Kapanadze replication
Started by DELAMORTO, 2023.09.18, 10:04:25
0 Members and 22 Guests are viewing this topic.
DELAMORTO
What I understand is that a high-voltage, high-frequency source with adjustable frequency is needed. Current response depends on frequency. Frequencies are 100 kHz and higher. A metal mass (copper tube) is attached to the hot end, accumulating potential. When a low-frequency transformer is connected, an arc with a high-frequency burst occurs, starting at an amplitude of 220 volts. This is called automatic resonance; current is generated at the peak of the amplitude.
Setting up the current is simple: we hang the current clamp on the ground wire and change the frequency of the high-voltage generator to the desired current value.
The circuit is divided into a high-frequency current section and a low-frequency amplitude section. To keep the high-frequency current in its own circuit, it is shorted by a capacitor, which acts as a short-circuit at high frequencies—very low resistance—but for low-frequency amplitude, it acts as no resistance, as my previous experiments have proven.
Listen carefully to the YouTube recording and analyze every word of Giya.
DELAMORTO
Briefly, the conversation between Kapanadze's assistant and Kornei revolves around a ground wire that sparks, and his electronic device shows different currents on it. The pointer device doesn't show any current, so he considers it interference. To which Giya replies, "No, the device shows current correctly! What frequency are you using?" Kornei, unaware, says it's just sparking, that's all. Giya says yes, that's how current is generated in Kapanadze's setup, but he doesn't know how it's used; only Kapanadze knows.
Giya tries to find out how close Kornei is to replication, what he has, and how it's done. Then, having confirmed that he's still far away, she moves the conversation to other topics.
I'll also note that what was mentioned in the conversation was that the high-frequency generator operates not directly from the primary power source, but from a charged capacitor! Kapanadze was so worried about the current flowing into the primary source that he severed the power supply to the high-frequency, high-voltage generator.
andyw33
Thank you Delamorto for your insight and conversation description. The english translation of the video was little bit weird .
I am thinking about the principles and I have also some theory about moving charges in the ground connection. But I'm still at the theoretical level.
A.
DELAMORTO
Kapanadze also talked about the Smith board - you can't get more than 50 kilowatts from it... Well, why not use the Smith principle to create high-frequency current?
DELAMORTO
Everything is as usual with Tesla.
Shocks are created in the inductor, which create high-frequency oscillations in the current circuit. These oscillations should not decay, since this is our high-frequency current. And then, as I showed, the current is modulated to industrial frequency and amplitude. The chokes will protect the transformer from impulse interference from the spark generator
andyw33
Delamorto, Thanks for images
Do I read the scheme correctly?
a) part #1 is feeding the oscillator
b) part #2 is the high frequency oscillator - "operates not directly from the primary power source, but from a charged capacitor".
c) part #3 is the current circuit with "high-frequency oscillations"
A.
andyw33
@Delamorto, do you think that the spark gap is mandatory here?
A.
  Hey guys, I'm back...
And still with the same interests in finding and replicating a real free energy device, or devices.
  There was some conflict before I left a few years ago, but I see that it is fairly quiet here now. So, here we go again.
  Concerning the question about the spark gap. If there was none, the circuit would not work as planned, or not at all. So, yes a SG is a must have, there.
  Guys, I wanted to mention about the inventor of a free energy self running car, motorcycle, home back up power system, etc. His name is Maxwell Chikumbutso, and I'll send a link to his devices, in my next post. HE has been undercover for the last couple of years, due to being poisoned in the US, as well as his partner being poisoned to death. Still, his idea of tapping into "radio waves" may be worth looking into. As that is what I've always been interested in, the NO FUEL solid state devices, like what Max, Tariel, Akula, and several others have come up with and shown running.
  I also want to greet some of my old friends in the field, such as Itsu, Verpies, apecore, and several others who have helped me out through out the years.
And also make an apology to anyone that I may have offended in the past. As that has never been my intention.
  There is still much to learn here, after all these years. And, I'm back...
  Nick Zec,  NickZ
Verpies
Welcome back Nick !
Are you still tracking this guy ?:
Quote from: NickZ on 2023.10.19, 16:49:40This is another video by Andrey245 on YT, showing where to place the HV pulse, to obtain the highest output from the PP circuit.
  He has many videos, of his tests and trials, if any one is interested.
  https://youtu.be/EIS7xES9trI
Maxwell Chikumbutso has been discussed on this forum extensively.
  Verpies, and All.
  Thanks for the welcome.
  I am not tracking anyone at this time.
  As you know, I have not been following this forum for the last few years. Because I could not, due to the change in admin policy blocking non members from this site.
However, I am still waiting for something reasonable to follow, or to replicate, along the free energy lines. And won't ever give up on that.
  I know that we can't do anything with what Maxwell has shown, but, the idea is not to throw the baby out with the bath water. I doubt that he is faking it. As the guy from the movie Stive, went to see him, and took an electronics specialist to look into fake devices. None were found, just the opposite.
  Anyways, Maxwell almost died for his projects and ideas. and spent one month in the hospital from being poisoned. And so, we'll just have to wait until the climate changes, to learn more about his projects and self running devices. As "extensive discussions won't work, in this case. Since we can't find answers by discussions alone. Yet, he is the only one that may have something to show, and tell. At least that I know of.
  PS. Thanks for the tip on Andrey245, I'll look into it, again. Or any others working on this theme.
   https://www.youtube.com/watch?v=9UxOvZatzKY
    The above video was one of my last videos posted on YouTube about 7 years ago. How time flys...
 Anyway, that was as far a a could take that type of replication. And, at that point, I ran out of steam. Maybe I was "close", back then...
   I had made a bunch of videos at that time, as I started experimenting over 12 years ago. But, I never did build the controlable Kacher circuit, which I had planned on building. Although my regular Kacher was somewhat controlable, to a degree. Anyway, it's all boxed up now, but still intact to some degree. Perhaps Delamorto will get a kick out of this video. As I believe the basic mode of operation may be similar to the original Kapanadze devices. Mine was the Ruslan 7 version, or at least, my take on it
forest
Do we have any theory how Kapanadze device works ?
   Hi Forest:
   Well yes. But, it is not MY theory, but, it is similar to the way that the Kapanadze solid state devices, work. The other devices, such as the Akula, and the  Ruslan, devices were their versions of the same working process. I am not here to convince anyone, I'm here to find out the truth of it.
As we can't as yet prove how it works, by showing it doing so. Such as self running, we'll have to wait and see what shows up that can self run.
However, the idea is that there are two parts to this device. One is the high voltage Kacher circuit, and the other part is the lower voltage push pull circuit. Any extra energy would come from the surrounding ambient. The how and why this works, is still unknown. But, it is what Tesla called the disruptive discharges. Causing the ambient to respond by a sort of back fire that the coils in the device can take in and tap, as Extra Energy.Than what was provided for from the input source.
These theories are what we need to further study and work on. These are not my theories, they are as I understand as being part of the working process.
