2026-08-15, 03:16:10
Pages: [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... 38
Author Topic: Don Smith Akula, Ruslan, Stalker, device discussion and replications.  (Read 186525 times)
Don Smith, Ruslan, Stalker, device discussion and replications.
Before we start All links to Roman ‘Karnaukhov's’ type devices, references can be found here.
 Dally, Shark & Ruslan workbench other unclarified links are unsorted and contain  a excess amount of ‘Crud’. Here.
 None technical & none related posts
Rules of Thread. ‘By using this thread you agree to The rules’.
This is a reference Thread, Trolling won’t be tolerated.
Be aware unrelated, abusive, none related, or MIXES wont be tolerated and will be removed to the ‘Removed Posts’ thread and locked.
« Last Edit: 2023-06-21, 13:25:16 by AlienGrey »
« Last Edit: 2021-12-18, 17:18:59 by Vasik041 »
Burst pulse pic I think this is how it's supposed to look.
https://www.youtube.com/watch?v=lNF1WBYNJA8
https://www.youtube.com/watch?v=zWIQXbocnwY
   Vasik:  Seam like he's got the signals right, but I don't really see any additional light from his bulb. Am I missing something?
Remember that I mentioned that unless 300 to 500w loads are used on the output, you won't be able to tell if there is really any interaction, or gain.
Or if it's just the addition gain from the addition of the Kacher signal, but with no OU to be found. Nor does he show it self running, without the batteries.
Nick found this will interest you! https://www.youtube.com/watch?v=tqFFdvheW1U
    AG:
    Yes, that is interesting, if true. But, he does not show it running WITHOUT a power supply, nor batteries, so I still am not very convinced from that short video, as yet. And, All they are selling are the schematics, but NO device. Why is that? Maybe, because it does not self run? And they want to just make some money on a false schematic?
   I don't have enough 12v batteries to test to see if instead of the feed back loop going to a PS, it should maybe go to two 12v batteries, instead.
And to have no PS on the feed back loop. In any case their $50 schematic, is not much to risk. And perhaps it works, who knows...
   At least that video is new, instead of watching videos that are now several years old, with no improvements or follow ups, to date. And all the inventors have vanished, never to be heard from again.
  It's hard to get excited over a video when there are nothing but fakes and scams going on, in the internet.
You might want to read this file in Google Chrome.
Во-первых я тебе ничего не должен , это раз ! Во вторых ...если у людей руки не от туда растут ,это проблема их. Я рассказал как это делается и показал !!! А насчёт судов и так далее ... Я даже не парюсь ! За меня всё сделают юристы . Я верну свой генератор и запущу его как два пальца .....! Теперь ещё один момент... Ты сейчас тут написал что не собирал ?! Так ? Значит ты ждёшь готовенькое ? Понимаешь ... Пока ты сам не начнёшь соображать и что-то делать,никто тебе ничего тут не даст. Нет таких людей ! Говорю же , займись делом , а не сиди тут и сплетни не слушай. Будет не легко ,но хочу тебя заверить что системы работают на все 10 000 %
Я расписал все подсказки уже много раз. Не думайте что произойдёт чудо и Вы так легко всё сделаете. Никто просто так от балды ничего не даст. думать головой нужно самим. Я работаю уже с 2013 года , при этом подрываю здоровье своё и кучу денег иногда в трубу . Рискую многим .... Вам этого не понять ! При этом я рассказываю и навожу на мысли. Но почему то никто не прислушивается , а всё время орёт : " Дай схему, дай Схему ..." А самое смешное что в это дело лезут люди ,не имеющие никакого отношения к электронике и радиолюбительству .... Агрономы разные, врачи .... Покупающие осциллографы и детали не зная даже применения им... !
А с чего вы взяли что это бифеляр резонирует ?  Запомните раз и навсегда !!!  Высокочастотный трансформатор не может быть многослойным . Ибо первый слой передающий, а второй принимающий. Или наоборот !  Это раз... !  2 . Попробуйте ко намотать двойную Теслу и запустить ...  будет работать ? НЕТ !!!   Эффект стоячей волны может быть только в длинном проводнике , или смотанном в катушку виток к витку . Я уже рассказывал про то как Тесла  сравнивал воду с электричеством. На водяной глади нельзя создать ещё одну.... Тут тоже самое !   Значит биф мотается поверх , а снизу Тесла    Дальше соображайте !
