The TPU: Is it Real ?
Started by ion, 2010.11.04, 12:57:15
Grumpy
why an electric arc is called an arc:
https://en.wikipedia.org/wiki/Electric_arc
Sir Humphry Davy discovered the short-pulse electrical arc in 1800.[2] In 1801, he described the phenomenon in a paper published in William Nicholson's Journal of Natural Philosophy, Chemistry and the Arts.[3] According to modern science, Davy's description was a spark rather than an arc.[4]
In the same year Davy publicly demonstrated the effect, before the Royal Society, by transmitting an electric current through two carbon rods that touched, and then pulling them a short distance apart. The demonstration produced a "feeble" arc, not readily distinguished from a sustained spark, between charcoal points.
The Society subscribed for a more powerful battery of 1,000 plates, and in 1808 he demonstrated the large-scale arc.[5] He is credited with naming the arc.[6] He called it an arc because it assumes the shape of an upward bow when the distance between the electrodes is not small.[7] This is due to the buoyant force on the hot gas.
Centraflow
One frequency, two pulses with different multi-pulse duties and sequence timing.
A and C timing gap dictates the output voltage, it is a differential output. Any ground used on the output is the second ground.
bte
I know this is ancient but do you have a link to this post? Or do you remember how it was switched? My fets get hot at 6mhz.
Quote from: Grumpy on 2010.11.04, 14:20:26
The overheating and "flipping over shut off" effects were only present on early units.
In the video "stevennew.mp4" with U.E.C at the top of the screen, SM states that these devices utilize a different method of induction which causes electron flow to produce useful electricity.  One of the device runs for about 20 minutes and the voltage is checked at the start (about 170 volts) and at 20 minutes (about 169 volts).  He states that this device makes batteries obsolete, can power cars and other devices, and that no other energy source offers the same energy density.  (See report by Michael Fennell.)
SM states that the devices are not recievers, and that the electricity is produced within the device.
Even if you abhore conspiracy theories, and such, you can see that if SM's claims are true, then we have a slight problem with the TPU.  It is a viable replacement for "oil" as an energy source.  Oil is still required for many other purposes and used in many many products.  The TPU does not replace oil entirely, it augments it.  It allows us to go beyond the level of energy that oil can supply to us.  There is no ground connection required.  There are no connections to anything but the load.  The TPU allows us to utilize an energy source anywhere in the universe, at any time, for any purpose - indefinitely!  This device and devices that use these same principles can usher in a new era for mankind!
Unfortunately, very few believe, and only a meer handful are willing to put in the bench time to achieve success.
Instead, we fight over the rights to the planets energy supply.  We surpress devices that are "too efficient".  We complain and argue.  We spend our time on projects that have less documentation than the TPU, and a miniscule amount of success.
Some have argued that the TPU must not bne "real" since so many people have been working on it and it's variations for so many years and nothing has come of it.  This is an incorrect assumption.  A frined of mine came forward on the Eergy Builders Forum and discussed his version that did produce useful power in excess of the power applied for operation.  (I don't recall exactly but I think he put 100w in and got 170w out.)  This device was a collector loop of several turns with four coils wrapepd over it, forming a toroid.  The coils were switched sequentially at around 28mHz.  It was not impessive until he looped the output back to the input.  After brief operation it overheated, cooked, fireballs on the bench, etc.  Two other people witnessed this event on Skype.
Everyone also seems to forget that GK's GK4 device produced some interesting results and was referenced by Spherics.
Before you say "nothing has come of all the work", take a good look at the work that was actually performed.  You will see that most of it is inapplicable, and unrelated, say 70% of it.  20% was wasted do to misunderstanding the information presented.  That leaves a paltry 10% of the useful, which amounts to a few weeks.  So, not much work has actually been performed towards a working TPU.
Grumpy
Quote from: bte on 2024.04.16, 07:38:54
From what I can remember the only "schematic" from SM was the brown paper one that Mike (Centraflow) reverse engineered.
The schematics from Spherics were very basic high or low side switching of MOSFETS with a snubber.  Shortly after the Spherics info was provided, Roberto in Italy built a unit, but he only used 1kv, which is below the minimum requirement.  I think he said you have to drop 1kv across the CCU coils.
