2026-08-15, 02:35:53
Pages: 1 ... 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31
Author Topic: Kapanadze replication  (Read 290791 times)
Has this been discussed already?
Does anyone by any chance have access to the forum: http://www.matri-x.ru/forum/?
I’m interested in a certain schematic that is used in this video: https://www.youtube.com/watch?v=AKdQbysXwng.
The author of the video posted this schematic in the subforum "Свободная энергия" (Free Energy), under the topic "Установка Тариеля Капанадзе" (Tariel Kapanadze Device).
I’m not able to register on that forum. Maybe one of you has an account on that forum.
It's very possible that the forum was closed because nothing happened there for a long time. The owner was collecting money for hosting.
If they had OU, they could have bought for hosting for a hundred years forward ...  :)
« Last Edit: 2025-05-03, 08:22:20 by chief kolbacict »
 :D ;D :D ;D
 Super interesting video with echoes of Kapanadze. This is worth replicating. I wonder what would happen if you looped it? Would you create a vortex, TPU style?
Anyhow, I believe it works. : https://www.youtube.com/watch?v=pLcaXieNlDY
This is a speculation,however I think its correct.The transformer in the aquarium 2 came
from a Russian IBM computer,it was used in a power supply 220 vac to 12 vac,it is 3 transformers in one.  The funny  coil has some thing to do with teslas high voltage,high frequency
stuff ,however its put there to fool people,its function is simply as a coil.
The main part that powers the electric heater is the blue coil it takes a lot of current to power
the heater,the coil is hooked directly to the transformer.The transformer can not output much
current yet the heater turns on.There is only 2 conclusions one is its a fake,or somehow the
current from the transformer is amplified in the blue coil.The spark plugs sparking is not
needed,a high voltage near the coil is needed.The transformer[first and second part] does do something in terms
of amplifying current,still working on this.In the picture the blue coil amplifies the small current
from the first transformer to a level needed to power the heater.The funny coil  in the picture
is a simple coil,the second transformers current is amplified thru this coil, this is to feed to the third transformer.The third transformer functions as a step down transformer,this feeds power to the circuitry that creates high voltage and other things,this closes the loop.In these devices the length of the wire plays a big part not how its wound, the same as in the tpu.The tpu is a dc based device,the kap device is an ac based device.
This is a three-phase transformer. I have one of these. I use it sometimes.
In the picture you see thin black wires,there only there on the first and second part of the
transformer,because there used for current amplification.The third part of the transformer
does not amplify current,so theres no wires, its purpose is to change 220vac to 12vac.In the tpu
a dc voltage is
applied, the output voltage is set by this,neither the tpu or the kap device generate voltages
as the result of there operation.When the pictures of the aquarium 2 came out,when I first
saw the green transformer, I thought what the hell is this.I bought 2 transformers from
Ukraine,took them apart to analyze them,very different from US transformers,two toroids back to
back,this relates to the tpu.The way its wound is also different, the windings over lap.
ya its a 3 phase transformer,kapandze was a very smart guy,but very tricky.He kept the secret of
the kap device, because its simple and once the secret got out
he would lose hes source of income.I don't know if hes sons know how to  build the device or
if the secret is gone with hes death.
The first picture shows the altered picture of the circuit based on more information,I made a
crude transformer
to show that when the primaries are connected in a certain way,it prevents the voltage ac from
being generated in the secondary.
picture oneside1 shows 12 vac applied to my transformer's primary one side,the secondary shows
an ac voltage.When the other primary is connected,the vac drops to nothing.We know that the
output of the aquarium 2 has to be 220 vac,50hz ,it is outputting at least 9 amps to power the
heater.If the
transformer in the aquarium 2, looses the 220 vac from the inductance ,then the 220vac has to be
applied thru the thin wire.The current applied to the blue coil must be very small,maybe around
.25 amp or less,at the other end of the coil it must be around 9 amps.From a conventional view
its impossible for an air coil to amplify current in this way,so the device must be a fake
maybe,maybe not.You need to view this in another way a conductor[copper] has a lot of free
electrons,it requires a motive force to
get the electrons moving. In my opinion that something comes from the transformer other than
current,as this something moves into the coil,free electrons are caught and influenced to move as
this something moves thru the wire
the current builds up.The point is the 220vac did not come from the operation of the device
but was added.Length plays a big part as the something picks up electrons,how the coil is wound
 plays no part.In my opinion when you configure opposing magnetic fields you cause an effect
on the gravity field which has to be the source of the energy that powers both the tpu
and the kap device.How the gravity field is channeled I don't know.I believe you can get
enough information to do a good try at a replication.
