The Lockridge device
Started by mbrownn, 2012.02.23, 02:07:10
Hiwater
Mbrownn  Looks like i put my last post in the wrong thread.
mbrownn
It does not matter hehe as all my posts are related to the lockridge device in some way or another.
The gray circuit could well be the motoring circuit of the lockridge, then we add the transformer and generator actions and "bingo" a potential self runner.
I have been thinking more about the transformer action, normally when the secondary is wound over the primary it reduces the field strength in the core, but in the lockridge we don't have that. We have the secondary on another part of the stator so the flux must pass through he armature to energize the secondary. This is why the inductive compensation improves motor power. The only difference is the energy in the inductive compensation coil is normally shorted where we will capture it to use elsewhere. Our problem here lays with the phase of the transformer action and how best to use it.
mbrownn
Here it is, this is how I think it could work using a Gray type circuit. It isn't a Lockridge device as such but a design of my own. This is using a partially modified four pole motor/generator.
The two transformers represent the four field coils, the other inductor is the rotor. The power is fed into the two motor coils in parallel and then into the rotor. These field coils are opposite each other on the stator. Two brushes will be required to power the motor. As the motor is in series with a capacitor all the inductive kickback ends up in that capacitor as well as the input power not consumed by the motor. normally a pulsed motor taking advantage of inductive kickback is in the region of 60 to 90% efficient but in this setup we will recover a significant amount of power in the capacitor. I expect to get somewhere between 50 to 100% of the power returned to this cap, this should be able to get us into the overunity window when it is used to power the second pulse of the motor.
The two field coils at 90 degrees to the power coils serve three purposes, secondaries on the transformer action which is also inductive compensation and generator coils. It may be that he location of these coils is not ideal for generation so we will have to test it.
We do not need to modify the rotor but splits in the case may be required to separate out the transformer/compensation actions.
The efficiency of the transformer and generator actions should be quite good as all the iron losses should have been provided by the motoring action but I suspect we will need twice the number of turns on the generator coils or more, when compared to the motor. As I said before, I don't expect a dramatic reduction in core flux caused by the transformer action because the secondaries are not wound over the primaries and in my previous tests shorting the compensation coil did not reduce the motor power but increased it. Air gaps will reduce the efficiency.
You will need to produce a commutator like we discussed before and place it on the motor shaft to do the switching
The bigger the capacitor the more power in each pulse but the lower the operating voltage, the capacitor must NOT be polarized and must be very fast, maybe made of a large bundle of smaller ones. See this circuit.
The reason I say that this isn't really the Lockridge is because the lockridge uses four brushes on the motor commutator and this does not.
Hiwater
   You know -------that circuit looks like it might just work. its relatively somple to do also. I will do some more study on it.
   Im not much on circuits, but i think i can figure this one out.
   I have two generator coils out of a golf gart starter-generator. They just fit in beside the motor coils i put in one of the GM generators. had to grind the pole shoes down to make them fit. They are 12 volt so they should put out at least 16 volts dc.
The motor coil pole shoe covers 3 armature slots, so does the golf cart generator pole shoe. thats 6 slots on each side with one
left over on each side right under the slot in the case. its really tight trying to get the generating coils in at 90 degrees because of the insulation on each coil next to each other. But they are in. I have motorised it it runs fine bot havent done any checking on what the out put is yet. I was going to put one more brush in and run the gen coils in series.
Whats your sugestion after i get the pulse unit made. Holiday this week so should have some time if not to much company.
mbrownn
For my Gray based circuit, I would suggest using the generator coils you have a standard in the 90 degree positions but what you need to do is find out how many turns they have on them. Try weighing a coil and measure the gauge and that will give you a clue provided there isn't too much resin on them. Then wind two coils with half the number of turns on two other shoes for the motor coils as the standard motor coils will be too low in inductance and draw huge current. If you choose a large enough gauge of wire so that the coil with half the number of turns weighs the same as the generator coil you will have them in resonance and they will perform so much better. This is something that most people miss when building transformers. If you don't have room to do this, just test what you have and we will look at the results.
You only need two brushes and they will be placed to make a two pole universal motor. The motor field coils will be in parallel with each other but in series with the armature, the generator coils will be in series.
