2026-08-20, 16:22:39
Pages: [1] 2 3 4
Author Topic: Companion wave generator  (Read 40303 times)
This process, which in the past I have called the 'Dual pulse protocol' has garnered my attention. The Companion wave (as it is publicly known) process seems to hold the key to all the devices not using rotors for mechanical BEMF.
Having attained this result in the past and seeing numerous documents explaining this I am going to use this result to hopefully loopback.
I have seen the comp wave result in numerous tests of mine and others. Bibhas De and Spherics both attest to the validity of this with very exacting specifications that matched what I had setup in my test. Spherics warnings matched with what SM had alluded to.
Using the 3 channel phasing controller I built from the good graces of JDO300's design with the SSR boards he also designed I can initialize the controller with a script that setups up the exact parameters I used to acquire the comp wave results. I can acquire this result adhoc by simply turning things on now.
I have a number of coil winds that are suited to perform the comp wave results. I first adhered to a setup by Grumpy and JDO300 using a toilet paper roll. This was safe. The next step was to 'put it in a ring'. I did just that but wound the bifilar zip with spaces to apply inherent cancellation. This is the coil that jacked the household GFIs. I was quite pleased with this adjustment. The comp wave did what I thought it would do and that is affect devices at a distant. Something that Bibhas De has mentioned in his document that Grumpy posted.
Currently I have a voice coil attached. These are the ones posted previously in the 'What is known about the TPU'. I purchased 2. I am low side driving the coil pair with a 200vdc potential and max 200ma using my EC600 electrostatic power supply. The first test was high side driven and when I ran the script my pc froze. On my isolated scope there appears a series of high spikes of 90 to 100v at regular intervals.
The EC600 is one sweet device. When I shut off the channels in the controller software the EC600 senses no load and decouples the input power.
Looking at the software screen the viewer can see the setup parameters of the Spherics parameters from page 19 of the AVEC 1.0 document. The top of the page explicitly mentions voice coils.
I continue on...
« Last Edit: 2011-05-09, 17:07:00 by giantkiller »
...The Companion wave (as it is publicly known) process seems to hold the key to all the devices not using rotors for mechanical BEMF.
Thanks for reminding me about the "companion wave". I read about it some years ago then I forgot it. Even though the bases are very fragile, both theoretically (Bibhas De is considering only empty space with no charge sources, Rho = 0, J = 0) and experimentally (crossed field antennae do not support his theory, they are just shortened antennae radiating classically with only a bit better efficiency due to the radiation of both magnetic and electric fields from the near zone), his way of thinking is interesting. I'll take a look at it again.
What I have attained in alot of my tests are the very high frequency wave forms appear as bursts, in parts of the base waveforms, or fully across the scope screen. The HF is always 1MGHZ to 20MGHZ. I had been pursuing builds based on coil topology, build and setup configurations, Frequency / pulsing / on-off time, rise and fall times, voltage amperage, biasing, but have always seen the HF. So that is what I am following at this point.
« Last Edit: 2011-05-11, 19:32:05 by giantkiller »
What I have attained in alot of my tests are the very high frequency wave forms appear as bursts, in parts of the base waveforms, or across the fully scope screen. The HF is always 1MGHZ to 20MGHZ. I had been pursuing builds based on coil topology, build and setup configurations, Frequency / pulsing / on-off time, rise and fall times, voltage amperage, biasing, but have always seen the HF. So that is what I am following at this point.
Although I am very interested in antennae and have several TRX, I have not experimented in this field relatively to the "companion wave". I was interested in Bibhas De's viewpoint about the Poynting vector because I have in mind different questions about energy in EM fields, that are not clearly answered by physics.
For example if we have two distant omnidirectional antennae not influencing each other and radiating the same signal, their signals interfere in free space. In some locations the field doubles when their waves are in phase (there, energy is multiplied by 4 because proportional to the square of the amplitude of the field) and in other locations, it is zero (destructive interference). In any case, energy in the whole space is conserved, but there is strange question about the path of the energy. We see that the energy is radiated the same in all directions around each antenna but doesn't arrive in some points, meaning that energy didn't not follow a straight line. The energy is located only where the field is located. Two fields adds, but the energy of two fields don't, the energy of the resultant field is not the sum of the energy of the two field taken separately.
