Does the same input cap voltage always result in the same PRF ? Yes it does look like it, when inputting 6V i always have a certain PRF, same with 8V, 10V etc., see below picture 2 graph of the Inp Voltage v PRF. Is the transition from the 12V to the 2V regime abrupt ?
Well, this transition was only there with certain earlier transistors AND with a Lower C1 (like 2nF). Now that i am using a C1 of 48nF (to lower the ringing frequency to 30KHz) and the BF871, BF869 and now the KT805AM transistors, i get longer runtimes and do not have this transition, they have the ringing signal all the way to the end. Below picture 1 shows the PRF and Input Cap Voltage versus runtime (14 minutes). I have 48nF as C1, the 3 Germanium diodes, the KT805AM transistor and a 600nF cap as L1 to ground cap. Itsu
« Last Edit: 2021-09-26, 10:36:27 by Itsu »
