2026-08-15, 07:15:41
Pages: 1 ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 ... 37
Author Topic: Romerouk's Muller Replication  (Read 664400 times)
maybe he just had the scope not adjusted correctly and the pulse train went down hill, i cannot remember the name but the old scope i used had a level adjustment for the x axis. any other inaccuracies between each pulse would be magnet/coil imperfections.
I am sure that is precisely what it is. My old Hitachi has the same adjustment available. It's called "tilt" or some such thing.
It is not tilted dammit!
What about that scope shot, would make someone take notice?
Where are Ion and WW, the "tube guys", at?
It's tilted Grumps. After looking at and using analog scopes for 26 years, I have a pretty good idea what a tilted scope trace looks like, and that is most definitely one.
from an oscilloscope users guide
Trace Rotation Control. The earth’smagnetic field changes from one location to the next which may affect the trace tilt.Oscilloscopes have a trace rotation control that can be used to compensate for the earth's magnetic field and adjust the trace to a perfectly horizontal position. This control is often a screwdriver-type adjustment.
There we go we have now diagnosed his faulty oscilloscope for him  ;D
Just keep in mind that what we see as tilt on that shot could also be a lower frequency additional AC or variation of a base DC signal being modulated by the waves we see.
If we have a video of the scope this would be apparent. If it was tilt that same video would show it as the pic shows it.
In addition.... any nearby strong magnetic dipole could cause tilt. This would not be limited to the Magnacoaster setup he may have had nearby. It can also be caused by an apparent magnetic vortex ( or electrostatic ) with the right strength and proximity.
So, I don't think we nailed a scope problem for him. The tilt can still be another puzzle piece.
Tilted my Arse!  I'll give Romero enough credit to know when his scope trace really is tilted and how to fix that little problem.
Think out of the box, my dear friends, way out of the box.
If you were an entity who's purpose is to supress free energy, what curious aspect of that scope trace would catch your attention and force you to take action?
Did Romero show his scope settings as well, or just the trace?
Thanks EM.
Here are Ben's (k4zep) thoughts on point 6)
http://www.overunity.com/index.php?topic=3842.msg292156#msg292156
Also, his findings agree with my assertion that the output voltage (15VDC) seems high for the RPM.
Don't lean too much that way just yet.
The FWBR will inject 2 X diode voltage drop on each half cycle - 1.4V.
In order to show a peak of 15V the drive AC voltage only needs to be 15 - 1.4 - the gain in voltage found in the usage of a FWBR.
So the average zero to peak voltage before the FWBR only needs to be ...
2Vp / sqrt of 2 minus the diode voltage drop (here divided by 2 since he has paralleled the bridge diodes with outside diodes) minus any peak voltage seen added by the additional diode junction capacitance.
So... the coil pair output could be around 10 - 11V.
There is another reason the voltage from the coils could be higher but I'll confirm that with a bench test to see if it might apply here before loosing my 'voice of reason' status  ;D
EDIT>>>
Oh!, there is another reason to see less voltage but may not apply due to frequency & rise-time. This is where the diode does not immediately 'turn-on'. They aren't ON, even in the forward direction until voltage is applied. This can be a big voltage loss in low voltage power supplies.
Think as you wish guys but imo you're reading far more into the trace rotation issue than what is really there. Sometimes things really are what they appear to be, and in this case, it's obviously a scope trace rotation pot that needs adjusting. But what does it matter anyway?
It could be many things, but the most obvious and most likely explanation, is that the scope trace rotation is in need of adjustment.
Just to put the lower frequency modulation question into perspective, assuming the RPM=1500, that amounts to 25 rots per second, and since there are 8 or 9 magnets per rotation, that puts us on the order of 800Hz try 225Hz. So, are you seriously thinking that there could be some few Hz signal modulating that wave form?  C.C
EDIT: corrected frequency
« Last Edit: 2011-06-23, 01:31:19 by poynt99 »
Just to put the lower frequency modulation question into perspective, assuming the RPM=1500, that amounts to 25 rots per second, and since there are 8 or 9 magnets per rotation, that puts us on the order of 800Hz. So, are you seriously thinking that there could be some few Hz signal modulating that wave form?  C.C
Can you determine the progression caused by the difference in coil number and magnet number.
If the scope trace showed "what to look for", would it matter then?
 :o
Please give me the part number for that magic FWBR WW, I've got to have one!
1kHz sine wave
Bridge formed with 1N4007
output cap= 100u
output load = 1k
AC input voltage required to yield 15VDC on output = 16.7Vp
No, but if someone offered you $1M if you chose the correct answer, scope trace rotation or "other", which would you seriously pick?
I did not say the scope trace was of no value. Peter and I are simply saying "don't get hung up on the fact the the trace is not horizontal; it's most likely a scope issue as noted".
:o
1kHz sine wave
output cap= 100u
output load = 1k
I don't care much for Wiki but try this -- http://en.wikipedia.org/wiki/Rectifier#Rectifier_output_smoothing
The very old rule of thumb for FW tube rectifiers in a bridge configuration is 1.4 X the P-P input will be the peak of the ripple on the first cap in the filter.
Notice: I didn't say there was a power gain. There isn't.
The only time I've had that ROT fail is when the rectifiers aren't chosen correctly for the application.
BTW:
I agree with you on the scope trace. I don't think the visible tilt is anything to hang your hat on.
it's modulated
EDIT:
(actually double modulated, but that is harder to see with such a limited trace)
If the trace is "crooked" then the double mod goes away, but the trace is still modulated at least once.
The Billion Dallar Question is:  What is modulating this signal?
Here I added a curved line to show the modulation better:
scope traces from Magnacoaster Patent also show voltage bias modulation:
Grumpy,
You do realize that much of that can be intentional or non-intentional stator magnet adjustments?
As far as what is being called the 'tilt' - I'm more inclined to think it is a snapshot of the rotor wobble over a maladjusted scope or rotating fields of some sort.
I hope to have some postable proof on my radial field idea but the only time I seem to have nowadays is when the boss isn't looking.
Grumpy,
I found it curious that both the RUK device and Magnacoaster appear to have similar modulation, and a claim of OU along with it.   I would like to know if the modulation is steady or changes with time...hmm...it may be that when the rotor rotation and the rotation of this modulation source coincide that you see gain.
WW: I have not overlooked the peripheral Hall trigger magnets - they are radial.
Grumps,
you are awesome dude!    I can't belive I did not notice the rotor modulation in those flat spots, thank you, thank you !
Now I feel better,  we can clearly see the rotor modulation, which corresponds with 8 pulse cycles, and each cycle has two pulses, one postive and one negative.   Remember  8 magnets fly past a coil per revolution and create a pulse pair, and if the rotor is warped or the magnetic field is not uniform around the rotor,  it will show up with a periodicity of 8 cycles of the pulse train.
Is this modulation good or bad?
As was previously stated 'Magnacoaster switched to a non mechanical version after he found the process using a rotor'.
And a partridge in a pear tree.. ;D
Grumps,
Glad to be of service!
...of if there is a not-so-perfectly-steady scalar wave rotating with the rotor, it will cause an increase in energy denisty which will cause a "voltage bias modulation", which is what that curve is on the scope trace.
(The trace location, in ref to zero, may not be accurate as it may have been lowered.)
Could this be an indication of OU?
An positive bias at the output is "gain".
Grumps,
That modulation appears to have a frequency about 1/3 of the generator coil frequency.
I wonder if the rotor is actually turning a little over 1300 RPM. Hummmm... That would place the passing magnet Hz @ a little over 21 the third harmonic of 7.
Nah!  That is even too far fetched for me  :D
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 07:15:41
