A look at Arie De Geus Patent No 1032759
Started by Peterae, 2015.03.29, 18:22:02
Thanks your signal gen + / - is wrong way round if you look at the circuit 0v is on left and positive goes to both caps, well thats how i read it although its not clear, would you place the switch on the neg side of the sig gen output?
Peter,
OK, i understood the ground point was in between the 2 capacitors, but i see your point about the switch.
Anyway, just change it to how you think it supposes to be connected, adjust the values (capacitance and inductance) and check the signals, they should be close to what you see on the scope.  O0
Sure  O0
It also changes where the scope probes 0V is connected to 0V sig gen also not middle of caps.  O0
**Note this looks like it maybe a result of connecting a voltmeter across A & B because when i disconnect the meter the resonant frequency changes a lot and i loose the DC offset on the Scope point A, although i have seen a slight DC offset so far it's under 10mv.
At Resonance i do get a dc shift of the level on the point A, placing a Voltmeter across A & B i can measure between 5-6 volts DC but only at max resonance, on the scope i have a DC offset of 37V which is how i think it manifests itself, although the biggest DC voltage is at the lower resonant frequency of around 1Mhz without the phase shift, although a DC offset is present higher up in frequency the DC voltage measured is lower.
So why would A be showing a DC offset, my scope channel is set to 0V center line.
Yellow probe is A
Blue probe is B
0V of signal gen and scope probes is left side of Coil A as per diagram.
Dam i've been going over how i have this hooked up to make sure everything is right, it looks like i am running in bucking mode all along. Sorry my mistake, which is even weirder now, i will need to draw a circuit of what i have hooked up as soon as i get some time over next few days.
Still getting the weird super imposed signal as well.
Quick sketch, God knows how i connected it up like this but this is what i have, looks like 2 series LC circuits in bucking mode.
I mixed up the green end.
Peter,
i rearranged the LTspice circuit as per your drawing above, but we need some more info, like coils inductance, capacitors capacitance, input signals (voltage, waveform, frequency), etc.
Here i made some guesses on what i see on the scope (1MHz sine wave) and some earlier info.
But the sim shows some 180 degree phase shift between the A to ground signal and A to B signal:
thanks for the simulation, I think the noise on the sinewaves is an interaction between the 2 series LC windings as they are closely coupled, not sure if you can simulate a Bifilar coil?
Inductance is in one of the posts above, https://www.overunityresearch.com/index.php?msg=120229
at 272.88uH
both variable caps are both below 25pf and vary from about 5pf so 5-25pf.
The resonant frequencies ive been running at are in the scope shots.
If you sim at 10pf each cap with that inductor it would be interesting to see where your resonant frequency is at.
The phase shift is weird it changes, if you look at this test https://www.overunityresearch.com/index.php?msg=120240
you see that the higher resonant frequency 5.4Mhz is 180 Degrees but the lower bigger at 1.18Mhz is not.
I'm running about 20Vp-p but should check that maybe. sinewave because my squarewave is bad above 1Mhz, the singal generator is 50Ohms output although it does have a 600Ohm output as well but not tried that yet.
The interesting thing was putting a DVM across A & B and getting a DC offset, i wonder whats in the DVM to recreate this.
I also want to try an avremenko plug on the open end of the coil to see what it picks up.
Peter,
Quotethanks for the simulation, I think the noise on the sinewaves is an interaction between the 2 series LC windings as they are closely coupled, not sure if you can simulate a Bifilar coil?
I don't think these 2 closely coupled series LC windings are forming a bifilar coil, they are not directly connected to each other, and yes, LTspice can simulate a Bifilar coil.
Also, as verpies often mentions, how bifilar?  There are 3 (or 4) ways you can hook up coils to form a bifilar coil:
Quoteboth variable caps are both below 25pf and vary from about 5pf so 5-25pf.
In the scope shots i see 5.4MHz, 5.6Mhz, 1.18MHz, 10.6Mhz, 8Mhz, and in your last screenshot 1Mhz, but IMO these were all from before you changes your circuit from what you called "bucking mode" to the present setup.
Do you have still the same resonance frequencies?
QuoteIf you sim at 10pf each cap with that inductor it would be interesting to see where your resonant frequency is at.
The sim follows the LC resonant rules like in this calculator: https://www.1728.org/resfreq.htm   so in this case Frequency with C = 10pF and L = 273uH is 3.0461Mhz
QuoteThe phase shift is weird it changes, if you look at this test https://www.overunityresearch.com/index.php?msg=120240
Would that not be normal with 2 LC circuits closely coupled?
QuoteThe interesting thing was putting a DVM across A & B and getting a DC offset, i wonder whats in the DVM to recreate this.
Well, your guess is as good as mine.  ;)