Before you have your commutator finished you can test the unit on DC then AC and post your results as any information you give will be helpful.
The tests you did before are the tests we need, especially when you have it pulsing.
One additional test would be to measure the motor torque and speed when running and when generating and compare that to the input power.
There are a few unknowns here, will we get any generation? Will we need to put slots in the case to get the transformer action we want? What size of capacitor will we need?
I am really excited about this as I believe we are getting closer.
Hiwater
  Havent been able to get anything done on the lockridge since i was last on the board. Had good intentions , but that is as far as it has got.
  Just too busy working to get anything done.
   I have been following some of UFO politics posts at The EF forum. Looks pretty impresive.So have been trying to draw on paper how to rewind
my gen armature with the 14 armature slots and 28 comm bars. I cant figure it out yet. Maybe you can.  Guess I just dont quite understand it yet.
New things take time for me to understand.  Anyway thats about all i have been doing. How about you are you staying cool. Been really hot here.
mbrownn
I haven't been able to get anything done either, so we are both the same there.
UFO has posted some good stuff, unfortunately he is going over Matt Jones's old work that has proven unsuccessful. I tried to give UFO a tip but either he does not understand or he is misleading people as his reply had nothing to do with what I posted. I haven't followed my post up yet as he has a tenancy to attack people. He makes a lot of claims that cannot be just mistakes and mixes it with some missinfo so I am suspicious of his intentions. Hopefully I can get some tests done soon.
mbrownn
Sorry I have not been here for a while. I don't have an internet connection at the moment but hopefully i will soon.
Hiwater
Quote from: mbrownn on 2012.08.02, 22:53:19
   Seems like summer time is hard to get anything done with what i really want to do on these motors.
   Hope ypu get your internet back up soon.  When you do take some time and go on the EF forum, on UFOs armature rewinding thread. So we can see if we can figure out how to wind one of these generator armatures with the 14 slots. I dont quite understand it yet.
   You would know the right questions to ask. I did try to rewind an armature with the dual pentagon . Got it to turn, but wasnt right. He did respond to my questions on that winding but havent gotten time to rewind it the way he said.
I believ there is something to the way he is rewinding them. These also do recharge the battry somewhat when they are running because of the pulsing effect of the way it is wound.
From what i understand it dont take much amperage to run these. So it may help in the overall process of efficiency.
  Let me know what you think. Have a great day Curt.
mbrownn
I like some of what UFO posts but I don't agree with it all. The rotor he is winding is almost the same as the posts earlier in the lockridge thread, been there and done that. Diodes on the rotor are not needed although a wave wound rotor is what the lockridge had in my opinion. Google wave wound rotor or armature.
It would seem that the lockridge used the simplified Gray circuit as I call it but we will need to change the geometry to make it work.
All motors need amps multiplied by the number of turns times the duty cycle to get torque, its as simple as that. To get the amps we need low resistance and as we are pulsing against an inductance we need to either lower the inductance or increase the voltage to get the amps. Lowering inductance reduces the recovery so this isn't a good option and higher voltage increases heat loses through resistance so again we have a problem.
The capacitor in the Gray circuit reverses polarity thus giving current flow double that of a battery so this is a way round that problem. ie if the cap is at 12v current flows until the cap discharges and continues to flow until the cap reaches -12v, this is effectively 24v even though we only have 12v
I tried to talk to UFO but he wasn't listening or didn't understand, I don't want to get involved with the name calling so I just kept quiet. erfinder has done a test for me on the Gray principal but I haven't been able to discuss the results with him as yet because I don't have an internet connection. All I know is on his test he got a 30v (about 15%) gain in voltage over the input on the cap but I don't know if he has taken into account that the cap is working on AC while the motor is DC so his working voltage will be double what he is reading.
The only requirement for the wave winding is so that the brushes on the commutator can do the switching, if we mount a second commutator on the motor shaft we can use a standard lap wound rotor.
There is another thing with winding the coils that I have been told about but more on that later.
In summary UFO is where others were at early in the lockridge thread but he has grasped one part of the concept that others failed to grasp while missing another concept. I am not knocking his work, he does some great real experiments but it takes time to understand what is going on before you can come to real factual conclusions. In this and other threads, I have been giving you some of the things he has missed, so you can be one step ahead if you want. Take a look at that Gray circuit I posted, you don't need to rewind the rotor, It's the stator we need to modify and add a second commutator on the motor shaft.
mbrownn
This thread has been a little quiet, sorry for not being able to post much but circumstances dictated that I have to concentrate on other things. I haven't forgot about you and I am still working on it.
