Kapanadze replication
Started by DELAMORTO, 2023.09.18, 10:04:25
0 Members and 27 Guests are viewing this topic.
maxmalone
Quote from: DELAMORTO on 2024.12.02, 16:14:14
Post #568  8)
These are just words. Have you done any testing for what you are saying? Can you share it?
chief kolbacict
I was doing that before. The lamp was lighting,and it was better, when ground circuit has resonance. But there is not more  energy in lamp than in battery..
maxmalone
Quote from: chief kolbacict on 2024.12.02, 16:35:57
Me too  :o
DELAMORTO
Quote from: maxmalone on 2024.12.02, 16:17:20
In my experiments I avoid high voltages and discharges. The reason is that I can do what I want without them. The second reason is that discharges have a bad effect on measuring equipment. When I have something specific to show, I will definitely show it. I'm too lazy to prove it now. I have no right to convince anyone.
maxmalone
Quote from: DELAMORTO on 2024.12.02, 22:03:33
I also no longer want to check everything for others who say they know but don't want to  ;) This way we have >2025 and nothing more.
DELAMORTO
Quote from: maxmalone on 2024.12.03, 07:58:23
No need to check, you can put it together in your head - why Tesla(Kapanadze) used grounding and why it only works at high frequency.
chief kolbacict
forest
maxmalone
#583
chief kolbacict
This is Delamorto' picture. Let's he answer. ???
DELAMORTO
#585
Quote from: chief kolbacict on 2024.12.03, 14:41:59
I cut a copper tube from an air conditioner and inserted a ferrite rod inside to adjust the frequency.Tube with a cut.
The grounded end of the secondary winding helps to form standing waves along the length of the coil. Standing waves occur when a wave reflects off the end of the wire and interferes with itself, creating areas of maximum and minimum amplitude. This phenomenon plays an important role in creating resonant conditions. Ferrite rod allows to shift nodes.
It is precisely the interference that is the supplier of additional energy. This effect was described on the sheet of paper that Kapanadze held in the Greenbox video.
As Kapanadze said, it's not enough to know the scheme, you need to be able to set it up!
As an example - DD sensor of a metal detector, what seemed simpler, 2 coils - receiving and transmitting. But if you don't balance them, it won't work.
maxmalone
#586
Quote from: DELAMORTO on 2024.12.03, 15:37:20
Interference? What causes more energy to be created? If you have one wave and add another, you get their sum and everything is fine here. I'm asking how, having one wave, you want to have the sum of the same wave?
Where does the second wave come from for free?
maxmalone
DELAMORTO
Quote from: maxmalone on 2024.12.04, 08:10:23
Well, you're asking childish questions - what is the purpose of grounding and high frequency in the installation?
Reflection is used by waves from the ground. Plus, the patent says ether, any grounded coil is already an antenna!
I wrote - study why Tesla grounded the resonator!A simple example - two Tesla transformers, one transmits, the other receives. Why is the hot end of the second Tesla resonator grounded, and discharges go into the air from the cold end?
All for the same reason - the reflection of the wave from the ground, the receiving resonator becomes both a receiver and a transmitter.
maxmalone
Quote from: DELAMORTO on 2024.12.04, 09:54:17
Do you realize how many people deal with Tesla coils? how many companies? how many research institutes? inventors, military etc...
Do they not know this? did they not notice anything strange that would suggest an excess of energy? are they a secret organization like the Illuminati? NO. Those days are long gone.
The same if I talk about metal detectors or transformers, specialist diodes and other components. Do all these people produce, test, sell and develop technology and have not encountered the FE effect?!?!?!
After a dozen or so years I ask myself this question because it is impossible for such a device to exist and no one could repeat it, especially since there are no special technologies here that none of us can even have.
there is a 1% chance that Kapanadze discovered something that is still unknown today.
Have you asked yourself why the ground wire is so thick? 20-36mm2? Why? Because there are large amps flowing there? Really? 25A is a lot? a 1m2 cable is enough. If there is 300A there, why doesn't the camp meter show it. Let's assume there is 300A there, you knew the greenbox and you saw a guy holding a coiled cable several times. What would that mean? that the wires would move there, right? you know why. But we don't see that. So why such a wire? because it had one? possible. Is it HV insulated? no. I think that max up to 400V if it has a coating, then up to 1000V. Yes, about 1000V we can see on the voltage measurement on the bulbs. You remember because you saw it.
So on the grounding wire there is 25A 230-1000V? so what?
I agree that it is a wave reflected from the ground, but how to make a reflected wave at 25A and 230V? it must be resonance or a spark gap, right.