All is happening as if the energy didn't move but would be a potential energy available at any location where there is a field and becoming real when an antenna transforms the field in a HF current. So the idea of an energy flow viewed with a Poynting vector becomes meaningless.
@Ex
Good point. Maybe we are missing another parameter?
The comp wave can be attained albeit I have seen a small one. If you apply 1million volts to an aluminum plate the plate moves. Comp wave extreme or just a high potential deflection?
Everything is ether. Elements are a stable pattern in the ether. The oscillation of the ether as a whole allows the patterns to
continue. It provides the energy to keep spherical ether patterns continuing whilst allowing those spherical ether patterns
to also emit ether waves. All elements emit ether waves.
You apply a voltage across a conductor. Ether waves are propagated from both ends at the same time. As they move
through the copper the ether waves that the copper is made from cause further strong waves to move out from copper into
the ether around it, (This is the ether shock wave), whether or not that ether is patterned into the elements of what
constitutes air.
The ether shock wave is NOT the magnetic field. The ether surrounding the copper, could be ether patterned into air, or
ether patterned into insulator, or just ether. This ether interferes, if you like, with the shock wave, and causes subsequent
ether waves to affect the ether waves of the copper. It's a cyclical interaction that settles to a repeatable pattern of
interaction. Once the repeatable pattern is established even though you still have the same voltage across the conductor
the wave from the copper is effectively attentuated and goes into building this repeatable pattern. PART OF the repeatable
pattern is the magnetic field. All these waves are longitudinal.
A SEP coil generates a stable repeating pattern in the ether. Anether shockwave travelling through this pattern causes
this stable repeating pattern to alter. As the shock passes the pattern reverts but in a finite amount of time. If you send out
another ether shock before the pattern reverts completely, and from a different location, you can now manipulate the
pattern, expand the pattern, or cause the pattern to rotate around in space. Even if this pattern does not manifest in a way
that we measure as a magnetic field, it can still interact with copper to produce a current like effect.
The amplitude of the shock ether wave depends on the physical amount of copper the ether waves from both ends of the
copper coil travel through and on the voltage applied across the coil.
You want constant pulse width in time, not percentage duty cycle, across frequencies.
The shock wave comes from the copper. The HV causes the copper to generate the shock wave. + previous answers.
Faster rise time, faster fall time. Time spent at top of pulse should be only large enough to generate a feeble magnetic
field. Straight up, straight down. I'll send a diagram.
To be able to apply the voltage and remove the voltage before the current rises too high requires the highest inductance
possible.
The magnetic component is manipulation of the atoms. The current production is the manipulations of electrons. The companion wave component is the manipulation of either the nucleus or the atomic or subatomic bonds.
« Last Edit: 2011-05-10, 21:24:46 by giantkiller »
@Ex
possible
I understand that the goal is to create the shock while avoiding a magnetic field. But any accelerated charge radiates EM waves and EM waves carry a magnetic field. The shorter the rise time, the more the acceleration of electrons, the higher the frequencies. Even an single period of a sin signal at Ghz frequencies has a rise time much shorter than that we could obtained from a squared pulse by discharging a HV capacitor in a straight copper conductor. So I'm not convinced we could observe by this mean something else than a burst of classical EM waves.
We must be careful. In particular, relativity explains also magnetism viewed by an observer, as effects of length contraction on moving electrons when there is not for the positive charges which are at rest in the lattice of the conductor, thus an apparent difference of the positive/negative charge density. A magnetic field and an electric field are identical effects viewed from different referentials. Remarkably this is perfectly compatible with Maxwell's equations. So we face two powerful theories saying the same. I think that only very clever experiments could make appear new phenomena at the fringe. I have not much time now but I will reread the papers about the companion wave, may be there is a way.
@EX,
Everything we can see or measure at any given point are merely an after effect or deprication of a previoulsy higher frequency aspect. Advancing our visibility further into the past of the aquisition moment is the goal of science. The moments are always attainable but how do we quantify? Are the tools we have capable of discrete measurements, the fine line between did we measure or are we affected and how do we separate the two?
The fringe, in this case, is the boundary where our tools of matter in this band of existence are placed in such a configuration of use as to allow us to expose the artifacts of the fringe or to see just over the boundary of what we deem as the current reality. Or broadening our scope of acceptance by numerous proofs.
