2026-08-15, 07:18:59
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 ... 38
Author Topic: Don Smith Akula, Ruslan, Stalker, device discussion and replications.  (Read 187464 times)
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #183 on: 2023-06-17, 14:20:32 »
   Thanks Itsu, for confirming that also my grenade is wound correctly. Mine is wound just like your darker bolder print in your previous post. So, I don't understand what all the discussion is about.
   Maybe Vasik would like to be part of this forum again. And may need help, like I did.
   NickZ
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #184 on: 2023-06-17, 14:44:03 »
   AG:
   How about you wind up a grenade and show us how it's inductance is near zero. Because I don't see that in practice.
May be wishfull thinking, instead.
   So, how about it, will you build something, or just keep suggestng things to others,  that you have not tried?
   Maybe you know why 37.5 meters is the right wavelength. Or even 40 meter, instead. Why is that the "right" size?
Remember, there are no self runners running at the SAME frequency, or even close by. What does that tell you? Not much, it looks like.
 NickZ
« Last Edit: 2023-06-17, 19:22:56 by NickZ
img  worldcup
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #185 on: 2023-06-17, 14:53:35 »
I got my eye on this topic.
Won't be posting much in this thread to avoid distraction, But now i post just to cheer up up, apecore, and all others who got light of hope  O0
img  Apecore
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #186 on: 2023-06-17, 15:40:53 »
Quote from: NickZ on 2023-06-17, 14:44:03
   AG:
 NickZ
Nick,
I have one and had even lower ones.
I tried to get a grenade in half wave resonance.. 4Mhz.. but 3.7Mhz was the limit.
Edit:
https://youtu.be/uhxOdjuRgnc
In my vid it seems it is half wave resonance.
img  Apecore
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #187 on: 2023-06-17, 15:42:17 »
Quote from: worldcup on 2023-06-17, 14:53:35
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #188 on: 2023-06-17, 16:06:06 »
   AG:
 NickZ
Nickz,
I can see that you are vilifying AG. There's nothing wrong in what he said. Grenades inductance can bre as low as 20μH. It all depends on how they are wound
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #189 on: 2023-06-17, 17:46:01 »
   Max:
   As you think that AG is right, perhaps you should follow his advice. And show us how well your grenade shows zero inductance, instead. As I already know what his suggestions lead to, nothing, at all. And I don't need nor want his insulting advices, while he is just forever only guessing, while telling me what I should do. I have known him for years. Have you?
   BTW: If you think that near zero inductance is what is needed, please show us how well that works for you. So far much of what Stalker has mentioned can't be replicated, and I am trying to figure out why that is. Not by guessing...from someone that has never built what is being discussed on these threads.
   NickZ
img  forest
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #190 on: 2023-06-17, 17:47:08 »
Do you have a working generator of square wave in the range of 1 - 5Mhz to power grenade ? Seems a hard problem to me
img  Apecore
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #191 on: 2023-06-17, 18:00:31 »
Quote from: AlienGrey on 2023-06-17, 16:02:51
Have you tried to biffilar wind one  ?
img  Apecore
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #192 on: 2023-06-17, 18:02:24 »
Quote from: forest on 2023-06-17, 17:47:08
What you mean " to power grenade?
Switching 1kV at 5Mhz is not a problem
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #193 on: 2023-06-17, 18:11:31 »
   Forest:
   I don't know who you are asking. But, yes I do have a working push pull square wave generator that runs the grenade. But no such generator needs to run at over 10 to 30KHz to operate the grenade.
   The Kacher is what runs at 1 to 2MHz,  or so.
   Running the Kachers at higher than 3MHz will result in less and less output, and therefore no effect to the grenade.
   NickZ
« Last Edit: 2023-06-22, 22:31:32 by NickZ »
img  Apecore
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #194 on: 2023-06-17, 18:52:58 »
Quote from: AlienGrey on 2023-06-17, 18:30:17
this test
Ok,
So that Nick coil as you are showing is only 2 layers?
When doing this with all layers of grenade you get close to 12-15uH. 4Mhz...
Ps,  why do you call it Nick?
Ape
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #195 on: 2023-06-17, 19:03:28 »
  AG:
 That is amazing, but will it self run, or is it just another distraction?
Well, I can tell you that it won't fly, nor will it do anything at all, towards OU. So, why do you bring that up, now.
  More distraction...which don't have anything to do with me, or with my grenade, Nor with what we are looking for. A grenade and Kacher that work.
   NickZ
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #196 on: 2023-06-17, 19:28:34 »
Quote from: Apecore on 2023-06-17, 15:40:53
Nick,
Edit:
   Really, Ape? And just what could it do at those low inductances.  Perhaps you can show us how well it actually works. It's output, and such. I'll check your video, first.
   NickZ
img  Apecore
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #197 on: 2023-06-17, 19:34:25 »
Quote from: NickZ on 2023-06-17, 19:28:34
   NickZ
Well Nick,
We all know no one showed selfrunners yet but I tougth we were exploring the grenade together?
Unfortunately there is lots of discussion rather then a development in patterns.
But when I have some nice results I will show you.
Grt
Ape
   Ape: Yes, we are looking at the grenade, but in relation to what works. Not just trying to find the matched frequency, but what will that frequency actually do, at the output. So, that is what needs to be compared to, in the end. Otherwise, it doesn't mean too much, just by itself. Slayer states 143uh. Is that so low an inductance? Compare to your 10 to 15uh?