Какие нахрен рыбки ? Вы всё в осциллограф пялитесь ? Зачем ? Забейте на все эти показания приборов.Используй осциллограф только для проверки частоты и импульсов...Т.е. их наличие в схеме. остальное замерять не надо . 2. Где по вашему холодный конец Бифа ? Что за фигня ? Биф мотается для того чтобы один слой работал как трансформация, а другой как фильтр ! Трансформатор на воздухе не может быть многослойным... Иначе он просто не будет работать как полагается. Я это уже сказал не раз...Но почему то вы не можете связать мои объяснения по каждому элементу отдельно ?! Куда вы все спешите то ? Ещё раз говорю что в этой системе всё похоже на обычный генератор . Но усилие толкания тока(магнитного поля) в катушке для наведения ЭДС делает ТЕСЛА ток и стоячая волна. Допустим стоят две Теслы .. Приём-передача ... В системе можно обойтись и одной этой катушкой. Но тогда надо делать по системе Капанадзе ! То есть загнать в резонанс стоячей волны . А это тупо подбирать конденсаторы для разрядника. Не очень эффективно и удобно. будет всё гулять и выходное напряжение тоже. Потому лучше использовать Теслу для наведения высоковольтного напряжения + частота приёмной Теслы что находиться под вашей катушкой. Просто если вы Акулу пытаетесь повторить...То там он хитро спрятал эту Теслу и я когда искал как создать эту волну в первом слое Бифа , замучился до жути. Система конечно работала ,но геморройно и не стабильно . На самом деле на выходе у Акулиной установки 100 Гц и 209 вольт было Моя последняя разработка на катушке зажигания тоже работала по тому же принципу. Катушка давала импульс с частотой следования 50 Гц . Потому там на выходе чистые 50 Гц и 230 вольт . Так как именно управляя Теслой вы получаете раскачку тока наводя ЭДС , другими словами крутите магнитное поле в катушке или вибрация туда сюда с частотой 50 Гц .... Помните слова Капанадзе ? Когда вы поймёте что это так просто , вы будите смеяться ... Делайте выводы
Чую что начинаете понимать ! Но ! именно нижняя обмотка и есть резонатор стоячей волны !!! Но это не приходящая обмотка , а Тесла . Всё что на неё подают ...Типа Дали и остальные... Это возможно ! Например 25 ватт Акула в Германии . Точно такое же чудо делал и я для штатов и у Лорда на канале есть этот девайс. Он в Америке и там его запускали сами американцы. Но у меня там получилось снять 40 ватт и даже чуть больше. Но есть минус .... Тесла там при перевозке изнасилована компанией по перевозке (швырянию посылок) В общем не важно .... Капанадзе говорил про то что это всё доступно каждому и патенты весят в нете в свободном скачивании. Там же есть и ротовертр (Динамо-машина) Тоже кстати одна из этой оперы....
Так ребята !   Я скажу Вам всем проще. Если вы хотите что либо собрать ,не гонитесь за мощностями. А значит накачка годиться простая без резонанса. Тупа магнитное переменное поле ! Далее ...Расположите катушки так чтобы одна катушка своими полем не складывалась с другой. То есть сдвинуто надо сделать. Иначе ОЭДС будет мешать !  Теперь вспоминаем Теслу и когда подносим к ней лист подключенный через лампочку на землю... Что мы наблюдаем ? Ответ правильный !  Лампочка светиться    Этот ток вам и нужен !  Теперь наводя этим всем на вашу катушку ,конец которой заземлён ... Вы делаете магнитное поле продольное(толкающее ) и поперечное ,создающее поток движения !  Я же говорил что генератор БТГ работает как обычный генератор . Значит Тесла толкает ток или другими словами продольным полем сталкивает или переносит магнитное поле отрывая его от накачки. ОЭДС нет !  Ничего не мешает и сопротивления тоже нет !  Как у нас по классике ? Токи по бокам катушки ?!  Воот ! Бока то не совпадают
А теперь сделайте управляемую Теслу ! То есть прерывайте толкание тока с частотой ниже накачки. Это и есть движение тока !!!  Ну догадайтесь же уже наконец блин....
Сколько можно говорить то ?
