from. But what we must also accept is that these magnetic fields operate over distances through space to couple power effects that will create motion. Power is limited to the distance between two magnets and this force falls off as the distance cubed, very fast drop with distance. Magnetic fields are very short range powering effects.
Aluminum and Copper are not magnetic they have diamagnetic qualities. Aluminum also has a weak paramagnetic quality. And lastly they also have electrical conductance qualities. The resistance of Aluminum wire is 2 times the resistance of Copper wire.
The nuclear center of the atom is not bonded into the outer electron shells which bond atoms together.
It floats inside the electron shells and is held centered from its diamagnetic field qualities, which is repelled from both poles of the electron shell orbitals. This area is where the mass of the atom is located, and it is not stationary as we think the atom is in a material.
It moves in a dual cone spin that opposes the spin of the electron shells, gyrating like a top pushing against a resistance.
The angle of the cones can be changed and manipulated, but at rest is naturally a 30 degree angle at the tip or center of mass of the atom.
This field in diamagnetic elements can also become a coherent field at larger dimensions, same as the electrons magnetic field can do.
All the working free energy devices that use conical structure are accessing this same template, and accuracy of frequency is essential to bring up the coherent Isotope field to larger dimensions, and have it begin to self power from the Field Fabric.
We can bring up conical fields that have only vibration energy present and will not have a positive electrical charge on them. They will however distort the gravity and inertial fields of the earth around them, as they are the mass in motion of nearly the entire weight of an object.
The Isotope of every atom taps into the Field Fabric at some frequency or a couple frequencies, and converts these to 4 other frequencies.
This create the strong force which interacts with gravity and inertia, and also a positive electrical charge. Cold Electricity that does not vibrate the electron shells to create heat.
These manipulations rely on calculations of geometry based on what the atom produces, as to vibration frequencies, and dimensions in space.
Aluminum, Bismuth, and Copper, are not magnetic, they are electrical and mass vibrational atoms, in order of electrical conductance, Copper, Aluminum , Bismuth. Bismuth having the highest resistance to electrical currents and copper the lowest resistance.
Bismuth having the highest diamagnetic quality [repulsion to both magnetic poles of a magnet with very little or even no motion present.]
To see repulsion from copper and aluminum, we have to have motion between the magnetic field and the mass of the element.
The faster the motion the stronger the diamagnetic repulsion becomes.
The diamagnetic field can also become a larger coherent field bubble, that is spherical operating, if we locate a correct frequency and fractal to expand it.
So from the mass vibration aspects of these three elements, we can bring up fields of conical form with a positive charge spin, or diamagnetic spherical form.
The nuclear center of these atoms have most of the power in these fields, Electrical, and Diamagnetic Mass [strong force mass vibration].
Magnetic field is very small, and can be influenced from outside to align isotopes.
In general when we alter the electric voltage on copper it effects the tension between E and P layers but does not effect gravity or inertia to a great degree.
However we do know from ESR and NMR science the ratio between the EM frequencies on the E and P layers will be a constant.
What does that mean technically?
The Electron shell will begin to flip over at a specific EM frequency with a resonance, and when it does the Proton field will not.
However when the Proton field begins to flip over and over at tis resonance, the electron shell will not. Thus it is possible to generate either hot electricity or cold electricity depending on if we are only flipping one of the fields at resonance at a time based on applied frequencies.
There are however ways to induce opposing spin of both simultaneously, and combine that spin to add using phase reversal by accessing the ratio.
Two designed elements to resonate each one, in a series circuit simultaneously.
We must rotate one of them to a 90 degree position of the other, and induce the ratio between them that will cause a circuit level field coherent, existing inside the atoms already.
Sine application of one outside magnetic field in one orientation will pull both into the same alignment, this is not the best solution.
Fortunately mass vibration is stronger then EM can become, and with it we can set up mass resonance to manipulate the Isotope level of the atom to move away from the applied magnetic field on the circuit. Some of these vibration fields are so strong, a magnet cannot release them when set up.
Maybe we have all heard about people observing both hot and cold electricity??? Trying to comprehend it, but developing strange explanations that make no sense.
Mental model offered
At rest a copper atom is grinding against itself under a power that is present, creating opposing dual spin between its two main layers at different diameters. As a top that is free spinning will not keep spinning due to friction, the two opposing spins would wind down if they were not receiving constant power from the field fabric.
We can deduce from what is already known in science, atoms are being powered moment to moment in a very methodical way which is constant and continuous. They maintain resonance frequencies, and spring back to these frequencies over and over when acted on by any outside force, that does not dislodge the strong force enough to cause fission or fusion.
Proof is already present in current sciences of NMR and physics.
Is it possible to raise up a field force that will power itself using identical dynamics, or frequencies?
You all need the proof, it will change your belief systems, without having to witness a flying saucer craft.