Basically the OU monkeys are playing with handgrenades be they alive or duds.
Following good RF mechanics:
The two coils must be attached to each other as close as possible to the coiling. Having 2 connecting leads from 2 coils connected with alligator clip leads changes the dynamics and depricates the environment for the comp wave production.
Posted is a picture from Wattsup of just this solution and one wire soltuons.
« Last Edit: 2011-05-11, 20:23:50 by giantkiller »
More on Energies in the Electron Vortex
The kinetic energy of the vortex is what remains when the "hole" creating the vortex is closed.   It is equal to mc2 as shown above.   Kinetic energy must be equal to potential energy.   The centrifugal force used to hold the hole open for the vortex to form is mc2/r.   The energy used to open the hole is the same as the potential energy that would erupt were the hole to be closed.   It is (mc2/r)r which is mc2 because energy equals force multiplied by the distance over which it acts.   So we can see that in a nether vortex such as the electron, Ek = Ep = mc2 where Ep is potential energy.
Gravity at the vortex center would be shown by the equation g = c2/2r where "g" is gravity and "r" is the radius at the electron center.
Kp = mgr = m(c2/2r)r = mc2/2.   This is the potential energy of mass or Mass at the electron center prior to a fall to the exact center of the vortex from the vortex periphery.   Note that it is half of the total kinetic and potential energy of the vortex were the hole to close suddenly. This is the potential energy due to gravity.
However, there is also the tangential component of mass or Mass that is moving at velocity "c".   This also has a potential energy that is equal to that due to gravity.   The two potential energies, the one due to gravity and the one due to the tangential component (angular momentum) total the same as the kinetic energy for the vortex (which is mc2).
mc2/2 + mc2/2 = mc2
http://www.softcom.net/users/greebo/vortex.htm
Coil is U.S. paper towel roll of 42 turns of bifilar speaker cord. Inductance is <2mh.
Only using single silver run.
Cannot compress the highest spike any less.
Had the EC600 upto 400VDC and smoked the Li-ion battery on the isolated scope. The scope still works.
Test #1
using EC600
100vdc applied
resistor is 430 ohms
Delay is 100ns
Compwave appears.
Test #2
Using EC600
100vdc applied
Resistor is 330 ohms
Delay is  67.20ns
Compwave appears slight sine wave moves from main wave to right of screen like ripple in a pond but back and forth at a speed of 1 sec of the screen distance.
Ringing also appears on input pulses
Test #3
Using Battery for coil supply
12vdc applied
No comp wave at all but large ringing.
So as I try to apply more current the compwave becomes more difficult to attain or maintain.
I had a setup last year to do this and cannot remember what the driver voltage set up was. My bad.
It seems this setup only works with very low inductance coil. The parameter seems to be any voltage, low current, low inductance.
Another attempt is to bias the unused used bifilar line to setup a magnetic field.
« Last Edit: 2011-05-16, 04:43:32 by giantkiller »
Apply a 12vdc bias @5ma to secondary. Shortened delay to 33.6ns and digital meters goes to 1.
Put delay at 84ns and meter show 15vdc on a 12vdc RV battery.
Will put ECD600 100vdc through bias coil next.
« Last Edit: 2011-05-16, 07:10:40 by giantkiller »
The "companion wave" is a momentum wave. It can be detected only by the mechanical force exerted onto an antenna mounted on a piezoelectric sensor. There is no possibility of direct electric measurement of the source. See §4 http://www.bibhasde.com/veipaper.pdf
The paper dating 1993, I'm afraid the author failed in realizing himself the experiment.
Apply the bias to both wires of the bifilar coil.
When you have several in a circle, you can connect the DC bias, wrap right over the bifilar coil and connect to the next bifilar coils section.
Added bifilar coupling coil.
Any low inductance air core winding will do as a compression wave generator.
The pulse protocol specifications are exactly as Spheric stated. I did not change the parameters when swapping to this next coil.
Next I bias this one. It is smaller and fits on the bench.
Then I swap in the paper tube one as a verification.
Then i pull 3 low inductance coils out of inventory and put them in a circle. This exact placement will perform better than Hutchison's random placement.
This has a secondary of high inductance in a 6" Tesla coil like John Hutichson uses.
http://www.overunityresearch.com/index.php?action=dlattach;topic=79.0;attach=5031
Electrogravity and mass
There might be a link between Harold Puthoff's Polarized Vacuum (PV) theory, which models
gravitic effects, and the presented scalar field: a bidirectional longitudinal electroscalar wave.
