2026-08-15, 02:54:55
Pages: [1] 2 3 4 5 6
Author Topic: I Got a Speedup Effect..  (Read 22143 times)
I am creating a "Paradox" for Lenz drag with this generator build.  Either Lenz Law OR Faraday's Law of Induction must bend.  No permanent magnets.
Here is the result..
https://www.youtube.com/watch?v=1NA_lXULhNk
It's a stock armature and commutator (rewound in a special way) slapped inside a crappy induction motor stator as the output.  There is more happening than shown.  More to investigate..
This video shows the output looped to the motor input.  The output power of 1 output phase + the Lenz assist is enough to sustain the motor..
Now it is not OU at this point, because I am powering the brushes.  Remember this is using no magnets or field coils.  The output coils become the field coils that helps sustain rotation.
dude. very impressed!
my grandfather told me about his dad where he had 2 motors on a board cannected at the shaft with all wires run to a small box with a switch. he said he flipped the switch and gave it a spin by hand and off it went.
thought about that a lot. thought there could be nothing other than an unconventional rewire of one or both motors.  was 1910s or so. so cant think of any other special parts that could make that happen. its part of what keeps me in belief of such things. you have just revived excitement in it again
thanks for showing.
mags  ;)
Hi Mags,
I am willing to answer detailed questions.  As long as replicators and seekers share what they find.  I released the main gain mechanism in a public-domain release.
The idea is to rotate the magnetic field in an armature that is physically rotating in the opposite direction as the field. .  So what is Lenz to do?  If Lenz opposes the magnetic rotation, it inadvertently motors the armature, thus increasing RPM of the rotating field.
Mr.Jim Mac ( aka Floodrod )
Thanks for sharing…
Hoping for the best !!!
Here the link to your forum and topic…
https://www.mooker.com/showthread.php?tid=322
This is the same tech that Thane Heins was working on, very cool.
Not sure how much relation it has to thanes stuff.
I have an update..
I don't need to even loop it.  Lenz alone is enough to sustain the rotation.  The more I input into the armature, the quicker it spins, and the more output I get.  I do not know if the output is enough to keep the armature powered. But it absolutely needs to be made with proper wire gauge and 3 phase output so we can find out!
Here is a vid of the output coils becoming the field coils, and spinning the motor when the motor is totally disconnected.  Remember, there are no field magnets or field coils.  The output coils become the field.
https://www.youtube.com/watch?v=YbDwc_N-tiQ
ok. that last vid...  do you still have input to the armature? or is that disconnected also?
had a situation once...  starter wasnt working on a suburban.  i had previously used the seat heater switch as a sort of kill switch, or say starter enable switch in my bosses daughters vehicle, the suburban.  shop forman said my switch was the problem.
i disagreed. the starter solenoid was being engaged but the starter motor was not. i said it was the contacts in the starters built in solenoid.  but he went ahead and put an outboard ford solenoid, wired it with heavy wire to the starter motor post AND the starter solenoid in parallel to engage the starter to the flywheel..
this did energize the solenoid to engage the flywheel and run the starter motor. but now we had a new problem...
when the engine started and the ford outboard solenoid was no longer sending power to the starter/ starter solenoid, meaning no power from the battery to the starter, the starter gear remained engaged with the flywheel.  wasnt at first apparent what was going on.
what we found was, the ford solenoid(large relay) that sent power to the starter WITH the starter solenoid input still in parallel with the starter motor, when the ford solenoid no longer sent power to the starter, the magnetic field in the starter motor was sustained with no power input, but being the starter motor shaft was still engaged with the flywheel, and the starter acted like a generator and kept the starter solenoid energized, holding the starter shaft gear engaged with the flywheel.  after about 10 to 15 seconds, i suppose the field in the spinning starter deminished and the gear would finally release.
so once the starter was linked to the flywheel which kept the starter spinning, the starter became a generator for a short period after the battery was disconnected, and energized its own solenoid coil keeping the starter gear in place with the flywheel gear.  was the strangest thing.  once the forman realized what i was arguing was fact, he said " i thought i was fixxing a starter but instead made a generator.  we laughed for days on that.  but the fact that the starter motor, while spinning, held some mag field even after the external solenoid deenergized, and was putting out current still, was very interesting.  the starters built in solenoid being kept energized by the starter, was the load, and it was the resistance that let the starters self sustained field die out in like i said, about 10 to 15 sec.
so now you have me thinking on that more.  there were no magnets in the starter. as long as the starters solenoid coil was in parallel with the starter solenoid coil, residual mag flux and current flow kept it going for a bit....
finally i told him to get a new starter....prob solved
mags
I have an update..
Very interesting Jim. Love your builds. It's not clear to me how you're powering the armature but it reminds me of the homopolar type motors that just used the armature. I built one years ago from one of Brad's vids I think. They were DC though. Looking forward to understanding this more.
Reading the starter story, I am not not sure what was happening.
Jimboot-  My armature is custom wound with magnet wire to create a rotating magnetic field when the armature commutator spins against the brushes.  And it's wired so the magnetic field (once spun) rotates counter to the shaft from an outside perspective. So the outside power just powers the brushes just like a universal motor.  Then it just needs a kick from a motor to start up.  The counter rotating field induces the output stator for usable power.  And the magnetic field of the output stator becomes the field coils, as that field is now aligned in the proper orientation to assist rotation rather than oppose it (because the direction of the physical shaft rotation is opposite that of the magnetic field).
To get the armature to counter-rotate it's field compared to the shaft, the armature needs to be wound to create a rotating field in space that rotates quicker than the shaft.  The formula is:  Field RPM Minus Shaft RPM = RPM in Space..  So rotating the shaft one way doubles the frequency.  Spinning the opposite way sets the RPM equal to the shaft but in opposite directions.