I tried HV MOSFETS, but they were slow and had an intrinsic effect that made them very noisy and hard to work with.
I worked diligently with HV BJT's for over a year, got burned out on it, and have not touched it for over a year.  Next step is to rebuild my test board with heatsinks for the BJT's.
Busy with work and home now though...
bte
Quote from: Grumpy on 2024.04.16, 14:20:21
Understandable. All of my noise issues disappeared when I went to an isolated gate drive, but the chinese isolated driver boards need long pulse widths (>100ns) and I'm opting to build my own with faster FETs.
Centraflow
Quote from: bte on 2024.04.16, 14:34:29
If you really want to know there was only a clock source (crystal oscillator), a sequencer IC, and 3 mosfets.
As SM said "you would not believe how easy this is".
bte
I'm sure, and it's a goal to work on a coil configuration like sm, but I need to start at the initial idea, the eureka moment, where the basis of the effect is first. I think sm mentioned two transformers out of sync gave him his revelations to start on the tpu.
bte
Quote from: Centraflow on 2025.02.20, 18:41:35
I'm glad you understand it, at least someone does. I'm not even sure how the windings are configured in his tpu. Like what is the most basic vanilla no nonsense version, has to be simple, those open units were simple to the extreme
chief kolbacict
What is the cause of the current of the ring accelerating electrode of the electron gun of the kinescope?
After all, electrons fly through the hole and are not discharged on the electrode.
And they are discharged only at the anode. It's just some stray electrons that end up hitting it.
Or is the electric field being spent on accelerating the beam ?
bte
What was his sequencer ic? The brown paper is hard to read the parts. I can see cmos chips
Centraflow
Quote from: bte on 2025.02.20, 19:49:33
The windings and how they are connected is one of the most important parts.
Those open units had a problem, you turn them over and they stopped working.
You take a weak magnetic field and you accelerate it. The faster it moves through a coil the more current is generated. You could take a strong field and move it through a coil SLOWLY to generate the same current.
What magnetic field comes for FREE but is weak?  ;)
Centraflow
Quote from: bte on 2025.02.21, 12:47:30
No idea what he used, I know what I use though.
bte
Quote from: Centraflow on 2025.02.21, 16:38:46
Earth's, but how to move it?
Centraflow
Quote from: bte on 2025.02.21, 17:14:09
You are moving it when you place a compass between North and South, the field goes through the compass magnet on it's way to South, or no!!
The word COMPASS, it PASSES through the susbended magnet, does it not!
bte
Quote from: Centraflow on 2025.02.21, 17:54:47
This makes less sense than before. Maybe I'm out of the loop.
I'm taking notes though.
Centraflow
STEAP and the TPU are black holes for the magnetic field, pull it in and spew it out.
There are 2 Norths and 2 souths, a 2 solenoids bent around but have a gap, N  gap  S
        S  gap  N
The first TPUs were only one toroid N  gap  S, turn it over in the same plane and it stopped working, with two it does not stop.
Centraflow
Quote from: bte on 2025.02.21, 18:03:01
bar magnets on the table NSNSNS with gaps between them just so they do not pull to one another, where are the fields?
Aking.21
And so a brave new world begins:  According to Grok3
Recommended IC: CD4017 (Decade Counter)
Why It Works: The CD4017 is a dirt-cheap (~$0.30-$0.50) sequencer with 10 outputs, but you can easily use just the first 3 (Q0, Q1, Q2) and ignore the rest. It steps through outputs one at a time with each clock pulse, perfect for sequencing.
Setup:
Clock Input: Feed it a clock signal (e.g., from a 555 timer or even a manual pushbutton) to advance the sequence.
Outputs: Connect Q0, Q1, and Q2 (pins 3, 2, and 4) to the gates of 3 MOSFETs.
Reset: Tie Q3 (pin 7) to the reset pin (pin 15) through a resistor. This makes it cycle back to Q0 after Q2, giving you a repeating 3-step sequence: Q0 → Q1 → Q2 → Q0.
