2026-08-15, 04:11:40
Pages: 1 ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21]
Author Topic: Grenade coil type systems  (Read 138833 times)
PW, verpies,
The fields are not homogenous, as far as i can see as moving the probe from OD to ID shows many fluctuations.
Also measuring a single magnet across its surface shows many different readings.
Another problem is the positioning of the probe when probing inside the gap as we have many "degrees of freedom" to control.
This picture shows me having the probe in what i call the 0° position:
Let me double-check on this as i am sure i found a 0mT spot with the probe in 0° position while running 8A through the coil.
What is the stack sequence of the sausage in this image (i.e., left to right, magnet, ferrite, ferrite, etc).  Also please provide the approx. thickness and diameter of each (ferrite/magnet).
PW
Also, please provide the dimensions of the copper coil (not including the plastic former).
Where is the copper foil located?
PW
if you only had magnets at one end of the sausage, the following might prove interesting:
Step 1:  Measure the surface field of the magnet side of the gap with the coil deactivated.  Place the probe's measurement face directly against the surface of that pole piece.  Note the reading.
Step 2:  Remove the magnets from the sausage.  Position the probe to make a surface field measurement of the pole piece on the DC coil side of the gap.  As above, place the probe's measurement face directly against the surface of that pole piece. (pick a location that is directly opposite from where you made the step one measurement).  Ramp up the coil current and see if you can attain the same (or greater) field strength as measured in step one.  Note the amp draw.
You will have to decide if removing the magnet is too much hassle.  You'll likely need a spacer to replace the magnets' width in the stack.  Use another ferrite if you have one or just a plastic spacer if you don't.
If there are magnets at both ends of the sausage, it might take a bit more thought on how to do this.  Perhaps Verpies can offer a suggestion.
I was just wondering how much surface flux your DC coil and ferrite cores can achieve without the magnets involved...
PW
PW
PW, verpies,
for details on my device see here:
Data left to right;
2 stacked ringmagnets each 57 x 21 x 13mm (OD ID H),    Soft core (underneath the coil) 50.5 x 25 x 28.5mm (OD ID H),   Soft core 50.5 x 25 x 28.5mm (OD ID H),   2 stacked ringmagnets each 57 x 21 x 13mm (OD ID H)
Coil data:
coil former OD 53mm
Coil width 27mm
coil thickness 11mm
530 turns 0.8mm magnet wire
88m length
3.5 Ohm
No copper foil is present.
With all 4 ringmagnets stacked together on the right side of the device i measure 180mT at the surface (OD) of these magnets in the gap, but 170mT when moving a few mm inside the gap to match the OD of the soft core.
See also this earlier measurement here:  https://www.overunityresearch.com/index.php?topic=4515.msg108422#msg108422
With the 4 magnets removed and measuring the flux on the surface of the 2nd core at the OD in the gap i measure 115mT (max.) at 7.6A current (max).
That would be in the Staaar Yoke device. They also used an aluminum foil in it for the orthogonal winding.
Itsu's Grenade device does not have a copper foil in it nor the orthogonal winding.
When you make your surface field measurements, do so on the "face" of the pole pieces, not on the OD.
Perhaps consider removing the two magnets on the coil end of the sausage to see if this will allow you to null the field with the DC coil (with the probe measurement axis parallel to the sausage axis, which I believe you call the 90 degree measurement for some reason...).
Although having only the two magnets on the opposing end will likely not meet Verpies' field strength versus diameter requirement, it might allow further study of the field conditions in the gap when the field is nulled with the DC coil.
Perhaps Verpies can provide more guidance regarding this...
PW
I am probably not expressing myself clearly enough, sorry for that, but i did make my latest measurements on the "face" of the pole pieces.
But as the strongest readings are at the outside of the core / magnets, i referred to this outside as OD, so here a picture of where i measured the above readings:
Concerning: "the probe measurement axis parallel to the sausage axis, which I believe you call the 90 degree measurement for some reason...", i from now on will call that the 0° position.
I will do some experiments with fewer magnets to see if i somehow can "null the field with the DC coil".
