Water powered 1 cyl riding mower engine has alternators, and electric start starter. You tube 2008 2 videos by S1R9A9M9 . About 7 peak amps current (not average amps,) at about 15 % duty cycle , and requiring about 110v DC to zero ohms resistance spark plug . Water flow slowly into carb, with choke. MUST BE APPLIED THROUGH CARB VACUUM TO WORK. Georgia technicians converted several car engines back in 2005-2008. Spark plug electrolysis, without separate cell. There is also some water vapor creating pressure to push piston , of polarized charge ions separating from each other during piston movement, along with small amount Hydrogen gas. . Timing must be changed ATDC to about -34 degrees. Must be magnetic field applied to plug cable, and electromagnet with current .Web site shut down. I copied tech data so as could review later. Nathren got himself in trouble with other's accidents of reproducing, and won't talk any more. He either used Inverter box with series inductors + diodes, or just hand wound electromagnet with separate hand wound step up pulse transformer for the 110v. Alternators together with one diode for pulsing on+ off DC as about 8 amps dc at idle speed after starting. To start, without alternator on, vibrating relay used to get vibrating contacts for the 12v battery. After the Briggs 18hp engine running, him and son disconnected the car battery, so as self running on the 12 magnets alternators. Flywheel goes around 360 degrees. On time POWER only about 15-34% of the time. Electromagnet called the S1R9A9M9 triple coils assembly. See photos on internet. The shop technicians did not publish report, since the car engines were slightly rough running, and the special commercial relays were no longer available to purchase. I had figured out , they were using the wrong inverter type box. There are 3 types of inverters to change to DC. Square wave, modified square wave, and pure sine wave. The modified one does not deal properly with INDUCTORS , as inside their relay. They should have used the more expensive pure sine wave box inverter. Alliexpress china is cheaper than Ebay/ Amazon.