Two superimposed LES waves that travel in opposite direction can result in a standing scalar
field wave. The components of the two opposite LES waves cancel each other, as pointed out by
Tom Bearden. The time derivative of this standing scalar wave is equivalent to a space charge
(see equation (6)), or in other words, a vacuum polarization. This pattern of bidirectional LES
waves (space charge) alters the diëlectric 'constant' of space slightly, which explains the bending
of light (TEM) waves by gravity. Without the exact definition of the LES wave, Tom Bearden's
notion of a 'standing bidirectional scalar wave' cannot be understood at all, and also the
theoretical link with Puthoff's PV theory would not exist. The bidirectional LES wave requires a
'phase lock' of two LES waves in opposite direction. This tuned phase between the bidirectional
LES waves, transmitted by two massive bodies, could be gravity.
The Hutchison effect includes levitation of heavy objects. Hutchison's equipment consists of two
or more tuned Tesla transformers, such that a bidirectional standing scalar S wave might be
induced between the Tesla transformers. The longitudinal electric field might be cancelled by
means of proper tuning of the transformers. The paragraph “Electrodynamical free energy
devices” described that indeed a Tesla transformer can induce observable longitudinal
electroscalar field waves, because of the high voltage high frequency characteristics.
Thermoscalar effects
Solids, fluids or gasses can be heated or cooled by direct thermic conduction or by means of
electromagnetic fields. By definition, a scalar field S can also induce thermic effects in metals or
plasmas, since the longitudinal S force F = qvS accelerates or decelerates charged particles.
Several thermoscalar effects can be described:
Suppose S>0, then positive ions or nuclei are accelerated while negative ions or electrons are
decelerated. For instance, the speed of conduction electrons in metals can be greatly reduced
while the vibration speed of the metal nuclei is slightly increased, since the mass of the nuclei is
much greater than the electron mass. Because of the decelerated conduction electrons (that form
the glue between the metal nuclei) the atomic bonds break, and so the metal melts, distorts,
ruptures, without noticeable rise in temperature. This has been observed by John Hutchison: the
jellification and distortion of metals by an external field, without apparent rise in temperature of
the metal object.
Cold current effect
When S<0, then the positively charged metal lattice atoms are decelerated (cooled down) while
the conduction electrons are accelerated by the longitudinal scalar field force. This could very
well explain the cold current phenomenon where the temperature of conductive medium drops
and at the same time an extra current is observed, since the accelerated electrons diffuse away
from the cold spot into a warmer area with less energetic electrons. Several researchers have
observed this cold current phenomenon, such as Nikola Tesla, Thomas Moray, Edwin Gray and
Floyd Sweet.
Efficient lighting
A gas could also be ionised, or its orbital electrons excited into higher energy states, by means of
a negative S field, since such a field accelerates electrons while the positively charged nuclei are
decellerated. This means that ordinary lamps can emit light without a temperature rise of the
light bulb, so the lamp shines and it does not get hot. Such an effect has been reported by Floyd
Sweet. The energy efficiency of the light bulb is enhanced greatly by means of scalar field
excitation.
And why wouldn't a functioning TPU pull lightning out of the sky? It is just a Tesla coil as a horizontal platform.
This looks like Tariel Kapanadze's Diagram in his explanation of the special capacitance model and magnetic pole placement of Magnacoaster.
It does not offer a good explanation for free energy claims that involve permanent magnets,
unless magnets are not just magnets but also sources of scalar fields. Some experimenters
speculate about scalar effects induced by two magnets glued together: north pole agains north
pole, or south pole against south pole
. Then the magnetic fields cancel partially, which might
reveal the presence of a scalar field. Except for a rotational magnetic potential a non-rotational
magnetic potential might be induced by magnets. The secret of the mysterious Sweet magnets
might not be based on magnetism at all: Sweet described the conditioning of the motional
electric field in his essay “Nothing is Something”. This means that the Sweet magnets could have
been electrets as well, perhaps showed a permanent cylindrical electrical polarization and
perhaps extra scalar field properties. Then the claimed free energy effect, the observed cooling
effect and the observed reduced-weight effect by Sweet might all be based on electroscalar field
effects.
