2026-08-15, 04:52:59
Author Topic: Perception of the Atom  (Read 5042 times)
As mankind advanced technically, they had the attitude of burning fuels to obtain energy.
We ended up with a comprehension of how to destroy atoms using fission, and possibly fusion.
Both these usually produce some very dangerous side effects, destructive to the atoms in our own bodies.
The Atom was never recognized for what it is, based on what we know of it already. A constant output energy Source, which will self sustain and self recover.
The first method discovered and also resisted, was that of fast pulsing of high voltage. Frequencies the can rotate the electrons magnetic field angular direction much faster then the heavy protons ability to rotate and catch up with it.
In the state of angular magnetic separation both shells spin up free of the restriction of the other, and we can gain energy during this separation time, by extracting it.
This is difficult and if using copper it has been shown to work. The TPU is not well understood, as the frequencies and turns ratios have not been shared openly.
These parameters can be engineered, from smaller experiments using 90 degree coils and specific ratios, to show on scopes and meter how it can work.
If you already know it does work, one can approach it with a positive outlook and cipher it for themself.
If you want someone to hand it to you without comprehension, one may likely miss an important step and fail.
In this however even Stephen Marks could only get about 30 minutes before his copper would overheat.
The main point here is that our perception of what the atom is, is changing, and the result will be a system of free energy operating through existing atoms.
This also however is not the most direct path to free energy, as every atom does this by accessing the Quantum Background field, Wilbert Smiths Field Fabric, which is everywhere.
The next step is to create a full functioning atom at bench level dimensions.
It's energy willl be drawn directly from the Field Fabric.
The common mistake,
Lets pump more energy into the device from outside it!
Lets boost the power supply voltage, and increase the wire size to move more current.
Lets run the frequency up really high.
This approach is totally backwards, once again burning EM energy to suposedly gain a little more from it.
If your power comes from the wall socket, its missing the point.
This is not going to lead to the Source of power of all the Atoms in our world!
To disscover how they do it.
If we start out with a correct perception of the Atom, then gain a comprehension of where it gets its infinite supply of energy to recover itself, and yet not have a runnaway and explode, how it can balance all the forces to regulate its size and frequency perfectly.
The Atom does not have an external regulator, or governor to control it's frequency. It's frequencies are so precise we can identify atoms from spectography.
The Universe already has a background frequency set!
Come to know that, and you have the best Source of free energy.
Then we do not begin at the wall power outlet with our experiments, we start with space and discover the tools to tap into it.
Dave L
Space
Begining with "empty space" and showing one progression of numbers to access it.
The 333000 Hz frequency works.
However the ultimate may be the Plank Length which is proving to be quite strong.
Dave L
Hi so out of interest where do you get the 333khz from ?
As far as I know the magic frequency (as komonly known is 432 or a mulipal of it)
whitch is a base 9 (432/98 = 48) and also (432/6 - 72) the other wierd thing
7+2 = 9 and 4+8 = 12. hence Tesla considered 3 a golden ratio derivative,
to be special and 9 related to a creater.
What are your thoughts on subject.
The first goal is to prove to oneself what the Seed, or Source Frequencies are that we can tap into using direct experiments.
Once we have some of those we can then start to build forms, and these will be straight forwards formulas that result in geometric forms manifesting in the air in our work space.
We can verify them with a hand, feel them vibrate, and map them as to dimensions.
In experiments we have found Bashars 333000 Hz to work for this purpose.
We have also found Max Planks Planck length to work.
Now if one can get to that point of verification that these are real sources of energy we can tap into using mass vibration techniques, then we are ready to take the next step, Isotope Programming, and atomic mass spherical programming.
The data for this comes directly from current science, with one twist, we start with a vibration rather then an EM source. As in NMR the EM is applied externally to do the manipulations, but when we Source the power from the Field Fabric, we can do this directly using only vibration to align or to create the isotopes.
So the flow here [Quantum Field Fabric => Isotope Mass Vibration=> Electric Field => Magnetic Field
Wilbert Smith called it the Tempic Field. That field is the one we shape first, it will then control the others.
The Isotope field is a self sustaning, self correcting geometric form of energy.
When we create one from the Field Fabric, we are at the starting poinit of all matter and form inside this universe.
If done correctly the fortm will not expand and runnaway in an uncontrolled manner, neither will it exhaust itself and stop working.
To answer you then we have choices to play with for our energy Source and more them one fractal of each one can be used.
Some workable choices from the two Source Field Fractal Sets :
Bashar => 333000 Hz,  1H= 170.496 Mhz
Planck Length Fractal Set => 1H = 343.72771951 Mhz
Teslas 3 6 9 has its place in a higher order to manipulations.
In order to take a self sustaining field ssf back down we use 1/9 the frequency that we used to set it up. This creates a harmonic that will totally destroy the form at its source level.
This works for spherical manifestations.
For conical manifestations we use 1/3 the frequency used to start it working.
3 and 9 then are used to fracture operating fields and shut them back off.
There is also a phenomena of exchange using two numbers that add up to 9 separated by one element that is set to be the 9. The 9 element will not vibrate, but the other two will exchange places as they cross. This can be set up on three tubes of a Joe Cell, and it is somewhat magical to see what it does. I did it using 4 9 5, the 4 and 5 switched places routing through the center 9 point invisibly.
Dave L
Can we use quantum background frequencies 2,997 Mhz, 26,973 Mhz, 242.757 Mhz ? This numbers are 9 X multiplied Basic bashar frequency 333 kHz.
Many of these questions can be answered by people out there experimenting with the mass vibration energy and then keeping track. Usually we have a "target goal" to achieve and our higher self, if in alignment with our goal, will lead in the right direction.
Dave L
How do I set up SSF for a quantum source frequency of 333 khz around the bizmut coil ?
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 04:52:59
