2026-08-15, 00:58:40
Pages: 1 ... 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29
Author Topic: The TPU: Is it Real ?  (Read 471309 times)
Now home again and can use my computer and not a phone.
The problem as always is that certain people have nothing to add, just try to take advancement away.
What is not realised by many is that there are TWO grounds from TWO supplies. It is two lots of electrons moving within part of the same circuit but become combined!
So how is this done! Lets look at a transformer which has three coils, say one primary and two secondaries which are equal, like a 240v to two 12v secondaries.
Let us use it in reverse such as in a step up transformer, but we are going to feed the two 12v inputs with two different pulsed supplies.
Each supply has its own electron current which "creates its own magnetic flux" in each of the coils. In a round about way two lots of electrons combine, once converted to the form of "magnetic flux" within the transformer core. "Energy can not be created or destroyed only converted", so this conforms to the laws that exists ATM, but it does not finish there, there still has to be an energy input, that is still to come O0
AH someone is going to say, what about saturation of the core, well that is where frequence and duty comes into play, duty being the cause of the change of frequency so as to create two frequencies from just one, "the clock".
The energy input is all around us, just think what happens inside a compas needle when it alines with the fux lines of the Earth! what happens when you place two bar magnets NSNS! yes there flux adds up and the magnetic field strength has increased.
SM said that if you turned over one of his units it would stop! what he did not say is that if then turned 180º in the same plane it would start again. But it does not end there!
This works because it takes a very very small amount of energy in the form of flux from another source, and adds it to a very efficient converter of flux to current where the flux is more than what the current was to make it in the first place. Convert it all back to a differential current and you have WHAT LOOKS LIKE OU.
Here is a break down of SMs words, it should help you to understand what he was talking about.
Excellent posts Centraflow
There is no need to violate the COE when we are swimming in a sea of energy.
Your descriptions remind me of articles I read years ago by T.H.Moray and Viktor Schauberger. It relates to a "universal" mechanism or process which could extract energy from supposedly stationary fields. Ergo, extracting energy from a constant force acting on something in one direction.
This concept sounds very similar to what you are describing.
Now you should go back in time to here:-    Just thinking aloud - TPU
All this is from years back.
It takes a lot of real scientific investigating to get to the end and produce a real working unit.
Dedication to the cause.
That's what I read every day, and of course it doesn't prove anything. While some truths have certainly passed through this channel, that doesn't mean that saying anything is truth at the first stage.
It's a simple matter of logic. And when it's used incorrectly, it becomes a fallacy.
I read in the PDF above:
NOW Here's the REAL trick: Because the power was cut before they reached the Anode, the circuit was never closed and there was never any current flow, only electron flow due to their response to the voltage potential...
Would moving electrons no longer be a current? A current is coulombs per second, regardless of whether the charges are moving in a wire or in a vacuum in ballistic flight.
Next, the electrons must be accelerated, and this energy is taken from the electric field. An anode current flows during this phase and provides the energy.
The electrons then may have enough kinetic energy to reach the plate when the circuit is opened, but this overlooks the fact that if the circuit is open, the plate quickly becomes negatively charged as electrons accumulate, its potential drops rapidly and the electric field may even reverse, slowing down the electrons more and more as they arrive.
These concepts are related to space charge. It should not be forgotten that the electrons in the vacuum between the electrodes represent a charge. Even if a flow of electrons is indeed a current by definition, we are no longer dealing with a simple current flowing through a wire that remains electrically neutral. We must also address the issues of charged media.
All these questions obviously aroused the interest of engineers and physicists from the very beginning of the first electronic tubes, particularly because space charge limited the performance of the triode, and they have already answered them. There is nothing magical about it, contrary to oversimplifications.
Thanks 6flt,
Your explanation actually is quite useful if we ignore that you have it the wrong way round, which both Mike and SM stated in their explanations.
In time your contributions could be positive when you realize that good information is at your feet , that assumes you can become content with helping others.
Perhaps thinking about hundreds of tiny compass needles (with no mass) in a charged field where the electron flow has switched off leaving behind ,just for an instant,a charged capacitor and displaced compass needles .  Discharge this cap(needles move) into another one which is capacitively coupled,rinse and repeat. That is pretty simple but by no means complete.