I removed the left 2 stacked magnets leaving only the right 2 stacked magnets.
Measuring with the probe in the middle of the gap halfway the OD / ID of the soft core in the (new) 0° position, see picture, where the coil is DEACTIVATED (136mT).
When activating the coil at max 8A, the reading is reduced to 70mT:
Then i removed one of the 2 right stacked magnets, leaving only one (the weakest).
Measuring with the probe in the middle of the gap halfway the OD / ID of the soft core in the (new) 0° position, see picture, where the coil is DEACTIVATED (75mT).
When activating the coil at max 8A, the reading is reduced to 11mT:
So nearly there (0mT), so looking for an even weaker ring magnet............
While nulled as best you can, can you move the probe around a bit to find something closer to zero?  Start out with just some slight twists of the probe to the left or right to see if it will null.
PW
I found a weaker speaker magnet which i put in as the only magnet,
Same setup as before, measuring 60mT with the coil deactivated, see picture:
Around 6A through the coil the meter reads 0mT.
Seen the above update from PW, i will see what i can do as there is little time to adjust the probe before the coil heats up too much and i need my both hands to manage the movements of the coil and magnet when energized
Forget my last post...
Now that you can null the field, measure the radial field (what we are now calling the 90 degree reading with the measurement axis perpendicular to the sausage axis) with and without the DC coil activated with the current necessary to achieve the 0 degree null.
PW.
PW,
it depends on what position (height) the probe needs to be.
When at the same height as previous done (halfway the OD / ID of the core) i can set the reading to 0mT with deactivated coil and this will stay low (max 8mT) when activating the coil with 6A.
But when increasing the probe height to be higher than the OD of the core (5mm) then we have a reading of 25mT with deactivated coil and 57mT with 6A through the coil.
For this latter position see this picture:
Its bin a while since your last post.
Is the subject still an active bench topic or is it already put to bed?
Maybe you or Verpies could give a short conclusion where this has ended or should proceed from?
Best regards,
Ape
Hi Ape,
well its kind of shelved for the time being, other things have come in between for now, so who knows if it will be followed up or not.
Hi Itsu as I understand it the grenade device captures the magnetic wave that’s transmitted from the none standard Tesla coil (re Don Smith's) vids on the net, I was wondering as this is a 90deg phase shift wave if you had done any tests on your recovery device or have any information you could share.
I hope asking you is ok as i am really interested is solving some of the mystery’s of this device.
Please feel free to PM me. Sil
Hi Ape,
I understand.its also a very specific topic.
Let me try to activate in general the Ruslan topic..
I can recall long ago with T1000 to have a test in order to charge a cap/ plate/ grenade by a kacher setup.
I didn't succeed also I' m not aware if somebody has done it succesfully.
In other words, charging an object with longitudinal waves.
We all know ionizing something can not be done with a sinewave as the average charge from a sinewave cycle is always zero.
Now there has been circulating some vids that a unipolair wave is generated from a kacher setup in a slight different setting.
So again if T1000 can remember what I'm talking about it hopefully gets some attraction here.
Hi Mr Ape I'm not sure where your going with this, But if your talking about an ac fed cap / inductance (tank coil) then it's a tuned circuit, but put a diode in circuit and it's a different matter, are we talking about Hertzian waves or scalar or acoustic waves audio stuff? Hertzian is 2 dimensional (it only has losses) wile scalar is 3 dimensional and doesn’t have losses and it’s not a wave.
But in saying that a lot of BS has been said and other stuff un said.
So tell me what are you trying to do I might be able to help?
PS where has your PM service gone ?
Apecore; picture this idea suppose we have a simple Tesla coil
with a 100mm wave length with the energy spinning round it's length,
now suppose we split that wave length into 4 parts
and separated with nodes, now we wind another coil with two
layers and wind it to the same wave length so the node wave
length sits in the same wave length but folded over in the middle
so it produces canceling waves. Now perhaps all we have to do is
sync the both coils so they are at the same place at the same time
but apparently one is 3 times the speed as the other.
Longitudinal charging the grenade adding/ mixing current
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 04:11:40