This is my reply to a post on http://www.energeticforum.com/renewable-energy/12328-advanced-motor-secrets-david-squires.html#post209377 I think it has more relevance here so that is why I have placed it here too. There hasn't been much activity on this thread but it does not mean that the thread or the research is dead.
"I am familiar with finite element analysis although the only ones I have used is for stress and strain and for designing elastimeric seals.
I was thinking more about the electrical circuit and the geometry. I haven't researched Thane Heins, maybe it is time I did. I have managed to use inductive compensation to increase current flow in the motor while also using that current to charge a capacitor which will be used for the next pulse. Recycling it if you will.
If you remember how farmhand turned a universal motor into an induction motor this shows inductive compensation/transformer actions.
Inductive compensation is a transformer effect and if configured correctly can increase current in the motor in the same way a loaded secondary increases current in the primary in a transformer. This increase in current then increases the flux in the armature producing more torque. In a transformer the reverse is true because the secondary is wound over the primary. In the motor all the flux has to pass through the armature before it reaches the secondary thus increasing magnetic flux in the armature.
In a standard motor this compensation coil is opposite the power coil but I am experimenting with placing it somewhere close to 90 degrees. Some have shown in their videos that a shorted coil in this area can cause an acceleration so I am investigating it. A shorted coil is an inductive compensation coil. In their videos they had an open magnetic circuit where I have been using a closed one but now the geometry of the stator has to be taken into account. I believe this may be one of the reasons for the splits in the case of the Lockridge.
This is more appropriate to the lockridge thread so I will also post this there"
mbrownn
Steve and hiwater, please get a copy of the squires video. I think this is of huge importance.
Here is a copy of what I have posted here http://www.energeticforum.com/renewable-energy/12328-advanced-motor-secrets-david-squires.html#post209715
"Thanks to the member that sent me the video
You have got to see this video, I have only watched it once so far but I think it answers a lot of questions.
The use of the choke has to be the primary function of the trifilar coil on the lockridge device. I had considered it as a possibility but dismissed it because I didn't really understand how the coils can maintain their current and that the core has to be so big. Its magnificent.
The method of keeping the saturation out of the pole coils may also be a function in the lockridge but I will have to test this. If this is the case, the coils on the poles are the generator coils with the power coils being at 90 degrees. this way there is little if any back emf in the power coils and the coils that are by the moving field are the generator coils and compensation coils in one. Again if I am right the compensation and generated current are in the same direction. If I am right, Bingo we have it.
I will have to watch this many more times to try and understand it and then set up some tests to confirm it assuming I have this right.
Somebody please get back to me on this."
PhysicsProf
Quote from: mbrownn on 2012.09.25, 13:09:58
Mike -- I went to the thread you linked to, looking for the Squires video.   I'm not sure I'm finding it...
Did some searching, came to this:
QuoteAdvanced Motor Secrets
Suggested Retail Value
$147.00
Insane, Giveaway PRICE!
$17
Is this the "squires video"?   if not, please provide link to the squires video?
mbrownn
Here is a link to the video download, yes its 17 dollars.
http://www.advancedmotorsecrets.com/
There are many important points in this video. I think we should start a thread on it
PhysicsProf
Quote from: mbrownn on 2012.09.25, 23:13:57
OK -- I'm getting this; lots to learn!    Thanks, Mike.
mbrownn
At first there does not seem to be much in this about the lockridge device but it is all relevant and explains methods of reducing BEMF
mbrownn
Extract from http://www.energeticforum.com/renewable-energy/12328-advanced-motor-secrets-david-squires.html#post209897
"Squires suggests that the voltage needed to cause current to flow in the motor coil pulses not be provided by the supply. Instead it can be provided by the inductive kickback from a large choke that has a large mass of iron. In the lockridge we have a trifilar coil wound round the motor so it is now obvious to me that this has to be one of the main functions of the trifilar coil.