There are now so many different methods to achieve this, I would not know where to start, but the thing is, one must be able to feel and detect a gravity or inertial altering effect, a field warp in the background quantum field fabric, a distortion of the rectilinear perception due to applied self sustaining vibrations systems, which are the core of what the strong force in the atom is.
If 3rd and 4th density realities had an electrical charge between them we would have constant lightening all the time nearly everywhere.
Thankfully the background field octaves to do not work that way, they work from separation of vibration frequencies into bands that establish the densities of matter.
A ghost may appear in our 3rd density spectrum, but what actually happens is our background EM noise floor will drop, it will not start arcing or generating lightening bolts.
Lifter technology, that uses electrical force to generate lift in one direction is not true anti gravity, it is simply a thrust from using the electron shell manipulations. Electrical pulsing methods however can effect a negative spin metal to detach from gravity, but this is actually a nuclear force it is altering. Some metals, very few, do have a negative spin matching the electron, and when these are accelerated they will interact with gravity as a true gravitational manipulation from the mass of the elements.
Aluminum can produce a thrust away from a changing magnetic field from a coil, but the magnetic field will push in the opposite direction on the coil.
That is not true levitation of a self contained system and requires lots of external energy to be applied from a powering source other then the field fabric.
True anti gravity can only be accomplished through manipulation of frequencies passing through or around the atoms of the mass where gravity is generated from. Electrical power means are not the best solution.
Inertial manipulation
If we align all the Isotopes in a car to a vertical position so that spin turns horizontal in all its mass we can reduce inertia in the plane of spin.
We can cut a length of copper to a fractal of the sum of both copper isotopes, and manage this, as coppers diamagnetic field will reach between all its atoms already and align them in the same orientation. We can then find a point on the car frame to make contact such that the iron atoms will slowly come into spin alignment also with that one small copper pipe.
Unfortunately the engine in the car will be spinning in a vertical alignment and try to opposite this reduction of inertia in its plane of motion.
Why do you think the saucers are first designed as horizontal disc shapes?
However even in the car one will notice the forwards and backwards motions are less resistant to acceleration effects.
As we increase the 89/50 layering of fields on the car, in that method, the car will take off very fast, but it stops wanting to turn.
If the engine were set with a vertical shaft, and did not need wheels, it would begin to work as a saucer works.
If we instead move to a craft shell that is solid and made of a diamagnetic material in layering we could manipulate the spin to any angle we choose, and then accelerate with no inertia in one direction per alignment.
It is then a natural development process involving correct materials, and accurate frequencies of vibration to shift the alignments of the isotopes spin orientation around at will.
Two alignments of two different elements, using two different frequencies, can cause inertial reduction in only one line of motion and total stability in the other two.
This requires 3D thinking, and manipulations of the Nuclear center of the atoms coherent mass spin fields, which are free inside the electrons shell bonds to be oriented in nay way we would choose as larger coherent field bubbles.
The Tick Tacks showed clearly, a motion in one direction with no inertia, and stability in the other directions of motion. That is, when they move fast, it is always in one direction at a time.
Nuclear field coherence is the technique that works to accomplish this.
This should be self evident.
Dave L
Universal layered reality
The persistence of consciousness.
Every layer of our reality system runs on a frequency of perception received consciously.
Human perception does pretty good at 30 hz rates of change. Much faster changes go unnoticed unless we speed up our level of perception.
A cellar spider can vibrate it's legs so fast it becomes invisible to us for the most part.
TV was originally set up for 30 Hz frames and we see smooth motion at that rate of changing images. Europe used 25 Hz and no problem with it becoming jerky.
We process detection of motion with our eyes at very low rates of frequency for motion.
Our ears however can go from tones of around 40 Hz up to 22 kHz if we have good hearing, but a tone shorter then 1/30 of a second may not be noticed much at all. This is because our brain frequency range for being awake is used to about 30 Hz in the US anyway.
In the physical body, what we perceive is a little bit after it actually happens, after the brain can receive enough information, then recognize it over a chunk of time. Thus our perception normally lags the reality that is, and is dilated through time.
A sudden shock with power can cause us to become disoriented and alter our perception of time and events. In the jet, our left engine ate a bird, the shock went through the aircraft and everyone froze to silence. A second bird then was hit, and like magic we all came out of it realizing what had just happened. People started to speak again as if coming out of shock.
Our conscious connection with time flow rate is not fixed.
Touching the hot burner, and kissing the girl, are experienced with very different connection to how fast time is moving to our perception.
If we move down to the atomic levels of atoms perception experience, the frequency bands are very different for this small CU consciousness.
Even for a fly, we see motions that often confuse us and we find it hard to track a small fly as it zigs and zags, it seems to disappear then reappear.
Bashar purposed that the universe can only have motion present at specific intervals which are very fast, when the master consciousness of the entire universe passes through our location of space, and makes the changes, and adjustments.