3 coils on bottom copper core. Pulsed in parallel. Inductance is a little higher than previous Tesla coil so compwave a little smaller.
Bias is next on Tesla primary.
Did you try a dc bias on the bifilar coil?
Using this circuit for coil bias.
Put a 2.2k ohm in the +12vdc RV battery circuit.
Waveform is altered with +12vdc 5ma bias applied.
Next session will increase current of bias.
« Last Edit: 2011-05-23, 06:53:43 by giantkiller »
With respect to Reply #6:
Thanks for the "one wire solutions" and the *two-wire-Mobius-though-two-coils*.  They're easier than trying to hand-wind a conventional Mobius.
--Lee
Sweet's magnets were conditioned to produce a diverging/converging magnetic field.    This may make a scalar field more accessible.  Coils pointing inwards also provide this sort of magnetic field.
Not mine. Thanks to Otto...
--Lee
4 primaries wired in parallel.
4 secondaries wired in series, biased with 2.2k ohm resistor and 12v battery.
Same specs as single primary.
No difference as of yet. Needs more testing.
@GK
I put a closeup of your coil.
Your horizontals seem like you took twin speaker wire wound 2 something turns, in two sets per ring. If this is the case then please consider trying this.
Based on each horizontal loop wire turned 3 times.
L     - 1 - 1 - 1           Top layer three turns
      - 1 - 2                goes to second layer in same direction
      - 2 - 2 - 2 - C      2nd layer three turns then to Common
C    - 3 - 3 - 3           3rd layer three turns then to Common
      - 4 - 3                goes to third layer in same direction
      - 4 - 4 - 4 - R      Bottom layer
Put all three rings in parallel and run the whole coil in tandem.
Run L C and R off your audio output.
Put the long verticals in parallel or series as you want the output or keep them all separate for  now to identify their output polarities before you make an output strategy. Tank it and measure as you adjust frequencies on that freg gen program.
Once yo find the right frequency, play with the phasing.
I would say around 11,0000 hertz range but you will quickly find the sweet spot anyways. Then play with the phasing. Don't use those small coils yet.
Keep a nice magnet around to put it near the coils. If you have small neos like what I used in my moving litz wire video, try putting it in the center of the build.
Nice build by the way.
********* Pulsing coils ********
I have a new way of looking at coils and would like to share it with you.
Man if I noticed this years ago, I think it would have saved us so much time.
First of all we all agree that a scope will show the waveform of voltage/current activity or frequency responses at the scope point. OK so take any coil that has a center tap. Pulse one end and scope that end, you will see the response. Put the scope probe on the center tap and you will see half the first response. Now put the probe on the other coil end and you will see NO RESPONSE. On average, half the coil responds, the other half does not. NO matter if the coil is a straight piece of wire, a one turn loop or a 100 mile long wound coil, only half of it will really responds to the pulse. That is because the side that is connected permanently to the coil has already biased the complete coil and upon connection it will simply recede back into its half of the coil when the connection is made. It does not have to respond since it is already at its maximum forward position.
Remember in my pulsing coils videos when I pulsed the toroid coil and placed a Litz wire loop over it to light my LED, the LED would only light at a specific cross section and by moving it slightly off, the LED would not light up. Not knowing this, the loop was either on an active or non-active side of the coil.
If you want to have a strong pulse "reverberate" through 1 complete coil, or a complete Otto mode quadro coiling system, or whatever coiling system, YOU WILL ALWAYS NEED TWO IN SERIES. The pulse enters the first coil and thinks the complete first coil is only half of the total of two coils. So the pulse passes the coil completely. Then you pulse from the second coil side and now the pulse thinks it is only half of the total of two coils and passes it completely. You can have identical coils in series or two different coils in series as long as they are complimentary in inductance.
Telsa did this in the Tesla Ozone Patent. Two coils in series so the primary of the working circuit really was pulsing through out the coil and not only in half the primary coil. The capacitor discharge flys accros the primary and lands inside the coil of high inductance. Almost all the maximum level of the discharge is in the primary. Now I understand Teslas' logic for this.
Just think of the FTPU. Center toroid has two coils. There are two rings. There are two overwound coils. Always two.
