2025-12-18, 23:37:45
Pages: [1] 2 3 4 5
Author Topic: Mookie's Electrolyser Accelerator  (Read 88026 times)
As a consequence of Mookie employing his time and effort in experimenting with electrolysers and magnetism, he has recently afforded me a ‘Eureka!’ moment.
Though my interpretations of what is occurring differ vastly to that of Mookie’s own interpretations, I still have Mookie to thank for demonstrating the effect in the first place, and providing me with a new insight and indeed a new avenue to explore.
http://www.youtube.com/watch?v=lKqs5z2DrCk
Though I have stated much of my thoughts on the Dissociation of the Water Molecule thread, I want to reiterate my thoughts here before I go into detailing my planning, designing and indeed fabricating of a new cell based on what I… think I know.
Firstly, I believe the phenomenon we are witnessing is due to cavitation, and this is what I think is happening in Mookie’s set up.
He has stainless steel electrodes in a glass jar of water doped with a small amount of KOH. This simple electrolyser is powered by a stabilised dc PSU from a PC, and is using the 12volt terminals. Close to the glass jar electrolyser he has a powerful industrial electromagnet.
When he attaches the 12v PSU, normal electrolysis takes place. When he also powers up the electromagnet, the magnetic field produced by the dc current flowing through the electrolyser interacts with the powerful magnetic field of the electromagnet.  The electromagnet, being mains powered is hence running at 50 – 60Hz albeit via a variac.  This 50 – 60Hz mains frequency causes the electrodes to oscillate at this given frequency, applying more voltage simply increases the amplitude of the oscillations. Below a certain amplitude, little or no cavitation is in evidence, but up the voltage and the effect eventually displays itself.
One minor area of contention is that Mookie says it won’t work with stainless steel electrodes that are NOT magnetic.   Well, obviously magnetic electrodes will be influenced into vibrating far easier – or greater - than non-magnetic electrodes, but I personally doubt that this is a critical factor.  If this were a critical factor, then cavitation and hence evolving gases would surely be evident when the electromagnet was powered up near the electrolyser, even without the electrolyser itself being powered. This does not seem to be the case.  Now, there is some visual motion of the water that suggests that the plates might indeed be oscillating via the electromagnet and without the electrolyser being powered, but not to such a degree that initiates cavitation.  However, as yet it is unclear as to whether or not the glass jar is in physical contact with the electromagnet, and if this is the case then this observation could be simply a result of the electromagnet itself physically vibrating and nothing to do with its magnetic field.
The magnetic field of the electromagnet is proportional to the current flowing through it, which itself is proportional to the applied voltage, so reducing the voltage on the variac correspondingly reduces the current and hence the magnetic field.
There is quite a lot to explore here before designs can be optimised.  We first need to know if certain frequencies are more efficient than others in this process and what works best.  What would happen if the electrolyser voltage was also pulsing? AC might not produce normal electrolysis, but would cavitation efficiency rise or reduce… would AC work at all?
If Fleming’s right hand rule is a key factor, how do we go about designing an electrolyser that best exploits this rule?
I sense some fun and interesting times lie ahead.
Edit: I keep referring to Fleming's right hand rule, but actually Fleming's left hand rule may be more applicable here. The right hand rule is known as the generator rule whereas the left hand rule is known as the motor rule. Either way I feel Fleming's rules may play an important role here.
« Last Edit: 2010-11-01, 19:27:55 by Farrah Day »
I watched the video and found it quite interesting.
My interpretation of the vibrating plates is that this results mainly from the  magnetic attraction and repulsion between the plates and the oscillating magnetic field produced by the E-core transformer. That is why Mookie mentions that the effect disappears with non-ferrous plates. It's a simple and basic interaction. Mookie did not mention any numbers so it is difficult to say how much 12V current he is using, unless I missed that. Nonetheless, that is a static field, and it's effect would mainly be to make the vibration lop-sided rather than symmetrical. The jar is being slammed against the transformer and hence the loud clanking noise. As the electrodes are secured to the jar, the jar will move in concert with the electrodes. All pretty standard stuff.
However, the interesting part is how, with the addition of this vibration in the plate electrodes, the LPM rate seems to increase quite a bit. This is great and interesting research, however no one as far as I've read has asked the hard question yet: How much power is going into that transformer electromagnet?
