2026-08-15, 03:25:01
Pages: 1 ... 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38
Author Topic: Don Smith Akula, Ruslan, Stalker, device discussion and replications.  (Read 186578 times)
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #594 on: 2023-09-22, 10:22:05 »
Quote from: NickZ on 2023-09-21, 23:37:16
Nothing that Itsu does bothers me.
So why did you write the unsupported assertions in your reply #570 ?
You are being pretty rude.
...insults from you.
Insults are directed at a person. I have not hurled any AdHominem names at you.  Show me one.
Instead, I criticize your actions, your words, your ideas or lack thereof, your replication methodology your prejudiced rejections of proposed operating principles. These are not insults although they may feel as much unpleasant to you. Take it like a man and learn from them.
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #595 on: 2023-09-22, 10:50:14 »
Quote from: Classic on 2023-09-22, 10:16:50
Ladies and gentlemen, please stop this silly blame of each other.
Nick asked for it directly.
Also, I will not allow him to discourage others from experimenting with components which are unapproved by him, with impunity.
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #596 on: 2023-09-22, 20:29:10 »
Some initial tests with and without the slotted pipe inserted into the Grenade / Inductor former.
Using a FG as sweep generator with 20Vpp sine wave to drive the inductor and measuring the output of the Grenade with a 360 Ohm lamp load
1st screenshot shows a sweep from 1kHz to 10mHz (yellow without slotted pipe, white with slotted pipe):
We see a slight increase in overall amplitude without the pipe.
2nd screenshot shows a sweep from 1kHz to 2MHz (yellow without slotted pipe, white with slotted pipe):
we again see the overall increase in amplitude without the pipe, but also visible now the shift in resonance frequency (higher with pipe) from 1.32MHz to 1.42MHz)
* white with slotted pipe yellow without 1kHz 2MHz.png (98.07 kB, 800x600 - viewed 58 times.)
img  partzman
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #597 on: 2023-09-22, 21:03:57 »
It may be assumed but you didn't mention it so I have to ask, is the slotted tube grounded?  With the tube grounded, there will be mutual capacitances present between it and the various windings which should produce various resonant peaks not seen without it.
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #598 on: 2023-09-22, 21:28:10 »
not grounded, just floating, but i will retest with a proper ground tomorrow.
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #599 on: 2023-09-23, 00:20:29 »
Quote from: Itsu on 2023-09-22, 20:29:10
The Al causes a small frequency upshift and amplitude loss.  I actually expected more of these changes.
But that is not bad - it just means that the Al is absorbing RF energy.
Do you have non-conductive ferrite magnets that you can stuff inside ? (the Russians used to call it ferrite kielbasa - sausage, but they did not understand its purpose and only used soft ferrite without the magnets).
The purpose of the magnets is to provide static magnetic field polarization to the Al. The windings can also provide the static magnetic field, too, when they are powered by DC through an RF choke.
What are the OD & ID diameters of this Al pipe, anyway ?
Can you measure or estimate the DC & AC magnetic flux density (B) that the aluminum is subjected to?
« Last Edit: 2023-09-23, 02:22:15 by verpies »
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #600 on: 2023-09-23, 03:11:20 »
   Wow Verpies, amazing results. But will it fly?
   Keep guessing.
   One more of your negative comments, and it will be your last, here. Last call. Cut the personal crap.
Be a man, make something that works, for once. Stop being a dick.
My opinions of the split tube was to avoid wasting more time. Like we are doing now. You asked for it. Sorry to see you back. I don't care for your attitude. Nor your limited (NO) knowledge of self running devices.
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #601 on: 2023-09-23, 03:46:48 »
Quote from: NickZ on 2023-09-23, 03:11:20
Keep guessing.
At least I am making an educated guess about the operating principle, not aimlessly varying the build like you are doing.
What personal crap?  I haven't called you a name once. I just criticize your words and actions.
"For once"?  I have designed plenty of circuits that work.  Just none of them are OU.
Stop being a dick.
See, that is an AdHominem epithet.  Learn the difference between this and criticism.
Do you even know how the split tube is supposed to work ?
Can you justify your off-hand rejection of it with anything else but your feelings ?
Also, you don't need me to waste time. I haven't been here for a year and you did just fine without me.
You asked for it.
No problem
Yeah, apparently you do not care for people who disagree and argue with you.  ...even without Ad Hominems.
You are avoiding most of my questions and I answer every one of yours.  Count how many of my question marks you have ignored and how many have I.
