2026-08-15, 04:36:30
Pages: 1 ... 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29
Author Topic: Akula, Ruslan, Stalker, device discussion and replications.  (Read 195230 times)
   Max:
   What do I mean by interruption circuit. Well that may be hard to explain, however, what has been shown by the controlled Kacher, using the pp signal to "interact" have shown NO interaction, barely lighting any bulbs. None have shown any intereaction at all, at 500 watt loads. Nor can even light that amount of bulbs.
 So if there is no interaction, with additional energy there won't be any chance of self running. You can add all the input that you want, HV, low voltage, there will not be more out than in, because there is no real interaction, with the source of "extra energy", the surrounding ambient energies. I am not suggesting that you or any one believe me. But, that is my direction.
   Anyways, I am still working on all of this, and not ready to show what I mean.  Perhaps I am wrong, please show me how wrong I am.
I am not suggesting that it's the only solution, as you think. It is what I am working on, at the moment, to find out.
Yours above refers;
There can be interruption without interaction. That's where majority are stuck , I tell you now.
Inview of the above, that is where proper synchronization comes to play.
I will give you an example. The Katcher is a generator as well as the Push-pull.
Now, by analogy if you are an Engineer given two AC power generators to synchronize.
What would you look at.
1. you want to sync the voltages
2. You want to sync the frequencies
3. You want to sync the phase angles(phase sequences as for 3phase)
Think simple.
   Max:
   Those are good questions. But, I am not an engineer, nor would expect one to know anything about free energy systems. No money in it...
   You normally don't seam to understand what I am saying.
   In this case, it's not a matter of what you are refering to by synchronization, like heterodyning two frequencies together, but a matter of interruption, of the magnetic flux, at just the right frequencies. Stopping the magnetic flux, not adding to it. There is a difference.
   But, how to  do that at just the right frequencies, is the trick. Simple kachers seam to do it better, so far. But, also need to be tuned, to do so.  That is not as easy as it sounds. But, they do seam to be able to do the interupting, that I mentioned. Which is to interupt the magnetic circuits, by the kachers circuit.Yet, still needing further tuning, as in my case. Which can take longer than most guys will put up with.
  Again, I am in no way trying to convince anybody. Just looking for answers myself, and posting any new updates or results...
« Last Edit: 2023-09-27, 17:00:06 by NickZ »
It is the Tesla that is OU. It is the Tesla that is interrupted.
Like Apecore said " it has to be Engineered"
You must have the concept before this and others devices can be built. Without which, you're like a man winking at a girl in the dark.
It must be Engineered . No copy and paste.
  Max:
  The HV is the interuptor, that's why it's needed, so that it can temporarily stop ( interupt) the magnetic push pull circuit, not add HV to it. What happens if the magnetic circuit stops? It's like pinching the water hose, and quickly letting it go.
 First circuits used the simple Kacher, I am not sure just how this all works, yet. So, I won't bore you with any more details
  Like I mentioned, not trying to convince anybody. Just trying to get somewhere with this. On my own, as there seams to be little interest, or anyone actually building anything, other than Itsu. Which also is not interested in replications.
My interests lie in this logic. But, it's no easy pickings, either.
There are people that seam to not like me, for some reason.
...and then there are those who like you but dislike your research methodology.
  Max:
It is the push pull that interrupt or inhibit or stop or pulse the Tesla signal. The Push-pull is a pattern or form or template for the system environment.
The HV is the interruptor, that's why it's needed, so that it can temporarily stop ( interupt) the magnetic push pull circuit, not add HV to it.
Please draw the magnetic flux in that circuit.
Bad analogy because water has mass and magnetic flux does not.
Anyway there is an old IEEE article by Conrad and Brudny that mentions the influence of HV electric field on the magnetic circuit.  I think they call it creating a "virtual air gap".
1. As an observation i can say your wire length is not enough to get harmonics in standing wave, you need to use multiple of 1/2 wave length. Total length of wire to be considered including connections.
Also you need a phase shift in standing waves which will further amplify effects.
2. When ground is used means you add infinite capacity, means you need to add resistor.
3. Check how small is the inductance and capacitance in your system.
I will post later some details in Arie deGeus about his setup and it will be easier to compare and understand how and why is working.
Hi Classic,
Sorry for my late response.
Let me loint out how I think I have to configure this 2 coil " open" system.
Grenade and TC ( kacher secundairy) both I want to tune on the 2.0Mhz resonance frequency.
In my opinion when wirelength of those two connected coils are together 75 meter and we puks the primairy TC at 2.0Mhz we get a 2.0Mhz wave.