Obviously no advantage will have been obtained if one can achieve the same LPM rate simply by applying that extra power to the cell electrodes directly.
If it ends up that there is no real advantage going this route, it still makes for interesting research, and may open up some new avenues to pursue in the never-ending goal to break Faraday's law.
Poynt
The mookie has been at this for some time now,Its not his first summer!
Hundreds of hours breathing the HHO
Heres why we need to proceed
 Mookie Quote: [from here http://www.energeticforum.com/renewable-energy/5590-basic-electrolysis-6.html#post94116]
As far as output I need to be cautious in what I say. This "accellerator" is based on Felix Ehrenhaft's work in the 1930's. His experiments, and those who briefly followed up on it demonstrated a tenfold to 15x increase in the electrolysis rate. I have no way to properly measure that, but can confirm from my own experiments that the increase has to be at least ten times.The effect, as I said earlier, is obvious, dramatic and ferocious.
I assure you, firsthand, that the work that those that are doing this in a much more advanced way than what I have described here
will never see the light of day.
Farrah
You go Girl!!
Hi All,
A read of this may enlighten you on the effect,
http://www.free-energy-info.co.uk/Non-Ferrous-Magnet.pdf
Having worked with DC and AC electromagnet control systems (8 mega watt supply transformer) this effect seemed too familiar.
The plates are attracted to the magnet in the video. This will stir the contents with vigour and may be beneficial in removeing the gas produced from the plates but I fear heating from the eddy currents will eventually boil the solution
Steve.
Poynt
Farrah
You go Girl!!
Hi Chet.
What matters is the question I posed. That is the first one that should have been asked, and the first the author/inventor should have confirmed. It's extremely easy to do. He already has an AC voltage meter on his box. What he needs to do now is to put that variac output through an ammeter. Done.  ;)
It seems like Mookie is about to disappear for a time, which is a shame, but I’m not overly concerned as I have all I need to know in order to follow this up with some conclusive experimentation.
.99, I too feel it is important to know whether or not the electrolyser oscillates if it is not in direct contact with the EM, at least this way we could eliminate direct physical vibrations from the EM. This would also determine if the ss electrodes were in fact at least partially magnetic or not, in that they should still oscillate if they are. However, it doesn’t look like Mookie will be forthcoming with an answer to this question, and no one on EF thought to ask this.
Water is not magnetic. Ions within the water are not magnetic. Unlike an E-field which will align the dipolar water molecule, a magnet will have little or no effect on the water molecule.  Only when ions within the water are set into motion (a current flows) will an external magnetic field have an effect.
For myself, the matter of how much power the EM is consuming (and I expect probably at least 600W) is irrelevant at present, as Mookies set up would be nowhere near ideal. To me the fact that he appears to clearly be demonstrating a cavitation effect at 50 – 60Hz is the important thing. However, one thing that really does need to be determined is that the bubbles created by the EM are in fact hydrogen and oxygen, and not just water vapour.
A few other things also come to mind when I think of people using mains powered electrolysers in the past, that have claimed over-Faraday and say that they have witnessed bubbles emanating from between the electrodes rather than from the surface of them. Could this have been due to the plates oscillating at 50 – 60Hz and so creating a cavitation effect?  Mookies demonstration might just have answered a lot of questions.
I know Mookie says his electrodes need to be magnetic, but as already stated, I would be very surprised if this is so. If this was the case, then the EM alone should have produced some cavitation – it does not appear to.  No, I’m inclined to stick with Fleming’s rules here, and the fact that a current carrying conductor (the electrodes) will react (move) when their magnetic fields interacts with the powerful external magnetic field of the EM – and in this case at 50 – 60Hz.
