2026-08-15, 06:05:37
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 ... 38
Author Topic: Don Smith Akula, Ruslan, Stalker, device discussion and replications.  (Read 187207 times)
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #284 on: 2023-07-01, 21:29:19 »
Many persons had achieved 99% of this phenomenal and because they haven't consciously done what they were supposed to do with faith and purpose had missed the whole thing and gone back to square one.
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #286 on: 2023-07-01, 21:57:16 »
Quote from: NickZ on 2023-07-01, 21:11:05
Or can we just assume that 37.5 meters is the magic frequency?
Frequency requirements are usually functions of other parameters.
For example for a Linac:
https://upload.wikimedia.org/wikipedia/commons/0/08/Linear_accelerator_animation_16frames_1.6sec.gif
The optimal frequency for accelerating the charged particles is determined by their mass, charge and electrode spacing and the voltage amplitude between electrodes.
For NMR, the optimal frequency for precessing the nuclei is determined by the nuclei themselves and the surrounding static magnetic field.
It is very likely that the optimal frequency for your idea is determined by many factors, too.  I can't help you to define them because "the ambient" is a very ambigous concept with undefined properties.
BONUS RANT:
Notice that mathematically frequency is the inverse of time,
motion is the ratio of space to time,
energy is the ratio of time to space.
...more here.
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #287 on: 2023-07-01, 22:31:19 »
  Yes, could be many factors. However, it seams to be that IF the grenade is the base of the rest of the system, there should be an optimal frequency that it should be tuned to. Should be the best most ideal frequency to tune the grenade to, as well as the rest of the system to match. Or not? So, again why 37.meters. No one knows... Assuming of course that it's not NMR, that we are aiming for.
  And is why I ask...
page 13
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #288 on: 2023-07-02, 01:34:15 »
Enjoy your trek through life but leave no tracks
No one is saying much on how it works except verpies mentioned a tube or wire down the center of the grenade does any one know what that is about and what do you think that does?  And Wesley showed Tesla coils with a wire off them at ¾ any one like to comment on that ?
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #289 on: 2023-07-02, 02:27:44 »
Quote from: verpies on 2023-07-01, 21:57:16
BONUS RANT:
...more here.
So more to the point what are the red dots floating down the center ?
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #290 on: 2023-07-02, 05:03:59 »
Quote from: AlienGrey on 2023-07-02, 02:27:44
Charged particles.
Can be ions of air, electrons
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #291 on: 2023-07-02, 08:34:10 »
Quote from: verpies on 2023-07-02, 05:03:59
Charged particles.
Hmm well I wouldn't have thought so in our case! as that's not how it works
since in our circuit electricity is blocked by caps.
Come on you lot help me out here if you want to learn.
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #292 on: 2023-07-02, 12:02:55 »
Quote from: Maxolous on 2023-07-01, 20:15:40
Who says there is no fish waves, one the carrier (Push-pull), one the intelligent signal(Tesla). "Amplitude Modulation"
Max,
could you perhaps show us this "Amplitude Modulation" of the Tesla signal by the carrier (Push-pull) on your scope similar as i did here:
https://www.overunityresearch.com/index.php?topic=4471.msg105056#msg105056
( Which turned out to be an artifact of the scope here: https://www.overunityresearch.com/index.php?topic=4471.msg105074#msg105074 )
Thanks,  itsu
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #293 on: 2023-07-02, 12:58:41 »
Here is an Alexee Sergey circuit, Nick Z is your device on page 1003 Dally
wired the exact same way ???
And what cables do you have going through it it looks like a knitting needle.
sorry no intention to offend
« Last Edit: 2023-07-02, 14:20:03 by AlienGrey »
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #294 on: 2023-07-02, 13:39:12 »
Quote from: Itsu on 2023-07-02, 12:02:55
Max,
Thanks,  itsu
I will oblige your request ASAP.
I have one of my Push-pull MOSFETs(IRFP260) burnt this morning. This usually happens if it is not on load. Once fixed, I will show you.
Maxolous.
img  partzman
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #295 on: 2023-07-02, 14:17:28 »
Quote from: AlienGrey on 2023-07-02, 01:34:15
The slotted tube, wire, or ferrite toroids down the center of an inductor assembly such as the grenade, forms an asymmetrical transmission line.  What use is this one might say well, things can get interesting under certain conditions.  For example, the attached sim shows the results of an asymmetrical t-line operating at 1/2 wavelength for example.  This is 1/2 wavelength of the t-line parameters not the length of wire.