That this one awareness is a single dot or point that scans the entire universe at very high rete of velocity and frequency, to remap the entire thing.
As beings or objects, we then hold the persistence of vision or sensation, that makes it seem all disconnected. As our perceptions are delayed until after the changes happen long enough for us to perceive them. Thus we operate at a different frequency layer then that one awareness does, and we do not notice what it is doing.
This presents the concept of reality being strobed.
Because we cannot perceive anything where there is no change to store it as a memory, we cannot perceive this higher frequency and all seems to move about smoothly as connected motion.
We actually then have no idea how long we are frozen stationary at each frame of the universes changing reality.
For all we know the universe freezes us for a long time between changes, but we cannot observe or detect the down time when we are immobile.
Since 3rd 4th and 5th densities all have a different rates for updates, as people on earth we all sync consciously into 3rd, and become unaware of 4th and 5th running at much faster rates of change.
When the saucer craft accelerates its mass vibration frequency upwards and crosses into 4th density, we can no longer see it.
In order to accomplish this shift of reality frequency update, we have to make "the one awareness" deal with us at a faster rate by making what it updates take more of its universal time.
This is where humans begin to experience phenomena, they will relate to God, or some higher intelligence as they begin to touch on it. However it is the physics of the layers, and is not magic.
The difference between a religious society of mysticism, and an advanced race, is the understanding of this physics. This is because it operates the same for all beings.
The layers of manifestation of 3rd density reality, are working down from higher frequency realities to constantly create 3rd at lower frame rates.
That is, the human body requires a second body on 4th density to hold it's complete form and position in the universe. This will also hold the information of when and where it appears in each frame of the One Awareness passing through that location in space.
Every civilization that moves into 4th density access, from 3rd, has comprehension of this,a nd will then slowly begin to take responsibility for what manifests on their 3rd density world.
There are many paths to increasing our personal awareness of these other realms or realities stacked on top of this one.
Basically however it requires raising our frequency of perception in one of the possible ways that work.
In the car crash, the person flew through the air, and it seemed to take forever before he landed in the grass.
Strong fear was used in early times to connect with the higher spirits. [Our own 4rt density body.]
Today Strong feeling of Love has been used frequently to experience even the 5th density light beings.
NDEs [near death experiences] have revealed both perceptions, when the person returns with memories recorded.
The ones of ascension may start out with crystals, and feeling other such vibrations that shift the frequency of perception to a faster time flow rate.
They may think they are communicating with God, but first start out communicating with their own higher level selves.
As our frequency of perception reaches up into the center of 4th density spectrum, the 5th density body will come down and meet us there.
People will have angelic experiences of the higher light, which have meaning to them personally, and usually with great levels of emotions involved.
This is natural in the advanced races, but in the primitive races like ours it is used for deception experiences, to increase the emotional level impact.
This is the human deception experience on earth, that hands us emotional meaning.
That we can make scientific devices to expose and even calculate these levels, for direct understanding how they operate, changes our perception of what we are.
How is this done?
We were handed the methods after the first atomic bombs were set off on our world. If directed only from the 3rd density mental frame rate using deception experience, it could be a disaster for our world. We gained ability to destroy at the prime level of structure of our world of matter!
The Aliens showed up in great numbers to intervene and make us become aware more of what we are, that we begin to take responsibility for what we do on that level of creation.
Wilbert Smith was handed the strange coils, that should not do anything in our current technology.
This is because our science did not recognize vibration as a field with high energy, and originating in the Field Fabric of the universe.
Yet the bomb was based on a platonic vibration moving inwards to a central point, with a shock wave, calculated by our science that would release the strong force of the atom and start a chain reaction of destruction of the atoms moving back outwards with 137 times more force then EM.
Wilbert was also given the conscious structure of the universe, and told that awareness was present at every point inside it.
While he never realized what the coils could do at the level of Isotopes, he did realize that some of his people could use them telepathically.
This laid the foundation, for our culture to take the giant leap forwards into the age of power from the Quantum Field Fabric.
They tried!
It is then up to us to advance ourselves, in all honesty, and take inventory of what we are doing, on a world wide level.
Right now there is no Religious person I would want to be in charge, or any political figure either! Both are far too judgmental of the worth of life, and the survival of our species. We might do better with a scientist who is awake to the other levels, and how consciousness is a major factor in how we operate our world. To realize how fragile our existence actually is, based on vibration coupling links to power the matter from moment to moment, and hold it all together.
Raising our frequency is not imagination, but what we do with it can lead to imagination and self created causes.
It should be done as a science with the proper tools of measurement, and generation of correct fields of vibration.
It is the very science of consciousness.
The concept of a strobed universe is proven to be accurate, in the experiments with the Field Fabric frequencies.