Do you think it would work if you stacked these tablets and stuck them inside the Kapanadze coil, which is wrapped in blue electrical tape, and periodically compressed them with a magnetic field from the electricity they generate? Pressing the tablets with a magnetic field through iron washers, like in electromagnets? Would the device become self-sustaining?
https://www.youtube.com/watch?v=7gZ_C-c7d0M
You think this is impossible? Then why are there so many patents on a similar:
Solid-state reserve battery activated by compression
https://patents.google.com/patent/US20150017488A1
Shock-activated electrochemical power supplies
https://patents.google.com/patent/US4783382A
Reserve battery with fast voltage rise time, activated by impact:
https://patents.google.com/patent/US20240097148A1
Pressure activated battery system:
https://patents.google.com/patent/US12272844B1
Solid-state reserve battery activated by compression:
https://patents.google.com/patent/US10700364B2
Solid-state chemical current supply and method for raising discharge capacity
https://patents.google.com/patent/RU2313158C2
Piezoelectric materials generate electricity due to a change in the pressure acting on them (e.g. a shock from a hammer impact), but in this video we also see that electricity is generated even when the pressure is constant. ...and it is a surprising amount of electric energy dissipated in that glowing hot resistive wire, i2Rt
So, could Kapanadze's coil generate 220 V and tens of amperes of current with these tablets inside?
These aren't regular piezoelectric elements.
I don't know why the author called them "piezoelectric elements."
Regular piezoelectric elements look different.
Regular piezoelectric elements can't generate such a high current.
Regular piezoelectric elements can't generate electric current under constant mechanical pressure.
Please read the patents, they might shed some light on what we're talking about. The author seems to have confirmed on his forum that his tablets could be based on a similar technology.
So surprising that it seems unbelievable. :)
something similar, but less complicated, he doesn't need to store the battery for 25 years
https://piltek.com.tr/images/brochure_back.png
https://piltek.com.tr/thermalBatteries.html
Thermal batteries have electrolyte that is solid at room temperature hence effectively inactive.  Included in the battery is thermiite that can be ignited by various means, and that heats the electrolyte into its liquid form; then the battery is active. They have been around for many years.  Nothing of interest for OU researchers. OTOH that device which produced electrical power under constant pressure is something else.  Was it a scam?
« Last Edit: 2026-01-05, 17:41:44 by Smudge »
That would be true, but...
The author of this video is open to communication; his name is Yuri. You can certainly ask questions about this video,
and he'll likely respond on his forum, in this topic:
https://oldoctober.com/forum/viewtopic.php?p=63457#p63457
He understands English well. He might respond to comments on the YouTube video, but that's less likely.
In his comments to this video (he has another  Russian versions), he writes that he can't reveal the secret because he uses explosive components in this "piezoelectric element", and YouTube could ban him for it.
In a video about the process of creating a "piezoelectric element," Yuri demonstrated that he had to constantly monitor the temperature of the chemical substance for the piezoelectric element when pouring it into the mold, so that the temperature did not exceed a certain threshold and something bad would not happen.
In the old days, there were rumors that Kapanadze used some kind of secret technology intended for the military, which is why he couldn't publish it.
Many of Kapanadze's devices, especially those designed for high power, are mechanical, essentially heat engines with oil pumps, turbines, and cylinders with pressure gauges.
In fact, a long, fruitless search for energy in a coil with a capacitor and a spark gap might already suggest that it's like searching for a black cat in a dark room, or even more simply, a black cat in a bright room, when it's 100% clear there's no cat there. But what is there?
Something else.
« Last Edit: 2026-01-05, 23:16:36 by sergh »
Interesting video. He is applying a constant force, instead of a fast shock.
He didn't run the video for a long time. After a time it must run down.
He is releasing the energy over a long period of time instead of over a short period of time.
The law of Conservation of Energy and matter must apply to this piezo device, mechanical energy to electrical energy.
The output is DC not AC, the Kapanadze device is 220 VAC at 50 Hz.
Putting the piezo device with washers in the coil would require 220/10=22 units.
It would require a strong magnetic field vibrating at 50hz, where did the current to generate the magnetic field come from?
From the transformer?  The transformer winding is 17 ohms. The current has to come from the transformer.
If it applies 220 VAC to an air core with a low resistance, then the transformer would burn up quickly. There are a lot of Kapanadze's videos.