The center toroid has two coils in bucking mode. If pulsed from one side, it will have only one of the coils active. So you pulse for one side, then the other side, and so on.  The electronics to do this is above my head but maybe with an H-bridge type, or a simple pulse that splits with knowledge of the coils.
Romero's wheel uses drive coils. Two in series so I know that at least one of them is being used 100%, otherwise you are stuck with 50% of each coil. I know, some will say the 50% of one coil is still 100% of the energy put into it. Yes, but you are better off using a little more energy with two coils and have then each work 100% for the effect. Also with drive coils pushing against magnets, always pulse on the end that starts the wind closest to the core. At least if you have such a single coil that is only 50% active, put the active half nearest the core and if you have to switch the polarity against a magnet, then turn the coil itself and don't just switch the wires.This is where many go wrong. lol
So, to summarize lets look at a simple loop. Remember those???????
When pulsing DC from one end....
1 loop makes half an active loop,
2 loops in parallel but offset 180 degrees will produce two distinct half active loops.
2 loops in series makes 1 active loop,
2 1/4 turns of a loop will make a 1 1/8 loop active loop.
Think of this. If you wind a primary on a toroid core of let's say 10 turns, then continue the wind but off the toroid for another 10 turns. Pulse on the side of the toroid and the pulse will travel accross the complete coil half that is on the toroid.
If our scopes do not lie, then electricity does not travel in a circuit. It just permeates conductors or better still, electricity is two biasing potentials that just have one goal and that is to meet and annihilate each other. This way, both return to the ether where they came from in the first place. You can see it in thunder clouds. The cloud is a loop of negative potential, the ground is a loop of positive potential. When the cloud gets as strong as the already immense ground potential, the spark starts towards the Earth, but the Earth, with a sigh of boredom toward the clouds' tirade, always sends its own spark upwards to meet the clouds' thunder bolt. Always, always and always. Electricity does not travel in one direction. It leaves both battery poles and advances into the circuit to meet at one circuit dependant point, usually somewhere in a coil because the coil has much more inductance then any other component so the chances of meeting there are greater.
One day when someone invents the NEGATIVE DIODE, we will realize this and it will open up a whole new world of electronics. I would call it bi-directional electronics.
I have been spending some major time on looking for things in EE we are doing wrong because from all the efforts, there must be some very slight errors that produce a major lack of effect. Small things, seemingly insignificant things, without the foumulas that are man derived and formulated to fit so well our reality. Look at the effects for what they are in real life, compare these to other natural phenomena to see where we are going wrong in our quest for YES "overunity". So there is definitely more to come AND MORE TO BETTER UNDERSTAND.
So when you plan to pulse a device, think that only half of it will respond.
Now, if you pulse both ends of a coil at inverse on/off, then when one side is on the other is off and there should be nothing going on at all. But if each side is adjusted so that they share a mutual on time that overlaps, that will be the real on time and the coil will now respond in both halves without an outside assistance off an added coil in series. The overlap window is very small. Otherwise if pulsing from one end, add another coil in series to it and see how it goes.
I cannot remember Tesla ever stating this outright like I have, but when you look at his designs, it seems like his was instinctive but he had to know this otherwise he would never have wanted to invent something better, like AC, that sort of takes care of the problem to a certain degree, but not completely since he was not dealing with square waves. That's why I suggest you try your above coil with sine wave audio as an easy start. Then advance to square waves but I don't know enough about the EE end to say how. Maybe with two H-Bridges one on each end with one slightly off.
PS1: The guys that could take immediate advantage of this are those playing with JouleThief designs. If you have a 5 turns primary simply add another 5 turns to it but off the core. Pulse on the core end of the primary. see the difference. At five or more added turns, this will not change the inductance that much but now, it will make the primary that is on the core fully active. lol
PS2: Man, I am just waiting to be clobbered now.
The 2 primaries(purple and blue) are wound in opposite directions.
@GK
You will have to describe how the horizontal wires are wound because it will depend on that.
The way I see in each level your horizontals as being two lengths of dual speaker wire that have 2-3 turns each that you put one on top of the other before you wound the outer coils.
I made a quick drawing of how I see them and if that is how they are, showing how to connect them.
Let me know if this is clear enough or if your wind is different please advise.
Each horizontal is bifilar 4 turns each.
I will wire this up next excluding the middle set using only top and bottom layers.
Pages: [1] 2 3 4
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-20, 16:22:39