Не могу сказать про алюминий ничего. Не пробовал !  Нужно настроить в резонанс Теслу и приём ...Чтобы появился ток . Гранаты мотать не надо. Всё равно не знаете зачем и что они делают. Тупа мотаешь один слой длинный ,другой чуть короче. Всё одним проводом. Длинная катушка накачивает магнитное поле , короткая снимает. если не хватает напряжения , докинь с преобразователя. Но выход должен быть отфильтрован по ВЧ. Иначе твой резонанс уплывёт
Лучше найди ферриты 2000НМ . И сооруди как СР делал. Намного лучше будет для начала и понимания процессов. Напоминаю что работает электромагнитная стоячая волна !!!  Из-за сложения волн мы получаем увеличение магнитного поля , а там и его действие !   Антенна же тоже может усиливать ?  Моя тема - передачи в эфир. Я собирал не мало передатчиков и антенн. К сожалению самодельные конструкции этого всего нельзя использовать в современном радиовещании,но знаю я про это всё. Можно поставить хорошую антенную систему и не жечь электричество  на киловатты в фидер. Тут в генераторах что то подобное ...!"
https://www.youtube.com/watch?v=9BUuuCLbYs4
The Ruslan comments are from this clip posts..
First of all, I don't owe you anything, this time!  Secondly ... if people's hands do not grow from there, this is their problem.  I told you how to do it and showed it !!!  And about ships and so on ... I'm not even worried!  Lawyers will do everything for me.  I'll get my generator back and run it like two fingers .....!  Now one more thing ... You just wrote here that you did not collect ?!  So ?  So you are waiting for the ready-made?  You see ... Until you yourself begin to think and do something, no one will give you anything here.  There are no such people!  I say, get down to business, and do not sit here and do not listen to gossip.  It will not be easy, but I want to assure you that the systems work at all 10,000%
 I have covered all the tips many times already.  Do not think that a miracle will happen and you will do everything so easily.  Nobody will give anything from the bulldozer just like that.  you need to think with your head yourself.  I have been working since 2013, while undermining my health and sometimes a lot of money down the drain.  I'm risking a lot .... You can't understand this!  At the same time, I tell and bring to thoughts.  But for some reason no one listens, and all the time yells: "Give me a diagram, give me a diagram ..." And the funny thing is that people who have nothing to do with electronics and radio amateurs are getting into this business ...  .. Buying oscilloscopes and parts without even knowing their application ...!
 And where did you get the idea that this bifelar resonates?  Remember once and for all !!!  A high frequency transformer cannot be multi-layer.  For the first layer is transmitting, and the second is receiving.  Or vice versa !  This time ...!  2.  Try to coil a double Tesla and run ... will it work?  NO !!!  The standing wave effect can only be in a long conductor, or wound into a coil turn to turn.  I have already talked about how Tesla compared water to electricity.  You cannot create another one on the surface of the water .... It's the same here!  So the beef is dangling on top, and Tesla from below. Think further!
 What the fuck are fish?  Are you all staring at the oscilloscope?  What for ?  Just use the oscilloscope to check the frequency and impulses ...  their presence in the scheme.  the rest does not need to be measured.  2. Where do you think is the cold end of Biff?  What the hell is this?  The beef is wound so that one layer works as a transformation, and the other as a filter!  A transformer in air cannot be multi-layered ... Otherwise, it simply will not work as expected.  I have already said this more than once ... But why can't you link my explanations for each element separately ?!  Where are you all in a hurry then?  Once again I say that in this system everything looks like a regular generator.  But the effort of pushing the current (magnetic field) in the coil for induction of the EMF is made by TESLA current and a standing wave.  Let's say there are two Teslas .. Reception-transmission ... In the system, you can do with this one coil.  But then you have to do it according to the Kapanadze system!  That is, drive a standing wave into resonance.  And it is stupid to select capacitors for a spark gap.  Not very efficient or convenient.  everything will walk and the output voltage too.  Therefore, it is better to use Tesla to induce high voltage + the frequency of the receiving Tesla that is under your coil.  It's just that if you are trying to repeat the Shark ... Then there he cleverly hid this Tesla, and when I was looking for how to create this wave in the first layer of Biff, I was terribly tortured.  The system certainly worked, but hemorrhoids and not stable.  In fact, the output of the Akulina's setup was 100 Hz and 209 volts. My latest development on the ignition coil also worked on the same principle.  The coil gave a pulse with a repetition rate of 50 Hz.  Therefore, there are pure 50 Hz and 230volts at the output.  Since it is by controlling Tesla that you get a buildup of current by inducing an EMF,
By using Tesla, you get a surge of current by inducing an EMF, in other words, twist the magnetic field in the coil or vibration back and forth with a frequency of 50 Hz .... Do you remember the words of Kapanadze?  When you understand that it is so simple, you will laugh ... Draw conclusions
I feel that you are beginning to understand!  But !  it is the lower winding that is the standing wave resonator !!!  But this is not an incoming winding, but Tesla.  Everything that is served on her ... Like Dali and the rest ... It's possible!  For example a 25 watt Shark in Germany.  I did exactly the same miracle for the states and the Lord on the channel has this device.  It is in America and there it was launched by the Americans themselves.  But I managed to remove 40 watts there and even a little more.  But there is a minus .... Tesla was raped there during transportation by a company for transportation (throwing parcels) In general, it does not matter .... Kapanadze said that all this is available to everyone and patents weigh in the net in free download.  There is also a rotovertr (Dynamo-machine) Also, by the way, one of this opera ...