MOSFETs: Use N-channel MOSFETs like the IRF540 or IRLB8721 (cheap, ~$0.50 each). Each MOSFET's gate connects to an output (via a 100-1kΩ resistor for safety), source to ground, and drain to your circuit's load (e.g., motor, lamp, etc.). The MOSFETs can switch high currents (10A+) or voltages (up to 100V or more), depending on your needs.
How It Switches 3 Circuits
Step 1: Clock pulse 1 → Q0 goes high (5V or whatever Vcc is), MOSFET 1 turns on, circuit 1 activates.
Step 2: Clock pulse 2 → Q1 goes high, MOSFET 2 turns on, circuit 2 activates (Q0 goes low, shutting off circuit 1).
Step 3: Clock pulse 3 → Q2 goes high, MOSFET 3 turns on, circuit 3 activates (Q1 off).
Step 4: Clock pulse 4 → Q3 triggers reset, Q0 goes high again, restarting the cycle.
Specs
Outputs Used: 3 (out of 10 available).
Switching Capacity: The CD4017 outputs ~10-20 mA per pin, plenty to drive a MOSFET gate. The MOSFETs then handle the real load—could be 12V LEDs, 24V motors, or whatever your circuits are.
Cost: ~$0.50 for the IC + ~$1.50 for 3 MOSFETs + a few cents for resistors = under $3 total.
Alternatives
74HC4017: Similar to CD4017 but operates at lower voltages (2-6V) and slightly faster. Same 3-output trick applies.
Custom 3-Stage Shift Register: A 74HC164 (8-bit shift register) could work, but it's overkill and trickier to limit to 3 outputs without extra logic.
Minimalist Option: A 555 timer with a 4013 dual flip-flop could rig a 3-state sequence, but it's more parts and effort than the 4017 setup.
Why CD4017 Wins
It's dirt cheap, widely available (think Amazon, DigiKey, or any electronics bin), and needs minimal tweaking to lock at 3 steps. Pair it with MOSFETs, and you've got a robust, flexible 3-circuit sequencer. No need for a fancier IC unless you're cramming it into a tiny space or need microsecond precision.
My only criticism is that Grok3 didn't turn each circuit off first.  But then I didn't ask it to. Grok3 resets the sequence after all three (coils) are activated. Anyway, Mike, thanks for making it clear.
Centraflow
It is like a black hole for magnetic fields. The field inside the unit spins like a cork screw, a very tight cork screw, it creates a field which has a very fast angular velocity in the middle of the solenoids. It is like watching the water go down a plug hole in your sink. The closest solenoid to the core is a generating coil.
From all that you should be able to make your own,"sometime" in the future after the oil and gas industry of the USA and Russia, has colapsed.
Drill baby drill ;D The s**t is coming out of two holes.
I'm gone.
bte
A black hole for magnetic fields  ???
I need calculations and a build plan. Something I hope to do with my project to avoid replication fizzling out.
Centraflow
Quote from: bte on 2025.02.21, 19:20:00
You do not replicate, you investigate after weighing up how it might work. It took me 8yrs, from 2013 to 2021.
No free lunches,and I am not looking for making money, but I have given enough short cuts to a working model, and where the energy comes from.
bte
Yes, but the investigation of the primary effect is still lost on me.
Centraflow
Quote from: bte on 2025.02.22, 14:44:40
Magnetic thrust.
lfarrand
So you've got two plates of a capacitor (which are coils B & C1) with a solenoid wound such that a magnetic field can be created inbetween the plates. A changing magnetic field has a changing electric field perpendicular to the magnetic field.
It is known that when you charge or discharge a capacitor a magnetic field is created. If you invert this, then it stands to reason that creating a magnetic field inbetween the plates of a capacitor will charge the capacitor.
F6FLT
Quote from: lfarrand on 2025.02.24, 10:12:10
Your second situation is not symmetrical to the first.
When you charge a capacitor, its circuit is looped back. Under the effect of an electric field, charges can move and charge the capacitor. The movement of the charges is accompanied by the magnetic field.
If you use a magnetic field and the capacitor is in a closed circuit, the capacitor will charge (but also discharge with each alternation). This is the symmetrical case of the previous one.
But if the capacitor's circuit is open, obviously the number of charges on each plate can't change, so the capacitor won't charge. There's no reason for it to charge.