I am not even certain they exist.
Do you know something I don't ?
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #602 on: 2023-09-23, 05:43:43 »
   Yes, you are right about not liking people who just want to argue and hassle and critize every thing that I say. You are it.
  I prefer to work with people that cooperate compare and share notes on their builds, show scope shots, explain in simple terms what works and what doesn't, for them. Yet there is not a single person here who will build a totally exact as possible replication, and do their best to make it work, as shown. Not one in any forum that I know of at least.
  So, go ahead blindly give out more instruction for someone else to build, so you can continue to critize while doing nothing for this project, but more and more guesses. That won't work...
  I do want to get back to what Itsu and I were working to research and analyze different aspect of this particular build.
As talking to you, is wasting my time and efforts, Split tube.
img  Classic
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #603 on: 2023-09-23, 08:09:43 »
Quote from: verpies on 2023-09-23, 00:20:29
Introducing an aluminium pipe as core mainly decrease the inductance so, my guess a slotted pipe will introduce some kind of asymmetric effect because of the gap, consider electric flow in the inductor where inductance is switched up-down on every turn at every slot … like a pulsed inductance, but overall impedance should be reduced which may add on efficiency also, take in account overall outcome.
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #604 on: 2023-09-23, 10:05:59 »
I do have a bunch of non-conductive ferrite magnets (47.5 x 22 x 9.5 mm) which i can stuff inside the tube.
The OD & ID diameters of this Al pipe are 42mm & 36mm.
About measuring or estimating the DC & AC magnetic flux density (B) that the aluminum is subjected to is more difficult as i do not have any calibrated equipment able of doing so.
I have a hall sensor probe able of doing some measurements, but if it is saying anything significant i doubt it.
I will make some further tests later today.
I am also building your lossless clamp designed yoke driver to be able to drive the Inductor in series resonance to get some more power into the Grenade.
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #605 on: 2023-09-23, 10:24:28 »
Quote from: NickZ on 2023-09-23, 05:43:43
Yes, I want to criticise your methodology. But, I do not want to hassle you about everything for the sake of it- I just made a conscious decision to not let you get away with anything this time.  That is why this continues.
Yes, I do that when something new piques my interest and makes sense.  My lab is one of the better equipped ones here.
Well here is the clincher.  You are immune to even considering any explanations that do not involve your cherished energy from vacuum.
Any attempt to do so and you cry - too complicated, too complicated!  Tariel said it was simple - whatever that means.
That is because the device is poorly documented and can be replicated only superficially.
Most importantly its guiding operating principle is missing and you make no effort to postulate a plausible one.
..., and do their best to make it work, as shown.  Not one in any forum that I know of at least.
"As shown" refers to these superficial characteristics only.
Anyway, I think you are unfair to the people that had tried to replicate this device superficially in this forum (like you had) when you write that they have not done their best.
I don't give instructions blindly. I make suggestions that are guided by some operating principle.
You do not, you just try different parameters and permutations of components without a plausible operating principle to guide you.
You write it as if postulating some operating principle was bad and guiding the build according to it was "nothing".
While winding and soldering wires and tuning frequencies to obtain the highest amplitudes and bulb brightness was "something" good ...but never OU.
That won't work...
Do you know something I don't or can you foresee the future now ?
Did you find an inconsistency in my proposed operating principle  or find a proof that your operating principle works for sure ...and by exclusion mine cannot ?
You did a lot of work with Itsu on this device, what have you learned ?
What are you learning now ?  Is there a guiding operating principle that you are trying to confirm or deny with his build ?
You just resorted to derision when confronted with a component that does not fit your preconceived notions about this device and its superficial appearance.
This is what I was writing about lately.  You reject without justification and offer no alternative in return.  You don't support you assertions with evidence. That research methodology is fundamentally flawed.
Do you even know what is the function of that aluminum tube ?
Were all the conditions satisfied for it to perform this function when you had tried it?
Did you even know what these conditions are ?
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #606 on: 2023-09-23, 10:26:44 »
Quote from: Itsu on 2023-09-23, 10:05:59
Perhaps its readings will make sense if you feed the windings with similar currents that the waveforms have now ...but DC.
img  Grumage
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #607 on: 2023-09-23, 13:51:44 »
Verpies, a couple of questions please?
Was there a particular reason why Aluminium was chosen for the core?
Is the mass of this medium, pardon the pun, critical?
