2026-08-15, 04:53:34
Poll
  • No, it's a fake
    Yes
    May be
    I don't care
Pages: 1 ... 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 ... 101
Author Topic: Dally, Shark & Ruslan workbench  (Read 753418 times)
Nick,
Those last screenshots where taken with a cross in the inductor leads as compared to the drawing i showed.
How are your coils hooked up, similar as that drawing or do you have a cross in it somewhere too?
I am now back to exactly that drawing, and have again the 180° phase shift on the Grenade current the moment i get into resonance on the inductor current.
The problem is that at that same moment, the grenade current dips and the bulb(s) go out.
   Itsu:  My yoke secondary windings seam to be the inverse or opposite to the way they are shown in the diagram.
I use 12 and 12t primary, 26 or 28t secondary, and 3 or 4t secondary, on a 3 inch plus sized yoke. At the time I followed Ruslan's Top Ruslan 7 schematic and general lay out.
May be it is good instead ?
We are not supposed to power load with push pull.
vasik
Nick,  thanks,     both opposite means  they should produce the same phase signal, not 180° out of phase like mine when both are wound the same.
Anyway, who knows yet what is right.
vasik
Yes,   good point.
So the only way to know what is good or bad is to build up the whole system including kacher, feedback to 24V PS, good ground etc. and see if it will work on its own.
This is not a standing wave. This is an amplitude modulated HF signal.
A standing wave has space on the horizontal axis - this wave has time.
Is it ? I thought any wave thats locked to a reflection is a standing wave ring modulated or not ?
have you got a screen shot of one, struth is this subject confusing with different definitions coming in.
but thanks for the definition.
SIL
Or the sum of two HF signals offset in frequency by the apparent modulation frequency.
Huh?
PW
vasik
   Vasik:  Yes, I agree. Depending on how things are wired, it may be normal and good that something like the bulbs going out happens.
And yes, the only way to know is to connect up the Kacher, earth ground line, feed back PS, and retune again, to see what happens at the output, then.  Stand back and watch for smoke.  Just kidding...  I hope.
Geofusion, also had something similar happen, but when the kacher was turned on also, bingo, the bulbs would light up.
   Itsu:  Sorry, after further observations on my yoke windings, I find that both secondaries are really like the diagram (not crossed).
It was a bit hard to tell, before. And I didn't know what "cross" referred to. But, now I think that I know. Sorry again, for the wrong info.
Of course
Huh?
See my answer to AlienGrey below:
Standing wave looks like this when the horizontal axis denotes space:
https://upload.wikimedia.org/wikipedia/commons/3/33/Half-open_pipe_wave.gif
Because oscilloscopes do NOT depict space on their horizontal axis in the YT mode, the standing wave cannot be visualized like this on their displays without moving the probe uniformly and synchronously.
If you sample* the electric field of this standing wave at one point with one channel of the scope, you will obtain an ordinary stationary sinusoidal trace when the scope is triggered at an edge or a voltage level.
* except at the nodes (red dots).
I did severall Grenade / Inductor series resonance tests using severall value's of series capacitors.
Combinations tried are:
24.4 / 122KHz,
24.4 / 24.4Khz,
122  / 24.4KHz,
12.2 / 24.4KHz
Best results (as compared to the severall Stalker video's / screenshots) is the 24.4 / 24.4Khz combination.
So i will continue with that combination for the time being.
I did several Grenade / Inductor series resonance tests using several value's of series capacitors.
Which blocks have not been included in this experiment?  24V PS, ground lead, ... anything else?
Which blocks have not been built yet for this experiment?  24V PS, ground lead, ... anything else?
   Kacher circuit in sync with the TL494IN signal?  It's getting exciting now ... holding my breath...
Kacher circuit ...  It's getting exciting now
that is dangerous to his equipment.
24.4 / 122KHz,
24.4 / 24.4Khz,
122  / 24.4KHz,
12.2 / 24.4KHz
   Itsu:
   So that, is again somewhat similar to my best results, at around 19KHz, for both.
   Yes, to every ones equipment.  Maybe that's why Ruslan said that the HV doesn't have to be very strong, to do it's job. I agree.
The HV, HF is everywhere, including all over the push pull components, and lower rated caps, ground line, etc... nothing stops it.
Ground lead was connected all the time, but no kacher and no 24V PS feedback.
And yes,  the kacher is synced with the (delayed) TL494 signal.
24.4 / 122KHz,
24.4 / 24.4Khz,
122  / 24.4KHz,
12.2 / 24.4KHz
Best results (as compared to the several Stalker video's / screenshots) is the 24.4 / 24.4Khz combination.
Was you able to get 30 degree phase shift between currents ?
In one of the videos, Alexeev says that tuning to same frequency is ok, but it will be de-tuning if you change load.
Vasik
No not really 30°, but my used current probes are all showing different phases compared to each other, so its hard to see.
The current transformer toroid (Green) used in the Inductor circuit gets very hot, so probably heavily saturated.
Thanks Verpies,
I misread your use of the word "space" to mean a gap or discontinuity instead of the intended meaning of length or volume.
PW
I would like to confirm how you wound gradient coil, is it like shown in attached picture ?
Blue arrows show how layer was wound.
Vasik
Hi Vasik,
yes that is correct.
Question about ground,   it is only connected to the Emitter of the 2SC5200 (which is also connected to the return/minus plane of the PCB), right?
Yes, I think so.
Hi Vasik,
And you don't see any other resonances between 1.2 and 5.6 MHz ?
Like 2.3 MHz ?
Vasik
Well,  according to this post: https://www.overunityresearch.com/index.php?topic=3926.msg91340#msg91340         there is a smaller resonance around 3.8MHz.
But i can recheck following that used procedure.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 04:53:34