As far as Faraday’s laws are concerned, this measure of gas would only apply to the standard dc electrolysis occurring, NOT any gases produced via cavitation.  Remember, while Faraday’s laws can be used as a baseline for comparing other forms of water dissociation, Faraday’s laws only apply to the process whereby ions are involved in exchanging charges at the electrodes. This is something that many people fail hopelessly to get to grips with.  Faraday’s laws of electrolysis themselves are flawless in their simplicity and beyond question if people would only take the time to look them up and fully understand them. Over-Faraday may be quite possible, but this will never make Faraday’s laws redundant or obsolete as they only relate to a specific process. Whether cavitation can be made more efficient than Faraday electrolysis in terms of power vs gas output, is unknown to me, but it must be understood that you can not apply Faraday’s laws of  electrolysis directly to cavitation – or plasma electrolysis for that matter - as both methods evolve gases that are not derived from ionisation of the water molecule.  You can however use Faraday’s laws as a baseline from which to judge the performance or efficiency of other methods of dissociating the water molecule.
The most immediate thing to come to my mind when I look at Mookies demonstration (and if I’m right in my thinking that Fleming’s rules are in effect) is that the electromagnet could be replaced by strong neos within the cell, and instead of the electrolyser being powered by dc, the current could be pulsed.  Basically achieving the same effect by reversing the system. Given a high enough pulsed current, and of course depending on electrolyser design, the electrodes would then see the same oscillation effect. This would do away with the need for an electromagnet altogether and make design far simpler.
The beauty of using powerful neos is that any cavitation effect would be a by-product of Faraday electrolysis. By pulsing the current it may be possible to get the electrodes to oscillate and so induce cavitation with very little extra power consumption.  The fluctuating magnetic field produced by the pulsing current, would interact with the magnetic field provided by the neos. We basically create a SLF or mains ‘hum’ within the cells.
The variables that are most influential in both Mookies present set up and my proposed neo version would be the strength of the magnetic fields and the amount of current flowing through the cell.
How important are these super-low frequencies?  Many of us that have played with pulsed electrolysers in the past have employed PWMs that do not operate at anything close to 50 – 60Hz, so would never see this effect. Maybe we’ve simply been operating at too high frequencies!
Got to say this is the most excited I’ve been for a good while as there really is something to get my teeth into here – and possibly something that explains a lot of things that have to-date evaded explanation.
NB. Great link Szaxx!
« Last Edit: 2010-11-02, 09:37:56 by Farrah Day »
That's typical ::)
Actually I wasn't referring to that. What I was trying to say is that the plates oscillate because they are ferromagnetic, and since they are secured to the jar, and the unsecured jar is placed right up next to the EM (to maximise the effect), the jar bangs against the EM.
If the jar was moved 1mm away from the EM and it was secured so as not to move, the electrodes would still vibrate (albeit slightly less) but the jar would not hit up against the EM.
To maximize this effect, one could try nickle electrodes, as I believe they are ferromagnetic. Even better would be a SS electrode made in such a way that it was a flat sealed pocket (except for the top) in which one could insert various ferro materials to try.
99
Hm....
Seeing as how its the Nickle in the stainless that makes it 400. series.
Good to try.
There will be lots to play with!!
First things first
A valid replication of what Mookie has done ,and then Test/play /improve ......................
Farrah
Will you be listing your components ETC?
I want to replicate your replication!!
Thanks Farrah Day for starting this thread and thanks RAMSET for pointing to this forum.
As you probably read over at EF I plan on reproducing Mookie's experiment and purchased the same electromagnet he used.  My first setup will be to attach steel bars to the 3 legs of the EM about 10" long.  Then attach to the steel bars 16 ga 430 ss plates, 3" x 7" in between the 3 bars.  The spacing of the 16 ga plates will be in the area of 1/16" to 1/8".  Will try to get to 1/16" spacing so as to fit as many plates as possible between the steel bars as possible.  All of this will fit inside of a GE house filter housing, 4.5" ID x 10.5" tall.  The bars will come in from the bottom of the housing as well as the DC wiring.  Will use the 068 PWM to pulse 55 amps at 12 VDC, same as the Freddy Cell setup.  Will coat the steel bars with a thin layer of epoxy to protect from the KOH electrolyte.
The GE housing is rated at 120 PSI and will test the cell to 60 PSI.  This is also my test bed for the Freddy cell and the Zach West cell designs.  That GE water fi;ter housingr is 1/2" thick wall clear acrylic so can see the bubble action as it happens.  Will do time tests to fin out how long it takes to get to 60 PSI with pulsed DC vs. pulsed DC + EM.  Will test the HHO gas in balloon float test and pop test.