I was thinking that if metal foil were to be used the ends could overlap slightly and a strip of thin insulation provide the minute gap you mentioned in an earlier post? If metal foil is a suitable material I could send Itsu some Copper foil left over from a previous experiment?
In my own replication attempt, I made two Aluminium split tubes with a plastic insulation between them. Forming a simple parallel plate capacitor. Inside these plates was placed a coil of around 800 turns on a 50 mm diameter plastic tube. These were connected together to form a resonant circuit within the main coil on the 100 mm tube.
When powered up my device created severe disruption to everything. The camera would freeze and the fluorescent lights above would, whilst switched on become striated with dark and light areas along the length.
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #608 on: 2023-09-23, 14:01:04 »
Quote from: Apecore on 2023-06-08, 22:04:43
Neither Ruslan, Stalker, Dally or some other the setups have lots in common. So a review can be done regarding the overall mode of operation.... ( this Mode of Operation schould be defined first, even when its not clear we must set a idea and unless proven wrong we got to hold to it)
When we all agree on how we think this setup operates we have to define the conditions.
These conditions need to be challenged in a sort of test plan.
I wholeheartedly agree.
Even the most contrived operating principle is better for guiding these builds than the superficial replications which Nick has been pursuing for years.
I'd like to reserve the right to balk at any proposed operating principle which is based on immeasurable or unfalsifiable phenomena.
Executing this in a controlled matter and adjusting based on test results will not only lead us to our goal but also prevent us from doing the same ineffective steps over again.
Personally looking back I did a replication of the Ruslan setup, as a lot of us I didn't came further glowing a vew bulbs like a buck booster setup. Something is missing.
Yes!, the guiding operating principle.
It is not documented well so we must make educated guesses about it and verify them by experimentation.
My take on how this setup as it is presented to us on youtube operates is;
We create a LF signal in the grenade and by injecting a HF signal the mixer (grenade) it gets mixed and feeds the load.
We can discuss a lot about what is seen on schematics and is it really as build as shown on YouTube?
Only superficially.
So whats missing or in other words which step inside the system is not working properly?
If you propose a plausible energy gain mechanism it can be verified or rejected experimentally. Without it we are missing the principle that must guide these builds.
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #609 on: 2023-09-23, 14:17:15 »
Quote from: Grumage on 2023-09-23, 13:51:44
Yes, 100% of the natural aluminum on Earth has a magnetic moment, but it is not the best material.  Currently it is just what Itsu had on hand.
Not the bulk mass.
Big chunks of any conductive material (like aluminum) oppose the external radial alternating magnetic flux by means of the Lenz law and eddy currents (composed of slow electrons).
The purpose of the slot is to interrupt this current while still allowing the fast electrons/e+ to jump the slot.  This is two times the reason for which regular transformer cores are made out of isolated laminations.
Brass would be a better material.
Yes, rolled up metal foil would interrupt the eddy currents better than the undivided metal but it would also dissipate the energy of the fast electrons/e+ faster in the repeated passages through the dielectric layers traversed at very acute angles. So it might be a mixed bag of blessings.
Anyway, the walls of the roll would have to be thick so these fast electrons/e+ are not able to easily esape the metal as the magnetic confinement loses coherence and allows them to spiral out.  Thick walls allow them for more play-room.
Like this ?
img  Apecore
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #610 on: 2023-09-23, 14:56:56 »
Quote from: verpies on 2023-09-23, 14:01:04
Only superficially.
Well, much appriciated for this reply.
I had cancelled my account, but reading the last pages and some other thread I decided to comeback.
Good to see some people are taking pro active the lead and also like to work out of the box.
img  Grumage
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #611 on: 2023-09-23, 15:15:18 »
Quote from: verpies on 2023-09-23, 14:17:15
Like this ?
A little bit, yes. I think the term “ loosely coupled “ might be an exaggeration, more baggy…..  ;D
Here’s a link to the video I made nearly 10 years ago. Hopefully you can see the Aluminium tubes and their connection to the inner, Ferrite loaded choke.
https://youtu.be/LOqjTHmmumU?feature=shared
I have discovered an amazing source for metal materials here in the UK. They’re called M-Machine and they carry an immense variety of products. Brass tube amongst them. I could arrange something with Itsu if we can figure out what is actually needed.
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #612 on: 2023-09-23, 15:18:33 »
Quote from: Apecore on 2023-09-23, 14:56:56
That's a good thing. I've been away for a long time.
So what is your most plausible guiding operating principle of this device, that does not involve unmeasurable an unfalsifiable phenomena ?