If one accepts that we are immersed in a dynamo how would you create a sink or source to exploit it ?
This also aligns with Partsman and the anomaly which he and others are investigating.
It really is like a radio receiver but works with/on near field magnetic s which are in abundance in the dynamo of our planet.
35 khz and 5 khz oscillator and I.F. either way around .
Here is something from AI about the interaction between capacitance and magnetic fields which is fundamental to what so may inventors ,past and present exploit.
"A static magnetic field has no direct effect on a capacitor, as a capacitor stores energy in an electric field and blocks DC current. However, a changing magnetic field can induce a voltage across the capacitor's terminals or even change its capacitance if the capacitor contains materials like ferrofluid or has specific structures that are affected by magnetic fields.
No Interaction (Static Fields)
    No inherent magnetic effect: A standard capacitor is made of two conductive plates separated by an insulator (dielectric). It stores energy as an electric charge, not a magnetic field.
No magnetic field generated by a charged capacitor: A fully charged capacitor has no moving charges, and it is the movement of charges that creates a magnetic field.
Interaction (Changing Fields)
    Induced voltage (Faraday's Law): A changing magnetic field can induce a voltage across the capacitor's terminals, according to Faraday's Law of Induction. This is similar to how a coil in a changing magnetic field generates a voltage.
Displacement Current: The changing electric field between a charging capacitor's plates creates a displacement current, which, according to Maxwell's equations, also generates a magnetic field around the capacitor.
Changes to the capacitor's physical properties:
    Ferrofluid dielectric: Capacitors with ferrofluid as their dielectric can have their capacitance altered by an external magnetic field, as the field manipulates the ferrofluid.
    Specific capacitor structures: Some capacitors with specialized structures or materials, particularly those in aqueous or electrochemical systems, show changes in their capacitance when subjected to magnetic fields.
Physical Interaction
    Attraction: If a capacitor is encased in a ferromagnetic material (like a steel box, as seen in some motor-start capacitors), the box itself may be attracted to a magnetic field"
F6FLT
The phase tells us a great deal about people, https://www.psychologytoday.com/us/blog/cutting-edge-leadership/202408/why-are-people-so-resistant-to-change
I always found it strange how many scientists like to pretend their opinion isn't really their own as if talking in the third person. Pretending new science or technology is impossible because science claims it's so when it seldom if ever is.
It has little do with real science more so psychology and the fear of change imo.
This notion is also reinforced by the fact a majority of the greatest discoveries were found by accident. The person was not intelligent enough to deduce a specific outcome more so they stumbled upon it by blind luck. Only after the accidental discovery was made did they follow through. One could say were trying to do the same thing here.
ChatGPT thinks your wrong, "No, while the concept of space charge is well-studied, there are still ongoing research and discoveries related to its effects and applications in various fields, such as electronics and materials science. New insights continue to emerge, particularly in complex systems like semiconductors and dielectrics." You do understand that anyone can ask an AI and get the correct answer don't you?. ;D
As well, it seems very clear the technology in question falls under "complex systems". Hence the reason so few can seem to understand it.
In the TPU/STEAP the electrons are accelerated but not in a vacuum. The core of the TPU is made up of two positive plates in the form of a bifiler coil with each coil shorted. the over wound "bifiler coils" form the two negative plates, these coils are coils and not shorted. So you see there are two capacitors but intermixed with one another, and the negative plate/coils have distinct grounds because there are two distinct inputs of power.
SM talked about TUBES and it was not until Mosfets came along that this particular setup could be realised. A triode is a pure switch, no current can pass through it when it is OFF, a mosfet can in one direction, but with an addition of another diode on the drain it also can act as a triode. The function within the overall scheme of this will become aparent later on.
Now you realise that I am not talking about a simple capacitor but a complex capacitor system, this system being charged and discharge all of the time, a system of capacitance which as the charges change, the electric field produces a magnetic field, YES the curl field, ask AI, it is very real in an AC situation.
Of course, but when a system like the TPU is put together correctly with non magical science, it suddenly changes everything. Quote SM:- this is not rocket science.
The "UNIT" to keep things short, is a generator, it has to be to feed back into its input plus a little extra FROM SOME WHERE.
Foreget the somewhere for now, but how is power generated?