From this we derive the method of coupling links of vibration paths between elements of design, jumping from lines to areas to volumes, and all interacting constantly and consistently.
In the most simple one we set up a pi/2 harmony state and then experience it. It creates an infinite set of values moving inwards to very tiny levels of interaction and causes the One to spend more time in our local space doing updates which take it longer.
It also produces a field bubble of energy that is stable, does not grow larger out of control, or smaller as with entropy as the EM level does.
If we set up a class C amplifier, and hit it with a pulse of voltage, the circuit will oscillate for a time and slowly die as the EM energy is naturally harnessed to come back to stability on all the atoms outer layers. Every atom in the copper circuit will attempt to stop it.
If we set up two vibrations on two SS tubes with a pi/2 differential in frequency, they will continue to vibrate forever.
Dave L
What's the difference between a Xendra and an SSF bubble? I think only in the frequency of the mass vibration field.
https://margaritafabian.wordpress.com/2014/02/18/los-xendras-por-sixto-paz-wells-2/
Yes, the introductory work I provided in the Lesson material, is intended to open a person at a much lower intensity level then teleportation experiences. One must walk before they can run. http://www.resonantfractals.org/Doc/1index.html
They mention a portal of 10 meters, and that is definitely way more powerful then anything I would ask of any newbie to even attempt, with higher guidance or not.
I also see a lot of terminology presented there, that could be represented in a more scientific way, with far less faith involved.
Your higher self can present to you in any form you can accept, and much of this may be games of deception, until one has achieved divine alignment of all three levels.
To start out we all need to have practice methods, to open doors, but after one reaches into 5th density, they can then begin to do it all for them self, without these sort of mental models from others.
I managed to do a bilocation one time, and I appeared out on a beach where it was confirmed by another seeing me there, while I was physically inside in my room meditating to accomplish that. Really no big deal, and things like that do become possible as we explore our own personal field.
I did not need to address a confederation out there somewhere to assist me at all. I was merely curious if it was true and possible. It is.
However those sort of mental models can work, as your astral body can do that stuff, and make it seem very real, in a way you can accept it as real.
If you ask the manifestation who it is, you will get the correct answer back instantly. Then it will become obvious whether it is you on 4th or some Alien being from a past life history you had on another world.
When I asked for assistance from any or all beings out there during development of the 3SD, any who could assist, "they" opened a portal right next to my head to the left side, and I was then able to see into their reality in the Lyra system, where I had incarnated thousands of years ago. I also recognized the beings there and was comfortable with them. While it was very exciting to have this portal opened, they did not want me stepping through it at all.
Their goal was to transfer comprehension to our world how to use this technology to communicate remotely with 100 percent accuracy of perception.
They then stated, use this on your world until you have 100 percent accuracy, then you can begin to use it to approach the advanced races.
As I attempted to do more with them at that time, they then cut me off. They did not want communications that were filled with imagination or  deception. We have to get our 4th density awareness up to speed on our own world before we can attempt accurate communication with their culture.
So as I read through the site you provided, I am inclined to believe much of that is not actually an accurate communication, but much may be assumption from older works, with older vocabulary, from our history. If the author is that advanced, and wants to teach beginners to teleport, and have the Alien accomplish it for us, that is a very big jump in technical ability indeed. I have not had any such experiences with any off world Alien myself. They will sometimes assist in reaching a comprehension I am working with on my own, but they never do it for me.
I would then set out to find people who had mastered the teaching to confirm it works. Then test it locally for accuracy.
As far as the resonant fractal work, there have now been probably close to 100 or more that have confirmed it is real and at our level of comprehension it seems to work for every one who is sensitive to vibration who has tried it.
We are still at the level of discovering ourselves, and learning to measure the frequencies we are working at. We are babies compared to a normal day on Lyra.
I did like the one illustration of the figure 8 on the upper breast bone, showing that there is a crossing point between the two major chakras, throat and heart, where the GL is found to open to another reality, the 1st heaven. That is where that frequency is found inside the human body. In Cambodia it is called the central sun. Kosol used to suggest it a lot, and one day I finally found it, and then was eventually able to measure the frequency.
Here is a video I made of the GL several years ago.
https://youtu.be/3igI0WPmNUI
Dave L
David your informations about mass vibration are meaningless, unintelligible and unnecessary to most people. In order to understand your texts, some spiritually - vibratory preparation is required in terms of meditation, softening,changing your diet, ending bad habits e.g. smoking or drinking alcohol, positive thinking.Why don't Arno join this discussion?
On Sensitivity
No, this is not true, as none of that purification of the body is necessary, you can smoke and drink, and get fat, it will not effect the brains vibration resonance abilities, because they are technical. Your brain matter and nervous system work for you whether you do all that stuff or not.
Most of the effort of these spiritual paths are done to increase your personal focus, ability to direct the perception accurately, without distraction.