It took me a little while to figure out how to wire the armature because AI basically concluded it can not be done with 2 pole.  But I found a way.  One thing I did not mention yet is the brush placement is no longer standard. That also needs to change to make that field rotate at 2X the frequency of the shaft.
To make this happen, some commutator contacts need the magnet wire connections + Jumpers connected.  And others just need jumpers.
I have an update..
He made motors that speed up under load. Many videos. Years ago. That's how it relates.
mags
Mags,
The brushes are still powered separately. This is an electromagnetic generator (no magnets) that uses Lenz counter torque to rotate itself from the induced output's magnetism.  Whether or not it can produce enough output to to keep the armature powered -by looping- remains to be seen. A model will have to be built with proper specs and precision to find out.  I believe it may..
I have another video on private of the generator spinning itself while lighting a 12V bulb with roughly 1.5 amp going through it. As soon as I disconnect the bulb, the generator stops rotating.  So it is confirmed the induced magnetism of the output is acting as the field coil for rotation.
No other claims have been made at tis point, as I have not designed a proper output stator etc. I just whipped this together with parts I had on-hand to see if I can verify the effect.
I am attaching the armature winding pattern.  Please download and share it, leaving my name and credentials in-tact.  So if I go silent, this info isn't scrubbed from existence.
@ floodrod,
First thing, I have NOT built this but from my interest the thing thst makes the most sense is that the phasing of the coupling would have to b exactly right as claimed by others who had claimed success.
@ floodrod,
Magic of stationary brushes is they lock the phase to the shaft position mechanically.
Pitfall of brushes is they create a choppy rotating field.
My thought is "Looping" hinges on how smoothly you can rotate that field. More commutator contacts results in less loops of wire flipping at the same time.
One thing is for sure,  phasing of the output is important.  When using single output phase, effect is almost unnoticeable. No drag, but difficult to get the speedup effect.    But when I short or load the 2nd phase at 90, It takes off.  My build can only sustain it's own rotation with both output phases loaded or shorted.
I am thinking output phases may need to be configured to rotate the field also.  Like 2 phase at 90 or 3 phase at 120 cause rotation.  I will  know soon enough
Sorry I meant the  mechanical coupling shaft.
Can you explain more?  I have an attached motor, but seems it doesn't even need that once going.  It should be able to start with a lawnmower pull string or an Disengagable starter once optimized. I don't understand where a "shaft coupling" comes into play.
Please share the sources of the people you heard of doing this. I have not seen any builds or information that mentions rotating the magnetic field opposite that of the shaft or armature.
Thanks!
It was way back on a site called Keelytnet. gone now.
the coupling phase of the joining shaft needs to be in the right position rationally to each other .
I cant explain it better than this.
« Last Edit: 2025-11-02, 05:10:20 by 3D Magnetics »
at first i had thought you had no power input.  so now it is more like a shunt motor effect.  the powered armature induces the shorted stator, and just so happens to do so propperly to stay in motion. i think i remember a teslabpat that was similar.  not sure...
mags
The lower the resistance of a load across a coil, the more of the coil's stored magnetic energy is preserved.
The higher the resistance of a load across a coil, the more of the coil's stored magnetic energy is lost.
With zero-resistance load, an ideal coil repels with the same energy as it attracts (over the same distance), thus the energy dissipation over the entire cycle is zero. However, the mechanical energy required to turn it half a cycle is at its maximum.
(the above assumes one generator coil, with more coils the cycle gets divided into more parts).
Thus it is nothing unusual that the mechanical energy required to turn a generator a full cycle decreases as the total electric resistance approaches zero.
There is also an electric resistance when the mechanical energy required to turn a generator a full cycle reaches a maximum. That resistance is far from zero.
Verpies;
Except it spins itself with a Light Bulb load + a shorted phase.  It will probably even spin itself with a load on each phase and nothing shorted.
There is a Net Positive Rotational Torque.  It's not just getting easier to spin from resistance changes. Not only does it spin the armature, the net positive torque is great enough to overpower the resistance of the brushes, the bearings, the shaft coupler and it spins the open-circuit startup motor continually.
YES there is DC going into the brushes.  But powered armatures do not rotate without field coils or magnets.  The output coils induced EMF are aligned to become the field coils.
Observe-  Spinning itself with a Light Bulb Load  + a shorted phase...  When the outputs are disconnected, it stops rotating. https://www.youtube.com/watch?v=2RZjkmlwWFA
Verpies;
I would agree that there seems to be something going on here other than magnetic energy storage period being lengthened by low resistance.  In order for that light bulb to light from the stator windings, there has to be a magnetic field cutting those windings which would usually end in counter rotational opposition from Lenz.  The fact that it doesn't stop the rotor seems significant, like Lenz inversion.  Thanks for sharing and am looking forward to any new developments.
Dave
Ball bearing motor - Wikipedia https://share.google/gFkNJN18F6gCKSroP
Dave
there is a magnetic field cutting the windings. he is powering the armature. keeps saying that there is only power to the brushes,thus magnetic field from the armature.
mags
As I said, the armature is specifically wound in a way that makes the magnetic field in the armature rotate Clockwise by physically rotating the armature Counter-Clockwise.
Lenz tries to oppose the Clockwise Magnetic Field rotation by applying a Counter-Clockwise torque.  But the physical armature is rotating Counter-Clockwise.
I posted the exact winding pattern in this thread.
mags
I get that he is powering the armature via the brushes.  It seems like that magnetic field from the armature is finding some sort of attractive rotary force from the stator through Lenz inversion.
Dave
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 02:54:55