  Any ways, Ape, you now have 2Mhz grenade, now what?
   NickZ
« Last Edit: 2023-06-17, 20:00:24 by NickZ »
img  Apecore
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #198 on: 2023-06-17, 20:31:09 »
2 or 4Mhz.. I think uts 4Mhz.
So that means I get a standing 1/2 wave inside my 37.5meter grenade.
That means if that occurs the voltage at both ends will be zero at all time.
So I would say to Max, thats not what will bring voltage across our load.
When its the 2Mhz then we have a 1/4 wave standing... means always max voltage between the two grenade ends.
This I think is best for output voltage.
Next step is the currnt.. when we have 200Vols at our grenade it would be nice to have 5Amps also.
Only Stalker or Ruslan have it... even w/o a standing wave.. or.. what also is possible.
Having a lower grenade frequency then you add your groundwire length in order to get the related total amount of wirelength.
F.i. when having a 1Mhz frequency at grenade you need to add an extra 37.5meter groundline in order to get a standingwave.
Unfortunately the voltage different between both grenade ends will be less then having the 2Mhz situation.
You could ask... how to ground a 2Mhz grenade?.. well I add also 37.5meter groundline so I get a half wave standing in total.
With still having max voltage difference between both grenade ends.
In how this standing wave situation will remain when the load is connected I don't know.
But I do know all we get now is some power from inductor and a bit from kacher.... probably only buck boost principle and no additional power from the unknown.
Anyway, I'm convinced we wont find the clue by just replicating like a lego build.. so discovering something by looking a bit different won't hurt I think.
I know I'm pushing the discussion often out of your thread scope as it is called replication....
When you don't want that, its ok for me and I will stop here.
Because I'm done with 100% replicating something w/o understanding whats happening... and in fact waiting for the lucky shot for someone to disclose.
No hard feeling your the regulator here and its your bench and thats also ok for me.
Grt,
Ape
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #199 on: 2023-06-17, 21:52:47 »
Some more info (video's with text) from Vasik, it contains transcriptions of some (old) video's, but more expanded, i think very useful.
* gradcoiltest.pdf (17.1 kB - downloaded 56 times.)
* hv.pdf (295.49 kB - downloaded 51 times.)
* pp.pdf (32.63 kB - downloaded 49 times.)
page9
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #200 on: 2023-06-17, 22:12:39 »
   Max.
   Thanks for the advice, but, it sounds more like more of your insults,  to me
   I don't need you to tell me how to think,  or what to do, I'm a grown man.
   This thread is meant for discussion and replication efforts. Not insults, as I been getting from you and AG.
  I asked for some kind of proof of what is known and shown, not just theories and guesses. You have a problem with that?
  Like some hands-on tests and verifications, as Itsu has been showing, instead. Something wrong with that?
  I really don't know what you are talking about, Max. Other than your insults, I mean.
     NickZ
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #201 on: 2023-06-17, 22:47:17 »
   Ape:
    I really am focused on this project, not in a theoretical sense, but in a real sense, with a real mission in mind. And with a real self runner working finally on my bench.
   If you see that what we are discussing here does not serve you, I understand. But, I am focused on finding an answer to this particular riddle. I hope that you can understand. And can continue to contribute your part, in this.
    NickZ
« Last Edit: 2023-06-18, 00:04:33 by NickZ »
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #202 on: 2023-06-18, 00:50:43 »
   Itsu:
   Thanks for the additional info. I will review it. And thanks to Vasik, as well. I hope that he is doing well, I do miss him here with us.
   I also miss Geofusion, and others of like minds.
   NickZ
   BTW: Itsu how are we doing with the idea of the standing waves, etc...
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #203 on: 2023-06-18, 08:41:07 »
Quote from: Itsu on 2023-06-17, 21:52:47
Thanks Itsu for this wealth of information.
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #204 on: 2023-06-18, 10:54:51 »
Quote from: NickZ on 2023-06-18, 00:50:43
   Itsu:
   NickZ
Nick,
the problem with standing waves is that you can not see or measure them in a Grenade, at least not to my knowledge.
So it's hard to detect them if they are there.
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #205 on: 2023-06-18, 15:04:10 »
Quote from: Itsu on 2023-06-18, 10:54:51
Nick,
Drive a coil at it natural resource frequency or a coil that resonate at it natural frequency attains a standing wave.
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #206 on: 2023-06-18, 15:15:34 »
" a standing wave in a coiled wire can be created by applying an alternating current with a specific frequency that matches the resonant frequency of the wire. The wire will then vibrate at its natural frequency, creating a standing wave with nodes and antinodes along its length".
I quoted from somewhere.
This is what we are trying to achieve with Tesla on our grenade coil. If your grenade coil resonate at 1.4MHZ and you set your Tesla transformer to resonate at this same frequency, you will have a standing wave. Nobody is talking much about this. You have to be meticulous about this because it is laborious and not for the undetermined.
As I have earlier stressed, "Tesla will pull Gc to a stand"
It involves much adjustment of Tesla sec.
Maxolous.
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #207 on: 2023-06-18, 15:21:51 »
Quote from: AlienGrey on 2023-06-18, 14:28:40
No not with that type but in saying that if you drive it into it's resonance they should be at it's output, if you have a Amtr Radio background you could tune it.
That's the form
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 07:18:59