You can find the same results using a scalar bismuth coil and an F gen while setting comfortably in a chair and playing with the dial of the F gen.
As with learning a mathematics formula, the clear focus of the mind with constant ability to avoid distraction is necessary. You can go get a massage, and discover the relaxation will open you to feeing the body, and that works for everyone. In that state you will find it very easy to feel the scalar coil vibration system.
Set your hand on the hood of a car that has engine running and feel the vibration. Let that energy move into your hand, then up your arm, and feel it.
Do not set up an imaginary wall in your mind, that is a box that will tell you what you can or cannot feel.
Open the boundary of your imaginary limits, open your feel felt senses, and open to a possibility that you will explore for yourself.
All those spiritual practices are to get those mental walls to come down.
When we learned to walk, we did not need a spiritual teacher, or a method, how it works became self evident through trial and error. We then all learned to balance, to walk and finally to run, and at some point even how to ride a bike. This is no different.
To slide out of body is the next level, and discover the astral body is real. Moving into the physical body is not a graduation of all learning in life.
The only difference in this, is while we can feel it, others cannot see it.
The personal advance however is exactly the same, and everyone will do it eventually.
Everyone goes into delta sleep every night, and enters the 4th density realm.
If they do not, then the body starts to loose meaning and purpose, and in depravation of this sleep they eventually die, or go into the dream state while awake and hallucinate.
Most every young child can feel these vibration tools, before they are taught to put up mental walls and believe they are not real.
In any group of adults that are having fun and nice conversation, I can pass the GL tube around and after holding it for a time without thinking about it, they will suddenly exclaim "I can feel it!" It comes in when you stop trying to make it happen because the energy does not come from you, but it is your own energy that blocks you from feeling it. So you do have absolute control of this.
In party levitation it works the same, a group of adults are having fun and feeling good as during a party, they then do the motions with the counts, and boom it works. Most will then come out of that state, and forget or even deny it happened. Few if any will attempt to discover the physics of what happened. And yet it works for everyone who is in the mental state of a feel good party, fat or thin, drinking or not drinking, etc...
This is all about mental awareness of the vibration state of your own body. Keeping the mind present to observe the body when it is feeling good, or bad, etc... Depression makes us feel heavier, and joy makes us feel lighter, and in party levitation we see that it can actually make one lighter.
The current sciences for about 200 years have worked to move us and our experiences outside the experiment.
Placing our body back inside the experiment changes everything. We need both perceptions to understand the reality we find ourselves inside of.
In Japan the sumo health experts for chi energy were very heavyset, even fat. They could find a blocked meridian in a person almost instantly, hit one point on the body and it would assist the body to then begin to heal much faster. While they had shorter lifespans, their lives were very intense and energetic.
When the old group broke up, my old friend Arno, was totally working with the fallout of the vaccine in his country, where they were facing mandates, and people were suffering greatly from the suppression and the lockdowns. He was very busy with the healing work, and not able to focus on the science part very much at all at that time.
Arno is the real thing, with the healing side of the energy, and I was fortunate to have him for a time verify much of the science I was developing.
We found collective agreement that worked on both sides the same, and when it came to fruition, we seemed to then be done with the task we both embraced on for that time.
I then was able to finish the calculation side for the Isotope fields to a point of proof in manifesting them at larger fractal size. Self powering fields of energy, as atoms do it, and based on the same mathematics of atoms from our current sciences.
Many others were also verifying the connection between the science data I handed them, but none others were developing it personally.
Some in that group were so good with the intuition part, I would keep them out of an experiment, in order to cipher the mathematics, before they just made it happen instantly with no science at all involved. The 4th density body can do it all for them, then the connection to the science is lost in the speed of the manifestation.
Many who experience the acceleration of mind, see trying to prove anything to science is a labor they would rather avoid.
Because I met them on their level and honored the emotional part of the work, I was accepted enough to get them to respond to testing the science also. Many proved to me things I would have thought impossible, and in exchange I handed them formulas to amplify it in different ways.
I seem to be alone in my ability to work on either side of this and move between them in attempts to arrive at showing where they both connect.
I can usually hold my own in either group and show where the connections run between them, without experiencing depression. LOL!
On the whole however it is easier to teach a sensitive the science of the fractal resonant fields, then it is to prove it to the scientist who has never been inside one of his own experiments and feels outside completely dethatched from it.
Access of perception
We have the possibility to two different perception experiences as conscious life forms in the physical.
From inside our bodies, we look out to see the 10,000 things around us, that are all separate from us and we can study each of these one at a time, developing a science of material substance, interaction and reaction.
From the spiritual awareness, we see everything as a part of our self, from the outer boundary of the universe we look inwards to discover we can see and feel everything that exists inside this universe, as inside and one with us.
Both perceptions are possible, and both can hand us accurate data, if we ask the right questions.