The idea in this design is to move close to 100% of the EM "magnetic circuit" through the 430 ss plates.  Mookie had a gap of close to 3/8" of an inch between his plates and the EM face, because of the glass wall thickness.  That is a lot of wasted EM magnetic field.  So the idea in this test setup is to use more of that magnetic field.  Will find out if it works.
Mike R.
That's typical ::)
Yep, either way I'd be happier knowing if this worked with the two units not being in physical contact, confirmation of this one way or another would have been helpful. I don't think that even Mookies martenistic stainless steel (400 series I believe) is particularly magnetic, but it may well be enough to react slightly to the powerful EM. However, I do know that the 400 series is not as corrosion resistant as either the 200 or 300 series, which does not make it ideal for elecrtrolyser plates. As far as I'm aware it is the 200 and 300 series ss containing nickel that is non-magnetic. One thing for sure though, once we have current flowing through the electrodes, the magnetic interaction will be significantly stronger.
My first priority will be to determine whether or not the EM is having any direct effect on evolving gases or whether it is just down to the physical oscillations of the cell created by interacting magnetic fields. We know that electron current through the cell electrodes will produce its own magnetic field and so too the ionic current through the water. The magnetic fields produced by these currents will certainly interact with the EM field, which could well mean the direction of current flow is continually affected, but does this bare any relation to what we are seeing... or is it all down to cavitation?
Hi Mike
From what I can tell you will be looking at this from a completely different angle to myself, as I suspect that our personal interpretations of what is occurring differ greatly.  That said, it will be no bad thing to have two completely different experimental set ups on the go. You may have gleaned that - given water is non-magnetic - I'm extremely doubtful as to whether the EM magnetic field is having any direct effect on the water itself.  At this stage I'm more inclined to side with Ohmasa, http://www.youtube.com/watch?v=NUPE0Z9V82E in that it is more likely to be a physical effect created by the mechanics of the set up.
Whereas it seems you will be more closely replicating Mookies set up, I'll be designing experiments specifically to support (or not) my own theories of operation.
I'm planning my first experiment as I write. What I intend to do is step by step experiments whereby I will hopefully be able to conclusively nail down the key reactions and interactions.
At least I can speak my mind here and post freely without the worry of having my posts deleted... or my being banned! ;)
Welcome vrand
If you feel inclined to document your build we can setup a workbench for you to place your build info.
Documenting a build whether successful or not at least allows others to follow on or add to your build.
There are 2 options for a workbench They can be set for public viewing or just OUR members.
Peter
Peter
Must say I didn't realise this, I thought only members could view workbenches! Where and how is this option accessed?
Yes Farrah/Poynt
It would be better for me to post links that don't require "LOGIN"
Please??
Makes me itchy!!
PS
@vrand
Thank you so much for sharing your skills,knowledge, and hardwork!!
This is a real "Thriller"!!
PPS
Mookies work is based on this mans work, a post from
Torana
 »QuoteAnyone reseaching Felix Ehrenhaft....
1845 Luigi Palmieri used his "palmieri circle" to split water using the Earths magnetic field.
Details of his experimental set up have obviously been shelved.
Theres a paper written about him,"The scientific life of Luigi Palmieri" by L Casertano , 1999,Vol 42 No 3.  I tried the URL ,wasnt happening for me.
The book " Electricity" by Robert Ferguson ,1867 makes interesting reading if you can keep up with the Victorian language and conventional current. Takes your thinking pattern back 140 years, before the rules stepped in.
http://books.google.co.nz/books?id=RukDAAAAQAAJ&printsec=frontcover&dq=electrici
**you HAVE TO type in page number 200 to find the section on "Electricity induced by the magnetism of the earth" and Palmieri.
Both Faraday and Palmieri were alive at the time and these theories were accepted. This is before AC took off and all other options dumped, the 1882 edition is suited to AC,its a different book .
Palmieri predicted weather changes from measuring electrical disturbance similar to Subblefield,
His pioneer work lays foundation for alot of 'free energy' research using air core coils.
wiki has a bit of info but not much
http://en.wikipedia.org/wiki/Atmospheric_electricity
http://en.wikipedia.org/wiki/Luigi_Palmieri
« Last Edit: 2010-11-02, 19:25:49 by ramset »
OK Farrah, your bench has been opened for public (i.e. non-member) viewing.