Due to the open ends of these two coils a 1/4 wave appears in each one where the zero node is positioned at the coil connectio  point( both coils have equal wirelength)
No ground is used here.
Is this assumption fals or unrealistic?
The real problem with this system it's the method used which add too many things that need to be fine adjusted, most of the system use sine wave instead of square which reduce absorption of energy from 2x3/8 to 2x1/4. Also everything is simple cascading using mutual inductance, where maximum attention and adjustments are needed for coupling.
You need a great precision and accuracy in build to obtain, amplify and maintain the effects involved in absorption of energy from local environment and any little discrepancy in wire length will amplify losses instead of overcome them.
For example if the gain is in range of 5-10% from first circuit and further amplified in 2-3 circuits. Lets say in first circuit for any little mistake you lose efficiency than amplified what you can get ?
Also you need to know that at high frequency and high voltage or high current copper wire will lose at least 60% of its ohmic resistance which is a great factor for inductance and q factor.
When using a resonator which is your secondary it must amplify, that means you need a different ratio for of multiple fraction of wave length.
When mutual inductance is used for power transmission you need some certain capacitance as can be observed in tide windings you need to carefully adjust capacitance in order to maintain inductance and q factor at desired level otherwise you introduce a lot of losses in the system and great amount of work is carried out.
As a general rule when replicating is to copy the work if you don't understand how and why is working said device. Or if you can understand the phenomena and you can see in your mind device working following the input a along the system, find the relationship between each component and recalculate the whole system for each component you change and double check if is generating same effect in system.
Why is important to calculate Q factor ? Is the most important characteristic of the system. A high Q factor for a coil typically falls within the range of 50 to 1000 or even higher, depending on the specific application. This range indicates that the coil has low energy dissipation and is highly efficient in storing and transferring energy.
You may observe there is a relation between cross section area of conductor, length of it and diameter of the coils and all them depend of the frequency injected in the system.
When designing such a system you need to have in mind a desired output and know about load and its impedance, or how you are going to use the output if different loads are used.
Mainly this type of systems works and produce positive results based on frequency and voltage amplification or F and current, more complicated systems will work with F and V+C
So, regarding your system you have described above based on 2 mhz you need 150 m wire for each, if you halve it you are using 1/8 than you need to adjust everything accordingly.
Using much higher frequency will result in less wire to be used, also a square wave signal or slightly trapezoidal will improve energy extraction.
In order to be able to adjust your system you need to understand what each component is doing and what outcome is in different mode connection. I would recommend to start calculating your Q factor as you know what you used, it would be silly for me to start guessing.
While writing it just stroke me an idea that you may use chatgpt or similar to check step by step your system and once you know try to ask as simple as possible for interaction between two components you are using and always ask to double check as accuracy of such software instruments isn't great and do not account for complex interactions. Check if correct formula is used in your calculus and double check results obtained.
Personally i wouldn’t build anything before a great understanding of the system or principles involved, otherwise i would be stuck almost at every stage.
I would recommend to read the story of king’s army written by giantkiller on this forum and 7redorbs on overunity.com which may describe in a more understandable way what is going on in such setups, and when reading (be aware of long explanations) try to build an image in your mind of the things described.
When speaking about electrons try to visualise a long row of people with their hands up in the air and each one copy the movement of one in front with the same amplitude and orientation, than imagine a guy at the airport with flags in his hands indicate where and how the pilot needs to move the plane, than amply this to the row described, or imagine in AC two rows which interact with each other smashing or avoiding each other upon indications of large amplitude, speed or when two parallel rows are facing opposite directions (bifilar), where a phase shift indicate a certain delay for one of the rows.
Certainly if we attach strings to each one hands might help to reproduce the same movement at high speed in case one would have a different idea :) and i am saying strings not rods because we aim for an harmony not segmented movement where all move in the same time.
After you built this image add a specific medium in which everything is happening, medium which itself have a certain density, viscosity
I hope from all my heart this helps.
Conventionally, inductors are current devices and HV does not affect their impedance unless isolation breakdown occurs.  However high frequency increases their reactance and the skin and proximity effects increase their resistance.
I just want to say something clear in addition to what I already said above.
If someones aim is to gain something with the use of another something which is unknown, the one seeking to gain must acknowledge the existence of unknown something in the first place. If the approach or basis of the method that such a unknown thing do not exist any attempt is futile and nonsensical.
See attached image to understand what is really happening
   Guys:
   Looks like we have lots of untested opinions here today.
