This is a pulse current reading using a Tesla receiving transformer as an example. There is a video by Kapanadze from 2007 in which he demonstrated current amplification. The current amplifier is visible there. Unlike conventional pickup, there is full synchronization with the passing voltage. The high-voltage low-frequency transformer is controlled by a phase detector, as resonance occurs between the two coils, it closes the coil around the coil with a discharge. It creates a separate strong magnetic field, which interacts with the passing voltage (video from post 1). Only the current is amplified, the voltage remains the same.
To increase the current it must have current and voltage components together. That is why it is specified in watts. It is a simple task 2*2. you have 10V and 10A so you have 100W now you say that you want to add the current itself, e.g. 50A I am asking how many watts does this current have? 0V? = 0W maybe 2V? ok so how many watts do you have now? You are telling me that if you have 10V and 10A you want to make +50A and get how much? 10V 50..60A? That is the problem. It cannot be done this way. It is an illusion, just like reactive current. Who decided that this coil in the picture is a current amplifier? We can also see a similar coil in 2 other Kapanadze films, if it can be considered similar. I like the scheme as much as hundreds of others