 So guys!  I'll tell you all in a simpler way.  If you want to collect something, don't chase power.  This means that the pumping is suitable for a simple one without resonance.  The magnetic alternating field is stupid!  Next ... Arrange the coils so that one coil does not fold over the other with its fields.  That is, it must be done shifted.  Otherwise, the OEDS will interfere!  Now we remember Tesla and when we bring a leaf to it connected through a light bulb to the ground ... What do we observe?  The answer is correct!  The light is on. This is the current you need!  Now, directing all this to your coil, the end of which is grounded ... You make a longitudinal (pushing) and transverse magnetic field, creating a flow of motion!  I told you that the BTG generator works like a normal generator.  This means Tesla pushes the current or, in other words, collides or transfers the magnetic field with a longitudinal field, detaching it from the pumping.  OEDS no!  Nothing interferes and there is no resistance either!  How is our classics?  Currents on the sides of the coil ?!  Whoa!  The sides do not match
 Now make a controlled Tesla!  That is, interrupt the pushing current at a frequency below pumping.  This is the movement of the current !!!  Well, guess what, damn it finally ...
 How long can you say that?
 I can't say anything about aluminum.  Have not tried it!  It is necessary to tune Tesla and the reception into resonance ... For a current to appear.  There is no need to wind grenades.  You still don't know why and what they are doing.  Stupid you wind one long layer, the other a little shorter.  All with one wire.  The long coil pumps up the magnetic field, the short one removes.  if there is not enough voltage, drop it off the converter.  But the output must be RF filtered.  Otherwise your resonance will float away
 Better find ferrites 2000NM.  And build as the SR did.  It will be much better to start and understand the processes.  I remind you that the electromagnetic standing wave is working !!!  Due to the addition of the waves, we get an increase in the magnetic field, and then its effect!  Can the antenna also amplify?  My topic is broadcasts.  I collected quite a few transmitters and antennas.  Unfortunately, homemade constructions of all this cannot be used in modern radio broadcasting, but I know all about it.  You can put a good antenna system and not burn electricity per kilowatts into the feeder.  There is something like that in the generators ...! "
« Last Edit: 2021-12-30, 09:53:44 by Maxolous »
Here is an old posting from Vasik41
Does did any one make this device ? Do you have a scope shot from the output device of the circuit shown ?
Many thank Sil
   BTW...
  Did you manage to scare off F6???
  I miss him already...
Well Tell me your exact DOB  ;D
   Well, I can tell you that he's back...
   Well, he was back... did you scare him off again?
« Last Edit: 2023-05-23, 17:11:39 by NickZ »
1/. Do you think  Tesla got a helping hand from Fleming ? Work that one out.
2/.The high voltage is used to loosen the the particles we want to excelorate, and the higher frequency increases the efficiency.
   AG:  Well, the idea is that the HV, HF from the Kacher circuit, is meant to interrupt the induction circuit's pulse. Not to "loosen" particles. Not to add anything to the system, but to interrupt the push pull's signal, and excite the surrounding ambient, thereby.
There is much more to it, than that, but I will continue this discussion on my new bench to discuss these things more in depth.
   However, to me the effect of cutting off or interrupting the induction circuit pulse, works the same as pinching a hose, and quickly letting it go. A higher pressure will result, in both cases. As an increase in pressure (or voltage in our case), is what we are looking for.
In any case that is how I see it, and is what I am aiming for.