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #613 on: 2023-09-23, 15:56:07 »
Quote from: Grumage on 2023-09-23, 15:15:18
Oh yeah, these were the times before the wife sent you to the couch for spending money on electronics.
Anyway, these aluminum liners were too thin to have a chance of working, because fast electrons could not spiral in such thin walls for a long time.
Also, you did not have a purposeful mechanism for creating the radial magnetic flux periodically in the aluminum.
That's great. Do they have pure iron ?
For now, I would suggest that Itsu keeps that aluminum tube as is but with a narrower slot (or slots).
Maybe later, he can cut a 1cm long ring off of it and surround it on both flat sides with soft ferrite to guide uniform magnetic flux from the permanent magnets through that ring.
There is long way to get it to multiply the fast electrons from there, though.
Most likely his diameter is too small and one day he will need your help to get a larger ring.  Maybe lathed-out or laser-cut from a 1cm-thick sheet metal (the flat sides should be ideally parallel).
img  Apecore
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #614 on: 2023-09-23, 16:10:27 »
Quote from: verpies on 2023-09-23, 15:18:33
I've been away for along time.
Thanks for that question.
There have been several, could be one of them the solutions. Personally I blame myself in lack of engineering knowledge and or given up to early.
Pourly documentated by myself as well is a flaw for picking up the tools.
In my understanding we have to create a process that aligns current and voltage... real power.
We get voltage from the inductorloop and probably we expect the current coming from the kacher.
This current needs to be injected and not getting absorbed in the same process cycle.
When the grenade is connected as an output coil it has to be a coil and a capacitor, at the same moment in time? I dont think so... as we have to use the karakteristics of these two components to align 'current and voltage'.
So now we come to the point of 'electrostatic induction' and timing/ synchronisation of this process.
In my opinion the grenade is missing a component i  order to absorb the current from this electrostatic induction as this charging looks to be done trough the antenna.
Foil or a additional tube inside the grenade as what is at the moment explored by Itsu in some kind of matter could be it.
2nd suggestion
I also challenged the possibility that the inductor coil is the output coil and push pull driven also.
I always found it strange that a fixed 470nF series cap was used in order to tune the inductorloop....
If this is the case the grenade could fit more i to the electrostatic process as well.
I hope this gives some food for tougth.
img  Grumage
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #615 on: 2023-09-23, 16:12:12 »
Ok….
I have just checked, you, Verpies have your own bench available. What about setting up a topic there based upon the current discussion?
Out of curiosity what diameter of Aluminium tube @ 10 mm wall thickness were you thinking of? And obviously the width.  The slit could be “ wire eroded “ what would be the maximum acceptable gap needed?
I would be more than happy to provide any mechanical help required.
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #616 on: 2023-09-23, 16:30:03 »
Enjoy your trek through life but leave no tracks
A 38 2" or equiv metric copper water pipe will work you could cut a slit down it with a nibbler or a saw.
might be easyer to get
sil
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #617 on: 2023-09-23, 16:48:46 »
Quote from: Grumage on 2023-09-23, 16:12:12
I don't think I do because Chet just told me that the forum has limited number of benches.
I could but I prefer to wait until Itsu finishes verifying Nick's M.O. - I hope he knows more about it than I do.
That is an engineering detail that can be solved by following the guiding operational principle.
It predominantly depends on the strength of the magnets. The stronger the magnets the smaller the ring can be.
This is because stronger magnets curve the paths of the fast electrons/e+ more than weak magnets, so they don't escape the ring.
An additional DC winding over the soft ferrite can aid the magnets and increase the almost static axial magnetic flux density (B) inside the ring.
I have an equation for it but I need to know the strength of the magnets to use it.  My intuition tells me 5cm < r < 10cm.
Who knows, maybe Itsu's pipe and magnets can satisfy the confinement condition already.
EDM is nice but slow and expensive.  For larger rings the saw-cut slit can be closed down to zero by squeezing the ring externally.
Intuitively: 0.1mm should be enough to stop the large eddy currents.  That's the common Kapton's tape thickness.
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #618 on: 2023-09-23, 17:22:04 »
Quote from: Apecore on 2023-09-23, 16:10:27
So why can't we just take the 100kV from a Van de Graaf generator and combine it with the 10A from an alkaline AA battery to get a MW ?
Both sources of voltage and current are already DC so there is no problem with aligning their phase.
« Last Edit: 2023-09-23, 19:15:16 by verpies »
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 03:25:01
