translation from bing.com of first page of pdf file:
A brief description of the TCU by Sergey Alexeev Is the frame, plastic ring 200 mm in diameter, its length is calculated circle. Further to this length, the twisting wires, are driven by two nail ... they wound coils 600 thin wire, then it is removed and twisted with a density of 1 turnover at 2.5 cm, so hath it ends naturally. This litc fit ring axially, i.e. circular, made from it conclusions and all this is isolated. to withstand 30-40 m2. The next step. Looped strip of foil insulation toroidal′no, so as to winding ... but it must not focus narrowly, that is how I understood the coils should not be korotit′ among themselves. Well again is isolated. From this lining will also need essno finding one. This century, facing the capacitor formed by the Litz and this paneling. Next. Insulation is placed on top of the movable coil, thick wire, toroidal′no, the surface of a doughnut. Litz wire and the detachable coil form element from which output exits, they are included in sequence. High voltage is applied between the Litz-minus (Amendment of Michael- minus the grounding, connection with Litz), and cover and foil-plus. (Voltage is supplied to the foil to remove the allowance on the amps on the domestic a thick ring, tension will have to pick up manually, in which the main hemorrhoid. IN Depending on where you are, depending on the terrain and climate, you will change and the stress that you want to apply to the foil. Hot magnetic flux- It is that which gives just the amps should go strictly for the internal ring, Therefore it is necessary to accurately observe the geometry of the rings, nothing broken. Stocks in the There should be no installation!) Continue to the next step. Rushed reels rotation field. Four reels, sectors on 90 degrees. The key point, celebrated author, winding wires, twist, including must be one way. Well, actually, kind of by design. Now connect the control scheme to torsion field coils, serve the high and catch the energy generation mode. Another key moment, celebrated author of the currents in the coils of torsion fields should quickly warm up a copper soldering tip. This is a preliminary test, as I understood it, this will not be the achieved. Management scheme is a running fire with overlapping pulses.