The martial artist of the inner path, can expand his field sphere to the size of a room, then experience anything and everything inside that room with great accuracy, in position and distance from his body. Even scan one item and record what elements are inside it without even touching it.
The only reason everyone cannot do that is they were never taught how it works and how to do it. The physics part of the CU conscious field that we each one are. That field coherence can be expanded to many different dimensions exactly as a magnetic field can also be expanded or contracted. There is nothing mystical about this once you learn and experience the basics.
One reason I shared the science of the RM-1 device, and you can learn it much faster then I did.
This is technical, and that device offers the proof first hand.
Sliding the Universe
As we then add the understanding that at specific diameters the universe can power that field bubble for you and hold your awareness in the expanded state, things really take off. You can then develop instruments to expand and then take down these larger fields of your own awareness. The tall whites use these kind of tools, and are not normally telepathic without them.
This will all come across as fantasy or magic until one experiences it for them self, but it is very technical in how it operates.
Dave L
« Last Edit: 2022-02-10, 08:17:58 by DaveL »
http://thechurchofufology.blogspot.com/2012/04/galacteus.html?m=1
That is a pretty good site to read their experiences. I always felt when reading these, I was so far away from any possibility of such things I would never get there. It all seems to be destined for some special people, and so easy for them, why did that not just happen for me also? I needed some proof to hold in my hands, to see for myself.
Many of these have had intervention through life from outside, and I could only recall one or two events that did not involve other entities at all.
The main problem there is that after all that reading, we still have no actual data offered to use in the science they are claiming to be channeling.
As there stated goal over these years was to keep the channel to this level opened, rather then to merely obtain information when it was opened, and then let it close and start to use that data.
So there is where I stopped reading all these reports of what they were experiencing, and started to have desire to measure it. Without ability to measure the frequency of the experience when it is happening, there is little ability to share it, or to cipher how it works from our reality side.
All of these peoples experiences has their place, but until we make it real to our own scientific understanding it will never be accepted by our culture.
There are enough of these historical experiences we do not want to ignore the possibility of them being real, and may offer a glimpse into what is possible when we are ready.
However to get there we have to take all the right steps in comprehension first. The same long process we went through to develop electrical power, an invisible phenomena we had at first no comprehension of. Literally thousands of small experiments to prove out each step. Edison finding that tungsten was the right element to make a light bulb, after trying hundreds of other things that burned up very fast after glowing.
Fortunately most of the science part was already there when I started searching for the perfect elements to use in the scalar coil system.
Bismuth and Aluminum popped right out of the NMR charts for me! 100 percent abundance, and very high nuclear spin of the mass.
While there was no one placing these elements into the core of coils that I was aware at the time.
Bismuth is the basis for a whole new technology, and it was found in two different downed saucer craft hulls.
A universal amplifier of the vibration field energy system. After my builds and experience with this, I now have first hand experience of why these metals were used. What's more I can hand people frequencies that do something using them.
Actual data.
Flying saucers can turn on a dime then shoot off accelerating very fast, not a wonder my mind would speed up in these fields also!
Likely if these connections into the higher frequency realms had stayed opened for me, I would have been so consumed with that experience I would never be able to do the mundane experiments to find each step in how it all works in the physics of the 3rd density realm.
My physical mind then became a tool for my 4th density body to bring the technology into a physical mind that could fit it into the current science of our time, which was finally complete enough to achieve this effort.
Discovery that our conscious field in the head is a CU spherical field with multiple layers, and it has a field coherence that can be manipulated! It can be expanded to higher frequencies using devices! We do not have to have a guru to study under for 50 years to see how it works first hand.
I had the mental programming of the science enough to make the connections, and remove the mysticism of effects that can be duplicated accurately and repeatedly. I did not have to work hard to keep the connection opened all the time with constant meditations, I could return there with the flip of a switch to a recorded frequency.
Recognizing that these "spiritual effects" also had a physics that was possible to measure, is really a great leap in science, but is resisted by both the pure scientist, and the pure mystic as an overlap much too hard to bridge for most. One of the main problems is mystical vocabulary, and the use of mathematics and geometry.
Nissam Harriman has realized much of this, but is yet to offer any more advance in the process other then to verify Plancks numbers and make some corrections in them, as well as play with the platonic forms in models that have no specific dimensions of resonance. He has offered one set of dimensions for a tetrahedron quartz crystal, but I have recorded a great many forms and dimensions which work consistently, and can couple between the three different field forces along the tempic field path through a device. He seems to have missed the scalar cancelling coil part, where we can do scans and find points of resonance experimentally also, as well as measure an unknown vibration then trace it out to it's source.
Many people many different paths!
Someone however has to work at the roots, where the technician must have enough information to do something repeatedly and consistently.
Dave L
Finding points by accident in an experiment
In the 925 Hz document exploration, I ran into a frequency where we can contact the dead of our world.