Ok, cheers .99. Thought it might just draw in a few more minds and/or interested parties.
Welcome vrand
Peter
Hi Peter,
Thanks for the info.  As the parts start arriving and I start building I will take photos of the assembly process.  I will let you know when I have enough photos and experimental data so it can be stored on this forum workbench so others can see this experiment.
Mike R.
More on Felix Ehrenhaft [Mookies inspiration] from Torana at OU [today]
http://www.sciforums.com/showthread.php?t=66598
Sorry Can't help myself [need a tranquilizer]
1st posted replication attempt
From I_FLEW_MY_OWN at OU
Re: The downfalls of conventional electrolysis - and how to fix them
« Reply #431 on: Today at 09:31:30 PM »
I_Flew_my_Own Quote
@Ramset,
This ought to tickle you.  I just had a few minutes in the shop to try Mookies idea. I had thought that his method of adding magnetism to the water was very inefficient and indeed maybe it was not the magnetism at all but only the 60hz vibration created by his plates shaking. I dug out an old 3/4 hp. motor core and set it on the bench. Next I found a plastic container that would just push into the hole where the armature used to fit. Of course there was not one piece of stainless in the shop that was attracted to a magnet. Since another theory running through my mind was that eddy currents were shaking the plates I decided to press on anyway. My plates were 316  .032 x 2" by 3.5". I have some polyethylene tube sleeve which is an open diamond weave flexible mesh used to protect expensive machine tools or the threads on the ends of tubing. I used a piece of the mesh to space the plates about 1/16" apart. Just one plate then the mesh then the last plate wedged in the center of the plastic container which was sitting in the center of the motor core. I used 6 volts from a battery charger to the plates. Filtered water and small amount of sodium hydroxide. I used a variac to power the motor core. With the variac at 50 volts a piece of alum or steel held in the core would vibrate at 60 hz. With the plates energized I slowly turn up the variac to full 120 vac. Only the tiny stream of bubbles that you would expect came to the surface. There was no difference with the magnetism or not.  Which is what Mookie said would happen.
Then I stuck a 1"x1"x3" ceramic magnet in the container and the magnet promptly stuck to the motor core. This time there was a difference with the variac on full but not as pronounced as in the video. Next I pulled out the magnet and the plates. Then I stuck a magnet onto each plate. Magnet,plate,mesh,plate,magnet like a sandwich. Back into the water to retest.
 This was the real deal. With partial power the water boiled throughout its volume with millions of tiny bubbles. The surface was instantly covered with a mass of foam. No! I did not attempt to light it. I will later outside with a long flaming stick. The proverbial ten foot pole. My opinion at this early date is that it is just vibration. It is well worth pursuing and I will tomorrow.
Garry
Please view attached a drawing.
I can't access attachments on EF, so can anyone tell me if this is a true depiction of Mookies EM/electrolyser arrangement... or should the E-core EM depictions be swapped around? Thanks.
Farrah
Where is this link[attachment]??
post # Or??
Looked thru every Mookie post, No attachments except one that doesn't work[6761]
Its a photo he posted in his next post
Thats it Farrah, your drawing is good. The outside poles are the same while the inside pole is opposite to the 2 outer legs of the E.   The magnetic field makes a "M" shaped field.
A second big question, particularly after reading about the experiment above by iflewmyown:
With the added electrode vibration and obvious increase in cell "activity", has the cell H2 O2 production rate really increased?
Hopefully these tests will be performed before too many conclusions are drawn.  ;)
Consider one other point:
With an electrolyte added to the water a type of emulsion may be forming, particularly when mixed with the liberated hydrogen and oxygen atoms. Foam forming on the water's surface would be an indication of "impurities", and is often caused in liquids by any form of agitation. The extra cell "activity" may in fact only be the production of small air bubbles before they reach the surface and become the foam.
Surfactants break the surface tension, which in turn allows air to more easily mix with water and creates bubbles. Foam is produced as air is churned into water by turbulent flow or wave action.
Not 100% certain, just an idea.
Keep up the good work ramset!  Take a deep breath :)
We are just getting started :)
Pages: [1] 2 3 4 5
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-12-18, 23:37:45