   IF these types of devices are ambient harvesters, we do need to show by what process this happens. Or at least to show it doing so, then try to look to explain the cause, later. Science won't give you an answer, here. And many inventions were found by accident. So, if they are not that (harvesters) but something else, that's another story. If it's not running from the ambient, but running on some form of fuel, that is not the same thing. This thread is about fueless, devices. Not needing our fragile grid system, which could be destroyed or hacked at any time.
How can you know anything about the mode of operations before you know anything about just how these devices work. This is all unthread ground. We can't know what we are doing beforehand, impossible.
  The main thing is to get past just sharing opinions only. We have thousand of pages concerning our opinions, but, not a single self runner. Obviously those opinions did not make any difference, up to now. Including my own opinions.
Mine was not untested.
Well, you are this thread's boss but this thread's title doesn't state that it is only about fueless devices .
If you do this, you will arbitrarily exclude a large set of operating principles just because it does not fit your cherished idea about "energy from the nothing".
I think you will find out that the members of this forum do not care whether the device uses some kind of fuel, as long as it is free, safe and lasts a decade.
You restriction is only your own and it is not grounded in logic or reason.
   Verpies:
    Really!  And who would that be?  You proff?
    Can you design and build something, anything,  that can self run? No? Don't even think it's possible...huh.
Looks like you are not here for friendships. But, I am not interested in your opinions of my work, nor of my person, nor in your sermons. Or are you still having technical and personal issues. Unable to do any actual hands on work, yourself.
   Yes, this is my thread about what I have decided to look into. You have a problem with that?
   Start your own thread about non self runners. Needing some thing to burn. This is NOT about that.
   Show how well your methodology works towards a free energy device such as these. But, I know that you won't ever show a working self runner. Your limited conventional knowledge and critiques are of no interest to me.
 So,  don't waste your breath, on me.
« Last Edit: 2023-09-27, 18:39:55 by NickZ »
Nick,
It would help yourself and our overall motivation to see comments as help.
As I think Verpies is right.
Your friend Ape
Yes
...that can self run? No?
No.
Can you ?
If the protagonists from your thread's title are all fakers, like Delamorto wrote here, then I give it less than 1% chance that it is possible,  but that's good enough for me.
Your experimental skills and build quality is mediocre but acceptable, however you forgot to mention your deplorable research methodology, i.e. discarding M.O.s off-hand.
Your person, I never commented about that - only about your words and decisions.
No, I fixed all of my equipment.
Yes, your decision is emotional, biased and myopic.
   Well Verpies, perhaps you can find another thread to hassle. I've about had it with you, and your opinions.
I've given you several warnings about this already, which you continue to ignore. Watch now what happens next...
   I am not concerned about what you want. If you don't like what you hear here,  or prefer to give credence to the ideas about unproven fakes, perhaps you should ask Delamorto for proof,  and post there, instead. You are wasting my time and energy here, and I am done with you. You are no longer welcome on my thread. Got it,  proff???
Further posts will be removed, if you continue here you will be moderated.
Do you perhaps know how to find this article? Can't find it on the net.
Nick,
Your friend Ape.
    Ape,  I don't agree.
    I have never insulted you. Why would I do that, you have been my friend. Remember.
Any way, better to save that argument, as I do not want to hear any more concerning him, here.
I have known him for many years, he has not helped me in any way,  ever. Only negative comments and more and more negative comments. I'm done with him. He is no longer welcome here. I consider him only a pain in the ass now.
Like F6, classic, and some other guys, as well.
« Last Edit: 2023-09-27, 23:25:02 by NickZ »
   Max, no. It is the modulated, or free running not modulated HV pulse,  that turns the kacher on, or keeps it on, at a certain tuned frequency. Once on,  this HV HF pulse interferes with the PP magnetic pulse circuits,  to temporarily stop it, and interupt it. How it does this, I am still learning.
   This stopping of the powerfull magnetic pulse causes an impulse to the surrounding ambient, like a shock wave, and somehow still unknown to me how this causes the input of these surrounding ambient energies to be the further input source for the device. It supposedly causes the device to continue to function without the previous input source, which can then be disconnected.
   The idea here with this, is similar to Tesla's interruptor circuits. Like the guy turning off Tesla's generator, which caused his death from that mistake.
  You asked me, and I answered. May not be what you expected. I am not asking you to believe any of it. This is just how I see it. You can test it for yourself, if interested, and I know that you are interested. And is why I answer you, in my own way.
  Ape:
   Not to worry I will not bother you again. Friend.
I am not interested in Kapanadze, and his secrets.
   And you are not interested in the only guy who has an actual Ruslan replication.
That's fine,
   good luck with that.
« Last Edit: 2023-09-28, 01:55:02 by NickZ »
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 04:36:30