Not in the video but I believe relevant, is the fact that the motor coils, generator coils and trifilar coils are all wound on the same mass of iron. When an inductor that has an iron core is charged, that energy goes into the iron. If the iron was charged by the motor function, little or no more energy is spent on the iron during the transformer and generator functions therefore these functions should be more efficient than you would normally expect. If it is the choke that charges the iron and that choke is maintained in a charged condition as squires suggests, could it be that the motor function too is more efficient?"
Hiwater
Hi Again MBrownn.  From your preception on the squires dvd. Looks like it a must have. We dont have too much of this left to figure out. I read
        your posts at Ef before getting back on here. The transformer action is what you were trying to teach me last winter. Funny i never really
   really understood that Untill I read your last posts. Just like a regular 60 cycle transformer works. Now i got something to work with. THANKS. I
   have worked with the motor coil and gen coils a 90 degrees. But never thought of using the gen coil as the motor coil. i think that was what I un
   derstood of the coil in that position. Which should help move the armature ahead with the magnatic feild. like a dog chasing it tail.
   I will get the dvd to look at . thanks for keeping us posted as to what is happening.
mbrownn
The DVD is not specific to the Lockridge, in fact he is talking about other types of motor. Once you understand what he is saying about the principals, everything starts to fall into place. I have been talking a lot to erfinder, he has built some really good motors over the years, he prefers to turn the coils through 90 degrees as well as locate them at 90 degrees just like squires talks about but the topography of the delco generator does not really let us do that.
Remember, the coils that we normally power are the output coils in our case. Your rotor may have to be two pole and the coils at 90 degrees are powered by the pulse. By moving the brushes a little we might be able to get the motor to turn but I expect it to be weak. If I am right about my interpretation of the squires video, powering the trifilar coil up will improve the efficiency and the motor will spin better. This is all theory at this point.
The transformer action and generated BEMF should both be in the same direction and is our output.
All this is turning normal motor and generator principals on its head ;D ;D ;D Its the opposite, where have we heard that before?
ion
Everything stated below is to the best of my knowledge and is subject to correction.
Besides J ###### and P #########, what other references (preferably historical) can be found on the Lockridge device?
Without any other info, I guess we have to trust that the story is real without applying any investigative due diligence.
So we have:
An archive photo of post WWII Germany. (red flag, there are thousands of archive photos available to attach to a story)
A fascinating story of a FE generator found by US soldiers in a cleanup operation (anecdotal, nice)
A picture of a generator that was supposedly a replication of the original given to J ######. He has not publicly demonstrated this as a working device.(red flag)
A picture of a notebook given to J ######, the information of which contained therein has not been directly released nor have scans of it's pages. (red flag)
In both cases above, the grantor of the above information to J ###### wishes to remain anonymous. (red flag why? when he could earn much with his own book/DVD sales)
Please help me here, as I am having trouble believing this without outside verification.
I would love to believe, but considering the sources, I am leaning to believe it is a ploy for whatever reason we need not look too far to find  O0
Have the above named had success in replicating a machine and demonstrating such? (no!red flag)
Or are they busy selling info of how you or anyone might replicate such a machine? (yes!big red flag)
Trust me, I would love to believe, but my requirement for due diligence pulls me back.
Can anyone provide first hand provable historical data? How far have the originator(s) and distributor(s) of this info come to publicly demonstrating a working device?
mbrownn
Hi ION,
No there is no evidence that I can find other than the sources you quote and I understand your skepticism. In fact I probably would not have begun my research into this device if I had heard the doubts that some credible members have beforehand; however I did start to research and experiment.
Summary of my work
As you say, there is little evidence on the net, not much to go on other than the video by John fettuchini
I have had one email from someone who claims to know someone who owned one but there was no additional information and I can no longer contact that person.
I have carried out thousands of electrical simulations and from that I have concluded that it may be possible as all the simulators I have used produced similar results.
There is a patent that describes the process of how the Lockridge, if real, could have worked. This is the dynomotor patent. The key points here are a motor action, a generator action and a transformer action all on the same iron core so that there is only one iron loss. Yes this is an efficiency improvement and not the source of the power.
I have carried out 100s of experiments and found energy gains in the inductive kickback and resonance however these gains have never been enough to cover the losses. Some say these gains are just improvements in efficiency but I am sure they are gains. If you have ever experimented with charging caps with pulses through an inductor and calculated the total losses you will find that either the inductive kickback or the magnetism is "free" and therefore a gain.
