Kapanadze replication
Started by DELAMORTO, 2023.09.18, 10:04:25
DELAMORTO
Here's a video you should see.
The essence of the idea is to replace the light bulb with an oscillating circuit and tune it to a high voltage frequency.
This, by the way, will be exactly according to Kapanadze's patent, when 2 coils come into resonance)))
https://youtu.be/1InK_sYW6JE
andyw33
Quote from: DELAMORTO on 2024.08.19, 20:31:35
In a conversation via Skype, Kapanadze did not hide one of the principles of obtaining energy - "pull from support". I remember how I did experiments with such a thrust, unfortunately I can't give a link to the video, YouTube is blocked, but I can attach a photo. The light is on in the ground wire!
It would seem so what, the light bulb is shining in your hands next to the Tesla transformer..... but that's the point! Kapanadze said that the installation winds itself, that is, it uses traction in the grounding wire to increase the potential.
But in order for the energy to be wound up, you need to replace the light bulb in the broken wire with an oscillating circuit! Then the energy from the primary source, with the help of a high voltage source, will create a voltage difference, this will cause a pull in the ground wire. And the high voltage frequency will be the master frequency for this circuit; if you tune it to resonance, the amplitude in it will increase! The installation will screw itself up)))
Thank you Delamorto. Which place on the Kacher you touch with the wire from bulb? Somewhere near top? Is it direct connection to wire or through insulation?
DELAMORTO
This kacher is wound on a thick plastic pipe, inside there is a copper tube with a cut and a ferrite rod for adjustment. I touch the copper tube, as you can see in the video, the phyton grows and the lamp burns in the grounding gap. If you only touch the hot end of the casser, nothing happens.
maxmalone
It all depends on the current consumption. What you are showing is no different from the usual transfer of energy, e.g. through an extra coil.
The current from the primary coil enters the ferrite rod but this only works until the bulb is below the input source value. If you exceed this value the Tesla coil will turn off/leave resonance.
There is nothing more here. I did such tests a few years ago.
I only agree that in Kapanadze the current is present on the ground wire and this is the most important tip. However, such an effect can be achieved in two ways:
1. spark on the grounding wire.
2. Tesla coil connected to the e.ground from the secoundary coil.
Which version is Kapa ?
DELAMORTO
Of course you can!
The point is how to use it.
You just don't need a light bulb, you need a circuit that will swing from this energy and thereby increase the potential in the ground wire. The patent clearly states resonance between the coils.
A circuit that is turned on in this way can wind itself up, at resonance the amplitude on it increases and, accordingly, the thrust, all this triggers the self-promotion of the installation - or do you know how to achieve this differently, considering what is written in the patent?
maxmalone
Yes, according to the patent it is shown. Current from the coil goes to the capacitor. This is self-powering but we do not know if it is about resonance or about the current itself. In my opinion it is about the resonance of the same secondary coil on the capacitor of the primary coil.
Quote from: DELAMORTO on 2024.08.20, 11:36:18
Are the things inside the plastic pipe your inventions or have you replicated them from other people's devices ?
DELAMORTO
The idea of ​​such a tube is not mine, but the use in such a device is mine. But this is not so important, the main principle is to use traction from the ground to swing the oscillatory circuit!
chief kolbacict
#558
We bet you've never seen such a kacher. O0
They write that it  consumption from battery for average 60w. And it is lighted two bulb for 15w. but very bright. Much more bright than usually.  I did not  do it myself, although circuit is interesting.
maxmalone
Quote from: chief kolbacict on 2024.08.21, 08:24:06
What was it supposed to be used for?
DELAMORTO
I don't think that Kapanadze had a kacher, most likely a simple high voltage source.... but that's not certain)))
DELAMORTO
Video diagram and how to try it
giantkiller
Stick a magnet on the secondary
Chief
Did hear from a long time researcher who found your post and schematic worthy of further investigation ( towards wireless transmission??)
Might see if he will offer more suggestions ( usually a cheeseburger meal helps !;)
Thanks for sharing ...
chief kolbacict
Now I'll ought to to do it myself.  to see how it work.That is not very difficult.Day will be enough.
But I do not think that would be overunity there.  This is kacher,only symmetrical.
DELAMORTO
#565
Found a video that confirms my theory about the oscillatory circuit in the ground wire!