As can be seen, the rms current in the common of the distributed capacitance shown by IV3 from the t-line inductance is 2x the currents measured at the input and output of the t-line.  Why is this?  Because the polarities of the conventional current flows into the input and output of the t-line are equal at 1/2 wavelength.
img  Centraflow
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #296 on: 2023-07-02, 17:58:38 »
Quote from: partzman on 2023-07-02, 14:17:28
That is very similar to STEAP.
The difference is  the input is a positive pulse and the line resonates at its natural resonant frequency multiplied by the frequency of the pulse.
Advantage of this can be made by mixing 2 distinct frequencies.
Again 2 distinct pulse lines, 2 mosfets and charge chokes, can be mixed across a coil. This gives a distinct positive voltage across the coil (differential voltage).
This post is in ref:to PMs post, and I think it is in line with this thread as a simpler way of doing things.
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #297 on: 2023-07-02, 18:13:49 »
Here's the carrier (envelope) and the intelligent signal.
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #298 on: 2023-07-02, 18:15:15 »
And this
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #299 on: 2023-07-02, 18:22:48 »
The carrier is your LC resonance.
The intelligent is both your high frequency grenade and Tesla sync.
Suffice to say that your grenade is also like Tesla coil..
page 13
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #300 on: 2023-07-02, 18:25:04 »
Please, ignore the cursor reading at top left.
https://youtube.com/shorts/lVoS1g_2hnU?feature=share
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #301 on: 2023-07-02, 19:37:04 »
Quote from: Maxolous on 2023-07-02, 18:13:49
Max,
thanks, i see your time base is at 10us/div., so the peaks are at 25kHz (40us) is that your push-pull (carrier) frequency?
I have never seen such a screenshot before, so could you further explain where your probes are at?
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #302 on: 2023-07-02, 21:38:46 »
Quote from: Itsu on 2023-07-02, 19:37:04
Max,
This particular grenade res at 1.310MHZ
The the LC resonance is 26.2KHZ.
Since it is broadcasting, the probe should be outside to pick the out going signal.
I do hope we are getting the form now
« Last Edit: 2023-07-03, 03:58:30 by Maxolous »
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #303 on: 2023-07-03, 02:51:20 »
Max,
So this is your 1/4 wave resonance of the Grenade?
The the LC resonance is 26.2kHZ.
So this is your push-pull resonance frequency?
So the probe is laying say 5cm away from the Grenade?
What about the Kacher / Antenna resonance frequency? Is it this same 1.310MHz?
If so, would the probe not pick up that signal first?
As i do not have the push-pull (yoke) running i will not be getting this form anytime soon
Sorry for all these questions,   Itsu
« Last Edit: 2023-07-03, 09:48:50 by Itsu »
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #304 on: 2023-07-03, 03:57:01 »
Quote from: Itsu on 2023-07-03, 02:51:20
Max,
Yes
I guess you mean kHz?
Yes, 26.2KHZ .
I will modify that.
About 10cm, I guess.
Yes
This is the result of all signals.
Please, do and don't delay.
Not bordered.
Maxolous.
Nick
Go into your profile
Read your posts
And get to your last post ( locked topic)
And unlock and make a post,
It will move to top of forum list
I will remove this post when sorted
Also
Peter must have tried to fix issues
And changed front page topic list
I have seen this happen before when forum gets worked on
Will try to reach him later ( he works long hours)
BTW
Obviously you should check your topic for “lock”
Everyday
That is why I posted yesterday that I noticed it was locked
If someone is locking your topic
Perhaps you have a hack on your computer?
I would change your password
There are groups of giggling infant sociopaths in viewing community who actually live to enjoy these things ( disruptive towards open source FE)
As mentioned I will remove this post when you bump your topic
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #305 on: 2023-07-03, 09:54:36 »
Thanks Max,
OK, I understand, but would / should the kacher / Antenna signal not be a multitude times stronger than the "broadcasting" Grenade and thus obscuring its signal?
Anyway, do you think this AM modulated signal is essential for a self runner?
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #306 on: 2023-07-03, 10:51:49 »
Quote from: Itsu on 2023-07-03, 09:54:36
Thanks Max,
No, it's a modulated signal so , they are all now one and attain power
Achieve this , next maximize Tesla power to get what you want . Also, it depends on how you arrange your cct.
Maxolous.
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #307 on: 2023-07-03, 11:19:38 »
Do you mean you are modulating the kacher?
If so, how do you do that?
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #308 on: 2023-07-03, 12:23:20 »
Quote from: Maxolous on 2023-07-03, 03:57:01
Yes
Yes, 26.2KHZ .
I will modify that.
Yes
Not bordered.
Maxolous.
Err do you mean not bothered by any chance ?
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 06:05:37
