2026-08-15, 04:42:51
Pages: 1 2 3 4 [5]
Author Topic: Battelfield  (Read 21894 times)
   Ok, so now Vidura wants to see if he can ionize (burn) metal using high voltage.
   Has that got something to do with free energy, self running, or OU???
   No?
  Is that relevant??? I doubt it.
  We already know that spark gaps will eventually burn the metal, and need to be readjusted.
  I hope that you don't remove more of my posts,  as being not relevant.
   NickZ
Just to clarify, from al you have posted in the main topics most was throwing mud against me and what i am doing, that is the reason I removed it. Maybe the only thing with some sense was the comment about the wire lenghts, but it could not be discussed, as you immediately resumed insulting me. But if you throw mud you will get dirty yourself only.
   Vidura:
   Well, it seams to me that if this thread is about what you have mentioned originally concerning the research and practical applications of the Akula, Ruslan, Daly, antenna type self running devices. Then I don't see you doing so. Sorry.
  I am really interested in this theme, and don't see you getting anywhere with these tests.
   I don't call that throwing mud at you. You do.
   It is what I see, and my opinion of your work, and tests,  so far.
  NickZ
« Last Edit: 2023-01-26, 05:08:01 by NickZ »
Deleted
   Vidura:
  NickZ
Ok, understood. I know your opinion, but I will continue to do what I have decided. If you want to post about your method to find how it works it is ok for me, I will not criticise it. If you are respectful in your posts I will not remove it. Otherwise ,if you are unhappy at all with the actual topics, it might be better to start your own topic to share your experiences.
Regards Vidura.
Regards Vidura.
   Vidura:
    Ok, I understand, and will allow you to continue on, as Itsu has also done. Seeing that you are on a much more advanced mission   than we are on, as just simple experimenters and builders.
   I did try to start my own moderated builders thread, to focus on the Ruslan /Stalker self running devices. That has not been forthcoming, for some unknown reason, beyond my control.
   NickZ
Pages: 1 2 3 4 [5]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 04:42:51