« Last Edit: 2023-05-24, 17:58:01 by NickZ »
The high voltage from kacher is to create environment for the acceleration of electrons in the removable coil( grenade coil) . Hence the hissing sound you here in working device.
It will appear that the voltage stepped up, it's actually adding current. The push pull does not have enough power to sustain the system, but when current is added.
2/.The high voltage is used to loosen the the particles we want to accelerate, and the higher frequency increases the efficiency.
In one of the Smith video talks (over the phone)  he talks about
the Tesla coil being like Saturn and its rings and switching to using magnetics 'Fleming’s right hand rule or left hand rule depending
on where you are in the world, I tried winding two coils at 90 deg angle but didn’t get very much but real Tesla coils work fine like that
but with no ferrite it's difficult to separate the magnetics from electron flow, notice voltage and current are 90 deg phase shift.
I just thought it was best for you to see what was going on.
perhaps as you chatted to Vasic see what he thinks
Me when ever i have got involved it hasn't been too good !
Max  Apcore at the risk of backlash else where I recently  got my old test rig out  and blew up one of the old
IGBT's up in the output (so-much for protection circuit) and replaced both with IRFP150's.
I have loaded the 5 turn current winding with a 10W 12V filament bulb and the 38 turn winding with
240 V led bulb. that is fitted with HS bridge rect large electrolytic cap.
On switch on i get a dim glow on the quarts tube and nothing on the 240 V Led but slowly
they both get brighter and brighter until they reach a very bright maximum, but the .9 Amp current
doesn't change. I have no earth and no grenade fitted at this time. O0
PS What Nick says about me building stuff.   ;D
« Last Edit: 2023-06-10, 14:35:02 by AlienGrey »
AG,
Nick locked me out from is moderated thread because I don't agree with is  belief that the device doesn't need standing wave. Poor Nickz. I guess he doesn't know what he is saying. He is just in search of simple things to get his device working.
Nikola Tesla wrote about standing waves and their importance in electrical engineering in his paper titled "On Light and Other High Frequency Phenomena" published in 1893. He is the originator of all these.
I wonder what Nickz is thinking anyway. He doesn't like complex things. Geofusion that he is emulating had done much research beyond a simple kacher and grenade coil. Geo was the first I saw talked about interruptor circuit when I picked interest in this device.
Some persons are here deceiving themselves.
Unfortunately  a certain person has locked guys out of a similar thread, I feel we must keep this tread open with your help.
AG,
Hi Max,
I also can't acces the thread.
When nick doesn't change his own attitude no one will post something again at his most important thread.
But I think he is capable enough to get his decor piece in selfrunning mode.
I wish him all the best.
Ape
So lets talk standingwaves.
The goal is to get the standing wave in resonance..
In my opinion a standing wave only occurs when at minimum a 1/4 wave fits the wirelength. (1/2, 3/4, snd so one)
Without this wirelength/ frequency match no standing wave occurs.
Trick is to tune the coil so this frequency becomes its resonance frequency also
Hi Max,
Ape
Apecore
Nice to hear from you. I don't know what's wrong with Nickz. He never want to make any alterations on his device . He doesn't agree with others opinion. To him his build is the best. I believe it has become his shrine..
Oh yes,
Wavelength to match Natural frequency is a good way to go in this device. If resonance is achieved in the natural frequency is an added advantage.
Apecore
Oh yes,
So do we agree when we have double resonance in a grenade it benefits?
I have a US patent describing this.. it is layed out for pancake coils but in general its fits in every coil config.
   Ok guys: Your responses are getting very sick. I have done nothing of the sort to remove any one of you,  at all.
Instead, I have been waiting patiently for any of you to show something that you are working on, and to quit insulting me. So, now I can see your true colors, concerning what you think of me.
  I removed AG's last post, yes, after I asked him to be polite, he just keeps on with his insult, same with Max, and now even apecore.
All this over some waves that you feel are  important, but  have not shown anything to proof your point, at all.
So, now you want me to change MY attitude, or else. Well that is not going to work, and as none of you are into building anything, you just waste my time with these stupid accusations.
 I will sensor anyone that post insulting comments, that is why I started this moderated thread, to be able to control these types of posts. No one is forcing you to do anything, but I will not put up with your insults here.
Mote from Sil  Tread admin
Please stop trolling and disrupting this tread. You keep disrupting your own thread by deleting others related posts.
« Last Edit: 2023-09-30, 10:19:25 by AlienGrey »
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 03:16:10