Resonance has only given gains in voltage and heat in my experience, no extra current and therefore no extra power in the motor thus the gain comes out in heat generated in the motor. I have burned up many motors.
Through persistence I have been able come up with circuits that should exploit these gains. and the key point here is that low resistance is a must and Inductive kickback is a must.
The area where I have been struggling is BEMF. To get the motor running with low BEMF ment running it on the part of the power curve where it had to rise to the load and would stall if there was any increase in load. Drops in load would have resulted in a runaway motor and a burn out. Obviously this isn't a satisfactory condition and would at best result in a sweet spot which may produce an "overunity effect" None of my motors were able to run in this condition as the resistance was too high and as a result increasing the voltage would only produce gains in heat :(
One member has been drumming it home to me that I need a chance in geometry to make it work but being stubborn and believing that the lockridge may be real I could not see how that could be done in a standard motor case.
The babcock video confirmed some of my beliefs but still did not have the answer to the BEMF and geometry issue, this is where the Squires video comes in. This video does not really talk about the lockridge but many of the principals apply.
The first is the solution to getting enough current to flow in an inductor. Normally we raise voltage and I was looking at lowering resistance. Raising voltage increases heat, lowering resistance increases size and friction so gong down the route I was following would result in huge motors with only a meager output. The choke coil in the Squires video has the answer, by periodically disconnecting a series mounted choke from the supply, it would produce inductive kickback of a voltage that would overcome the inductance of the motor thus allowing sufficient current to flow. The motors own inductive kickback could then take over giving a gain. From the information given by John fettuchini we know the lockridge had a trifilar coil wrapped round the motor case, he also stated that two of the windings were in series with the motor. This is the choke that squires talks about. Not mentioned is the fact that having the choke wrapped round the motor will saturate the motor to some extent and that this may help the efficiency of the motor function, only my theory.
The second part is the BEMF, according to squires and my friend that has been trying to get me to change the geometry, the most BEMF is generated where the greatest change in concentration of flux is occurring. This is right where we normally mount our coils. By moving our coils away from this point while still keeping them in the magnetic circuit we can reduce the BEMF. He also uses a magnetic shunt to maintain the flux in the power coil but I cannot see how this would have been done in the lockridge yet, if at all. Our answer in the lockridge is to use a 4 pole setup in the case and two pole on the armature but for simplicities sake i will only talk about two field coils.
Imagine a universal motor with two field coils, take one coil off and mount it at 90 degrees, this coil is the power coil and is in series with the armature. the other coil is the generator coil as this is where the BEMF will be generated, it is also the inductive compensation coil which is a transformer action. The only problem we have now, is to get the motor to turn. Maybe by moving the brushes a little a weak motor action can be obtained and maybe the influence of the field created by the trifilar coil has some influence on this, or maybe it is a case of adjusting the position of the power coil either side of the 90 degree position. Remember that this motor will not be self starting so It could be the lag in the current that actually causes the motoring action once it is turning. I don't know but it is time to experiment.
If the power coil was wound round the stator instead of a pole piece the motor would turn but then it would not resemble the lockridge device.
Could it be that the lockridge was put out as a hoax to try and see if someone could figure out how to do it, this is possible ??? but personally I believe there was such a device.
ION, I like people to ask the difficult questions as this helps me to learn. Keep asking those questions and pointing out the obvious. O0
Hiwater
    MBrownn.   Two pole armature. Clarification. This is still the wave wound armature as was discussed before in this thread. with one pole on each side. In other words just 2 commutator bars making continuity.
        Thanks Hiwater.
mbrownn
If we use a four pole wave armature we may have to alter the locations of the coils more, to be honest I don't have this thing totally worked out and this is why we will need to experiment but the principals are much clearer now
ion
From mbrownn:
QuoteION, I like people to ask the difficult questions as this helps me to learn. Keep asking those questions and pointing out the obvious.
Thank you for the gentlemanly response. As stated earlier, I would love to believe and have dreamed that such a device may be possible. (yes I have had actual dreams where I witnessed such a device running).
I have tested motors and dynamotors on the bench and learned much, but apparently not enough to have success.
