Checking out Joel Lagace - Hang on I'M SERIOUS!!
Started by Aking.21, 2025.02.08, 20:53:34
0 Members and 11 Guests are viewing this topic.
chief kolbacict
If we place a parametric inductance between the capacitors.
At the moment of charge transfer from one capacitor to another, it will increase its inductance.
Then we could be charge into second capacitor more than  was into the first. :)
But we need energy for change its parameter. :'(
web000x
Quote from: chief kolbacict on 2025.03.11, 17:52:37
Or if you had opposing variable capacitances, you could shuttle the charge back and forth between the two capacitances, conserving the charge, all while powering a resistive load.  This is what Chris Carson was doing I do believe.
Verpies
chief kolbacict
Quote from: web000x on 2025.03.11, 18:28:37
Or if you had opposing variable capacitances, you could shuttle the charge back and forth between the two capacitances, conserving the charge.
Yes.
But again, energy is needed to move the plates apart.
Aking.21
Has anyone considered what effect resonance has in a CLC circuit?
Verpies
Quote from: Aking.21 on 2025.03.12, 20:30:08
Yes, the CLC energy transfer is already fully resonant, i.e. it happens at the natural LC frequency.
chief kolbacict
If the plates of the capacitor are not moved from each other, but moved, similar to what is done in a variable capacitor of a radio receiver. Thus reducing the capacity. The attractive forces will be applied to the capacitor bearings. And less force will be needed for the shift. Why won't this work ?
Verpies
Because force is not energy.
Force times distance is energy.
Even if the force to slide capacitor plates past each other is smaller for the same capacitance change, the distance of that movement is proportionally larger.
Aking.21
Aking.21
Aking.21
Verpies
Long leads with crocodile clips = LF or DC thinking.
PhysicsProf
Quote from: Aking.21 on 2025.03.15, 08:04:28
Lagace's latest video:  https://www.youtube.com/watch?v=ZBisYxSyXhY
Interesting vid, in 2 parts (see photos /screen shots) .
Which part do you all think is most interesting - part 1 with the fluorescent tube, or
Part 2 with the "Russian " noise generator?
PhysicsProf
Quote from: PhysicsProf on 2025.03.19, 20:56:01
Aking.21
I don't have a preference, I am waiting to see what he comes up with  He's getting his act together so we'll see.
However, I do have doubts about his measuring ability.
But I have no doubt we'll all learn something.
Magluvin
ive been holding my breath on this a bit.. just not sure why there is so much attraction to what joel is showing in those latest vids.
so far all im seeing is a possible deception on his claims.  he would have been better to just talk about it all instead of showing stuff that clearly does not work as he said, as shown in experiments here by some of you all here.
ill admit that it all renewed my interest in what can possibly be done with the cap to cap, but my version seems more applicable.  would need a lenzless transformer.  meg, whatever...will be testing the orbo this weekend.  it is lenzless.  if the input winding is good enough to do a full, or close to full transfer from cap A to cap B, then the output should be of significant interest.
i had said from the beginning when i got here that the transformer joel used wouldnt, shouldnt work as he described, as the currents of the output winding cannot produce anywhere near the current as is input to the 2v winding.  and you found that to be true. 1 to 1 ratio was way better.
this should be very basic understanding.
anyway.... ive lost complete interest in joel and what he claims.  but again, for me it did seed other ideas to go after.
mags
forest
from cap to other cap , yes but the first cap is Earth. what do you think ?
Magluvin
Quote from: forest on 2025.03.22, 17:45:48
hey forest..  good to hear from you.
the way i look at earth gnd is, it is such a large volume that when we take or give from it, the charge made by that, in the earh, neg or pos, that charge is so very little that it creates very little opposition to taking and giving electrons back and forth.  like a small cap, once you charge 1 plate, pos or neg, the opposition to taking on more electrons or removing more, is greater and takes more energy to do so. like a crystal radio, it can take good advantage of the earths abillity to allow electron flow into and out of the radio circuit.  without that earth gnd, the radio is still able to work, but it faces very tiny capacitances within the circuit, again with higher opposition to the ac current flow, thus way less output in order to hear the signal.
ive used a legnth of copper pipe as a gnd for a crystal radio, suspended from the ground and gotten a listenable output.  that pipe had more electrons to move back and forth than just the radio circuit itself.  i did this when i was a kid with a radioshack electronic kit as i wanted the radio to be portable without an earth gnd.
mags
Verpies
Quote from: Magluvin on 2025.03.23, 14:20:59
...earth gnd is, it is such a large volume that when we take or give from it, the charge made by that, in the earh, neg or pos, that charge is so very little that it creates very little opposition to taking and giving electrons back and forth.
Think, is charge preserved in a CRC or CLC energy transfer ?
Magluvin
Quote from: verpies on 2025.03.23, 14:35:48
id need for you to expand on that
mags
Verpies
Quote from: Magluvin on 2025.03.23, 16:13:49
The "preservation" refers to the quantity of charge (expressed in Coulombs) before and after the transfer.
IOW: Is charge conserved in such transfer ?
Magluvin
Quote from: verpies on 2025.03.23, 23:03:22
did you mean conservation of charge?
mags
Verpies
Yes, is charge conserved in such transfer ?
Magluvin
Quote from: verpies on 2025.03.24, 07:12:20
charge into the earth?
mags