In one, it is a 3-phase device. It uses 3 coils - one for each phase, they measure the frequency at 50Hz.
Below is a screenshot of the 3-phase device. In my opinion the current is generated in the coils.  This cannot be a conventional method of generating current.
This has been a problem - people want a conventional solution. Because of the high energy output of the Kapanadze device that's not possible.
Also, until the Aquarium v2 device, the other devices were a box hooked to a coil with a high voltage discharge across the coil.
As for the mechanical versions of the Kapanadze devices, I think they were powered by a hidden electrical Kapanadze devices.
Keep in mind that Kapanadze was a very tricky guy, he did everything possible to hide his secret.
No, not from a transformer. Kapanadze's device creates a 26-amp current in the load! This current can also be used to create a magnetic field in the coil.
The output current can flow through this blue coil, wound with ordinary electrical wiring.
Imagine the blue coil on the plastic tube connected in series with the load and the hidden "piezoelectric elements" inside. The current flowing from the "piezoelectric elements" creates a magnetic field that compresses and expands the "piezoelectric elements" inside the coil. The magnetic field can act on iron washers with springs or magnets, producing the necessary vibrations. Vibratory pumps for coffee machines operate on a similar principle. This small device creates pressure pulses of up to 20 atmospheres while consuming only 50 watts.
Thus, a device consisting only of a coil, its internals, and a powerful load can be a self-sufficient oscillator!
The other components seen in Kapanadze's video may only be necessary for starting, maintaining the required frequency and voltage, and supplying the necessary components for the continued operation of the device.
In general, Kapanadze's device, in its simplest form, requires very few components other than the coil itself.
Not all of the wires in Kapanadze's video may be real wires. Capillary copper pipe, similar to those used in refrigeration, can easily be disguised as wire.
At the output, the load may have a nearly normal alternating current, since during the mechanical relaxation phase, when the "piezoelectric elements" are not generating current, the coil can discharge into the load, creating a pulse of opposite polarity, acting like a regular electrical choke.
This is what will revolutionize our understanding of Kapanadze's device:
 -  Watch this video at 12:43. The power to the generator is completely disconnected, as are the transistors and everything else in and around the jar, is de-energized.
 And what do we see in the next few seconds? Without external power, the coil continues to generate 25 amps of 220 V for several seconds, without any power supply from the output. A strange sound is heard, likely due to 50 Hz desynchronization.
https://www.youtube.com/watch?v=2oGHuHy-xEc
« Last Edit: 2026-01-06, 09:42:18 by sergh »
With older devices its a box with
a coil and a high voltage theres nothing to see ,it could be anything and it is much higher
current.
Another problem the wire has a thick insulation so the coil can't create a strong magnetic field
effectively ,9 amps can not generate[aquarium 2] a strong magnetic field.Where does the current
to compress
the piezo elements come from,one wire to the transformer one wire to ground.If the the washers
and 22
piezo elements are in the tube[aquarium 2 device],where does the 9 amps come from?
I have seen a lot of theories come and go none worked,people tend to focus on a specific thing and
ignore
other things,like the winding of the blue coil as the key to the device[grenade coil]
You have to collect a lot of facts and simulate things to see if they can work.
If i were you I would talk to that guy and get an piezoelement from him ,put two washers and monitor the
output while applying an ac magnetic field to see if  it can work,and scope the output.
It would be nice,but it's impossible.  :(
chief kolbacict,
Why is it impossible for him to get a piezo element from the inventor ?
One possible answer is that this "piezo element" does not exist.  ;)
I don't think Yuri is a liar.
Anyone interested should try asking on his forum to reveal at least some of the details.
"Ask, and it shall be given you; seek, and ye shall find; knock, and it shall be opened unto you"
If the Kapanadze coil has about 100 turns, then at 9 amps of current, 900 amp-turns is quite sufficient with the correct placement of the magnetic elements inside the coil.
A coffee machine pump is estimated to have 400 amp-turns and produces pressure pulses of up to 20 atmospheres, depending on the model.
The coil winding wires can be threaded through holes in the plastic tube on which the coil is wound to prevent the coil from unwinding.
The current flowing into the ground is still unclear; perhaps there are some unknown features.
For example, charges can be released from the piezoelectric element, which creates some kind of current.
« Last Edit: 2026-01-08, 15:11:11 by sergh »
Maybe it's current flowing from the ground ?
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 02:35:53