You make many good points and I will defer to your greater knowledge of the history of the device (I have never seen the video of which you speak...John fettuchini)
Maybe a list of links to all available information would spur others including myself to do more research.
Thanks again for your kind reply...ION
mbrownn
I am sure you have seen all the videos I have seen, the only additional information I have seen is in threads that JB has taken part in and radio interviews and there isn't much more there.
From what I have learned, my statement about it being a hoax is a distinct possibility because the information in the energy from the vacuum video seems to be incorrect as far as the magnetic field is concerned. It has no similarity to the SG and two north poles together is irrelevant in my opinion. It could be that JB has no better idea as to how it works than us or its a hoax. I am confident that JB knows more than me but the statements in the video that, to me, are obviously wrong have me thinking that it could be a hoax to get us to work out how to make such a device.
The problem with the hoax theory is that, as I learn, the different components of the device seem to be exactly what is needed to overcome various problems. Too much of a coincidence for it to be a cobbled together imaginary device.
It would be nice to have the definitive research library on the lockridge device but the problem is we don't know what should be included and what dismissed. For example Peter's "electric motor secrets" is a good learning tool but is clearly not how the motor worked. It does however get you thinking and makes you draw the conclusion that standard motor theory is an incomplete picture.
So what makes me think this is real?
We know motors require only current flow to make them run and the voltage is only relevant to overcome resistance, power input is irrelevant. Current is not consumed in the motor as we put 1A in and get 1A out. we can collect what passed through the motor and use it again. The maths show us that the power consumption is what is feeding the losses and not the load. With this in mind we can see that with sufficient efficiency a motor that recycles its supply current could indeed produce more power than it consumes.
We know inductive kickback can give us our power back less losses and as we can also collect the input less losses so the total electrical power available to us to use is double what we put in. We know that the inductive kickback also produces a magnetic field that is usable. Nothing new here it is the basis of pulse width modulation. what we haven't been doing is collecting the current and using it again.
The first problem is that when we take a standard DC motor and pulse it we have to increase the applied voltage to make it start to turn at low duty cycles and strangely enough it is this problem that lead me to conclude that the trifilar coil has something to do with this. I assumed it was the impedance matching ability of such a coil that was the reason but now I am coming to the same conclusion but it is doing it in a different way ie how Squires does it in his video.
BEMF is the thing that prevents us from making this happen. I assumed that the motor was run in the first part of its power curve as little BEMF was generated in this condition but the problem is as soon as you introduce a load the motor stalls. By combining a transformer effect in the motor we can overcome the problem, as we increase current draw from the secondary winding of the transformer, it draws more current from the supply. This will in turn increase the current flow in the motor causing the torque to increase with the load as it does in the second half of the power curve of a universal motor. once we have sufficient speed in the motor for it to be useful again BEMF rears its ugly head, Squires has, at last, shown how to mitigate this. It is not done in exactly the same way in the lockridge but the principal is the same. Its a geometry change, we place the power coil in a place where there is a smaller change in flux.
This also leaves us with a problem if we want to make use of both sides of the armature as the magnetic fields in the stator will tend to short. The simplest way to fix this is to split the case of the stator into two halves. This is exactly what we have in the lockridge, its nothing to do with north poles shooting out of the gap, its two separate the fields.
Now we have separated the BEMF from the power coil, by moving its location, we can use it as an output. It is generated power and not a loss. The compensation field is also the transformer output and is available to us and not a loss. These both appear available to us in the same coil and in the same direction.
The input and inductive kickback are both collected, less losses and used to power the next pulse. If it were not for the fact that capacitor losses are around 50% our motor would not need an input at all but unfortunately it does. We take this power from our output but even so we should still have some output in excess. No laws of physics broken.
The interesting thing is that we have not even mounted a generator on our motor so more could be gained here.
Now we have to build it and tune it to demonstrate it.
Could it be that the device was real? Could it be that JB got to this stage and was unable to get it to run and so put out a hoax to see if someone could find the solution? Either or both are possible but I choose to believe the first scenario although the "Both" seems just as likely.
I put out everything I have learned and everything I theorize about, I'm sure it is not all correct but my intentions are honerable. If you see holes in my argument, point them out and ask me about them. If I don't know the problem, I can't fix it.
