2026-08-15, 09:56:54
Pages: 1 ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20]
Author Topic: STEAP and the TPU  (Read 179286 times)
What is the orientation of the windings in this coil ?
If they are in the classical axial orientation then the compass is incorrectly oriented inside the coil to rotate optimally.
Do you know that your Rigol signal generator can be upgraded to 200MHz for free ?
Yes, I know you can have 200MHz, but it is still under warranty.
The compass test is not exactly the same but it shows a rotation relationship at 7Hz which is interesting. However, this is not proof that SM did it this way. My coil has coils 2x1300 turns. I only use one winding.
I will change the compass orientation as you suggest.
You will need it if you drive an inductive load with a square wave without a buffer or a clamp.
The firmware change is reversible and undetectable.
That is the way to go O0, but I needed a person who would understand how it works, so they have a learning curve to go through. That is about to change very soon.
Mike, here's a proposal.
1 you open a GoFundMe site, maybe "buy me a coffee" and/or a PayPal account. Or perhaps all and more.
2 Publicly ask for a 100-dollar contribution for every successful TPU replication.
3 You show us how to build it as if you were a teacher in a school. and we were the students.
Most of us will think it's well worth it.
If it goes global then we can shame Elon Musk and others who will undoubtedly benefit:  to pay you.
Most probably won't pay, but a high percentage will.
This is using Kapanadze's law to everyone's advantage.
Everyone wins including the inventor...
Think about it, Mike.
This is a forum of "research" I am not selling anything, though my 5 children and 9 grand children may not agree with years of work for nothing!!
I have one person I have been leading through the whole system by placing the ideas in front of him, without drawing an exact schematic and writing pages of instructions.
This system of "energy generation", because in principle it is a linear generator, was found by accident, SM and his audio room expansion system.
These are the things to research:-
Audio effects and how they are produced, especially echo and reverberation.
Audio amplifiers, A, AB, C, D etc
Passive effects and not electronic
Passive delay lines
DC to DC boost converters
Induction heaters
Carriers and modulation there of. This last one is extreamly important.
Eddy currents, induction and effects there of
Closed loop infinite currents
« Last Edit: 2024-05-31, 20:30:56 by Centraflow »
This video by Peter Lindemann covers electric motor secrets and touches upon DC-to-DC converters.
Also, those of you who had the schoolgirl motor running for months without additional power will have a trip down memory lane.
  The video has only just been put up on YouTube.
https://www.youtube.com/watch?v=kZYwU4coxT4
Hey Mike
I have a question about the wire diameter and type of wire your using for the toroid coils.
Is it large twisted multi strand or solid core?. If my working theory for this kind of device is correct solid core should not work or not nearly as well.
Freie Energie für alle
14awg
AC, Toni is correct, but it can be also 16awg, all depends on the current you are going to put through it.
Steap has near infinite current, all depends on the load impedance. If you induce a current into a shorted coil the current will be infinite, it will also refect back into any other coils inductively connected ;)
If you take the upper mid range audio frequency(6th octave) you will have 5.12kHz, X 3.2 will give you 16.384kHz,  divide this by 2.1 it will give you 7.8kHz, 1000 times the earths resonant frequency!!! 16.384kHz is half the clock frequency of 32.768kHz, STEAP needs 2 frequencies of 16.384kHz 180º out of phase, and a modulation frequency of 5.12kHz (audio test frequencies 4-6kHz enhanced room sound range).
As SM said, "so many stories to tell".
The range of human hearing is divided into eleven octave bands, each band having double the frequency span of the previous band. These are called the 1/1 octave bands. The human ear can hear a maximum of 10 octaves: 20-40Hz, 40-80 Hz, 80-160 Hz, 160-320 Hz, 320-640 Hz, 640 Hz to 1.28 KHz, 1.28-2.56 KHz, 2.56-5.12 KHz, 5.12-10.24 KHz, and 10.24 KHz up to the upper edge of the human ability to hear. The next octave would start at 20.48 KHz, which is barely above the high threshold of human hearing.
Years of investigation and experimenting.
Centraflow
Steap has near infinite current, all depends on the load impedance. If you induce a current into a shorted coil the current will be infinite, it will also reflect back into any other coils inductively connected
A shorted coil, sneaky and it makes sense in the context were talking about. In fact it's kind of brilliant and electrical isolation is always an issue with these kinds of systems. Thanks, that's a really good idea.
I was wrong about the wire and forgot your using two stacked toroid elements where I was thinking about one.
Centraflow
Can be one, only stacked to make a smaller footprint. The big one of SM with 2 cmcs was two units stacked to give more power.
The TV unit was a single unit in two halfs and stacked.
As long as the coils are connected correctly, both work.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 09:56:54