This was not planed at all!
Here I am trimming down an iron wire slowly, measuring its length as I hit different points of resonance, and sudden there is my father appearing to me and telepathically speaking to me, I felt the love and recognition instantly.
209.39 mm = khz
After a time of this I moved on, and continued with the trimming on the grinder to finish the record to the point where resonance was lost.
925 Hz - A Tree
That we could find this effect using technical process, was very amazing for me at the time.
While as that was not the intended goal, I did not move into that sort of application as maybe other psi people would have chosen to do.
It is however hidden in that document.
Another person with correct motivation to follow that path could take it further to develop devices strictly for that purpose.
There are so many branches off this science, one must choose which path to explore.
EM generation is but one of these that is exposed as a very real possibility.
Dave L
Experiences that the Galacteus group has gained can have every person including you David.Try a similar lifestyle for one year.Fractal resonance or mass vibration works without any technical equipment.Perhaps it is related to mercaba.When a person smokes and drinks alcohol so it greatly reduces its mass vibration and then needs technical equipment to work with effects 4. density.The effects of the Galacteus group were obviously influenced by 5. or even higher dimensions (densities) and it is not a technical physical phenomenon.It is necessary to continuously cooperate with the higher self at least from the 5th density on specific things in physical reality and to comply with the conditions for increasing the spiritual vibration of people in the group.It is in accordance with your document bands of human consciousness. Leave behind our logic and simply feel our intuition in everyday life.
Did you read the replies in the article that supports them? Ron
This article is charming, lofty, intriguing and innocent. All terms that describe the impression of this "group of friends" on a first encounter. What the article fails to mention is that this group and their leader display all the classic symptoms of a cult. Key components are seduction, energetic manipulation, oppression, coercion, strict hierarchy and mandatory severance of ties with family and society. Members are not encouraged to think for themselves and ultimately all decisions are made by the leader who proclaims that only through him can they attain salvation. They believe their purpose is to help people, when in fact they are the ones who need help. Members trying to leave this group in an effort to re-insert themselves into society have faced years of psychotherapy, risking severe depression and suicide. I cannot stress strongly enough the danger of befriending this group.
Hello Ronee, than you for your answer. Do you know celestial prophecy ?
Not really but I have had some connections to the other side that can't be ignored, besides my connection to Dave.
Edit: This would be more along my line of belief...
        https://beforeitsnews.com/new-world-order/2022/02/dr-michael-salla-the-global-reset-reptilian-overlords-the-cabal-black-magic-extraterrestrial-wars-over-the-rulership-of-earth-10984.html
Ron
« Last Edit: 2022-02-11, 22:49:17 by ronee »
The Spiritual ascension, and technical progress for mankind.
There are a great many different goals, when we examine the concept of a spiritual reality.
Ascension, leads to exit of the physical, and personally I already know that is called death from our physical perception.
The ascended ones do not return to perform miracles on 3rd, they may again incarnate with no memory at this level.
While we become aware of other realities, our mission changes, and we have to make a choice.
Invest in this world, or give up on it and exit.
Loosing touch with the physical reality is possible, and also imagination may come in to supply false narratives of escape from the present situation.
It is not hard to observe in the followers what their goals are. Are they here to assist others, to do service to mankind, or are they here to condemn it and exit, to escape.
We can only teach a person if we come to where they are first, and then take each step with them, that leads to greater comprehensions.
Emerging them in the bliss of the higher light will kill the logic center of the brain. It is as the greatest orgasm we can have in the physical body, and instills the desire to leave. Orgasm of the entire nervous system and brain matter.
Every step on the cycle of incarnation is designed to create constant desire to move around it to the next part of the cycle.
Once we are back in the light body, and have exited the physical, we are soon faced with the desire to return, and from that level it is very attractive.
To again lower the frequency of our awareness and experience the human conditions of love and longing, of intimacy between only two people.
Again having no memory of all the answers, and the challenge of personal progress and growth.
Eventually the higher goals to advance the culture, and contribute to the species. All life appears to do this, even at the level of bacteria.
I got lost one time in Eckankar, and trying to reach the higher light more often, and finally realized what it was doing to me. The fear of death is lost completely. Then what? I did remember some of my early Christian training, and recalled "God loved the world so much he sent his only son to redeem it." Did I still Love this world enough to do service to it? To use my physical body and mind, in a way to benefit all mankind?
I suppose it was the Love for my children that brought me back to become skeptical again, and start my mind working on all its levels simultaneously.
I decided this creation is worth working with, from the perception of a creator, it is worth investing in. Leaving will come again soon enough, and the next step back into the higher light. I had experienced that already, but was still in the physical body, and had to make peace with being aware of all these levels simultaneously. I know that many people cannot make that transition, to operate in multiple realms simultaneously, they are not ready.