As you can see, it tunes the resonance in the coil with a ferrite rod, in addition, it has no circuit capacitance, which makes oscillations in the circuit, increases the amplitude and current.
But even so, he managed to light the bulb!
https://www.youtube.com/watch?v=5xNqbEHfP00
DELAMORTO
Conducted an experiment as described in the patent, about the interaction of two coils and dynamic tuning. ;D
https://www.youtube.com/watch?v=NKNYmPNkJ20
Remember the video with Aquarium, where Kapanadze points with his finger and says: "This is the primary coil, when current flows into it, its electromagnetic field acts, where it should, on the second, independent coil."
I wondered why it sounded like "Where it's needed"
And then it dawned on me that the patent was about rhythmic stabilization! I figured it out - it's phase tuning! And how can we phase-tune 2 circuits? It's simple - place them in space the same way as in a metal detector coil! There, the shift of the TX relative to the RX of the coil rotates the phase! That's why the coils are positioned so strangely in his aquarium, he simply moved them relative to each other so that their phases matched!
And when the phases coincide, resonance occurs! All these sparks, high voltage - an old and forgotten way to pump up the TX circuit!
I only needed 1 microcircuit to swing 2 circuits with different frequencies and adjust their phases! Moreover, when resonance occurs, I tried to destroy it, but it turned out to be tenacious. All that remains now is to increase the frequency of the circuits by 20-30 times, then there will be interaction of the receiving circuit with the grounding and we will get what we have been looking for for so long!
By the way, in the video my receiving circuit has a small 5 watt load - a light bulb. At the same time I was looking at how to remove energy from the circuit in resonance.
Kapanadze increases the voltage for a greater amplitude of the TX circuit swing! And in resonance, the overall amplitude grows, hence the discharges that he expects. The discharge is a limiter of the receiving circuit swing and at the same time an indicator that the circuit has swung and the load can be connected!
DELAMORTO
Smith's setup also used phase tuning of the coils! To do this, he made an additional winding, which shifted the phase.
Also in the first installations Smith physically moved the TX coil, inside the RX! Again, he phased them and got into resonance!
Please note the interrupt frequency - 300 kHz ;)
The first video experiment of SR193, it lit a light bulb also with a coil that had an additional winding, which coordinated the phase.
https://www.youtube.com/watch?v=W9WZt-WMJ2k
DELAMORTO
Thus we get the following:
The high frequency should be from 300 kHz, at this frequency it is possible to capture additional charges using grounding.
TX and RX coils are adjusted to match the phase, then a general resonance occurs!
These two factors lead to the release of excess energy in the RX coil.
maxmalone
Quote from: DELAMORTO on 2024.11.30, 17:18:42
I have never seen charges from the ground fly to the source. You need to first create a potential difference and that is 50% so what later flies from the ground is nothing more than another 50% which is 100% of the energy you first used to create it.
Resonance is just an accumulation of energy. A capacitor does that too. Resonance does not create energy!
Don Smith never showed a real device in action. It was all just demonstrations of how it could work. He made money on these demonstrations by saying... here you have everything you need to build such a device, but it was all for the money. Look how quickly he got angry when someone asked technical questions. He called him names and threatened him to stop talking and leave. It's like a cult.
Coil placement on the coil can be tuned like a metal detector, i.e. phase. I agree.
DELAMORTO
Quote from: maxmalone on 2024.12.01, 17:36:59
The oscillatory circuit at high frequency interacts perfectly with grounding. There are many examples of this, in this forum thread too.
maxmalone
Quote from: DELAMORTO on 2024.12.01, 19:44:25
Every current works well with the earth :) It doesn't have to be resonance. Just ex. a spark is enough.
A tesla coil connected to ground works just as well as one connected to negative. Does it work better connected to ground? How much?
DELAMORTO
All sparks in Kapanadze's installations are 19th century technologies of TX circuit swinging and tuning into resonance of two circuits. The modern base allows all this to be done on 1 microcircuit. In the archive there is a LC generator on LM386. The frequency is set by capacitors up to 300 kHz. The diagram is from my video.The amplitude of the swing depends on the voltage from 8 to 15 volts (100-500 volts amplitude to the circuit)
maxmalone
Quote from: DELAMORTO on 2024.12.02, 10:42:48
Show me even one resonant system that multiplies the energy supplied. It may be with grounding from the earth. I'm looking for FE like you but I didn't know anything like that until now.
DELAMORTO