Resonant circuit for 50H at 230V 25A in TT mode - how?
DELAMORTO
I gave a Tesla transformer as a simple example of the interaction of high frequency and grounding. But you have already applied its parameters to Kapanadze's installation - why?
In 25-amp Kapanadze installations there is no Tesla transformer. There is high frequency, a circuit and grounding.
Have you ever measured the reactive current in a pumped-up circuit?
And in a circuit of several turns pumped up to a spark breakdown between the turns? The coils melt from such currents, but you do not see them...
Unfortunately, YouTube is seriously blocked here, I can't find and show a video in which an oscillatory circuit made of thick wire is swung to such an extent that the wire glows like a light bulb from the reactive current.
https://www.youtube.com/watch?v=3YmQv6UtPPw
forest
Trust Tesla not youtube. Tesla patent of radiant energy is the answer. Somehow the Kapanadze device occur to Earth as a very long antena capable of sucking energy from magnetosphere and charges from grounded metals, ssomehow like Plauson patents but in more efficient way.
DELAMORTO
Quote from: forest on 2024.12.05, 16:53:08
Well, when will you understand )) A grounded oscillatory circuit pumped up to incandescence is the same as raising an antenna kilometers up. Potential difference - is this term familiar?
Everything that is on Tesla on the Internet does not give >1! Tesla transformer - the efficiency is miserable!
Tesla, being unemployed, dug trenches for lighting cables. Since then, a device that transmits energy without wires has settled in his head. So that he doesn't have to dig holes! Why don't we use wireless energy transmission - it's very harmful to the environment, people, animals. Back then, in Tesla's time, they didn't know that. Electricity had just begun to be studied.
Kapanadze never said that his installation is a generator! He said - my device is for receiving energy! You need to understand the difference - to generate, or to receive!
And has no one thought that there are many frequencies at which the ether resonates? But in Kapanadze's patent, it is written directly where the energy comes from in his receiver! And Smith has a strange frequency in the circuit....
DELAMORTO
Now let's read the patent carefully - the device takes the initial energy from, for example, a battery, according to measurements 60 watts. As it is written in the patent - this energy must be constantly connected. We ask ourselves the question - with what power in the range of 300 kHz do beacons for aircraft work (these frequencies are reserved for them) And we get additional energy for swinging and maintaining the oscillatory circuit in resonance!
Now remember my video with two circuits, when they are phase-tuned into resonance! I tried to destroy the resonance, reducing the influence of the TX circuit on the RX - moved it further away. The amplitude of the TX (yellow beam) fell, and the blue RX remained in place! So if you get additional swing from the ether, then you will get the effect that Kapanadze called - INERTIA! This is when the primary source is already disconnected, but the oscillations continue, the lamps are on! And why are they on - there is a second source of TX oscillations! But it is weak to maintain the amplitude of the circuit at the proper level!
https://www.youtube.com/watch?v=NKNYmPNkJ20
maxmalone
So first we power the circuit and then receive e.g. 300 kHz which itself sustains the swinging?
around 300 kHz these are usually radio stations. When you tune to 300 kHz or this special frequency do you really think this is a Kapanadze device?
Maybe Kapanadze uses a power source based on a chemical substance. Currently, work on E-CAT has been going on for a long time. There, the power source is chemistry and elements like zinc and lithium.
Barium titanate was once discussed because something similar is seen in a device with disks. Also note that in the patent there is a reference to a patent about piezoelectrics and this could be barium titanate or something similar.
DELAMORTO
I tried to enter into resonance with barium titanate, very old experiments. All I got were high-voltage discharges. There is no power as such at all. There are modern generators using piezoelectrics - all this is a consumable, fuel that lasts for a short time. The patent clearly states where the energy comes from - it is its own resonance and resonance with the ether. No chemistry is indicated there, so do not invent something that is not there!
Broadcasting of a radio station is the vibrations of the ether, thanks to which we receive television and radio. No one tried to resonate with them, but only received these vibrations. Perhaps this is the meaning and effect.
maxmalone
DELAMORTO
lfarrand
Quote from: DELAMORTO on 2024.12.06, 10:18:02
What about super-regenerative radio receivers? Don't they work along a similar principle of resonating (pumping up signal / amplifying) and quenching (discharging power)?
Armstrong's Super-Regenerative Circuit
Super-Regenerative Receivers
chief kolbacict
Quote from: DELAMORTO on 2024.12.05, 16:35:22
If the coil heats up, it radiates heat into the environment.  To replenish the dissipated energy, a power source is needed.  :(