The danger of the cults of enlightenment, that overwhelm people with the higher states of bliss, is that some decide they only then want to go back.
Personally I came here to be here. And to be a part of something greater then myself.
It is true that when some find the higher light, they can no longer tolerate living in this physical as it is today. There will be confusion, and desire to imprint 5th density laws on 3rd density physical, and it cannot work. They will all begin to say the same things, "No one can harm you if you do not grant permission." "Fear is not real, only Love is real." This is not true in the 3rd density reality, we live on a food chain world, even a shark or a bear can turn you into food. A war may start to kill people based on allegiance or beliefs alone. A bomb does not ask permission.
Death here can be instant ascension, and that is why from the 5th density, we may even plan this stuff to experience it, as the acceleration of death is not feared at the level of our higher self.
I believe that if we approach this as a technical process that it actually is, we can cipher the next level where science is being created and held constant. Having the entire picture of the levels and what they actually are. We can in fact begin to cipher gravity, travel to distant location, and begin to master free energy systems.
5th density people will say stupid things "there is no time. time is an illusion". I will then say, in the 5th density is there change or motion or vibration frequency? This leads to the awareness that if there is consciousness, there must be frequency or clock rate, and that time is integral to creating that experience period. Time is merely moving at a different rate for awareness present there.
Thus we can in fact chart these frequencies, and show that even the 5th density of angels does in fact have a physics to it's reality.
I have had the very same experiences as many others, with very different observations of these experiences, using my logic mind at the same time.
In healing I had the Archangel Michael floating before me a few feet off the ground. I felt the radiance on my skin and face, of his presence, and experienced instant answers to my questions telepathically. The communication was so fast, it defies what we might believe is possible, but the answers did come in a time frame that was present, and somehow connected into my physical brain such that they were being accurately received. I completely understood them.
Some people would then bow down to such experience and worship it, I took it further to discover my own light body on that level. And yes on that level we are all equals, and no one can harm us. So what? How does that become useful to mankind? Should we become followers of some cult and let them decide how we use it, or should we use our personal connection while we are here to work at the level of this civilization?
There is responsibility in what we teach others, and to ensure they are not advanced too fast.
By starting with vibrating up crystals, opens this door slowly enough we can manage as each time it opens a little more, and we stay grounded on this world. Science must be balanced with spiritual progress, until they merge into one truth. We should be able to avoid Jonestown syndrome, where one leader controls everyone and decides when it is time for all of them to ascend. If everyone knew what I know, their might be a lot more suicides.
It is not my desire to create a new death cult, or one that blinds people and then steals their money, and this is possible to do.
We must come back down to where they are, and then guide the path, when they ask, at each step, by example, with free will choice always present.
It is possible to prepare people for what they may encounter, but let them assign the value to it personally, and integrate it into their current life.
What I do is simply ask, "ok what is next for me?" And in the unfolding of energy from the Quantum Field Fabric, I then get the next step, and sometimes it is too intense, so I will wait to take it until I am ready. Most of my greatest advances have been where my wife was away on a trip, and I had no problem with local disturbances or distortions I have created, then finally taken back down just before she returned, as if there is a higher power up there assisting me.
In this, one should begin to realize, there is a higher power at work, and it is us.
We should be able to avoid the "mind control cults," continue to use our own discretion and power of reason, towards the greater good of mankind, and achieve sanity.
The animal mentality, is like mob rule gone crazy. It must be managed and controlled from outside. The civilized being is deemed worthy of the knowledge and trusted to use it with wisdom for the greater good of all involved. Without some form of higher spirituality or morality, it can be used to destroy a world. This is a personal choice, and a personal development, no one can do it for anyone else.
When a Person has seen the entire incarnation cycle, and realizes what it is, they can then choose to be where they are at, and begin to use what they know where they are at, and stop trying to accelerate themselves around it faster. LOL!
From the 70's "be here now."
The new age guru tells you that, and then zaps you with the higher light, taking you to the 5th density, and you are lost, definitely not here now anymore. LOL! You shave your head, pick up a drum and go marching through the streets with no possibility of any reasonable retirement in old age.
Any guru like that will quickly get a bad reputation from sane people, and his cult will not endure the test of time.
It is the duty of any spiritual path to simply connect you with your higher power, then release you to do what you have planned as your path.
To remove your ability to function in the physical is a great injustice. While Eckankar teaches this directive they do not follow it, they constantly warn you if you turn away from the Eckmaster you will be judged not worthy to advance for lifetimes to come. Anyone who touches their own higher light will discover this to be a lie.
The Buddha's whole system was all about how to escape this reality, the Western cultures are all about how to improve this reality.
Why is deception allowed? That is a whole other discussion.
Dave L
Could function photosynthesis of plants in total darkness if they were placed in a fractal E/P bubble?
Pages: 1 2 3 4 5 6 [7] 8
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 01:56:32