Well it is a sort of AC wave, but a type of sine magnetic wave which is produced from "two" changing charge/discharge voltages inside that special complex capacitor.
One of the give aways to this is all to do with the output taken from TWO POSITIVE lines, no ground as in 0V, but an elevated ground such as 200v in relation to 300v and giving you a 100v+ DC output.
This changing magnetic wave, or I should say waves because there are two generators and two inputs, complicated but cleverly designed to be simple in the end. The input and the output do not really see one another, magical, NO F6, slight of hand as far as the electrons are concerned.
Well this magnetic wave generates current in the negative coil/plate, took me some time to realise what was going on, the negatives of the capacitors were also the generator coils for the input. This was SMs electron party as in 3D magnetics clever story.
As I have said many times, go and look at Prof: Eric Laithwaits Magnetic River university videos, look carefully at his lab tech man ;)
Thanks 6flt,
I responded to a specific point in the PDF, the question of electrons in a vacuum tube, giving refutable arguments demonstrating that the text in the PDF stems from ignorance. I know vacuum tubes well; I was 14 when I started my first radio experiments with them.
You don't respond to this point, but talk about something else as if you were responding to what I said. It makes no sense.
No one disputes the possibility of influencing the dielectric of a capacitor by the electric field induced by a variable magnetic flux, and certainly not me. I have discussed this elsewhere in relation to the polarisation of the dielectric.
It's about time you learned the basics of electronics and physics, so you can finally understand that there is absolutely nothing new in what you're saying, but rather inconsistent interpretations of subjects where you want to see anomalies or discoveries when they are just commonplace effects that you are unaware of or whose limitations you do not understand, such as the question of space charge, and others here too.
I know nothing about medicine, so I don't give medical lessons to others. Unfortunately, when it comes to free energy, that's often what it's all about: ignorant people who think they're experts seriously spouting the worst nonsense. We might believe their childish drivel if they were able to provide experiments that work, but that's not the case either. So a little modesty wouldn't hurt, along with the intelligence to understand that people much smarter than us have already been working on these subjects for a long time, and that it's in our best interest to understand what they have understood before hoping to fly on our own wings. I mean ‘understand’, not to spin any topic any way you like.
If the output does not see the input, then why does it behave differently when there is a signal at the input and when there is not?
I can take a lot of crap, but this is just too much.
At which school do you teach F6, of course it is in the UK as you are on a GMT time zone which is one hour behind me, physics department? come on you know who I am, and I have been around the block a long time. But you will have a lot to lose if you expose yourself here.
So who is talking ****, have you read my last post, do you really experiment or just use the internet to find an answer to what I have posted?
I have used an open thread on purpose, though I have posted on a thread you can not see, only for real investigators.
Are you worried, do you have an agender, maybe just loose face.
For years you have been prowling the net on this and that forum, I think it is about time you hung your net days up, you are running out of forums.
@Centraflow
It's funny how you don't respond to any technical objections. Your digressions about me are completely irrelevant to the issues at hand. Have you just discovered space charge, or had you forgotten its role?
Perhaps you missed the last question. Here it is again. If, as you say, "the input and the output do not really see one another", then why does it behave differently when there is a signal at the input and when there is not? Causality, does that no longer apply?
In that case, can we use it as a parametric capacity in the OU parametric generator?  Or does it take more energy to change the magnetic field than we get in a parametric circuit? Similar to what happens with a varicap' circuit.
One thing is certain, such a capacitor will be very slow, because it is associated with the mechanical movement of particles in the ferromagnetic fluid.
Centraflow
Indeed, this is what many inventors called an energy diode or new kind of induction. It can be traced back to patents in the late 1800's.
My journey started with an idea for a circuit but had no idea what it would do. For me it was strange because I can usually figure out a circuit immediately from years of building and testing. So I built the circuit, fired it up, it went berserk and it took me years of research and testing to figure out why. Of course the answer cannot be found in any textbook and my solution was found in the most unlikely of places. I was researching the Dendera Light in the Hathor temple in Egypt when the answer hit me. What are the odds?, lol.
So there is magic and it is to explore as many truly new and innovative ideas as we can. In effect... to learn.
@Centraflow
The problem is F6FLT, you think you are the only one who knows EVERYTHING, which you don’t as you are finding out and you don’t like it.
I wish I knew everything but of course this is not possible for anyone.
As far as charge separation, this is exactly what I am talking about, after all the basis of the TPU is just that but in a different way than just a capacitor on its own.
As I have said there are two capacitors which are coupled in a very unusual way, each of which have separate charge separation within themselves, and a differential charge separation between the two (separate negative plates), two different voltages.
For now I will keep this to myself and a “few” on this forum. If I disappear the art will not, though it is well kept in other places as well, one of which I am sure is in Germany in the hands of lawyers.
By the way Francis, in French it is spelt two different ways, depends on if you are male or female, and F6FLT could be your car registration number plate, the DVLC could tell me that.
I am an investigative scientist, the tpu is not my invention, I have just been able to find out how it works and renamed it STEAP which is more inline with how it works.
No money making for me, just bills and hard investigating along with many many hours of bench time in my lab.
Centraflow
Right on AC, it works like a diode.
I also had something similar going on back in 2010 with coil-capacitors where induction was made perhaps in similar ways like TPU collectors do.
It was all about causing induction on one of capacitor plates which actually was a coil. Maybe something similar you had in mind?
I like this post from Centraflow
Centraflow nailed it imo. "Scientific investigating" is also how I found some success. We could ask what this means, for me it means treating any given technology as a puzzle. It's not my job to judge the technology only to gather as much evidence on it as I can and try to put it into perspective. The people involved, the literature, the technology, the patents, the history, replications and any related science. We should become an expert on the technology to such an extent we can answer almost any questions and begin to understand how it actually works.
For example, by my estimate the Adams motor required about 1500 hours of research and 400 hours of testing before I had anything resembling positive results. Here is how I do it, I pick a few devices and like a computer whenever my mind has any idle time I think about the devices or draw some sketches of it. It may only be an hour a day but over the course of years all the hours add up because it's always in the back of our mind.
We could think of it this way, many people have hobbies and spend literally thousands of hours collecting trinkets, coins, cross word puzzles, miniature railroads, models, golf, fishing, ham radio and so forth. My hobby just so happens to be energy and energy devices and I really enjoy the puzzle aspect of it, the unknown.
Like this.
The pulsed inputs are from a charged common mode choke, charge and discharge, as in DC to DC boost converters. The pulses are out of phase with different duties, hence two different voltages, though in practice it is a little more complicated as you use 3 switches.
This way the voltages are controlled so as they have different voltages, this important because your final output is a differential positive voltage, DC.
This has already been posted on this forum, but I am placing a link here.
https://www.youtube.com/watch?v=YHykWjtVdNM
It is quite relevent to the TPU because of how it is wound.
Laithwait must have gone through many configurations of coils until he could levitate and move along his maglev train that he invented.
The TPU creates a "magnetic wave", a changing "amplitude" that mirrors an alternating current, so a changing magnetic field.
As we all know, a changing magnetic field will induce a current in a wire.
SM said that you can move a magnet across a long wire slowly or fast across a shot wire, this a just a generator, but think in terms of the TPU construction.
Remember there are no moving parts in the TPU.
Centraflow
This sounds similar to my work with AC induction motors and generators.
Any AC induction motor can become a generator when connected to the grid and run faster than the synchronous speed of 60 Hz here in Canada. Here we can discard most of the often complex AC theory and say when the rotor magnetic field changes slower than the grid it's a motor. When the rotor magnetic field changes faster than the grid it's a generator. Ergo, any magnetic field change faster than the normal system magnetic field change represents a generator function. As well, as Faraday eluded in his lectures, "it does not matter why the magnetic field changes only that it does" as the concept is universal to the process of induction. If the magnetic field changes more for any reason that is the answer we were looking for whether we accept it or not.
Like this.
Thank you CF for such a simple and straightforward experiment.  Lot easier building a wright bros. plane than a 747.
When I get some downtime I will have to explore this configuration further O0
It seems like good optical/galvanically-isolated drivers/amplifiers would be ideal for such setups.   Or at least proper differential probes to measure with an oscilloscope...
You use a decade counter, feeding, VOM1271 mosfet drivers. The clock is all you need, a SG is good enough.
The counter breaks up the clock into the frequencies you want, and is the form of duty as well as a sequencer.
Next to no electronics.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 00:58:40
